Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 118 • Страница 4 из 6<  1  2  3  4  5  6  >
TSC! Russia Vice-captain
АлексЕ
OS X 10.5.1 + FAHMon 2.3.2a = нормальная работа. :hitrost:
В OS X вроде привязки к ядрам нет или я просто не знаю как это сделать. Да и не нужно обычно, в linux тоже на C2D привязка не нужна.
Что же касается скорости, то задания разные, надо проверять на одном типе заданий. Под OS X чаще выдаются 2605, под XP - 2653, скорость счета у них разная.
Революционеров можно убить, идеи — никогда.
+ Attempting to get work packet
[17:35:19] - Connecting to assignment server
[17:35:20] - Successful: assigned to (171.64.65.56).
[17:35:20] + News From Folding@Home: Welcome to Folding@Home
[17:35:20] Loaded queue successfully.
[17:35:20] - Couldn't send HTTP request to server
[17:35:20] + Could not connect to Work Server
[17:35:20] - Attempt #3 to get work failed, and no other work to do.
Waiting before retry.
[17:35:55] + Attempting to get work packet
[17:35:55] - Connecting to assignment server
[17:35:55] - Successful: assigned to (171.64.65.56).
[17:35:55] + News From Folding@Home: Welcome to Folding@Home
[17:35:56] Loaded queue successfully.
[17:36:45] + Attempting to send results
[17:36:55] + Could not connect to Work Server (results)
[17:36:55] (171.64.65.56:8080)
[17:36:55] - Error: Could not transmit unit 08 (completed March 26) to work server.
[17:36:55] + Attempting to send results
[17:36:57] - Couldn't send HTTP request to server
[17:36:57] + Could not connect to Work Server (results)
[17:36:57] (171.64.122.76:8080)
[17:36:57] Could not transmit unit 08 to Collection server; keeping in queue.
[17:36:57] + Closed connections
[17:36:57]
[17:36:57] + Processing work unit
[17:36:57] Core required: FahCore_a1.exe
[17:36:57] Core found.
[17:36:57] Working on Unit 09 [March 26 17:36:57]
[17:36:57] + Working ...
[17:36:57]
[17:36:57] *------------------------------*
[17:36:57] Folding@Home Gromacs SMP Core
[17:36:57] Version 1.74 (September 24, 2007)
[17:36:57]
[17:36:57] Preparing to commence simulation
[17:36:57] - Ensuring status. Please wait.
[17:36:57] Created dyn
[17:36:57] - Files status OK
[17:36:57] Error: Work unit read from disk is invalid
[17:36:57] Finalizing output
[17:36:57] - Expanded 2450803 -> 12918705 (decompressed 527.1 percent)
[17:36:58] - Starting from initial work packet
[17:36:58]
[17:36:58] Project: 2605 (Run 10, Clone 27, Gen 36)
[17:36:58]
[17:36:58] Assembly optimizations on if available.
[17:36:58] Entering M.D.
[17:37:15] percent)
[17:37:15] - Starting from initial work packet
[17:37:15]
[17:37:15] Project: 2605 (Run 10, Clone 27, Gen 36)
[17:37:15]
[17:37:15] Entering M.D.
[17:37:21] mdrunner cpfilename:
[17:37:22] g local files
[17:37:22] in in POPC
[17:37:22] Writing local files
[17:37:23] Extra SSE boost OK.
Я так понял клиент устал пытаться слить задание, забил..., скачал новое и считает дальше. Или я не прав?
АлексЕ
Не забил, а просто отложил отправку результата до лучших времён. Потом снова повторит попытку отправки (через 15-20% счета).
Для тех, у кого Леопард 10.5 стоит.
Если нужно запускать консольную версию FAH в режиме демона (скрытом), то можно использовать такой вариант:
1.) Создать файл fah-run и запихать его в папку с клиентом.
cd ./Users/Behc/fah/
./fah6 -smp -local -verbosity 9
2.) Создать файл FAH-SMP.plist со следующим содержанием:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Disabled</key>
<false/>
<key>Label</key>
<string>FAH-SMP</string>
<key>ProgramArguments</key>
<array>
<string>/Users/Behc/fah/fah-run</string> путь к fah
</array>
<key>RunAtLoad</key>
<true/>
</dict>
</plist>
3.) Запихать FAH-SMP.plist в /Library/LaunchDaemons/
4.) Перезапустить компьютер.
А есть ли где то пошаговая инстракшн для настройки клиента под МакОсЬ..?
Последний раз редактировалось Andrey@War 08.01.2011 5:13, всего редактировалось 1 раз.
TSC! Russia ex-Captain
Andrey@War писал(а):
А есть ли где то пошаговая инстракшен для настройки клиента под МакОсЬ..?
Это наверно тока у кенсея или бехса спрашивать у них вроде макбуки были.
Ясно... Что ж будем сами.... Спасибо.
Andrey@War
так же как под линем. качаешь *.tgz, распаковываешь, ./fah6 -smp. можно готовый конфиг подсунуть, можно отвечать на вопросы. абсолютно никаких сложностей, получилось ровно с первого раза.
Don't panic!
Последний раз редактировалось Kensei 08.01.2011 15:01, всего редактировалось 1 раз.
Andrey@War
1) Скачиваешь клиента Mac OS X 10.5+ Intel 32/64-bit SMP Installer;
2) Устанавливаешь. Настраиваешь через ярлык в "Системных настройках";
3) Перезапускаешь компьютер.
Для мониторинга я использую виджет F@H WUdget.
Kensei
Можно и без Unix-way метода обойтись. :)
Behc
а чем он сложнее? ничего ни к чему не привязывается и никуда не ставится. мне так больше нравится. :-)
Don't panic!
тупо поставил на старый макбук про, считает. На рабочем столе не палится. Другое дело, что даже на 8600ГТ можно насчитать больше, чем на коре дуба №2, а считать не дают - видеоклиента того, макоси выкуси ((
Помогите миру своим оверкомпом! tsc.overclockers.ru
Фото: 3
chepser
ну на линух его через wine грабли запускали...
видать и макОСь как-то можно подружить ;)
Присоединяйтесь к команде распределённых вычислений TSC! Russia
боже упаси!Такого счастья мне не надобно!
А много ли народу на маках считает?
И что слышно про бигжабы для маков??? А то 16-ти ядерные рабочие компы на обычных SMP показывают слабенький PPD....
VELVET83
Мало.
Пока нет их. :old_sad:
There should be no bigadv WUs for MacOS yet since the core is still under development.
Кто-нибудь сталкивался с такой проблемой на маках:
После окончания просчета задания, клиент долго не может получить новое задание - от 10 минут до нескольких часов. Такое происходит регулярно на всех маках, где я установил клиент и уже несколько месяцев.
Причем, если задание не приходит уже час или более, я перезапускаю клиент и вроде бы он через минут 10 скачивает новое задание и начинает его считать.
(в логе видно, что у меня есть "Arguments: -bigadv", который я прописывал еще до того, как спрашивал в этой теме про бигжабы. Видимо забыл отключить. Сейчас стер этот параметр, посмотрю, что получится. Но этот параметр был прописан только на одной машине)
Версии клиентов: 6.29.3 (installer) и 6.29r1 (console only)
Компы: Mac Pro с двумя ксеонами, OSX 10.6.7
"UnitInfo.txt"
Current Work Unit
Tag: P6041R0C283G190
Download time: November 2 22:36:20
Due time: November 10 22:36:20
Progress: 100% [||||||||||]
"FAHlog.txt"
--- Opening Log file [November 3 18:35:38 UTC]
# Mac OS X SMP Console Edition ################################################
Folding@Home Client Version 6.29r3
http://folding.stanford.edu
Launch directory: /Users/macpro3/Library/Folding@home
Executable: /usr/local/fah/fah6
Arguments: -bigadv
[18:35:38] - Ask before connecting: No
[18:35:38] - User name: VELVET83
[18:35:38] - User ID: 3090383A316A21AD
[18:35:38] - Machine ID: 1
[18:35:38]
[18:35:38] Loaded queue successfully.
[18:35:38]
[18:35:38] + Processing work unit
[18:35:38] Core required: FahCore_a3.exe
[18:35:38] Core found.
[18:35:38] Working on queue slot 00 [November 3 18:35:38 UTC]
[18:35:38] + Working ...
[18:35:38]
[18:35:38] *------------------------------*
[18:35:38] Folding@Home Gromacs SMP Core
[18:35:38] Version 2.22 (May 7 2010)
[18:35:38]
[18:35:38] Preparing to commence simulation
[18:35:38] - Ensuring status. Please wait.
[18:35:48] - Looking at optimizations...
[18:35:48] - Working with standard loops on this execution.
[18:35:48] - Previous termination of core was improper.
[18:35:48] - Files status OK
[18:35:49] - Expanded 7880841 -> 10126021 (decompressed 128.4 percent)
[18:35:49] Called DecompressByteArray: compressed_data_size=7880841 data_size=10126021, decompressed_data_size=10126021 diff=0
[18:35:49] - Digital signature verified
[18:35:49]
[18:35:49] Project: 6041 (Run 0, Clone 283, Gen 190)
[18:35:49]
[18:35:49] Entering M.D.
[18:35:55] Using Gromacs checkpoints
[18:35:59] fcSaveRestoreState: I/O failed dir=0, var=B08090AC, varsize=53000
[18:35:59] Can't restore state.fcSaveRestoreState: I/O failed dir=0, var=B047B0AC, varsize=53000
[18:35:59] Can't restore state.fcSaveRestoreState: I/O failed dir=0, var=B06830AC, varsize=53000
[18:35:59] Can't restore state.fcSaveRestoreState: I/O failed dir=0, var=B0A930AC, varsize=53000
[18:35:59] Can't restore state.fcSaveRestoreState: I/O failed dir=0, var=B06010AC, varsize=53000
[18:35:59] Can't restore state.fcSaveRestoreState: I/O failed dir=0, var=B0A110AC, varsize=53000
[18:35:59] Can't restore state.mdrun returned 3
[18:35:59] Gromacs detceScatveedR easnt oirnevSatlaCan't restore state.fcSaveRestoreState: I/O failed dir=0, var=B07870AC, varsize=53000
[18:35:59] Can't restore state.Can't open checkpoint file
[18:35:59] Can't open checkpoint file
[18:35:59] Resuming from checkpoint
[18:36:01]
[18:36:01] Folding@home Core Shutdown: UNKNOWN_ERROR
[18:36:01] CoreStatus = 62 (98)
[18:36:01] + Restarting core (settings changed)
[18:36:01]
[18:36:01] + Processing work unit
[18:36:01] Core required: FahCore_a3.exe
[18:36:01] Core found.
[18:36:01] Working on queue slot 00 [November 3 18:36:01 UTC]
[18:36:01] + Working ...
[18:36:01]
[18:36:01] *------------------------------*
[18:36:01] Folding@Home Gromacs SMP Core
[18:36:01] Version 2.22 (May 7 2010)
[18:36:01]
[18:36:01] Preparing to commence simulation
[18:36:01] - Looking at optimizations...
[18:36:01] - Not checking prior termination.
[18:36:02] - Expanded 7880841 -> 10126021 (decompressed 128.4 percent)
[18:36:02] Called DecompressByteArray: compressed_data_size=7880841 data_size=10126021, decompressed_data_size=10126021 diff=0
[18:36:02] - Digital signature verified
[18:36:02]
[18:36:02] Project: 6041 (Run 0, Clone 283, Gen 190)
[18:36:02]
[18:36:03] Assembly optimizations on if available.
[18:36:03] Entering M.D.
[18:36:11] Completed 0 out of 250000 steps (0%)
[18:44:44] Completed 2500 out of 250000 steps (1%)
[18:53:18] Completed 5000 out of 250000 steps (2%)
[19:01:51] Completed 7500 out of 250000 steps (3%)
[19:10:23] Completed 10000 out of 250000 steps (4%)
[19:18:57] Completed 12500 out of 250000 steps (5%)
[19:27:30] Completed 15000 out of 250000 steps (6%)
[19:36:02] Completed 17500 out of 250000 steps (7%)
[19:44:36] Completed 20000 out of 250000 steps (8%)
[19:53:09] Completed 22500 out of 250000 steps (9%)
[20:01:42] Completed 25000 out of 250000 steps (10%)
[20:10:14] Completed 27500 out of 250000 steps (11%)
[20:18:48] Completed 30000 out of 250000 steps (12%)
[20:27:22] Completed 32500 out of 250000 steps (13%)
[20:35:54] Completed 35000 out of 250000 steps (14%)
[20:44:28] Completed 37500 out of 250000 steps (15%)
[20:53:01] Completed 40000 out of 250000 steps (16%)
[21:01:34] Completed 42500 out of 250000 steps (17%)
[21:10:07] Completed 45000 out of 250000 steps (18%)
[21:18:40] Completed 47500 out of 250000 steps (19%)
[21:27:14] Completed 50000 out of 250000 steps (20%)
[21:35:46] Completed 52500 out of 250000 steps (21%)
[21:44:20] Completed 55000 out of 250000 steps (22%)
[21:52:53] Completed 57500 out of 250000 steps (23%)
[22:01:27] Completed 60000 out of 250000 steps (24%)
[22:09:59] Completed 62500 out of 250000 steps (25%)
[22:18:32] Completed 65000 out of 250000 steps (26%)
[22:27:06] Completed 67500 out of 250000 steps (27%)
[22:35:39] Completed 70000 out of 250000 steps (28%)
[22:44:12] Completed 72500 out of 250000 steps (29%)
[22:52:46] Completed 75000 out of 250000 steps (30%)
[23:01:19] Completed 77500 out of 250000 steps (31%)
[23:09:52] Completed 80000 out of 250000 steps (32%)
[23:18:26] Completed 82500 out of 250000 steps (33%)
[23:27:00] Completed 85000 out of 250000 steps (34%)
[23:35:32] Completed 87500 out of 250000 steps (35%)
[23:44:06] Completed 90000 out of 250000 steps (36%)
[23:52:40] Completed 92500 out of 250000 steps (37%)
[00:01:14] Completed 95000 out of 250000 steps (38%)
[00:09:47] Completed 97500 out of 250000 steps (39%)
[00:18:22] Completed 100000 out of 250000 steps (40%)
[00:26:55] Completed 102500 out of 250000 steps (41%)
[00:35:28] Completed 105000 out of 250000 steps (42%)
[00:44:03] Completed 107500 out of 250000 steps (43%)
[00:52:37] Completed 110000 out of 250000 steps (44%)
[01:01:10] Completed 112500 out of 250000 steps (45%)
[01:09:44] Completed 115000 out of 250000 steps (46%)
[01:18:18] Completed 117500 out of 250000 steps (47%)
[01:26:53] Completed 120000 out of 250000 steps (48%)
[01:35:26] Completed 122500 out of 250000 steps (49%)
[01:44:00] Completed 125000 out of 250000 steps (50%)
[01:52:33] Completed 127500 out of 250000 steps (51%)
[02:01:07] Completed 130000 out of 250000 steps (52%)
[02:09:41] Completed 132500 out of 250000 steps (53%)
[02:18:15] Completed 135000 out of 250000 steps (54%)
[02:26:49] Completed 137500 out of 250000 steps (55%)
[02:35:22] Completed 140000 out of 250000 steps (56%)
[02:43:56] Completed 142500 out of 250000 steps (57%)
[02:52:30] Completed 145000 out of 250000 steps (58%)
[03:01:03] Completed 147500 out of 250000 steps (59%)
[03:09:37] Completed 150000 out of 250000 steps (60%)
[03:18:11] Completed 152500 out of 250000 steps (61%)
[03:26:45] Completed 155000 out of 250000 steps (62%)
[03:35:19] Completed 157500 out of 250000 steps (63%)
[03:43:53] Completed 160000 out of 250000 steps (64%)
[03:52:27] Completed 162500 out of 250000 steps (65%)
[04:01:01] Completed 165000 out of 250000 steps (66%)
[04:09:35] Completed 167500 out of 250000 steps (67%)
[04:18:08] Completed 170000 out of 250000 steps (68%)
[04:26:42] Completed 172500 out of 250000 steps (69%)
[04:35:15] Completed 175000 out of 250000 steps (70%)
[04:43:49] Completed 177500 out of 250000 steps (71%)
[04:52:22] Completed 180000 out of 250000 steps (72%)
[05:00:56] Completed 182500 out of 250000 steps (73%)
[05:09:30] Completed 185000 out of 250000 steps (74%)
[05:18:04] Completed 187500 out of 250000 steps (75%)
[05:26:38] Completed 190000 out of 250000 steps (76%)
[05:35:11] Completed 192500 out of 250000 steps (77%)
[05:43:46] Completed 195000 out of 250000 steps (78%)
[05:52:20] Completed 197500 out of 250000 steps (79%)
[06:00:54] Completed 200000 out of 250000 steps (80%)
[06:09:29] Completed 202500 out of 250000 steps (81%)
[06:18:03] Completed 205000 out of 250000 steps (82%)
[06:26:38] Completed 207500 out of 250000 steps (83%)
[06:35:12] Completed 210000 out of 250000 steps (84%)
[06:43:46] Completed 212500 out of 250000 steps (85%)
[06:52:21] Completed 215000 out of 250000 steps (86%)
[07:00:55] Completed 217500 out of 250000 steps (87%)
[07:09:30] Completed 220000 out of 250000 steps (88%)
[07:18:04] Completed 222500 out of 250000 steps (89%)
[07:26:39] Completed 225000 out of 250000 steps (90%)
[07:35:14] Completed 227500 out of 250000 steps (91%)
[07:43:49] Completed 230000 out of 250000 steps (92%)
[07:52:23] Completed 232500 out of 250000 steps (93%)
[08:00:57] Completed 235000 out of 250000 steps (94%)
[08:09:32] Completed 237500 out of 250000 steps (95%)
[08:18:06] Completed 240000 out of 250000 steps (96%)
[08:26:41] Completed 242500 out of 250000 steps (97%)
[08:35:14] Completed 245000 out of 250000 steps (98%)
[08:43:49] Completed 247500 out of 250000 steps (99%)
[08:52:23] Completed 250000 out of 250000 steps (100%)
[08:52:28] DynamicWrapper: Finished Work Unit: sleep=10000
[08:52:38]
[08:52:38] Finished Work Unit:
[08:52:38] - Reading up to 23811192 from "work/wudata_00.trr": Read 23811192
[08:52:38] trr file hash check passed.
[08:52:38] - Reading up to 30739192 from "work/wudata_00.xtc": Read 30739192
[08:52:38] xtc file hash check passed.
[08:52:38] edr file hash check passed.
[08:52:38] logfile size: 194413
[08:52:38] Leaving Run
[08:52:41] - Writing 54763065 bytes of core data to disk...
[08:52:42] ... Done.
[08:52:49] - Shutting down core
[08:52:49]
[08:52:49] Folding@home Core Shutdown: FINISHED_UNIT
[08:52:49] CoreStatus = 64 (100)
[08:52:49] Sending work to server
[08:52:49] Project: 6041 (Run 0, Clone 283, Gen 190)
[08:52:49] + Attempting to send results [November 4 08:52:49 UTC]
[08:54:39] + Results successfully sent
[08:54:39] Thank you for your contribution to Folding@Home.
[08:54:39] + Number of Units Completed: 274
[08:54:42] - Preparing to get new work unit...
[08:54:42] Cleaning up work directory
[08:54:42] + Attempting to get work packet
[08:54:42] Passkey found
[08:54:42] - Connecting to assignment server
[08:54:43] + No appropriate work server was available; will try again in a bit.
[08:54:43] + Couldn't get work instructions.
[08:54:43] - Attempt #1 to get work failed, and no other work to do.
[08:55:01] + Attempting to get work packet
[08:55:01] Passkey found
[08:55:01] - Connecting to assignment server
[08:55:02] + No appropriate work server was available; will try again in a bit.
[08:55:02] + Couldn't get work instructions.
[08:55:02] - Attempt #2 to get work failed, and no other work to do.
[08:55:24] + Attempting to get work packet
[08:55:24] Passkey found
[08:55:24] - Connecting to assignment server
[08:55:25] + No appropriate work server was available; will try again in a bit.
[08:55:25] + Couldn't get work instructions.
[08:55:25] - Attempt #3 to get work failed, and no other work to do.
[08:55:59] + Attempting to get work packet
[08:55:59] Passkey found
[08:55:59] - Connecting to assignment server
[08:56:00] + No appropriate work server was available; will try again in a bit.
[08:56:00] + Couldn't get work instructions.
[08:56:00] - Attempt #4 to get work failed, and no other work to do.
[08:56:43] + Attempting to get work packet
[08:56:43] Passkey found
[08:56:43] - Connecting to assignment server
[08:56:44] + No appropriate work server was available; will try again in a bit.
[08:56:44] + Couldn't get work instructions.
[08:56:44] - Attempt #5 to get work failed, and no other work to do.
[08:58:14] + Attempting to get work packet
[08:58:14] Passkey found
[08:58:14] - Connecting to assignment server
[08:58:15] + No appropriate work server was available; will try again in a bit.
[08:58:15] + Couldn't get work instructions.
[08:58:15] - Attempt #6 to get work failed, and no other work to do.
[09:01:08] + Attempting to get work packet
[09:01:08] Passkey found
[09:01:08] - Connecting to assignment server
[09:01:09] + No appropriate work server was available; will try again in a bit.
[09:01:09] + Couldn't get work instructions.
[09:01:09] - Attempt #7 to get work failed, and no other work to do.
[09:06:42] + Attempting to get work packet
[09:06:42] Passkey found
[09:06:42] - Connecting to assignment server
[09:06:43] + No appropriate work server was available; will try again in a bit.
[09:06:43] + Couldn't get work instructions.
[09:06:43] - Attempt #8 to get work failed, and no other work to do.
[09:17:23] + Attempting to get work packet
[09:17:23] Passkey found
[09:17:23] - Connecting to assignment server
[09:17:24] + No appropriate work server was available; will try again in a bit.
[09:17:24] + Couldn't get work instructions.
[09:17:24] - Attempt #9 to get work failed, and no other work to do.
[09:38:55] + Attempting to get work packet
[09:38:55] Passkey found
[09:38:55] - Connecting to assignment server
[09:38:56] + No appropriate work server was available; will try again in a bit.
[09:38:56] + Couldn't get work instructions.
[09:38:56] - Attempt #10 to get work failed, and no other work to do.
[10:21:50] + Attempting to get work packet
[10:21:50] Passkey found
[10:21:50] - Connecting to assignment server
[10:21:51] - Successful: assigned to (171.64.65.54).
[10:21:51] + News From Folding@Home: Welcome to Folding@Home
[10:21:52] Loaded queue successfully.
[10:21:52] + Could not connect to Work Server
[10:21:52] - Attempt #11 to get work failed, and no other work to do.
Folding@Home Client Shutdown.
--- Opening Log file [November 4 10:31:08 UTC]
Arguments: -bigadv
[10:31:08] - Ask before connecting: No
[10:31:08] - User name: VELVET83
[10:31:08] - User ID: 3090383A316A21AD
[10:31:08] - Machine ID: 1
[10:31:08]
[10:31:08] Loaded queue successfully.
[10:31:08] - Preparing to get new work unit...
[10:31:08] Cleaning up work directory
[10:31:08] + Attempting to get work packet
[10:31:08] Passkey found
[10:31:08] - Connecting to assignment server
[10:31:10] + No appropriate work server was available; will try again in a bit.
[10:31:10] + Couldn't get work instructions.
[10:31:10] - Attempt #1 to get work failed, and no other work to do.
[10:31:19] + Attempting to get work packet
[10:31:19] Passkey found
[10:31:19] - Connecting to assignment server
[10:31:20] + No appropriate work server was available; will try again in a bit.
[10:31:20] + Couldn't get work instructions.
[10:31:20] - Attempt #2 to get work failed, and no other work to do.
[10:31:42] + Attempting to get work packet
[10:31:42] Passkey found
[10:31:42] - Connecting to assignment server
[10:31:43] + No appropriate work server was available; will try again in a bit.
[10:31:43] + Couldn't get work instructions.
[10:31:43] - Attempt #3 to get work failed, and no other work to do.
[10:32:10] + Attempting to get work packet
[10:32:10] Passkey found
[10:32:10] - Connecting to assignment server
[10:32:11] + No appropriate work server was available; will try again in a bit.
[10:32:11] + Couldn't get work instructions.
[10:32:11] - Attempt #4 to get work failed, and no other work to do.
[10:33:04] + Attempting to get work packet
[10:33:04] Passkey found
[10:33:04] - Connecting to assignment server
[10:33:05] + No appropriate work server was available; will try again in a bit.
[10:33:05] + Couldn't get work instructions.
[10:33:05] - Attempt #5 to get work failed, and no other work to do.
[10:34:39] + Attempting to get work packet
[10:34:39] Passkey found
[10:34:39] - Connecting to assignment server
[10:34:40] + No appropriate work server was available; will try again in a bit.
[10:34:40] + Couldn't get work instructions.
[10:34:40] - Attempt #6 to get work failed, and no other work to do.
[10:37:21] + Attempting to get work packet
[10:37:21] Passkey found
[10:37:21] - Connecting to assignment server
[10:37:22] + No appropriate work server was available; will try again in a bit.
[10:37:22] + Couldn't get work instructions.
[10:37:22] - Attempt #7 to get work failed, and no other work to do.
[10:42:56] + Attempting to get work packet
[10:42:56] Passkey found
[10:42:56] - Connecting to assignment server
[10:42:57] + No appropriate work server was available; will try again in a bit.
[10:42:57] + Couldn't get work instructions.
[10:42:57] - Attempt #8 to get work failed, and no other work to do.
--- Opening Log file [November 4 10:51:12 UTC]
[10:51:12] - Ask before connecting: No
[10:51:12] - User name: VELVET83
[10:51:12] - User ID: 3090383A316A21AD
[10:51:12] - Machine ID: 1
[10:51:12]
[10:51:12] Loaded queue successfully.
[10:51:12] - Preparing to get new work unit...
[10:51:12] Cleaning up work directory
[10:51:12] + Attempting to get work packet
[10:51:12] Passkey found
[10:51:12] - Connecting to assignment server
[10:51:13] + No appropriate work server was available; will try again in a bit.
[10:51:13] + Couldn't get work instructions.
[10:51:13] - Attempt #1 to get work failed, and no other work to do.
[10:51:29] + Attempting to get work packet
[10:51:29] Passkey found
[10:51:29] - Connecting to assignment server
[10:51:30] + No appropriate work server was available; will try again in a bit.
[10:51:30] + Couldn't get work instructions.
[10:51:30] - Attempt #2 to get work failed, and no other work to do.
[10:51:53] + Attempting to get work packet
[10:51:53] Passkey found
[10:51:53] - Connecting to assignment server
[10:51:54] + No appropriate work server was available; will try again in a bit.
[10:51:54] + Couldn't get work instructions.
[10:51:54] - Attempt #3 to get work failed, and no other work to do.
[10:52:23] + Attempting to get work packet
[10:52:23] Passkey found
[10:52:23] - Connecting to assignment server
[10:52:24] + No appropriate work server was available; will try again in a bit.
[10:52:24] + Couldn't get work instructions.
[10:52:24] - Attempt #4 to get work failed, and no other work to do.
[10:53:13] + Attempting to get work packet
[10:53:13] Passkey found
[10:53:13] - Connecting to assignment server
[10:53:14] + No appropriate work server was available; will try again in a bit.
[10:53:14] + Couldn't get work instructions.
[10:53:14] - Attempt #5 to get work failed, and no other work to do.
[10:54:46] + Attempting to get work packet
[10:54:46] Passkey found
[10:54:46] - Connecting to assignment server
[10:54:47] + No appropriate work server was available; will try again in a bit.
[10:54:47] + Couldn't get work instructions.
[10:54:47] - Attempt #6 to get work failed, and no other work to do.
[10:57:38] + Attempting to get work packet
[10:57:38] Passkey found
[10:57:38] - Connecting to assignment server
[10:57:39] - Successful: assigned to (171.64.65.54).
[10:57:39] + News From Folding@Home: Welcome to Folding@Home
[10:57:39] Loaded queue successfully.
[10:57:46] + Closed connections
[10:57:46]
[10:57:46] + Processing work unit
[10:57:46] Core required: FahCore_a3.exe
[10:57:46] Core found.
[10:57:46] Working on queue slot 01 [November 4 10:57:46 UTC]
[10:57:46] + Working ...
[10:57:46]
[10:57:46] *------------------------------*
[10:57:46] Folding@Home Gromacs SMP Core
[10:57:46] Version 2.22 (May 7 2010)
[10:57:46]
[10:57:46] Preparing to commence simulation
[10:57:46] - Looking at optimizations...
[10:57:46] - Created dyn
[10:57:46] - Files status OK
[10:57:47] - Expanded 1762451 -> 2252021 (decompressed 127.7 percent)
[10:57:47] Called DecompressByteArray: compressed_data_size=1762451 data_size=2252021, decompressed_data_size=2252021 diff=0
[10:57:47] - Digital signature verified
[10:57:47]
[10:57:47] Project: 6051 (Run 1, Clone 106, Gen 481)
[10:57:47]
[10:57:47] Assembly optimizations on if available.
[10:57:47] Entering M.D.
[10:57:53] Completed 0 out of 500000 steps (0%)
И еще один вопрос:
В дополнительных настройках клиента есть строка "Core network adress:". На что влияет этот параметр и имеет ли смысл туда что-нибудь прописать? :)
VELVET83
Не сталкивался с таким. Попробуй клиент 7-й ветки, может там такого затыка нет.
Продолжу писать о своем опыте с Фолдингом и Маком... Вдруг, кто поможет или, ноборот, надет что полезное для себя...
Нашел тут статейку одну о запуске Линукса или Убунты на маке через виртуальную машину.
Решил попробовать.
Задача: запустить линукс/убунту на маке для счета больших заданий.
Пока получилось только запустить убунту; только 32-разрядную - 64-разрядную не успел попробовать.
Столкнулся со след. проблемами:
- для счета smp-заданий требует 64-разрядную операционку. Обычные задания считаются.
- не получается указать в настройках виртуальной машины передать в виртуальную ОС больше 8 ядер. На компе 16 потоков (2 четырехядерных процессора с HyperTreading)
VELVET83
Зачем? И Ubuntu - это одна из версий Linux, скажем так, упрощённо.
Баян, которому уже три года.
Что используется для создания виртуальной машины: VMWare, Parallels, VirtualBox?
Цели не ясны, чем 7-й клиент не подходит не понятно.
Эээ... Зачем что? Зачем мне понадобилась статья?
Затем, о чем я уже написал: "запустить линукс/убунту на маке для счета больших заданий".
Зачем Linux или Ubuntu? Затем, что только на них можно считать оч. большие задания.
Почему линукс или убунту? Потому что можно поставить линукс или убунту - т.к. это одно и то же для счета оч. больших заданий.
Видимо, баян. Но я пока не очень разбираюсь в линуксах и убунтах, поэтому искал дистрибутив, который не требует установки, а сразу запускается в виртуальной машине. И пока не разобрался как найти такой дистрибутив 64-разрядный. Буду разбираться дальше и наверное что-нибудь найду в соответствующем разделе этого форума или сам разберусь.
Пока VMWare, т.к. она уже была установлена.
цель одна - считать на маке большие задания. Желательно очень большие. Без перезагрузки в другую операционную систему.
По поводу 7-го клиента. Несколько месяцев назад ты писал мне, что биг жаб для мака нет.
Или ты имел ввиду, что с помощью обычного клиента нельзя считать бигжабы? А, типа, с 7-ым клиентом можно и их считать на любой платформе?
P.S.: Может, я не понимаю чего-то более глобального? Например, можно ли считать большие задания в ОС, запущенной в виртуальной среде?
P.P.S.: С субботы, 12 ноября 2011 г. перестали приходить SMP задания для маков, на которых я установил фолдинг. Все маки находятся в одной рабочей сети. В чем проблема - пока не знаю. Может, быть что-то изменилось в сети.
Лаборатория
