Статус: Не в сети Регистрация: 29.05.2007 Откуда: Подольск, М.О.
Позавчера после реанимации клиента после долгого отсутствия, на видеокарте благополучно посчиталась 1 жаба на 21 ядре, и уже 3 сутки приходят только 22ые, которые ни фига не считаются
15:34:19:WU01:FS01:Starting 15:34:19:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\macew\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 2488 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0 15:34:19:WU01:FS01:Started FahCore on PID 7996 15:34:19:WU01:FS01:Core PID:1140 15:34:19:WU01:FS01:FahCore 0x22 started 15:34:20:WU01:FS01:0x22:*********************** Log Started 2020-03-17T15:34:19Z *********************** 15:34:20:WU01:FS01:0x22:*************************** Core22 Folding@home Core *************************** 15:34:20:WU01:FS01:0x22: Type: 0x22 15:34:20:WU01:FS01:0x22: Core: Core22 15:34:20:WU01:FS01:0x22: Website: https://foldingathome.org/ 15:34:20:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org 15:34:20:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora 15:34:20:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org> 15:34:20:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 7996 -checkpoint 15 15:34:20:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0 15:34:20:WU01:FS01:0x22: Config: <none> 15:34:20:WU01:FS01:0x22:************************************ Build ************************************* 15:34:20:WU01:FS01:0x22: Version: 0.0.2 15:34:20:WU01:FS01:0x22: Date: Dec 6 2019 15:34:20:WU01:FS01:0x22: Time: 21:30:31 15:34:20:WU01:FS01:0x22: Repository: Git 15:34:20:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe 15:34:20:WU01:FS01:0x22: Branch: HEAD 15:34:20:WU01:FS01:0x22: Compiler: Visual C++ 2008 15:34:20:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT 15:34:20:WU01:FS01:0x22: Platform: win32 10 15:34:20:WU01:FS01:0x22: Bits: 64 15:34:20:WU01:FS01:0x22: Mode: Release 15:34:20:WU01:FS01:0x22:************************************ System ************************************ 15:34:20:WU01:FS01:0x22: CPU: AMD Ryzen 7 3700X 8-Core Processor 15:34:20:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0 15:34:20:WU01:FS01:0x22: CPUs: 16 15:34:20:WU01:FS01:0x22: Memory: 15.92GiB 15:34:20:WU01:FS01:0x22:Free Memory: 8.76GiB 15:34:20:WU01:FS01:0x22: Threads: WINDOWS_THREADS 15:34:20:WU01:FS01:0x22: OS Version: 6.2 15:34:20:WU01:FS01:0x22:Has Battery: false 15:34:20:WU01:FS01:0x22: On Battery: false 15:34:20:WU01:FS01:0x22: UTC Offset: 3 15:34:20:WU01:FS01:0x22: PID: 1140 15:34:20:WU01:FS01:0x22: CWD: C:\Users\macew\AppData\Roaming\FAHClient\work 15:34:20:WU01:FS01:0x22: OS: Windows 10 Pro 15:34:20:WU01:FS01:0x22: OS Arch: AMD64 15:34:20:WU01:FS01:0x22:******************************************************************************** 15:34:20:WU01:FS01:0x22:Project: 11742 (Run 0, Clone 3605, Gen 4) 15:34:20:WU01:FS01:0x22:Unit: 0x000000088ca304f15e69b91adf88d685 15:34:20:WU01:FS01:0x22:Reading tar file core.xml 15:34:20:WU01:FS01:0x22:Reading tar file integrator.xml 15:34:20:WU01:FS01:0x22:Reading tar file state.xml 15:34:20:WU01:FS01:0x22:Reading tar file system.xml 15:34:21:WU01:FS01:0x22:Digital signatures verified 15:34:21:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core 15:34:21:WU01:FS01:0x22:Version 0.0.2 15:34:32:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%) 15:34:32:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900 15:34:53:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked? 15:34:53:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan 15:34:56:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked? 15:34:56:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan 15:34:59:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked? 15:34:59:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan 15:34:59:WU01:FS01:0x22:ERROR:114: Max Retries Reached 15:34:59:WU01:FS01:0x22:Saving result file ..\logfile_01.txt 15:34:59:WU01:FS01:0x22:Saving result file badstate-0.xml 15:35:01:WU01:FS01:0x22:Saving result file badstate-1.xml 15:35:02:WU01:FS01:0x22:Saving result file badstate-2.xml 15:35:04:WU01:FS01:0x22:Saving result file checkpt.crc 15:35:04:WU01:FS01:0x22:Saving result file science.log 15:35:04:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT 15:35:05:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 15:35:05:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11742 run:0 clone:3605 gen:4 core:0x22 unit:0x000000088ca304f15e69b91adf88d685 15:35:05:WU01:FS01:Uploading 11.59MiB to 140.163.4.241 15:35:05:WU01:FS01:Connecting to 140.163.4.241:8080 15:35:05:WU02:FS01:Connecting to 65.254.110.245:8080 15:35:06:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 15:35:06:WU02:FS01:Connecting to 18.218.241.186:80 15:35:06:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration 15:35:06:ERROR:WU02:FS01:Exception: Could not get an assignment 15:35:06:WU02:FS01:Connecting to 65.254.110.245:8080 15:35:06:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 15:35:06:WU02:FS01:Connecting to 18.218.241.186:80 15:35:07:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration 15:35:07:ERROR:WU02:FS01:Exception: Could not get an assignment 15:35:12:WU01:FS01:Upload 0.54% 15:36:06:WU02:FS01:Connecting to 65.254.110.245:8080 15:36:07:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 15:36:07:WU02:FS01:Connecting to 18.218.241.186:80 15:36:07:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration 15:36:07:ERROR:WU02:FS01:Exception: Could not get an assignment 15:37:43:WU02:FS01:Connecting to 65.254.110.245:8080 15:37:44:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 15:37:44:WU02:FS01:Connecting to 18.218.241.186:80 15:37:44:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration 15:37:44:ERROR:WU02:FS01:Exception: Could not get an assignment 15:39:13:WU01:FS01:Upload complete 15:39:13:WU01:FS01:Server responded WORK_ACK (400) 15:39:13:WU01:FS01:Cleaning up
нашел на форуме, что возможно из-за заводского разгона видюхи. даунклокинг не помогает... видео радеон 290x
если убрать client-type=advanced, то тогда такое пишет 16:13:16:WU02:FS01:0x22:ERROR:exception: Error invoking kernel sortShortList: clEnqueueNDRangeKernel (-5)
Можно прописать, чтобы не приходили жабы на 22 ядре?
TSC! Russia Captain
Статус: Не в сети Регистрация: 16.08.2007 Откуда: Красноярск
Мейс Винду Да все верно, Bad State detected это переразгон или карта не стабильна при счете на 22 ядре, оно значительно сильнее греет карту и требовательнее к ресурсам, например требуется хороший БП, охлаждение. Можно попробовать снизить частоту памяти и чипа. В настройках клиента есть выбор типов заданий, обычно стоит на Any, можно выбирать несколько видов болезней: рак, Паркинсон и другие, только сейчас в этом нет толку, т.к. идет флэшмоб по борьбе с коронавирусом и все задания для этого проекта, но не хватает мощностей серверов для генерации и обработки, в связи с вновь присоединившимися считающими, читаем чуть выше сообщения.
_________________ У тебя мощнейший комп, ты уверен? И для чего он тебе? В TSC! Russia ты узнаешь что такое мощь тысячи компов! TSCRussiaTeam.ru
sashmxm писал(а): скорость до ляма почти подскочила.
Уже до 1 миллиарда в сутки, если быть точнее
А можно где-то увидеть статистику Folding@home, помимо https://foldingathome.org/statistics/ ? Там как-то не очень понятно, только текущие данные. Не видно динамики.
Вот тут у них страница не обновляется похоже, одно и то же число со вчерашнего дня: 110 685 фолдеров.
TSC! Russia ex-Captain
Статус: Не в сети Регистрация: 13.07.2007 Фото: 0
Статус: Не в сети Регистрация: 22.04.2012 Откуда: Москва
Folding@Home достиг мощности вместе взятых 7 лучших суперкомпьютеров из Top500, у проекта уже более 400 тыс. участников https://habr.com/ru/news/t/493498/
TSC! Russia member
Статус: Не в сети Регистрация: 01.02.2014 Откуда: Саратов/Энгельс Фото: 32
Отослалось через несколько попыток (p11763 0-6916-12)
Код:
07:03:42:WU01:FS01:Downloading 51.19MiB 07:03:48:WU01:FS01:Download 20.51% 07:03:54:WU01:FS01:Download 48.47% 07:04:00:WU01:FS01:Download 74.72% 07:04:04:WU01:FS01:Download complete 07:04:04:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11763 run:0 clone:6916 gen:12 core:0x22 unit:0x0000001480fccb0a5e71136ba6614f90 07:04:04:WU01:FS01:Starting 07:04:04:WU01:FS01:Running FahCore: "C:\NO UAC\FAHClient/FAHCoreWrapper.exe" C:\FaH-workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 7612 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0 -forceasm -twait=80 07:04:04:WU01:FS01:Started FahCore on PID 8572 07:04:04:WU01:FS01:Core PID:7976 07:04:04:WU01:FS01:FahCore 0x22 started 07:04:05:WU01:FS01:0x22:*********************** Log Started 2020-03-24T07:04:04Z *********************** 07:04:05:WU01:FS01:0x22:*************************** Core22 Folding@home Core *************************** 07:04:05:WU01:FS01:0x22: Type: 0x22 07:04:05:WU01:FS01:0x22: Core: Core22 07:04:05:WU01:FS01:0x22: Website: https://foldingathome.org/ 07:04:05:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org 07:04:05:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora 07:04:05:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org> 07:04:05:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 8572 -checkpoint 6 07:04:05:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 07:04:05:WU01:FS01:0x22: 0 -gpu 0 -forceasm -twait=80 07:04:05:WU01:FS01:0x22: Config: <none> 07:04:05:WU01:FS01:0x22:************************************ Build ************************************* 07:04:05:WU01:FS01:0x22: Version: 0.0.2 07:04:05:WU01:FS01:0x22: Date: Dec 6 2019 07:04:05:WU01:FS01:0x22: Time: 21:30:31 07:04:05:WU01:FS01:0x22: Repository: Git 07:04:05:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe 07:04:05:WU01:FS01:0x22: Branch: HEAD 07:04:05:WU01:FS01:0x22: Compiler: Visual C++ 2008 07:04:05:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT 07:04:05:WU01:FS01:0x22: Platform: win32 10 07:04:05:WU01:FS01:0x22: Bits: 64 07:04:05:WU01:FS01:0x22: Mode: Release 07:04:05:WU01:FS01:0x22:************************************ System ************************************ 07:04:05:WU01:FS01:0x22: CPU: Genuine Intel(R) CPU @ 2.00GHz 07:04:05:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 63 Stepping 1 07:04:05:WU01:FS01:0x22: CPUs: 24 07:04:05:WU01:FS01:0x22: Memory: 7.90GiB 07:04:05:WU01:FS01:0x22:Free Memory: 5.17GiB 07:04:05:WU01:FS01:0x22: Threads: WINDOWS_THREADS 07:04:05:WU01:FS01:0x22: OS Version: 6.2 07:04:05:WU01:FS01:0x22:Has Battery: false 07:04:05:WU01:FS01:0x22: On Battery: false 07:04:05:WU01:FS01:0x22: UTC Offset: 4 07:04:05:WU01:FS01:0x22: PID: 7976 07:04:05:WU01:FS01:0x22: CWD: C:\FaH-workdir\work 07:04:05:WU01:FS01:0x22: OS: Windows 8.1 Pro 07:04:05:WU01:FS01:0x22: OS Arch: AMD64 07:04:05:WU01:FS01:0x22:******************************************************************************** 07:04:05:WU01:FS01:0x22:Project: 11763 (Run 0, Clone 6916, Gen 12) 07:04:05:WU01:FS01:0x22:Unit: 0x0000001480fccb0a5e71136ba6614f90 07:04:05:WU01:FS01:0x22:Reading tar file core.xml 07:04:05:WU01:FS01:0x22:Reading tar file integrator.xml 07:04:05:WU01:FS01:0x22:Reading tar file state.xml 07:04:05:WU01:FS01:0x22:Reading tar file system.xml 07:04:05:WU01:FS01:0x22:Digital signatures verified 07:04:05:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core 07:04:05:WU01:FS01:0x22:Version 0.0.2 07:04:18:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%) 07:04:18:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900 07:05:22:WU00:FS01:Upload 0.86% 07:05:22:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%) 07:05:28:WU00:FS01:Upload 4.74% 07:05:35:WU00:FS01:Upload 19.39% 07:05:42:WU00:FS01:Upload 70.65% 07:06:09:WU00:FS01:Upload complete 07:06:09:WU00:FS01:Server responded WORK_ACK (400) 07:06:09:WU00:FS01:Final credit estimate, 66599.00 points 07:06:09:WU00:FS01:Cleaning up 07:06:29:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%) 07:07:35:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%) 07:08:40:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%) 07:09:45:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%) 07:10:54:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%) 07:11:58:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%) 07:13:03:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%) 07:14:08:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%) 07:15:12:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%) 07:16:20:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%) 07:17:24:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%) 07:18:28:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%) 07:19:33:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%) 07:20:37:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%) 07:21:45:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%) 07:22:49:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%) 07:23:54:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%) 07:24:58:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%) 07:26:03:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%) 07:27:10:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%) 07:28:15:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%) 07:29:19:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%) 07:30:24:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%) 07:31:28:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%) 07:32:36:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%) 07:33:41:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%) 07:34:46:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%) 07:35:50:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%) 07:36:54:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%) 07:38:03:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%) 07:39:07:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%) 07:40:11:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%) 07:41:16:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%) 07:42:20:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%) 07:43:29:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%) 07:44:33:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%) 07:45:37:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%) 07:46:42:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%) 07:47:46:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%) 07:48:54:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%) 07:49:59:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%) 07:51:04:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%) 07:52:08:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%) 07:53:13:WU01:FS01:0x22:Completed 450000 out of 1000000 steps (45%) 07:54:21:WU01:FS01:0x22:Completed 460000 out of 1000000 steps (46%) 07:55:25:WU01:FS01:0x22:Completed 470000 out of 1000000 steps (47%) 07:56:30:WU01:FS01:0x22:Completed 480000 out of 1000000 steps (48%) 07:57:34:WU01:FS01:0x22:Completed 490000 out of 1000000 steps (49%) 07:58:38:WU01:FS01:0x22:Completed 500000 out of 1000000 steps (50%) 07:59:47:WU01:FS01:0x22:Completed 510000 out of 1000000 steps (51%) 08:00:51:WU01:FS01:0x22:Completed 520000 out of 1000000 steps (52%) 08:01:55:WU01:FS01:0x22:Completed 530000 out of 1000000 steps (53%) 08:03:00:WU01:FS01:0x22:Completed 540000 out of 1000000 steps (54%) 08:04:05:WU01:FS01:0x22:Completed 550000 out of 1000000 steps (55%) 08:05:13:WU01:FS01:0x22:Completed 560000 out of 1000000 steps (56%) 08:06:17:WU01:FS01:0x22:Completed 570000 out of 1000000 steps (57%) 08:07:21:WU01:FS01:0x22:Completed 580000 out of 1000000 steps (58%) 08:08:26:WU01:FS01:0x22:Completed 590000 out of 1000000 steps (59%) 08:09:30:WU01:FS01:0x22:Completed 600000 out of 1000000 steps (60%) 08:10:39:WU01:FS01:0x22:Completed 610000 out of 1000000 steps (61%) 08:11:43:WU01:FS01:0x22:Completed 620000 out of 1000000 steps (62%) 08:12:48:WU01:FS01:0x22:Completed 630000 out of 1000000 steps (63%) 08:13:52:WU01:FS01:0x22:Completed 640000 out of 1000000 steps (64%) 08:14:57:WU01:FS01:0x22:Completed 650000 out of 1000000 steps (65%) 08:16:05:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%) 08:17:10:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%) 08:18:14:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%) 08:19:19:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%) 08:20:24:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%) 08:21:32:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%) 08:22:36:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%) 08:23:41:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%) 08:24:46:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%) 08:25:50:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%) 08:26:58:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%) 08:28:02:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%) 08:29:07:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%) 08:30:12:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%) 08:31:17:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%) 08:32:25:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%) 08:33:29:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%) 08:34:34:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%) 08:35:38:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%) 08:36:43:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%) 08:37:51:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%) 08:38:55:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%) 08:39:59:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%) 08:41:04:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%) 08:42:08:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%) 08:43:16:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%) 08:44:20:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%) 08:45:25:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%) 08:46:29:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%) 08:47:34:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%) 08:48:42:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%) 08:49:46:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%) 08:50:50:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%) 08:51:55:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%) 08:52:59:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%) 08:53:00:WU00:FS01:Connecting to 65.254.110.245:8080 08:53:01:WU00:FS01:Assigned to work server 40.114.52.201 08:53:01:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1070] 6463 from 40.114.52.201 08:53:01:WU00:FS01:Connecting to 40.114.52.201:8080 08:53:03:WU01:FS01:0x22:Saving result file ..\logfile_01.txt 08:53:03:WU01:FS01:0x22:Saving result file checkpointState.xml 08:53:03:WU01:FS01:0x22:Saving result file checkpt.crc 08:53:03:WU01:FS01:0x22:Saving result file positions.xtc 08:53:03:WU01:FS01:0x22:Saving result file science.log 08:53:03:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT 08:53:04:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64) 08:53:04:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11763 run:0 clone:6916 gen:12 core:0x22 unit:0x0000001480fccb0a5e71136ba6614f90 08:53:04:WU01:FS01:Uploading 33.37MiB to 128.252.203.10 08:53:04:WU01:FS01:Connecting to 128.252.203.10:8080 08:53:25:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80 08:53:25:WU01:FS01:Connecting to 128.252.203.10:80 08:53:29:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0 08:53:29:WU00:FS01:Connecting to 65.254.110.245:8080 08:53:30:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 08:53:30:WU00:FS01:Connecting to 18.218.241.186:80 08:53:30:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration 08:53:30:ERROR:WU00:FS01:Exception: Could not get an assignment 08:53:46:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.252.203.10:80: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера. 08:53:46:WU01:FS01:Trying to send results to collection server 08:53:47:WU01:FS01:Uploading 33.37MiB to 155.247.166.219 08:53:47:WU01:FS01:Connecting to 155.247.166.219:8080 08:53:47:ERROR:WU01:FS01:Exception: Transfer failed 08:53:47:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11763 run:0 clone:6916 gen:12 core:0x22 unit:0x0000001480fccb0a5e71136ba6614f90 08:53:47:WU01:FS01:Uploading 33.37MiB to 128.252.203.10 08:53:47:WU01:FS01:Connecting to 128.252.203.10:8080 08:54:29:WU00:FS01:Connecting to 65.254.110.245:8080 08:54:30:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 08:54:30:WU00:FS01:Connecting to 18.218.241.186:80 08:54:30:WU00:FS01:Assigned to work server 13.90.152.57 08:54:30:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 13.90.152.57 08:54:30:WU00:FS01:Connecting to 13.90.152.57:8080 08:54:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80 08:54:51:WU00:FS01:Connecting to 13.90.152.57:80 08:55:00:WU01:FS01:Upload 0.37% 08:55:00:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed 08:55:00:WU01:FS01:Trying to send results to collection server 08:55:00:WU01:FS01:Uploading 33.37MiB to 155.247.166.219 08:55:00:WU01:FS01:Connecting to 155.247.166.219:8080 08:55:00:ERROR:WU01:FS01:Exception: Transfer failed 08:55:00:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11763 run:0 clone:6916 gen:12 core:0x22 unit:0x0000001480fccb0a5e71136ba6614f90 08:55:01:WU01:FS01:Uploading 33.37MiB to 128.252.203.10 08:55:01:WU01:FS01:Connecting to 128.252.203.10:8080 08:55:13:ERROR:WU00:FS01:Exception: Failed to connect to 13.90.152.57:80: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера. 08:55:22:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80 08:55:22:WU01:FS01:Connecting to 128.252.203.10:80 08:55:25:WU01:FS01:Upload 0.19% 08:56:06:WU00:FS01:Connecting to 65.254.110.245:8080 08:56:07:WU00:FS01:Assigned to work server 40.114.52.201 08:56:07:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 40.114.52.201 08:56:07:WU00:FS01:Connecting to 40.114.52.201:8080 08:56:28:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80 08:56:28:WU00:FS01:Connecting to 40.114.52.201:80 08:56:49:ERROR:WU00:FS01:Exception: Failed to connect to 40.114.52.201:80: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера. 08:56:58:WU01:FS01:Upload 0.37% 08:56:58:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed 08:56:58:WU01:FS01:Trying to send results to collection server 08:56:58:WU01:FS01:Uploading 33.37MiB to 155.247.166.219 08:56:58:WU01:FS01:Connecting to 155.247.166.219:8080 08:57:15:WU01:FS01:Upload 0.75% 08:57:23:WU01:FS01:Upload 1.31% 08:57:29:WU01:FS01:Upload 1.69% 08:57:35:WU01:FS01:Upload 2.06% 08:57:42:WU01:FS01:Upload 2.44% 08:57:50:WU01:FS01:Upload 3.00% 08:57:56:WU01:FS01:Upload 3.56% 08:58:02:WU01:FS01:Upload 3.75% 08:58:15:WU01:FS01:Upload 4.12% 08:58:23:WU01:FS01:Upload 4.68% 08:58:44:WU00:FS01:Connecting to 65.254.110.245:8080 08:58:44:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 08:58:44:WU00:FS01:Connecting to 18.218.241.186:80 08:58:45:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration 08:58:45:ERROR:WU00:FS01:Exception: Could not get an assignment 08:58:49:WU01:FS01:Upload 5.06% 08:59:05:WU01:FS01:Upload 5.62% 08:59:13:WU01:FS01:Upload 5.99% 08:59:20:WU01:FS01:Upload 6.56% 08:59:26:WU01:FS01:Upload 6.93% 08:59:38:WU01:FS01:Upload 7.49% 08:59:44:WU01:FS01:Upload 7.87% 08:59:58:WU01:FS01:Upload 8.05% 09:00:13:WU01:FS01:Upload 8.62% 09:00:31:WU01:FS01:Upload 8.80% 09:00:39:WU01:FS01:Upload 9.18% 09:00:45:WU01:FS01:Upload 9.55% 09:00:52:WU01:FS01:Upload 10.12% 09:00:59:WU01:FS01:Upload 11.05% 09:01:06:WU01:FS01:Upload 11.80% 09:01:12:WU01:FS01:Upload 12.36% 09:01:18:WU01:FS01:Upload 12.92% 09:01:25:WU01:FS01:Upload 13.49% 09:01:31:WU01:FS01:Upload 14.05% 09:01:37:WU01:FS01:Upload 14.61% 09:01:43:WU01:FS01:Upload 15.17% 09:01:50:WU01:FS01:Upload 15.55% 09:02:16:WU01:FS01:Upload 15.92% 09:02:16:ERROR:WU01:FS01:Exception: Transfer failed 09:02:16:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11763 run:0 clone:6916 gen:12 core:0x22 unit:0x0000001480fccb0a5e71136ba6614f90 09:02:16:WU01:FS01:Uploading 33.37MiB to 128.252.203.10 09:02:16:WU01:FS01:Connecting to 128.252.203.10:8080 09:02:37:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80 09:02:37:WU01:FS01:Connecting to 128.252.203.10:80 09:02:58:WU00:FS01:Connecting to 65.254.110.245:8080 09:02:58:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.252.203.10:80: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера. 09:02:58:WU01:FS01:Trying to send results to collection server 09:02:58:WU01:FS01:Uploading 33.37MiB to 155.247.166.219 09:02:58:WU01:FS01:Connecting to 155.247.166.219:8080 09:02:59:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 09:02:59:WU00:FS01:Connecting to 18.218.241.186:80 09:02:59:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration 09:02:59:ERROR:WU00:FS01:Exception: Could not get an assignment 09:03:04:WU01:FS01:Upload 0.94% 09:03:10:WU01:FS01:Upload 1.50% 09:03:16:WU01:FS01:Upload 2.06% 09:03:22:WU01:FS01:Upload 2.81% 09:03:28:WU01:FS01:Upload 3.93% 09:03:34:WU01:FS01:Upload 4.50% 09:03:40:WU01:FS01:Upload 5.06% 09:03:46:WU01:FS01:Upload 5.99% 09:03:52:WU01:FS01:Upload 6.93% 09:04:00:WU01:FS01:Upload 7.49% 09:04:07:WU01:FS01:Upload 8.24% 09:04:14:WU01:FS01:Upload 8.99% 09:04:20:WU01:FS01:Upload 9.74% 09:04:26:WU01:FS01:Upload 10.12% 09:04:33:WU01:FS01:Upload 10.68% 09:04:39:WU01:FS01:Upload 11.05% 09:04:48:WU01:FS01:Upload 11.61% 09:04:54:WU01:FS01:Upload 11.99% 09:05:08:WU01:FS01:Upload 12.55% 09:05:19:WU01:FS01:Upload 12.74% 09:05:26:WU01:FS01:Upload 13.30% 09:05:32:WU01:FS01:Upload 13.86% 09:05:38:WU01:FS01:Upload 14.42% 09:05:47:WU01:FS01:Upload 14.99% 09:05:53:WU01:FS01:Upload 15.55% 09:06:05:WU01:FS01:Upload 16.11% 09:06:11:WU01:FS01:Upload 16.67% 09:06:21:WU01:FS01:Upload 17.23% 09:06:27:WU01:FS01:Upload 17.79% 09:06:34:WU01:FS01:Upload 18.54% 09:06:41:WU01:FS01:Upload 18.92% 09:06:48:WU01:FS01:Upload 19.67% 09:07:01:WU01:FS01:Upload 20.23% 09:07:07:WU01:FS01:Upload 20.60% 09:07:16:WU01:FS01:Upload 20.98% 09:07:23:WU01:FS01:Upload 21.35% 09:07:31:WU01:FS01:Upload 21.92% 09:07:38:WU01:FS01:Upload 22.10% 09:07:53:WU01:FS01:Upload 22.29% 09:07:59:WU01:FS01:Upload 22.67% 09:08:06:WU01:FS01:Upload 23.23% 09:08:13:WU01:FS01:Upload 23.79% 09:08:21:WU01:FS01:Upload 24.35% 09:08:27:WU01:FS01:Upload 24.73% 09:08:33:WU01:FS01:Upload 25.10% 09:08:40:WU01:FS01:Upload 25.47% 09:08:46:WU01:FS01:Upload 26.04% 09:09:04:WU01:FS01:Upload 26.41% 09:09:10:WU01:FS01:Upload 26.79% 09:09:20:WU01:FS01:Upload 26.97% 09:09:29:WU01:FS01:Upload 27.54% 09:09:35:WU01:FS01:Upload 28.10% 09:09:45:WU01:FS01:Upload 28.66% 09:09:49:WU00:FS01:Connecting to 65.254.110.245:8080 09:09:50:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration 09:09:50:WU00:FS01:Connecting to 18.218.241.186:80 09:09:51:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration 09:09:51:ERROR:WU00:FS01:Exception: Could not get an assignment 09:09:56:WU01:FS01:Upload 29.03% 09:10:02:WU01:FS01:Upload 29.41% 09:10:42:WU01:FS01:Upload 29.78% 09:10:49:WU01:FS01:Upload 30.16% 09:11:09:WU01:FS01:Upload 30.35% 09:11:09:ERROR:WU01:FS01:Exception: Transfer failed 09:11:10:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11763 run:0 clone:6916 gen:12 core:0x22 unit:0x0000001480fccb0a5e71136ba6614f90 09:11:10:WU01:FS01:Uploading 33.37MiB to 128.252.203.10 09:11:10:WU01:FS01:Connecting to 128.252.203.10:8080 09:11:51:WU01:FS01:Upload 1.12% 09:11:57:WU01:FS01:Upload 87.85% 09:11:59:WU01:FS01:Upload complete 09:11:59:WU01:FS01:Server responded WORK_ACK (400) 09:11:59:WU01:FS01:Final credit estimate, 63691.00 points 09:11:59:WU01:FS01:Cleaning up
TimopheySnz писал(а):
результаты не повалились с той же скоростью, что и новые юзеры
а как это увидеть, скажи пожалуста
_________________ Keep it locked, keep it fold, keep it crunching baby!🔫 🖥⛏🏥 @TSCRussia
Статус: Не в сети Регистрация: 27.08.2015 Откуда: Снежинск
т.е. мы все считаем нЕчто, результаты чего не увидеть? для подобного вроде придумали SETI з.ы. у меня уже всю неделю "No WUs available for this configuration" может это от железа зависит?
Можно выключить ULPS, т.к. на отдельных проектах с небольшим числом атомов - может сбрасывать частоту ниже бустовой в целях экономии, верно и для R-VII. https://community.amd.com/thread/176003
tsaMolotoff писал(а):
сейчас дает 1.2М очков в день
Нормально для 56-й.
Добавлено спустя 15 минут 52 секунды:
Карточка древняя, могли пересохнуть термопаста и/или термопрокладки, можно аккуратно поменять, пасту лучше на 8 или 12 Ватт м К, радиатор нужно прикручивать назад аккуратно, все винты по очереди по трети оборота каждый, чтобы не перекосить площадку и не сколоть чип. Может БП по 12 вольт не держит нагрузку, можно посмотреть мультиметром при другой нагрузке. Можно обновить биос мат.платы, драйвера чипсета и видео.
Все COVID-19 проекты только на 22 ядре.
update: На foldingforum.org также жалуются на проблемы с близкими по номерам проектами на различных конфигурациях, возможно проблема не в железе, а в софте на стороне докторов.
Статус: Не в сети Регистрация: 30.04.2013 Откуда: Москва Фото: 0
решил попробовать на стенде,после боинка своеобразно все делается,вчера и сегодня задания были,даже щас только что загрузилось,но это все на проц,делались примерно по 3ч
Статус: Не в сети Регистрация: 24.11.2002 Откуда: New Mexico, USA Фото: 32
R-VII действительно на многих заданиях работает примерно на 250МГц ниже бустовой частоты. Иногда "всего" на 150 ниже, но в среднем 250. Обидно. Посмотрел ULPS - уже выключен в реестре во всех местах. Жаль, т.к. именно этот комп работает от солнечной энергии.
_________________ Всё в одном: ИнтелоХомяк, АМД Fanтик и Барсучок Хуанга
Сейчас этот форум просматривают: sashmxm и гости: 7
