Куратор(ы):   Gottex
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 1894 • Страница 1 из 951  2  3  4  5 ... 95  >
FAQ
Фото Rampage IV Extreme
Фото Rampage IV Black Edition
Официальные страницы на сайте ASUS:
Rampage IV Extreme Eng
Rampage IV Extreme Rus
Rampage IV Black Edition Eng
Rampage IV Black Edition Rus
Характеристики Rampage IV Extreme
• Процессор
Intel® Socket 2011 for 2nd Generation Core™ i7 Processors
*Refer to http://www.asus.com for CPU support list
Supports Intel® Turbo Boost Technology 2
• Чипсет
Intel® X79
• Оперативная память
8 x DIMM, Max. 64GB, DDR3 2400(O.C.)/2133(O.C.)/1866/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Quad Channel Memory Architecture
*Hyper DIMM support is subject to the physical characteristics of individual CPUs.
Supports Intel® Extreme Memory Profile (XMP)
*Refer to http://www.asus.com or this user manual for the Memory QVL (Qualified Vendors Lidts).
• Поддержка технологий Multi-GPU
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
• Слоты расширения
4 x PCIe 3.0/2.0 x16 (x16; x16/x16; x16/x8/x16 and x16/x8/x8/x8, (Red)) *1
1 x PCIe 3.0/2.0 x16 (x8 mode, (Gray)) *1
1 x PCIe 2.0 x1
• Хранилище данных
Intel® X79 chipset :
2 x SATA 6Gb/s port(s), (Red)
4 x SATA 3Gb/s port(s), (Black)
Support Raid 0, 1, 5, 10
ASMedia® PCIe SATA controller :
2 x eSATA 6Gb/s port(s), (Red)
• Локальная сеть
82579+8111E, 1 x Gigabit LAN Controller(s)
• Bluetooth
Bluetooth V2.1+EDR
• Звук
Realtek® ALC898 7.1-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
• Порты USB
ASMedia® USB 3.0 controller :
8 x USB 3.0 port(s) (4 at back panel, (Blue), 4 at mid-board)
12 x USB 2.0 port(s) (8 at back panel, (Black)+(Red), 4 at mid-board)
• Разгонные функции
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
ROG iDirect
Extreme Engine Digi+ II :
- 8 -phase CPU power design
- 3 -phase VCCSA power design
- 2 + 2 phase DRAM power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- Q Reset
- EZ Plug
ProbeIt
UEFI BIOS features :
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
BIOS Flashback
USB BIOS Flashback
Overclocking Protection :
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED II
- ASUS C.P.R.(CPU Parameter Recall)
• Особенности
ASUS EPU :
- EPU
CPU Level Up
ASUS Exclusive Features :
- MemOK!
- Onboard Button : Power/Reset/Clr CMOS (at back IO)
ASUS Quiet Thermal Solution :
- ASUS Q-Fan Plus
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
• Разъемы на задней панели
1 x PS/2 keyboard/mouse combo port(s)
1 x Bluetooth module(s)
2 x eSATA 6Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0
8 x USB 2.0 (one port can be switched to ROG Connect)
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
1 x RC Bluetooth switch(es)
• Разъeмы на плате
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
3 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x OC Key header(s)
1 x OT header(s)
2 x Subzero Sense connector(s)
1 x Slow Mode switch(es)
7 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x Q Reset switch(es)
2 x EZ Plug connector(s) (4-pin in white for memory DIMMs; 6-pin in black for PCIe slots)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x BIOS Switch button(s)
• Аксессуары
I/O Shield
4 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x CrossFire cable(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x ProbeIt cable set(s)
1 x 12 in 1 ROG Cable Label(s)
1 x OC Key(s)
1 x OC Key cable(s)
1 x X-Socket pad(s)
• BIOS
2 x 64Mb Flash ROMs, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
• Администрированиe
WfM2.0, DMI2.0, WOL by PME, WOR by PME, PXE
• Диск с драйверами
Support DVD:
- Drivers and Applications
Kaspersky Anti-Virus
ASUS TurboV EVO Utility
ASUS PC Probe II
ASUS Update
ASUS AI Suite II
ASUS AI Charger+
Daemon Tool Pro Standard
ASUS WebStorage
• Форм-фактор
Extended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
• Примечание
*1-1 This motherboard is ready to support PCIe 3.0 SPEC. Functions will be available when using PCIe 3.0-compliant devices. Please refer to http://www.asus.com for updated details.
*1-2 For PCIe 3.0 x16 (X8 mode), PCIEx8_2B(Grey) shares bandwidth with PCIEx8_2A(Red).
Характеристики Rampage IV Black Edition
CPU
Intel® Processors
Intel® Core™ i7 Processors for LGA 2011 Socket
Supports Intel® 22 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* Refer to http://www.asus.com for CPU support list
Chipset
Intel® X79
Memory
8 x DIMM, Max. 64GB, DDR3 2800(O.C.)/2666(O.C.)/2400(O.C.)/2133(O.C.)/1866/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
* Refer to http://www.asus.com for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Multi-GPU Support
Expansion Slots
4 x PCIe 3.0/2.0 x16 (x16 or dual x16 or x16/x8/x16 or x16/x8/x8/x8, black) *1
2 x PCIe 2.0 x1
Storage
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), black
ASMedia® ASM1061 controller : *2
2 x eSATA 6Gb/s port(s), red
4 x SATA 6Gb/s port(s), gray
LAN
Intel® 82579V, 1 x Gigabit LAN Controller(s)
Bluetooth
Bluetooth V4.0
Audio
ROG SupremeFX Black 8-Channel High Definition Audio CODEC
- SupremeFX Shielding Technology
- Cirrus Logic® CS4398 DAC: 120 dB SNR, -107 dB THD+N (Max. 192 kHz/ 24 -bit)
- TI 6120A2 high fidelity headphone amplifier
- WIMA® film capacitors
- ELNA® premium audio capacitors
- High-fidelity audio OP AMP(s)
- Differential circuit design
- NEC TOKIN UC2 audio relay
Audio Feature :
- Sonic Radar
- DTS Connect
USB Ports
ASMedia® USB 3.0 controller : *3
8 x USB 3.0 port(s) (6 at back panel, blue, 2 at mid-board)
Intel® X79 chipset : *4
10 x USB 2.0 port(s) (4 at back panel, black, 6 at mid-board)
OC Panel
2.6 " LCM display
EXTREME/NORMAL mode switch
EXTREME Mode for subzero OC benching:*5
- VGA Hotwire
- Subzero Sense
- Slow Mode
- Pause Switch
- VGA SMB header
- ProbeIt
- 4 x 4-pin extra fan connectors
NORMAL Mode for in-chassis usage:*6
- CPU Level Up OC button
- FanSpeed control button
- LCM backlight on/off button
I/O Ports:
- POWER:1 x SATA power connector
- ROG_EXT port:1 x 18-1 pin data connection port
ROG Exclusive Features
ROG Connect *7
- RC TweakIt
- RC Diagram
- RC Remote
- RC Poster
Extreme Engine Digi+ III :
- NexFET™ Power Block MOSFET
- 60A Chokes
- 10K Black Metallic Capacitors
Mem TweakIt
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
- ROG BIOS Print
- GPU.DIMM Post
- Tweakers' Paradise
- ROG SSD Secure Erase
ROG RAMDisk
GameFirst II
iROG
Extreme Tweaker
Special Features
ASUS Dual Intelligent Processors 4 with 4-Way Optimization :
- The tuning key perfectly consolidates ASUS-exclusive DIGI+ Power Control, TPU, EPU, and Fan Xpert 2 optimize the digital power setting, system performance, power saving and whole system cooling configuration
CPU Level Up
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: Media Streaming Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
- Wi-Fi GO! & NFC Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- TurboV EVO
- USB BIOS Flashback
- MemOK!
- AI Suite 3
- Ai Charger+
- Front Panel USB 3.0 Support
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY :
- DirectKey
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS USB BIOS Flashback
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Operating System Support
Windows® 8.1
Windows® 8
Windows® 7
Back I/O Ports
2 x eSATA 6Gb/s
6 x USB 3.0 (blue)
4 x USB 2.0 (one port can be switched to ROG Connect)
5 x Audio jack(s)
1 x ASUS Wi-Fi GO! module (Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.0/3.0+HS)
Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
1 x TPM header
6 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
1 x System panel(s) (Q-Connector)
1 x Chassis Intrusion connector(s)
1 x DirectKey Button(s)
1 x DRCT header(s)
1 x MemOK! button(s)
11 x ProbeIt Measurement Points
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Reset button(s)
1 x ROG extension (ROG_EXT) header(s)
Accessories
User's manual
I/O Shield
6 x SATA 6Gb/s cable(s)
1 x ASUS 2T2R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
1 x SLI bridge(s)
1 x X-Socket pad(s)
1 x ROG Magnet
OC Panel Kit:
- 1 x OC Panel(s)
- 1 x OC Panel 5.25-inch bay metal case
- 1 x OC Panel Cable(s)
BIOS
2 x 64Mb UEFI AMI BIOS, PnP, DMI2.7, WfM2.0, SM BIOS 2.7, ACPI5.0a, Multi-Language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions, and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability
WfM2.0, DMI2.7, WOL by PME, PXE
Support Disc
Drivers
ROG RAMDisk
ROG CPU-Z
ROG Mem TweakIt
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
ASUS WebStorage
ASUS Utilities
Form Factor
Note
*1. This motherboard is ready to support PCIe 3.0 SPEC. Functions will be available when using PCIe 3.0-compliant devices. Please refer to http://www.asus.com for updated details.
*2. These SATA ports are for data hard drives only. ATAPI devices are not supported.
*3. Support ASUS USB 3.0 Boost.
*4. 2 x USB2.0 ports at mid-board shares with ROG extension (ROG_EXT) port.
*5. Extreme Mode capabilities, including V1, V2, DRAM and other voltage definitions, vary by chipset. Please refer to your motherboard manual for details.
*6. One 5.25" drive bay is required for NORMAL Mode installation.
*7. ROG Connect port locates on the upper USB 2.0 port of the 2 x USB 2.0 + 2 x USB 3.0 module
Инструкция:
ИНСТРУКЦИЯ в PDF Asus RAMPAGE IV EXTREME
ИНСТРУКЦИЯ в PDF Asus RAMPAGE IV Black Edition
Обзоры:
Обзор и тестирование RIVBE на Overclockers
Обзор и тестирование RIVE на Overclockers
Софт:
Официальная страница загрузки Rampage IV Extreme
Официальная страница загрузки Rampage Black Edition
Самые новые драйвера на Station-Drivers для Rampage IV Extreme
BIOS:
Для инженерных процессоров SB-E необходимо использовать BIOS 1305, а для серийных использовать последний официальный.
Инженерный процессор работает корректно только на BIOS 1305. Если Вы прошьетесь на более позднюю версию, то необходимо будет делать FLASHBACK до 1305. Так же Вы можете прошивать Вашу мат. плату без процессора методом FLASHBACK подключив только питание.
BIOS ДЛЯ RAMPAGE IV EXTREME!!! ОЧЕНЬ ВАЖНО!!!
- Для процессоров SB-E рекомендуют биос не выше 4206
- Процессоры IVB-E стартуют ТОЛЬКО с биосом 4403 и выше (необходимо сразу прошить как купили мат. плату, т.к. может стоять биос 4206 и ниже)
Как прошить-откатить BIOS с 4ххх 3ххх 2ххх на текущую, предыдущую или 1ххх серию. У Black Edition серия биоса 0ххх . Метод FLASHBACK
1. Взять флешку любого объема (4Гб по умолчанию)
2. Отформатировать ее в FAT32
3. Скачать с офф сайта биос 1ххх 2ххх 3ххх 4ххх серии
4. Переименовать его в ERALL.ROM (если откат идет с 2ххх, 3ххх, 4ххх на 1ххх серию) или R4E.CAP (если откат идет с 4ххх, 3ххх, 2ххх на 4ххх, 3ххх, 2ххх серию). Для Black Edition необходимо скачать биос серии 0ххх и переименовать в R4BE.CAP
5. Переписать его на флешку
6. Выключить компьютер
7. Вставить флешку в белый разьём USB на задней панели мат. платы (Что бы узнать в какой USB порт вставлять флешку для Black Edition см. инструкцию к мат. плате на стр. 2-13)
8. Зажать кнопку "Rog connect" на 3 секунды и отпустить после того, как она начнёт мигать.
9. Подождать 2-3 минуты, пока она перестанет мигать
10. Готово
Как прошить BIOS с 1ххх на 2ххх 3ххх 4ххх серию?
Если у Вас BIOS 1403 и ниже, то для этого необходимо прошиться с помощью конвертера!!!
Скачиваем Rampage-IV-Extreme-CAP-Converter (лежит на сайте ASUS в BIOS-Utilities)
Скачиваем последний BIOS 2ххх.CAP (3ххх.CAP, 4ххх.CAP)
берем скаченные файлы
- Rampage-IV-Extreme-CAP-Converter.ROM
- Rampage-IV-Extreme-ASUS-2ххх.CAP (3ххх.CAP, 4ххх.CAP)
и записываем на флешку, предварительно отформатированную в FAT32, далее заходим в BIOS и переходим в раздел ASUS EZ Flash 2
ВЫБИРАЕМ файл Rampage-IV-Extreme-CAP-Converter.ROM и благополученно шьемся
Коды отладки:
Asus Rampage IV Debug Codes
00 - Not used
01 - Power on. Reset type detection (soft/hard).
02 - AP initialization before microcode loading
03 - System Agent initialization before microcode loading
04 - PCH initialization before microcode loading
05 - OEM initialization before microcode loading
06 - Microcode loading
07 - AP initialization after microcode loading
08 - System Agent initialization after microcode loading
09 - PCH initialization after microcode loading
0A - OEM initialization after microcode loading
0B - Cache initialization
0C – 0D - Reserved for future AMI SEC error codes
0E - Microcode not found
0F - Microcode not loaded
10 - PEI Core is started
11 – 14 - Pre-memory CPU initialization is started
15 – 18 - Pre-memory System Agent initialization is started
19 – 1C - Pre-memory PCH initialization is started
1D – 2A - OEM pre-memory initialization codes
2B – 2F - Memory initialization
30 - Reserved for ASL (see ASL Status Codes section below)
31 - Memory Installed
32 – 36 - CPU post-memory initialization
37 – 3A - Post-Memory System Agent initialization is started
3B – 3E - Post-Memory PCH initialization is started
3F – 4E - OEM post memory initialization codes
4F - DXE IPL is started
50 – 53 - Memory initialization error. Invalid memory type or incompatible memory speed
54 - Unspecified memory initialization error
55 - Memory not installed
56 - Invalid CPU type or Speed
57 - CPU mismatch
58 - CPU self test failed or possible CPU cache error
59 - CPU micro-code is not found or micro-code update is failed
5A - Internal CPU error
5B - Reset PPI is not available
5C – 5F - Reserved for future AMI error codes
E0 - S3 Resume is stared (S3 Resume PPI is called by the DXE IPL)
E1 - S3 Boot Script execution
E2 - Video repost
E3 - OS S3 wake vector call
E4 – E7 - Reserved for future AMI progress codes
E8 - S3 Resume Failed
E9 - S3 Resume PPI not Found
EA - S3 Resume Boot Script Error
EB - S3 OS Wake Error
EC – EF - Reserved for future AMI error codes
F0 - Recovery condition triggered by firmware (Auto recovery)
F1 - Recovery condition triggered by user (Forced recovery)
F2 - Recovery process started
F3 - Recovery firmware image is found
F4 - Recovery firmware image is loaded
F5-F7 - Reserved for future AMI progress codes
F8 - Recovery PPI is not available
F9 - Recovery capsule is not found
FA - Invalid recovery capsule
FB-FF - Reserved for future AMI error codes
60 - DXE Core is started
61 - NVRAM initialization
62 - Installation of the PCH Runtime Services
63 – 67 - CPU DXE initialization is started
68 - PCI host bridge initialization
69 - System Agent DXE initialization is started
6A - System Agent DXE SMM initialization is started
6B – 6F - System Agent DXE initialization (System Agent module specific)
70 - PCH DXE initialization is started
71 - PCH DXE SMM initialization is started
72 - PCH devices initialization
73 – 77 - PCH DXE Initialization (PCH module specific)
78 - ACPI module initialization
79 - CSM initialization
7A – 7F - Reserved for future AMI DXE codes
80 – 8F - OEM DXE initialization codes
90 - Boot Device Selection (BDS) phase is started
91 - Driver connecting is started
92 - PCI Bus initialization is started
93 - PCI Bus Hot Plug Controller Initialization
94 - PCI Bus Enumeration
95 - PCI Bus Request Resources
96 - PCI Bus Assign Resources
97 - Console Output devices connect
98 - Console input devices connect
99 - Super IO Initialization
9A - USB initialization is started
9B - USB Reset
9C - USB Detect
9D - USB Enable
9E – 9F - Reserved for future AMI codes
A0 - IDE initialization is started
A1 - IDE Reset
A2 - IDE Detect
A3 - IDE Enable
A4 - SCSI initialization is started
A5 - SCSI Reset
A6 - SCSI Detect
A7 - SCSI Enable
A8 - Setup Verifying Password
A9 - Start of Setup
AA - Reserved for ASL (see ASL Status Codes section below)*
AB - Setup Input Wait
AC - Reserved for ASL (see ASL Status Codes section below)
AD - Ready To Boot event
AE - Legacy Boot event
AF - Exit Boot Services event
B0 - Runtime Set Virtual Address MAP Begin
B1 - Runtime Set Virtual Address MAP End
B2 - Legacy Option ROM Initialization
B3 - System Reset
B4 - USB hot plug
B5 - PCI bus hot plug
B6 - Clean-up of NVRAM
B7 - Configuration Reset (reset of NVRAM settings)
B8– BF - Reserved for future AMI codes
C0– CF - OEM BDS initialization codes
D0 - CPU initialization error
D1 - System Agent initialization error
D2 - PCH initialization error
D3 - Some of the Architectural Protocols are not available
D4 - PCI resource allocation error. Out of Resources
D5 - No Space for Legacy Option ROM
D6 - No Console Output Devices are found
D7 - No Console Input Devices are found
D8 - Invalid password
D9 - Error loading Boot Option (LoadImage returned error
DA - Boot Option is failed (StartImage returned error)
DB - Flash update is failed
DC - Reset protocol is not available
*ASL Status Codes
01 - System is entering S1 sleep state
02 - System is entering S2 sleep state
03 - System is entering S3 sleep state
04 - System is entering S4 sleep state
05 - System is entering S5 sleep state
10 - System is waking up from the S1 sleep state
20 - System is waking up from the S2 sleep state
30 - System is waking up from the S3 sleep state
40 - System is waking up from the S4 sleep state
AC - System has transitioned into ACPI mode. Interrupt controller is in PIC mode
AA - System has transitioned into ACPI mode. Interrupt controller is in APIC mode
Монтаж суперкуллеров:
Список кулеров, установка которых не мешает первому слоту PCI-E
Возможна установка 1366 куллеров при замене штатного сокета на Х-сокет.
+ Silver Arrow Archon SB E-X2
+ ThermalRight SilverArrow-SB-E (установлено вертикально - выдув вверх - два вентиля по 140мм)
+ ThermalRight SilverArrow-SB-E-Extreme (установлено вертикально - выдув вверх - два вентиля по 140мм)
- ThermalRight SilverArrow-SB-E-Extreme установить горизонтально нельзя - все равно перекрывает 1 слот PCI-E . Без доработки никак. Только с такой доработкой можно использовать первый слот PCI-E.
Может быть даже хватит только обрезки радиаторных пластин, но тогда места между ВК и радиаторными пластинами не будет совсем (вполне возможно даже касание).
+ Phanteks PH-TC14PE-BK - встает на мать спокойно, даже с 150мм куллерами. Зазор от первой видюхи 2-3 мм
- Noctua NH-D14 (зазор 3-4мм. Установка 14мм возможна)
- Zalman CNPS12X Монтаж возможено 2 варианта.
+ в положении, когда куллеры будут толкать воздух в сторону середины корпуса
+ в положении бочкой, чтобы дул вверх
Схема линий PCI-E:
Работа PCI-E Gen3 с nVidia GTX6xx:
Geforce 600 Series Gen3 Support On X79 Platform
Официально поддержка PCI-E 3.0 на X79 чипсете с процессорами SB-E отключена. В качестве альтернативы Вы можете установить патч от nVidia для активации PCI 3.0
Подключение дополнительного питания памяти и pci-e, а нужно ли?
Читаем и вникаем
Подключение и использование OC KEY - работает при разрешении максимум 1920х1080
Установка Windows 7/8 UEFI:
Как собрать RAID массив в UEFI?
Как установить Windows 7 или 8 в UEFI режиме?
В данной теме ведется обсуждение:
- ТОЛЬКО Asus Rampage IV Extreme/Black Edition на Intel X79 LGA2011 (вопросы по ASUS MAXIMUS/FORMULA/GENE будут удаляться)
- Мат. платы, ее настройка, тюнинг, разгон;
- Проблемы, связанные с ее эксплуатацией;
- Особенности работы, совместимости, проблемы и тонкости с устройствами, возникающие при подключении и использовании
- Софтовые проблемы, применимые к конкретной мат. плате (драйверы, утилиты);
- Прочие, неразрывно связанные с платой нюансы, являющиеся индивидуальным совпадением и особенностью конфигурации
- Проблемы с CPU возникающие на данной мат. плате
Остальное будет считаться оффтопиком и будет удаляться.
Прежде чем задать вопрос, удостовертесь в том, что бы Ваш ПРОФИЛЬ был ЗАПОЛНЕН, в противном случае Ваше сообщение будет УДАЛЕНО !!!
P.S.
Я, как Куратор Gottex, разрешаю Вам, участники конференции, ОФФТОПИТЬ ТОЛЬКО ПРИ ОСТРОЙ НЕОБХОДИМОСТИ и помещать Ваш текст в ТЭГИ ОФФТОП
Код:
[off]  [/off]
Важная информация !!!
Разгон. Вольтаж. Особенности
Vcore - Эта опция встречается во множестве вариантов. Во-первых, ее значения могут напрямую задавать напряжение питания ядра процессора. Если вы не занимаетесь разгоном, установите Auto, в этом случае будет использовано штатное значение напряжения питания рекомендованное Intel.
Для продвинутых пользователей необходимо знать самое главное, если Вы занимаетесь разгоном, то обязателно позаботьтесь о хорошем охлаждении процессора. Никогда не прогревайте ядра выше 85 градусов, т.к. температурный рубеж это один из путей к деградации процессора.
Примерный вольтаж Vcore под разгон 24/7 для SB-E и IVB-E с включенным Hyper Threading
4.2Ghz-4.4Ghz - 1.23~1.25v, LLC medium 100~120%, VTT и VCCSA 1.1v (в качестве охлаждения использовать воздушный куллер)
4.5Ghz-4.6Ghz - 1.29~1.35v, LLC medium 120~140%, VTT и VCCSA 1.10~1.15v (в качестве охлаждения использовать воздушный куллер)
4.7Ghz-4.8Ghz - 1.39~1.45v, LLC medium~LLC high 140~180%, VTT и VCCSA 1.13~1.25v (в качестве охлаждения использовать СВО для продления срока службы Вашего процессора, помните, высокая температура это враг Вашему процессору и один из путей к деградации)
5.0Ghz-5.2Ghz - 1.50~1.55v, LLC extreme 140~180%, VTT и VCCSA 1.15~1.25v (в качестве охлаждения использовать СВО или Чиллер для продления срока службы Вашего процессора, помните, высокая температура это враг Вашему процессору и один из путей к деградации)
Load-Line Calibration (LLC) - Это опция, позволяющая скомпенсировать падение (проседание) напряжения питания ядра при увеличении нагрузки на процессор (так называемое Vdroop). При работе в штатном режиме лучше установить Auto, а при разгоне как правило зависит так же от Вашего экземпляра процессора.
Я прошу учесть, что процессоры все разные, качество кристалла тоже, поэтому для каждого камня нужно подбирать свой стабильный вольтаж и у каждого камня могут быть разные температуры по ядрам, важно отметить, что если разброс по температурам между ядрами составляет 15 и более градусов, лучше его немедленно обменять !!!
Что такое ДЕГРАДАЦИЯ ?
Это когда Ваш процессор больше не может удерживать стабильный разгон на текущих настройках и вольтажах
В чем она выражается?
Ваша система перестает быть стабильной, Вы часто получаете зависоны, BSOD с ошибками x101, x124 (см. FAQ коды ошибок при разгоне), проблемы при загрузке cold boot и т.д.
И что мне делать ?
Вы можете либо "задрать" указанный в ошибке (см. FAQ коды ошибок при разгоне) вольтаж, что бы снова удержать стабильность, к сожалению не на долго, может неделя а может и месяц, два, три или скинуть все в дефолт и пользоваться стоковой частотой.
VTT - Позволяет вручную указать напряжение питания терминаторов процессора (иногда называемое дополнительным напряжением питания процессора или напряжением питания системной шины). Его увеличение способно в некоторых случаях повысить разгонный потенциал процессора. Если вы не занимаетесь разгоном, используйте значение Auto. Для повседневной работы в стоке выставлять значение "руками" 1.1v. Помните, повышая данное напряжение Вы повышаете температуру процессора, обязательно позаботьтесь о должном охлаждении.
При разгоне для каждого камня это значение свое, тут так же очень многое зависит на сколько "удачный" экземпляр Вам достался.
ВАЖНО!!! Никогда не превышайте значение 1.23~1.25v В НАГРУЗКЕ!!! (мерить мультиметром), т.к. это ОСНОВНОЙ и самый быстрый путь к деградации процессора
VCCSA - это напряжение которое отвечает за целый комплекс компонентов такие как контроллер памяти DDR3 (IMC), модуль управления питанием (Power Control Unit, PCU), контроллеры PCI-Express и т.д. Основное конечно за что отвечает данный параметр при разгоне это питание контроллера IMC, важно понимать, что чем выше частота процессора, частота и объем вашей оперативной памяти (16Gb 2133~2400Mhz - 32Gb 2133Mhz), тем выше надо поднимать напряжение VCCSA. Для повседневной работы в стоке выставлять значение "руками" 1.1v. Помните, повышая данное напряжение Вы повышаете температуру процессора, обязательно позаботьтесь о должном охлаждении.
При разгоне процессора вольтаж VTT и VCCSA должны быть очень близки по значению к друг другу как в простое, так и в нагрузке, разница как правило составляет +/- 0.3
Охлаждение мат. платы - Если Вы разгоняете процессор до 4.6~4.8, то рекомендуется охлаждать VRM (Voltage Regulator Module - модуль регулятора напряжения. Служит для формирования нужных напряжений питания процессора.) при помощи СВО и если Вам позволяет корпус компьютера, то необходимо наклеить любые heatsink радиаторы на обратную сторону VRM площадки и постараться создать дополнительный воздушный поток для них.
Оффсет
При положении Offset, вольтаж подаваемый на Ваш процессор динамически изменяется, а именно "покой/просмотр кино/интернет/офисные приложения" у Вас подается 0.8~0.9v и частота процессора сбрасывается до 1200, а во время "игр/стресс тестов" и всего, что требует полный ресурс компьютера Вы получаете полный вольтаж подаваемый на процессор.
Offset хорош для сохранения температур и экономии жизни Вашего камня в покое .
Для включения режима Offset Вам необходимо:
- в биосе закладка Extreme tweaker находим строку CPU Vcore voltage ---> Offset
- в биосе закладка Extreme tweaker находим строку Offset Mode Sign ---> + или - (это зависит от Вашего разгона и камня, все индивидуально !!!)
- в биосе закладка Extreme tweaker находим строку CPU Core Offset Voltage ---> подбираем вольтаж
- и последний шаг (включать и отключать все как на картинке)
Самый часто задаваемый вопрос про Оффсет
А как в оффсете можно сделать сброс не только вольтажа, но и множителя до 1200???
При условии что Вы установили все как указано выше, после этого Вам необходимо зайти в Панель управления Windows, управление питанием и установить СБАЛАНСИРОВАННЫЙ режим и будет Вам 1200 или так же в управлении питанием в режиме "высокой производительности" необходимо установить МИНИМАЛЬНОЕ СОСТОЯНИЕ ПРОЦЕССОРА 5%
Самые распространенные коды ошибок BSOD при разгоне
0x101 = increase vcore
0x124 = increase/decrease QPI/VTT first, if not increase/decrease vcore...have to test to see which one it is
on i7 45nm, usually means too little VVT/QPI for the speed of Uncore
on i7 32nm SB, usually means too little vCore
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1A = Memory management error. It usually means a bad stick of Ram. Test with Memtest or whatever you prefer. Try raising your Ram voltage
0x1E = increase vcore
0x3B = increase vcore
0x3D = increase vcore
0xD1 = QPI/VTT, increase/decrease as necessary, can also be unstable Ram, raise Ram voltage
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x109 = Not enough or too Much memory voltage
0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
0x7E = Corrupted OS file, possibly from overclocking. Run sfc /scannow and chkdsk /r
Коды ошибок BSOD для Sandy Bridge
0x124 = add/remove vcore or QPI/VTT voltage (usually Vcore, once it was QPI/VTT)
0x101 = add more vcore
0x50 = RAM timings/Frequency add DDR3 voltage or add QPI/VTT
0x1E = add more vcore
0x3B = add more vcore
0xD1 = add QPI/VTT voltage
0X109 = add DDR3 voltage
0x0A = add QPI/VTT voltage
Как прошить Management Engine Interface (MEI)
Что такое MEI ?
Драйвер Intel Management Engine обеспечивает взаимодействие интегрированного в микросхему Intel ME микрокода компьютера на базе системной логики Intel с программной средой, иными словами он выступает в качестве интерфейса между встроенным ПО механизма Intel Management Engine и хост-системой. Для взаимодействия драйверов и приложений хост-системы(программной среды) с механизмом Intel Management Engine через основной интерфейс используется хост-драйвер для ОС Windows Intel ME Interface.
Многие технологии управления энергосбережением, мониторинга за состоянием системы(температура, регулировка скорости вращения кулеров), режимы ожидания и сна и т.п. взаимодействуют с аппаратной частью ПК посредством данного интерфейса
Как прошить MEI с 7 на 8-ю версию?
- скачиваем прошивку Intel ME Firmware v8.1.65.1586 (1.5MB)
- скачиваем набор инструментов для прошивки (под DOS, EFI, Windows, Windows64) Intel ME System Tools v8 r1 - (Updated: 13/10/2016)
- распаковываем Intel ME System Tools v8 r1 и Intel ME Firmware v8.1.65.1586 (1.5MB) и копируем на диск "С:" нужные нам файлы
- если у Вас 7-я версия прошивки, то шить необходимо при помощи Flash Programming Tool через *DOS с загрузочной флешки
- eсли у Вас 8-я версия прошивки, то шить можно при помощи FWUpdate через **Windows или при помощи Flash Programming Tool через DOS с загрузочной флешки
*Прошивка через DOS при помощи Flash Programming Tool
- скачиваем утилиту для создания загрузочной DOS флешки
- вставляем флешку, запускаем утилиту, жмем ок и ждем окончание процесса
- копируем из \Intel ME System Tools v8 r1\Flash Programming Tool\DOS два файла на флешку
- копируем из \Intel ME Firmware v8.1.65.1586 (1.5MB)\ файл прошивки на флешку (имя файла можете предварительно изменить на более удобное для Вас)
- перезапускаем комп загружаясь с флешки
- пишем fpt -ME -F имяфайла.bin жмем Enter и ждем пока прошьется
- после завершения выключаем компьютер на 5 сек
- включаем
- идем в биос в закладку Main
- смотрим строчку ME Version
**Прошивка через Windows при помощи FWUpdate
- копируем из \Intel ME System Tools v8 r1\FWUpdate\Local-Win64 файл на диск "С:"
- копируем из \Intel ME Firmware v8.1.65.1586 (1.5MB)\ файл прошивки на диск "С:" (имя файла можете предварительно изменить на более удобное для Вас)
- запускаем командную строку от Администратора
- cd c:\ жмем Enter
- пишем FWUpdLcl64.exe -f имяфайла.bin жмем Enter и ждем пока прошьется
- включаем
Так же необходимо установить драйвер Intel Management Engine Interface (MEI) Version 11.0.6.1194 WHQL (1.5Mo)
Что бы посмотреть версию через Windows Вам необходимо:
- копируем из \Intel ME System Tools v8 r1\Intel ME System Tools v8 r1\MEInfo\Windows64\ три файла на диск "С:"
- пишем cd c:\ жмем Enter
- пишем MEInfoWin64.exe жмем Enter
КАК ДОЛЖНА ВЫГЛЯДЕТЬ ПОСЛЕ ВСЕХ ОПЕРАЦИЙ ВАША ВЕРСИЯ !!!
При помощи Flash Programming Tool (DOS) можно делать бэкап!!!
ПЕРЕД ЛЮБОЙ ПРОШИВКОЙ ДЕЛАТЬ БЭКАП, ФАЙЛ СОХРАНЯЕТСЯ В ПАПКУ В КОТОРОЙ НАХОДИТСЯ САМА УТИЛИТА!!!!!!! fpt -ME -D имяфайла.bin
Что бы проверить какая у вас FW Version и Gbe Version, необходимо так же через cmd от Админа запустить MEInfoWin64.exe
GBE (нужен один файл - gbe15.bin) прошивается Flash Programming Tool DOS, команда fpt -GBE -SAVEMAC -F имяфайла.bin (ПЕРЕД ЛЮБОЙ ПРОШИВКОЙ ДЕЛАТЬ БЭКАП, ФАЙЛ СОХРАНЯЕТСЯ В ПАПКУ В КОТОРОЙ НАХОДИТСЯ САМА УТИЛИТА!!!!!!! fpt -GBE -D имяфайла.bin) После прошивки необходимо выключить компьютер на 5 секунд !!!
Если вы шьетесь через Flash Programming Tool или FWUpdate, то ВСЕ файлы прошивки необходимо положить в папку где находится fpt.exe или FWUpdLcl64.exe
Список драйверов для мат. платы необходимых после установки Windows
И так здесь я напишу исключительно личный список того, что необходимо установить из драйверов для нашей матери без лишнего хлама для корректной работы.
1. По хорошему в биосе выключаем Bluetooth (если не используется) и ASMedia SATA (если не используется) т.к. это все лишнее ... ИМХО
2. После установки Windows со всеми обновлениями устанавливаем Intel Chipset Device Software version 10.1.2.9 WHQL
3. Устанавливаем Intel Rapid Storage Technology version 13.1.0.1058 WHQL
4. Устанавливаем Intel Management Engine Interface (MEI) Version 11.0.6.1194 WHQL (1.5Mo)
RST (драйвер для Intel SATA контроллера) устанавливать руками через диспетчер устройств, IDE/ATAPI controllers --> Intel(R) C600 Series Chipset SATA AHCI Controller "ОБНОВИТЬ ДРАЙВЕР" и указать место куда распакован файл, т.к. весь хлам который идет в комплекте через инсталляцию Вам не нужен!
И на этом Все !!! Из дров больше НИЧЕГО НЕ НАДО, остальное как правило все автоматом встает, как звук например, который в принципе не требует супер новой версии дров, я так же не ставлю драйвер USB 3.0 т.к. попросту не пользуюсь этими портами, а если и втыкаюсь, то Windows дров достаточно для скорости передачи по ним, мне лично !!! Если у Вас чистая винда установленная в UEFI на GPT раздел, со всеми обновлениями, с дровами что я указал Выше, то никаких проблем с НЕОПОЗНАННЫМИ УСТРОЙСТВАМИ, с работой и скоростью загрузки не будет !!!
За все остальные Ваши твики, моды и дополнительные программы я ответственности не несу. Вся выше перечисленная схема являетя только моим стандартом и никогда еще не давала сбоя.
Пользовательские настройки разгона.
Никто не несет ответственности кроме Вас в случае повреждения мат платы или процессора
от Gottex 3960x@4.8, HT, Offset (замерял вольтаж мультиметром, в нагрузке получаем: vcore 1.392v., vccsa 1.18v., vtt 1.18v., самое горячее ядро 56'C)
от IceFireW 3930К @3800
#77#77#77#77#77#77#77#77#77#77
от IceFireW 3930К @4700
#77#77#77#77#77#77#77#77#77#77#77#77
от Zambeza 3930К @4600
#77#77
от Dr. Verhovcev @4500 НT off 1.27v manual
#77 #77 #77 #77 #77 #77 #77 #77 #77
от Dr. Verhovcev @4750Ггц НT off 1.375v manual
от bartx3 4930К @4500 HT on, offset+ 0.020v(в нагрузке по CPU-Z 1.416v)
от dyren 4930К @4500 HT on, offset +0.005v(в нагрузке по CPU-Z 1.344v) для 24/7
от t64a 3930K@4600
Работает как с HT - on, так и с HT -off. Vcore offset (MAX 1.36), можно ставить manual 1.352.
Раздел Extreme Tweaker:
#77#77 #77#77 #77#77#77#77 #77#77
Подраздел DRAM Timing Control:
#77#77
Подраздел DIGI+Power Control (все по умолчанию):
#77#77 #77#77
Раздел Advanced
Подраздел CPU Configuration:
#77#77 #77#77
Вы держитесь здесь, вам всего доброго, хорошего настроения и здоровья
Последний раз редактировалось Gottex 03.05.2017 14:54, всего редактировалось 52 раз(а).
В данный момент перелопачиваю множество англоязычных ресурсов. Из интересного и познавательного спешу всем сообщить Sandy Bridge-E очень боится чрезмерного напряжения VTT CPU Voltage . Ни в коем случае не поднимайте его выше 1,25v, так как я проводил тесты на двух 3930k и одном 3960х при напряжении VTT CPU Voltage равном 1,27v и поимел деградацию камней по частотному потенциалу в первых двух случаях на 200 и 250 MHz за 2 дня использования. 3960х перенёс два дня тестов без снижения частотного потенциала, но смею предположить что это просто удача конкретного экземпляра процессора. Посовещавшись с западными коллегами я получил подтверждение своих наблюдений и от них. Что характерно - если попробовать накинуть ещё напряжения на блоки процессора - частоту которая была доступна ранее так и не удаётся взять... Напряжение на ядрах при этом не првышало 1.4v, температура - до 80С. Вот такие вот вести с фронтов, камрады.
Первый параметр VTT (который номинально больше) был выставлен на 1,27v, второй на 1,24v. Деградация, в моём случае, ухудшила камни на 200 и 250 MHz по частоте и на этом остановилась. То-есть дальше пробовал гонять на 1,27 и камни сильнее не деградировали, возможно если погонять подольше по времени или ещё сильнее задрать VTT, то эффект деградации пойдёт ещё дальше. На этом, ценой двух потрёпанных Sandy Bridge-E я свои эксперименты с VTT CPU Voltage закончил :). Но можете мне не сочувствовать - камни дальше будут работать в номинале в дизайнерском ателье, свою жертву сообществу оверклокеров они принесли :D .
ASUS RIVE | i3930K(С1)@4600MHz HT-on@1,37v@NH D-14 | 4x4Gb RAM | 2x OCZ Agility3 120Gb RAID0 | GTX580| Antec TPQ 1200
Последний раз редактировалось Gottex 07.02.2014 7:06, всего редактировалось 3 раз(а).
процедура "опознания" RAID0 такова:
1. Скачать(взять с родного диска) дрова на SATA(в этой папке на рампагу IV лежит две папки с дровами: в одной на intel контроллер, а в другой на Asmedia) Лучше рейд "вешать" на интел(система будет стабильней).
2. Взять диск(образ) с "чистой" системой и создать загрузочную флешку.Как это делается - гугл в помощь. На эту же флешку закинь папку с дровами на контроллер из п.1
3. Создай RAID0 (CTRL+I) с нужными параметрами.
4. В биосе поставь "загрузку" контроллера с RAID.
5. Начинай устанавливать систему и когда не будет найден "винт", нажмёш кнопку установить драйвер и укажеш путь к дровам контроллера на флешке - драйвер RAID установится и тогда сможеш установить систему...
PS. Можно "дрова" на контроллер RAID0 поставить и через дискетку 1,44мб и нажатием в "нужный момент" F6..
:D
Если вы еще не сидите, то это не ваша заслуга, а наша недоработка.....
Последний раз редактировалось Gottex 06.02.2014 23:53, всего редактировалось 1 раз.
Rampage IV Extreme Guide от Shamino
http://www.mediafire.com/?ybc9bjlbxvhlud9
Много полезной инфы, особенно для экстремальщиков.
Все наверное и так уже видели, но на всякий случай интересный пост:
http://www.xtremesystems.org/forums/showthread.php?277223-X79-MEMORY-OC-GUIDE-(4-Different-IC)-G.SkILL-ASUS-Rampage-IV-Extreme
Забанен
А вот и ответ на мой запрос с XS
"I have problem with new bios 2xxx my i7-3960x ES (QA8V) doesn't works with new bios: it shows the post code 00,01. On the 1404 BIOS it works fine but then I flash 2003 it stops working.
I try to return to the 1404 by the method You wrote but I can't. Can You help?
P.S.
With all Serial CPU's like 3820,3930,3960 MoBo works fine!
And the CPU i7-3960x ES (QA8V) work on the MoBo with 1404 or later BIOS."
ответ от LardArse
that cpu is too old ES, we support C0 but not that
QA8V НЕ ПРОШИВАЙТЕ 2ххх серию! Не будет работать!!!!
Overclockers уже не торт...
Судя по ответу Asus те ES которые со степпингом C0 тоже будут работать.
Проверить можно пройдя на cpu-world
Вот для примера:
http://www.cpu-world.com/CPUs/Core_i7/Intel-Core%20i7-3930K.html
ES/QS processors
QBV9
т.е. если у Вас на крышке написано это, то весьма вероятно что этот процессор с новыми биосами заработает, если нет, то скорее всего вас ждет путь USB
Напишу проще, судя по высказываниям товарищей из Asus на биосах 2xxx ,будут работать только процы со следующей маркировкой:
Intel Core i7-3960X C0 QBU9
Intel Core i7-3930K C0 QBV9
Intel Core i7-3820 C0 QBWJ
Владельцам других инженерных процов я думаю лучше не уходить с 1ххх.
Но как показывает практика именно C0 инженерников очень мало и стоят почти как стоковые.
Принимайте в ряды!
Перешол с 990x на 3930К + RIVE. Перед покупкой начитался тут страстей :shock: Но все же взял, сразу поставил воду на мосфеты, и мост. Систему не переустанавливал, только драйвера обновил. Настороил на постоянку 4.0Ггц при 1.13v память 2133 1.53v. Дальше по разгону (для игр) поставил 4.5Ггц 1.25v память 2400mhz 1.59v vssa1.13 vtt1.13
Зачем трогать vssa, и vtaa так и не понял??? Оно вообще ни чего не дает, можно сидеть при номинальном 1v. и не дергаться, лично у меня. Память заявлена 2400Mhz при 11-11-11-28 1.65v(на этих настройках в линксе синька, через пару минут :diablo: ) по факту заработала 2400Mhz при 11-12-11-28 1.58v( с памятью не зачет). Удивили температурные показатели разницы, между 990x которому при 4.5Ггц требовалось 1.36v, самое горячее ядро в линксе было 62гр. 3930к при 4.5Ггц требуется 1.25v, и темпа при этом так же 60гр. В принципе не удивительно, тех процесс тот же, но транзюков у 3930к больше на один миллиард, + площадь + энерго потребление раза в полтора больше чем 990x.
Ревизия мамки С1 сделана в мае, из доп кабелей, подключил 2 кабеля на ЦПУ, один доп(флоппи) на память, на видики шестипиновый не подключал, так как видик один.
идите к чертовой матери со своим Студебекером!
кто такой Студебекер? это родственник ваш? папа ваш
Студебекер?
Знаток! Убивать таких знатоков надо!
Никто с турболимитами не игрался?
А нафиг оно надо??? Лично я на корню пресекаю любое вмешательство автоматики в работу компа в целом. Первое что делаю зайдя в биос сразу все что на автомате, бусты-шмусты, С1С2С10 и прочую лабуду сразу отрубаю. Как правило они в первую очередь стают виновниками не стабильности. Все выставляю исключительно руками, кроме доп таймингов, и "мифических" напряжений для оных.
А вообще плата очень сильно перегружена всякими лишними прибамбасами в виде "полезных программм", Rog connekt(разгонять комп, через юсб по ноутбуку :bandhead: ) как по мне бред полный, про блютус вообще молчу. Ах да ОС кей, генеальное творение тайских инженеров. Кто нибудь пробовал, прикрутить его к видяхе через фиксаторы?? попробуйте эмоциий масса, про кабель из системника(с вырезаной под него дырочкой, и заглушкой для подключения ключа) И самое главное PS2клаву, для управления меню ключа, и "волшебной" кнопки включения всего этого бреда на задней панели :crazy: Которую один умник вырезал, и приклеел изолентой к клавае, что бы каждый раз под стол не лазить :D А во стальном очень качественный и продуманный продукт. По сравнению с X58, на 2011 все как то спрогнозировано-предсказуемо. Хотя и горячо как по мне.
Студебекер?
"вот тебе бабушка и Юрьев день..."
Ответ Асуса на мою проблему:
For C1E to work properly you cannot use "strap" 125. Nothing we can do about that. Your only option is to use the 100 "strap" if you want dynamic SVID to work.
По-русски: "для корректной работы C1E переключение страпа не может быть использовано. Выберите страп 100, если хотите, чтобы динамический SVID работал"
Mythlogic Phobos 8715S
Для того чтобы работал сброс Vcore,необходимо cpu strap строго 100Мгц и офсет
Dmitryis писал(а):
Обновил биос 3602, при старте на пару секунд появляется логотип этот красный где написано нажмите ф2 или дел для входа в настройки биоса. Потом какое-то время черный экран и слева сверху в углу моргает черточка, потом снова экран с лого, потом опять черный экран с черточкой. Так раза два-три и начинается загрузка системы уже, ошибок при этом никаких не выдает. Нормально ли это? или какие-то косяки появились можно считать судя по этому? с прошлыми версиямт просто такого не замечалось, малоли...
У кого двойная загрузка, в BIOS поменяйте параметр в загрузках "Сообщения OPROM на сохранение текущего состояния" по англ. bot menu "Option ROM - Keep Current"
Куратор темы
ВСТРЕЧАЕМ Rampage IV Extreme – Black !!! Возможно она когда нибудь и увидит свет, но пока как прототип к сожалению.
Я бы взял себе ее только из-за цветовой гаммы, т.к. у меня моддерский корпус и внутри все без просвета черное, черная мать была бы кстати.
"Я не настолько богат, чтобы покупать дешевые вещи" (с) Барон Ротшильд
Фото: 19
В Noctua d-14 мешают скобы крепления вентилятора, если в верхний слот установлена видеокарта. Их желательно, насколько получится загнуть и обмотать скотчем или изолентой, во избежания замыкания контактов на видеокарте, если нет защитной пластины.
I7-3970X/Asus RIVE/GTX 780ti/Corsair D.Platinum/Samsung 840 pro/Asus Xonar STX/Aquaero 5 Pro/Dell U2713h...
Куратор темы
Господа, а как Вам ТАКОЙ вариант ухода за нашей матерью ? Я в шоке )))
СКРИНЫ
Куратор темы
Кому интересно, температура "задника" проца 3930к в стоке при 100% загрузке на сабже
на VRM наклеены вот эти малыши Koolance Video RAM Heat Sinks
Замер производился при помощи HDE Temperature Gun Infrared Thermometer w/ Laser Sight
скрин
взято отсюда
всем привет,ребят у кого нибудь была проблема,что встроенный на мать звук отваливается?
у меня нв второй плате одна хрень,ставлю 3-4 видюхи и все,звук пропадает и больше не включается.даже если втыкаю на место 690,просто не видит разъем.
вчера поменял уже 2 рампагу,знаю что у джоника такой же косяк был.
наверное буду обратно перелезать на формулу
Не знаю отношений кроме рыночных ©
i7 4930К @ 4600 1.2v \ Asus Rampage IV Formula \ 4x4 Geil Evo Two 2400mhz \ GTX780 Ti \ Corsair 650D.
Забанен
_Makaveli_
1 пробовал биос прошивать другой?
2 загружался со второй микросхемы?
3 плата перегибу не подвергалась?
4 на печатной плате нету пыли-мусора-царапин-капель-металлической стружки?
Танцы с бубном не помогли Джонику,- пришлось покупать звуковушку.
Сейчас этот форум просматривают: Chaos45, hatul', ineron, Nouneim71, stiffmaster, telemeh и гости: 21
cron
Яндекс.Метрика
