Куратор темы Статус: Не в сети Регистрация: 02.03.2008 Откуда: Cupertino, CA
Прошу обратить внимание на то, что прошивка и модификация BIOS'а производится на ваш страх и риск, и я не несу никакой ответственности за возможную порчу данных и неработоспособность платы после прошивки.
Этот набор предназначен для десктопных плат, не используйте входящие в него bat-файлы на ноутбуках, пожалуйста.
allegro16, it is actually very interesting for me, because I have 2 BIOS backups from ASUS P8Z77-V Deluxe, and they have 8 Mb size and not this weird 8 MB + 2 Kb size, that files from ASUS.com have. Try flashing this BIOS file, I have modified the individual data of one of my Z77-V Deluxe BIOS backups, changing it to yours from your previous post. It's 1206 version, but you can try USB BIOS Flashback to flash newer versions then, if it works. I will make the "Z77 BIOS shrink utility" to make this weird files from ASUS.com flashable, but I need some time to figure the differences out.
"Could not communicate with the HECI." - that means, that ME firmware is inaccessible during flash and FPT uses another method. It's not good, actually, but have no influence to flashing process and results.
UPD: It's simple. All Z77 BIOS files form ASUS.com are having 2 Kb header, that must be removed before flashing with other tools then USB BIOS Flashback and added before flashing with it. I think, that is a BIOS regions map for programmer chip on board. The actual BIOS contents start from 0x800 offset from the beginning of BIOS file. I will add the ability to add and remove that 2 Kb header to one of the next versions of FD44Editor.
Thanks. I downloaded your file, but after browsing all my usb thumbdrives, i found a backup created JUST before the system crashed. This is indeed 8192, not +2KB. I was lucky, because that was the ONLY backup i didn't delete.. I flashed this with FPT, and it worked!
I did got a message: “PDR Region does not exist” , not sure what that means and if it's normal.. Anyway, now both chips work.The formerly defective one still has all my settings, and XMP memory and iGPU (Intel 4000 HD) still work. They don't work on the new chip though (missing serial, UUID, etc?) I'll try to flash your BIOS tomorrow, and update it. Hopefully by then ALL will work.
Thanks!
CodeRush: no need to quote all the message, quote only needed parts, please
“PDR Region does not exist” - it's true! For our P67/Z68/Z77 BIOSes it is 100% normal, because there is no PDR region in them. I don't know exactly, what the problem with the new chip is, but I think that it's damaged ME firmware. "Could not communicate with the HECI." from FPT is a sign of that. You can look at "ME Version" string on the Main tab in BIOS setup, if it's N/A, then I'm right about it. You don't need my file anymore, use your own backup copy. Could you please send it to me via E-Mail or private messages here or on overclock.net? It would be used for FD44Editor development.
Good, was worried about that PDR thing.. Well, the new chip did have ME 8.x in BIOS, but maybe that part wasn't flashed correctly? I'll send the backup bios later today.
allegro16, I don't know. But I know, that the best method of correcting that is erasing all chip contents and flashing your working backup copy. Then you can use USB BIOS Flashback to flash the version you want.
Just wanted to let you know: Since i have a failsafe now (backup bios chip), i was able to test some things out. The BIOS 1205 i received from you somehow results in ME: N/A (and in some other places N/A as well) Flashed it several times, tried the -ME command after the initial flash also.. Nothing. So, i think something went wrong with the file you created.. I was able to edit my previously backupped copy though. (the one that restored my old chip) This had the correct ME: 8.0.4.1441, and all other settings and UUID, MAC, serial.
So, i'm happy, but you might check the file you've send me.
I'll send a copy of both a clean 1502 BIOS version (no mods), and the one i used in the end via PM.
allegro16, that file is an actual backup from P8Z77-V Deluxe board with replaced individual data. You may have different board revision, for example. Now I know how to deal with factory BIOS files, so I don't need to give anyone modified backups from another boards anymore. But still, thank you for letting me know it.
вопрос к знающим есть мат плата Asus P8H61-M LE rev.3.0 с убитым биосом Winband 25Q32BVA1G (1132), есть донор Winband 25Q32BVA1G (1104) с рабочей (такой же) мамки. Стартую "дохлую" мать с донором - стартует, вынимаю донора (в включенном состоянии), вставляю убитую микруху и пытаюсь ее прошить через асусовый прошивальщик из биоса прошивкой с сайта Асус на что получаю ошибку "image integrity check failed". Если вернуть рабочую микруху то прошивальщик позволяет ее прошить этой же прошивкой без ошибок. Вопрос: как прошить дохлую микру? позволит ли FD44Editor отредактировать файл биоса и избежать ошибки "image integrity check failed"
FTM4, воткни рабочую микросхему, загрузись в ОС и сделай с нее копию, как написано в FAQ в разделе "Снятие резервной копии при помощи FPT в Windows". Потом воткни сбойную и сделай копию с нее. Полученый файл залей на zalil.ru и пришли мне на него ссылку, я тебе сделаю БИОС, который потом надо будет прошить. Чтобы не ждать, пока я сделаю файл, прошей копию рабочей микросхемы, как написано в FAQ в разделе "Откат при помощи FPT в Windows". Перезагружайся, плата должна заработать. Но она не до конца работоспособна, у нее теперь данные в биосе от платы-донора. Получишь файл с ее данными - прошей его таким же способом. Ты мог бы и сам перенести эти данные при помощи FD4Editor, но он пока не поддерживает платы на H61, т.к. у меня нет ни одной резервной копии БИОСа от таких плат.
UPD: если нет Windows, можно использовать DOS или даже UEFI-shell, это не принципиально. Кстати, отличная идея добавить вариант с UEFI-shell в FAQ.
http://zalil.ru/33687763 вообщем вот бекап биоса с рабочей микры.. но я ее прошивал уже через EZ flash прошивкой с сайта, но с ней ща комп работает.. грузится. Старую (дохлую) я прошивал через виндовый прошивальщик прошивкой с сайта, прошивка завершилась успешно, но после перезагрузки опять черный экран.. не исключен вариант что сама микра дохлая. Вообщем воткну ее в мать и отправлю в сервис, пусть там сами колупаются, а то и так времени уже убил много
FTM4, не надо в сервис. Сам сделаешь легко. И я просил копию сбойной микросхемы, а не рабочей, но и на этом спасибо. Хотя тут будет немного больше работы. Для восстановления платы мне нужна информация со всех наклеек, которые на нее наклеены. Я внесу данные с наклеек в эту рабочую РК и дам тебе ссылку. Прямо сейчас сделай следующее: 1. Загрузись в Windows на нормальной микросхеме. 2. Аккуратно поменяй микрохемы. 3. Переименуй свой файл backup.bin в bios.bin и положи в папку C:/FTK/Win32 или C:/FTK/Win64, в зависимости от твоей версии. 4. Запусти flash.bat с правами администратора. Сначала он сотрет содержимое микрухи полностью, а потом запишет содержимое твоей РК в сбойную флешку. 5. Перезагрузись, все должно работать. 6. Никогда больше не используй для восстановления прошивки EZ Flash, ASUS Update, AFUWIN и прочую дрянь. Или FPT, или flashrom, или программатор.
http://zalil.ru/33687949 Вот этот файл надо будет прошить, чтобы восстановить все на место. Только мне нужна инфа с наклейки материнки, в которую будет установлена та микросхема, что мы чиним. Я подозреваю, что ты мне не ту инфу дал.
Последний раз редактировалось CodeRush 17.08.2012 16:55, всего редактировалось 1 раз.
Хорошо испорченый БИОС - намертво, данных нужных в нем нет. Только с наклеек. Мне нужно уехать сейчас, буду через 3 часа. Если что-то не получится, почитай FAQ в 3 посте, если все равно не получается - сделай скриншот и подробное описание, что и как делал, приеду - посмотрю.
зашил то что ты прислал комп стартанул.. полет нормальный.. вот скрин работы прошивальщика - есть предупреждения мб тебе будет интересно http://zalil.ru/33687979 - скрин ПС.. и да.. большое спасибо за помощь
Сейчас этот форум просматривают: mr_turbo, novarc и гости: 480
