Куратор(ы):   ykk
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 3664 • Страница 1 из 1841  2  3  4  5 ... 184  >
Куратор темы
Статус: В сети
Только что Intel запустил пресс-релиз:
Intel Identifies Chipset Design Error, Implementing Solution
Press Release Source: Intel On Monday January 31, 2011, 9:59 am
SANTA CLARA, Calif.--(BUSINESS WIRE)-- As part of ongoing quality assurance, Intel Corporation has discovered a design issue in a recently released support chip, the Intel® 6 Series, code-named Cougar Point, and has implemented a silicon fix. In some cases, the Serial-ATA (SATA) ports within the chipsets may degrade over time, potentially impacting the performance or functionality of SATA-linked devices such as hard disk drives and DVD-drives. The chipset is utilized in PCs with Intel’s latest Second Generation Intel Core processors, code-named Sandy Bridge. Intel has stopped shipment of the affected support chip from its factories. Intel has corrected the design issue, and has begun manufacturing a new version of the support chip which will resolve the issue. The Sandy Bridge microprocessor is unaffected and no other products are affected by this issue.
The company expects to begin delivering the updated version of the chipset to customers in late February and expects full volume recovery in April. Intel stands behind its products and is committed to product quality. For computer makers and other Intel customers that have bought potentially affected chipsets or systems, Intel will work with its OEM partners to accept the return of the affected chipsets, and plans to support modifications or replacements needed on motherboards or systems. The systems with the affected support chips have only been shipping since January 9th and the company believes that relatively few consumers are impacted by this issue. The only systems sold to an end customer potentially impacted are Second Generation Core i5 and Core i7 quad core based systems. Intel believes that consumers can continue to use their systems with confidence, while working with their computer manufacturer for a permanent solution. For further information consumers should contact Intel at http://www.intel.com on the support page or contact their OEM manufacturer.
Полный текст: http://newsroom.intel.com/community/int ... g-solution
Зеркало: http://finance.yahoo.com/news/Intel-Ide ... l?x=0&.v=1
Ссылки по теме:
Technology@Intel · Chipset With Potential Problem - What To Do
AnandTech - Intel Discovers Bug in 6-Series Chipset: Our Analysis
AnandTech - The Source of Intel's Cougar Point SATA Bug
The Tech Report - Intel finds flaw in Sandy Bridge chipsets, halts shipments
Tom's Hardware - Intel Identifies Cougar Point Chipset Error, Halts Shipments
Tom's Hardware - Sandy Bridge Debacle: What It Means for You
pcgameshardware.de - Probleme mit Intel-Chips P67 und H67 für Sandy-Bridge-CPUs bestätigt (на немецком)
РИА Новости - Ошибка в новом чипсете обойдется Intel в миллиард долларов
iXBT: Ошибка в чипсетах Intel 6-й серии
Overclockers.ru - Asus, Gigabyte и Toshiba принимают назад продукты на базе дефектных чипсетов Intel
Intel Provides Update on Support Chip Design Issue
Что известно на данный момент:
1. Баг затрагивает только четыре SATA2 порта. Два порта SATA3, а также дополнительные SATA порты, организованные контроллерами сторонних производителей (Marvel и др), багу не подвержены.
2. Баг выражается в постепенном падении производительности SATA2 портов в плоть до полного неопределения SATA устройств, подключенных к ним.
3. Intel уверяет, что SATA устройства при этом не страдают.
4. Темпы деградации портов зависят от: температуры, напряжения на чипсете (?) и активности использования устройств, подключенных к SATA2 портам.
5. Баг присутствует во всех выпущенных на данный момент материнских платах на чипсетах Cougar Point (P67, H67 и других под Sandy Bridge). В чипсете ревизии B1 бага не было, однако эта ревизия в продажу не попала. Все материнские платы, выпущенные для конечных производителей, произведены на чипсете ревизии B2, имеющей баг.
6. Производство исправленных чипсетов (ревизия В3) должно быть налажено в середине февраля. Материнские платы на новой ревизии чипсета следует ожидать в марте-апреле.
7. Чипсет Z68 сразу выйдет без этого бага.
Рекомендация пользователям:
1. Перевесить все имеющиеся SATA устройства на SATA3 порты.
2. Если же использования SATA2 портов избежать не удается, повесить на них малоиспользуемые, некритичные девайсы (например, оптический привод).
Реакция производителей материнских плат:
Процедура замены в зависимости от производителя материнской платы (на примере магазина "Юлмарт", Россия):
MB производства Intel
Замене подлежат все платы на степинге B2.
С 11 апреля платы можно сдавать в наш гарантийный отдел.
Далее они напрямую отправляются в Intel и через 10-14 дней приходит замена.
В случае отсутствия нужной позиции на складах интела, срок может увеличится.
MB производства ASUS
Замене подлежат все платы на степинге B2 в период с 1 мая по 31 июля.
Можно будет сдать старую плату и получить замену в нашем гарантийном отделе. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы.
MB производства MSI
Массовой замены не будет, в гарантию будут приниматься платы только с демонстрируемым дефектом,
иначе говоря если у вас все работает, поменять плату не получится.
По производителю ASRock
По производителю Gigabyte
Появилась информация. Можно будет сдать старую плату и получить замену в нашем гарантийном отделе, если дефект проявляется. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы.
В случае, когда дефект не проявляется, но Вы хотите её сдать, требуется ПОЛНЫЙ комплект (заводская упаковка, диски, кабели)
Asrock
Asrock (Россия)
Gigabyte
Gigabyte (Россия)
Gigabyte (Россия)
Asus
Asus (США и Канада)
Asus (Россия)
MSI
MSI (Россия)
MSI (Украина)
...производителей ноутбуков:
RETERA.RU - Из-за проблем с чипсетами Intel многие компании отзывают свои ноутбуки
Toshiba
Как отличить материнские платы на новом степинге от старых:
MSI
ASRock
Gigabyte
Asus
Примеры борьбы с магазинами, которые отказываются менять материнки B2 на B3:
Баг в чипсетах Intel P67-H67 #8270030
Форма-заявка на сайте Гигабайта
Последний раз редактировалось Dark Knight 27.05.2011 9:24, всего редактировалось 48 раз(а).
edit
Это чо типа мама убивает все подключеные к ней по сата девайсы ? а я собрался 80 гиг ссд интел покупать о_О
и вот это
это получается все с 9 числа или как ?
I7 2600K@4.5(1.3v)HT - MSI P67A GD55 - 2*560Ti SLI@950\2150 - 2*4Gb@1866(9-9-9-24) - 80GbSSDIntelG2 - Chieftec 750W - X-Fi Xtreme - 27" IIyama
Фото: 515
То, что тема вынесена в форум "Флейм", совершенно не значит, что в ней можно писать какой угодно бред. Попрошу учесть это.
Статьи http://www.overclockers.ru/tag/i.n.
На ЛС с просьбами выбрать матплату, память или SSD буду отвечать ЖК по 3.2 (игнорирование существующих тем)
Полный бы перевод дословный. Чтоб всем понятно стало. Чего ждать.
Добавлено спустя 2 минуты 14 секунд:
WizzarD4Я так понял что просто Сата контроллер деградирует и все. А не устройства которые висят на нем.
MSI GT72 2QE-1489RU Dominator Pro
Intel Core i7-5700HQ(3.7)|16Gb DDRIII 1600Mhz|1Tb 7200rpm|128GB SSD|4096MB NVIDIA GTX980M|17.3" IPS 1920x1080
Куратор темы
Статус: В сети
WizzarD4, я так понимаю, баг касается всех чипсетов 67й серии. Просто официально продажи матплат на этих чипсетах начались с 9 января, поэтому и речь про 9-е. Что за проблема с SATA девайсами возможна и насколько вероятна - из релиза не ясно. Ждём дальнейших разъяснений.
ASRock Fatal1ty P67 Professional, Intel i7-2600k @ 4.5, Scythe Ninja3, 32Gb Kingston HyperX FURY, MSI 570GTX, 25TB HDDs, Corsair 850HXEU
Дословно - Чипсетоы 6й серии произведенные до этого 31.01.2011 (или чуть ранее), получили багу, которая, в некоторых случаях, может вызвать снижение скорости работы портов SATA и, соответственно, девайсов подключенных к этим портам.
Тем вендорам, кто не успел багованные чипы выпустить со склада - заменят быстро и просто, тем кто уже отгрузил их - непонятно, как будет организована замена.
Похоже, Intel придется изрядно компенсировать вендорам возврат и обмен плат.
И мероприятие по замене, для вендоров, затянется до конца апреля.
А вот что для конечных покупателей - даже не знаю.
Скачайте книгу: http://www.*********/klub/kak-kupit-deshevo-noutbuki-telefoni-komplektuiuschie
True Slayer
Не так слово я деградация перевел. Ну не проблема эту вообще я считаю. Я уже аш испугался.
Плюс эта фраза:
То есть раньше конца февраля напрягаться по поводу новой системы не стоит... Ну и хорошо, еще цены на процессоры припадут :-)
Dr Kazay
Я с первого раза подумал что только чипсеты с 9 по 31 багованы.
А фиг там - с ХХХ до 31.01.2011.
А это несколько миллионов чипсетов, по моим прикидкам - этак 2-3 ляма.
Loc
Скорее июня.
Здравствуй, Штеуд, новый год! :-x Моё искреннее сочувствие тем, кто уже проапгрейдился на Санди. Если не железо, то нервы им теперь покоцает точно. Зря Intel анонс новой платформы на Рождество сделал. Походу, на заводах отмечать начали заранее, и прямо на рабочем месте. :hitrost:
В России конец света наступит на грабли.
[url=http://nick-name.ru/sertificates/820264/][img]http://nick-name.ru/forum/Grayhaund.gif[/img][/url]
[url=http://www.plagiatnik.ru][img]http://www.plagiatnik.ru/niks.php?nik=Grayhaund[/img]PlagiatNIK.ru - Ник Grayhaund защищен.[/url]
Вот те рас, только все значит настроил, в корпус упаковал, оприходовал и тут новость. Ждем подробностей и комментов интела. Может обойдется все :-)
а я предупреждал
жаль темку прикрыли
Если Бог за нас, кто против нас?(с) Библия
В случае масштабных военных действий, эвакуация населения не только не производится, но и не планируется.
ну посмотрим что будет, я уже всё собрал и настроил , разбирать не буду!! ))
Новость, конечно, неприятная - я-то уже проапгредийлся. Буду надеятся вендорам удастся пофиксить проблему патчами биоса... В конце концов на P8P67 deluxe два контроллера marvel и intel.
Everlast82 писал(а):
а я предупреждал
Борис, ты прав! :haha:
Ого! Значит они до сих пор отгружают брак? "Хорошая" новость для нынешних владельцев санди. :gun:
Если она решаема, то, я думаю, её быстро решат.
Я пью borjomi
Clay Allison писал(а):
патчами биоса
вобще-то, в докладе заявлено о ошибке в ДИЗАЙНЕ и о намарениях исправить ошибку в ЧИПЕ. То есть, мне кажется, софтом тут дело не поправить.
А потом как узнать мамка с новым чипом или нет
ykk писал(а):
Вопрос: чего делать тем, кто уже купил материнские платы на этом чипсете?
Жадать. :( В сообщении написано, что ител будет менять чипсеты, а обмен материнок зависит от желания производителя матери, компа или вообще магазина.
Денис78, скорей всего просто обновят версии ревизий самих плат. Тоисть если щяс мать допустим Asus P8P76 rev. 1.0 - то с новый чипом по идеи будет rev. 1.1 (или 1,0,1)
Intel Core i7 2600k/AsRock P67 Fatal1ty (B2)/Kingston HyperX DDR3/Asus ENGTX 460 768Mb Direct CU/Thermaltake Purepower 680W
А помните TLB bug? Ошибку сначала исправили новыми версиями биоса, при этом падала производительность. Только потом выпустили новые ревизии процессоров где ошибки уже не было. ;)
Я пью borjomi
Сейчас этот форум просматривают: ultrafx, wolfire и гости: 26
Яндекс.Метрика
