Статус: Не в сети Регистрация: 13.08.2007 Откуда: Ставрополь
Ребят тут у креатива новая бэтка драйвера вышла
File Name: SBXF_PCDRVBETA_US_2_18_0006.exe
This download is a beta driver providing Microsoft® Windows Vista® and Windows® XP support for Creative Sound Blaster® X-Fi™ series of audio devices. For more details, read the rest of this web release note.
Take note of the following:rs install this driver. Do not install this driver on a system used to perform critical tasks. Users who are looking for stable drivers should wait for the final release. When this happens, user should install the latest Sound Blaster X-Fi series driver available.
This download supports the following audio devices only: Creative Sound Blaster X-Fi XtremeGamer Fatal1ty® Professional Series Creative Sound Blaster X-Fi Platinum Fatal1ty Champion Series Creative Sound Blaster X-Fi XtremeMusic Creative Sound Blaster X-Fi XtremeGamer Creative Sound Blaster X-Fi Platinum Creative Sound Blaster X-Fi Fatal1ty Creative Sound Blaster X-Fi Elite Pro Creative Sound Blaster X-Fi
Added Features or Enhancements: Supports Dolby® Digital Live Supports DTS® Connect (For Windows Vista only) Requires the latest Creative Console Launcher application. Click here to download.
To get the above mentioned features you will need to purchase the Dolby Digital Live and DTS Connect software pack.
For systems using Windows Vista To find out the Product ID of your audio device and if it supports the following features in Windows XP, click here. Dolby Digital and DTS decode re-established for sound cards that included decoding in their Windows XP drivers (Not applicable for products that included a 3rd party software DVD player license in the package). DVD-Audio playback re-established for sound cards that included the application in their Windows XP software suite (For Windows Vista 32-bit only). Requires the latest Creative MediaSource DVD-Audio Player software. Click here to download.
Fixes: Resolves issue of audio popping when playing AC-3 Wave files or using Dolby Digital Live via the digital output on Windows Vista. Resolves Audio Control Panel issue of incorrect X-Fi CMSS®-3D behavior while using Audio Creation Mode.
Requirements: Windows Vista 64-bit, Windows Vista 32-bit, Windows XP Professional x64 Edition, Windows XP Service Pack 2 (SP2), Windows XP Media Center Edition (MCE) 2005 or Windows XP MCE 2004 Creative Sound Blaster X-Fi audio devices listed above
Notes: Do not install this driver for Sound Blaster X-Fi Xtreme Audio. To install this driver Download the file onto your local hard disk. Double-click the downloaded file. Follow the instructions on the screen.
Setup is unable to detect a supported product on your system Setup will now exit
Как с этим быть? У звуковухи ведь есть свой биос? Может в нем название устройства указано "неправильное" для линуксовых дров? Возможно как-нибудь перепрошить?
Статус: Не в сети Регистрация: 10.09.2007 Откуда: /home
Глядите, че прописано в installer
Код:
# Hardware detection # Check Disk space #---------------------------------------- supported_device_id=0021:002b:1003:0024:0029:6007:6002:6003:0022:002f:0023:0026:0028:6006:002c:0025:0027:0031
vendor_id=1102 device_id=0005
Если прописать нужный device_id в список, то ,наверно, должно поставиться?
Хм...почитал на предыдуще странице про перепрошивку и ничего не понял...для PonyProg отдельное устройство что-ли паять надо?
Статус: Не в сети Регистрация: 05.07.2005 Откуда: Донецк
Продолжение возни с дохлым 0670 который похоже всеже 0677
В мою карточку попробовали зашить мозги от Платинума и ОЕМ-ную прошивку которой поделился cka3o4nuk Результат - ID меняется как надо, но на какой-то VIA-шной плате в сервисе и на моей 865-й всё также нет звука и система с картой полчаса грузится (без преувеличений)
Никак не выделю время чтоб таки завершить апгрейд и на IP35 Pro переехать. Как переберу ящик - посмотрю что на ней будет.
Если не выйдет - заранее поинтересуюсь - SB0677 HP "белая" внешне нормальная 100% но нерабочая никому не надо? Даром не отдам, о цене можно думать.
Статус: Не в сети Регистрация: 06.12.2006 Откуда: Kherson Ukr Фото: 3
sauronru писал(а):
Для бета драйвера:2.18.0006
Ктото на них пробовал в часности с XtrimGamer - у меня не пошло . Отписался автору. Ответ: "ЧТото с этими дровами не то, как появится время погляжу что на моей системе будет." Будем подождать и понадеяться"
Статус: Не в сети Регистрация: 14.03.2003 Откуда: Samara Фото: 42
sauronru чет я потерялся немного.... В общем сейчас перелез на висту 64, дрова сначала поставил с диска от Даниеля, который в XP себя зарекомендовал отлично. В висте не работал саб, в тестах был, а в остальном везде нет. Поставил, но не с первого раза поверх свежие не бету дрова от креатива... Какие правильные обновления то ставить?
Статус: Не в сети Регистрация: 20.04.2007 Откуда: Россия, Саратов
тебе он хоть ответил - я скинул ему на указанное на сайте мыло субсустем ид и тишина - а если глянуть его пак - то добавил он дат для 678 карты (а значит что обладатели 670той может быть идут лесом).
бетка в принципе на то и бетка что бы на тей тесты прогнать и статистику собрать - нвидиа постоянно "сливает" беты что бы пользователи за них тесты прогоняли
_________________ И долго эхо в след ему молчало, нельзя же быть таким прямым как кишка.
Сранно т.к. ответ пришел ваще минут через 10 ... У меня пока эта бетка вроде все норм хотя с предидущей тож нормально было. Так что мож есть смысл откатиться на 2.18.0000 - там заработает? (Просто тему нарыл недавно) /XtremeGamer (SB073A). Subsystem ID 0031/ Гы а для Для бета драйвера:2.18.0006 - убрали
мини отчет:
2.18.0004 - полет нормальный - но DD/DTS нет - DVD-Audio работает на ура (родной проигрователь сакс вынес).
дат файлы от VBKesha не помогли - устройство не может быть инициализировано.
бета 2.18.0006 - опять же без косяков - но DD/DTS нет - DVD-Audio работает на ура
Пак от Даниэля - DD/DTS нет - DVD-Audio работает - на амд разлочка DDL не прошла - на интеле руки не дошли попробовать (не вижу смысла)
Youp-PAX - 6.10 - 615 - основаны как раз на 2.18.0004 и на 2.18.0006 - DD/DTS нет - DVD-Audio работает - в комментах народ хвалит и пишет что Dell OEM X-Fi Music card (0463) разлочивает.
У "Кеши" мыло на народе? мабуть то что на сайте указано не рабочее?
оказалось в спам ответ угодил действительно отвечает шустро.
sauronru писал(а):
мини отчет: 2.18.0004 - полет нормальный - но DD/DTS нет - DVD-Audio работает на ура (родной проигрователь сакс вынес). дат файлы от VBKesha не помогли - устройство не может быть инициализировано.
Странно я откатил (правда с гемором) - на эту версию - на профильной карте - все пучком.
У меня вот еще вопросик:
Реально ли креативом каим либо образом управлять из камандной строки ну переключать режимы и т.п. есть к примеру XFiModeChanger - он то как то это делать умеет.
Статус: Не в сети Регистрация: 02.03.2005 Откуда: Владивосток
sauronru писал(а):
мини отчет:
На моей карте спокойно разлочивается на 2.18.0004(так же и как на Youp-PAX - 6.10) DD/DTS - что под ХР SP3, что под Вистой 64 SP1 - так что дело не в дровах ... мне кажеться - причем твоя карточка в списке поддреживаемых разлочкой.
