Куратор(ы):   Atheros
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 2752 • Страница 1 из 1381  2  3  4  5 ... 138  >
Фото UEFI BIOS
Характеристики Rampage V Extreme
CPU
Intel® Socket 2011-v3 Core™ i7 Processors
Supports Intel® 22 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to http://www.asus.com for CPU support list
Chipset
Intel® X99
Memory
8 x DIMM, Max. 64GB, DDR4 3300(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
Quad Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to http://www.asus.com for the Memory QVL (Qualified Vendors Lists).
Multi-GPU Support
Supports NVIDIA® 4-Way SLI™ Technology *1
Supports NVIDIA® 3-Way SLI™ Technology
Supports NVIDIA® SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Expansion Slots
4 x PCIe 3.0/2.0 x16 (x16, x16/x16, x16/x8/x8 or x16/x8/x8/x8 mode with 40-LANE CPU; x16, x16/x8, x8/x8/x8 mode with 28-LANE CPU) *2
1 x PCIe 2.0 x16 (x4 mode) *3
1 x PCIe 2.0 x1 *3
Storage
New Intel® Core™ i7 Processors :
1 x M.2 Socket 3, gray, , with M Key, type 2260/2280/22110 storage devices support ( Supports PCIE SSDs only)
Intel® X99 chipset :
1 x SATA Express port, red, compatible with 2 x SATA 6.0 Gb/s ports
8 x SATA 6Gb/s port(s), red, *4, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Recovery Technology*5
ASMedia® SATA Express controller : *6
LAN
Intel® I218V, 1 x Gigabit LAN Controller(s), featuring GAMEFIRST III
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Anti-surge LANGuard
Wireless Data Network
Wi-Fi 802.11a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Up to 1300Mbps transfer speed
Bluetooth
Bluetooth V4.0
Audio
ROG SupremeFX 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- SupremeFX Shielding Technology
- ELNA® premium audio capacitors
Audio Feature :
- Blu-ray audio layer Content Protection
- DTS Connect
- Optical S/PDIF out port(s) at back panel
- Sonic SoundStage
- Sonic SenseAmp
- Sonic Studio
- Sonic Radar II
USB Ports
4 x USB 3.0 port(s) (4 at mid-board)
Intel® X99 chipset : *7
6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
ASMedia® USB 3.0 controller : *8
10 x USB 3.0 port(s) (10 at back panel, blue)
OC Panel
2.6 " LCM display
EXTREME/NORMAL mode switch
EXTREME Mode for subzero OC benching:*9
- VGA Hotwire
- Subzero Sense
- Slow Mode
- Pause Switch
- VGA SMB header
- ProbeIt
- 4 x 4-pin extra fan connectors
NORMAL Mode for in-chassis usage:*10
- CPU Level Up OC button
- FanSpeed control button
- LCM backlight on/off button
I/O Ports:
- POWER:1 x SATA power connector
- ROG_EXT port:1 x 18-1 pin data connection port
ROG Exclusive Features
DirectCU thermal design
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
Extreme Engine Digi+ IV :
- IR3555 PoweIRstage®
- MicroFine Alloy Chokes
- 10K Black Metallic Capacitors
ROG Extreme OC kit :
- ReTry button
- Safe Boot button
- Start button
- Reset button
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- Debug LED
ProbeIt
KeyBot
- CPU Level Up
- XMP
- Direct Key
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
- Tweakers' Paradise
- ROG SSD Secure Erase
- Graphic Card Information Preview
ROG RAMDisk
GameFirst III
iROG
Extreme Tweaker
USB BIOS Flashback
Overclocking Protection :
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED II
Special Features
5-Way Optimization by Dual Intelligent Processors 5
- 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ Power Control, Fan Xpert 3, and Turbo App
Gamer's Guardian:
- ESD Guards on LAN, Audio, KBMS and USB3.0/2.0 ports
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: Cloud GO!, Remote Desktop, Remote Keyboard & Mouse, File Transfer
- Wi-Fi GO! & NFC Remote app for portable smartphone/tablet, supporting iOS 7 & Android 4.0 systems
ASUS Exclusive Features :
- MemOK!
- AI Suite 3
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- Push Notice
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
- ASUS C.P.R.(CPU Parameter Recall)
Media Streamer
Turbo App
Fan Xpert 3
Operating System Support
Windows® 8.1
Windows® 8
Windows® 7
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x LAN (RJ45) port(s)
10 x USB 3.0 (blue)
2 x USB 2.0 (one port can be switched to ROG Connect)
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
1 x ASUS Wi-Fi GO! module (Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.0
Internal I/O Ports
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x SATA Express connector: red, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
1 x M.2 Socket 3 for M Key, type 2260/2280/22110 storage devices support ( Support PCIE SSD only)
1 x TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s) (1 x 4 -pin)
1 x CPU OPT Fan connector(s) (1 x 4 -pin)
6 x Chassis Fan connector(s) (6 x 4 -pin)
1 x Thunderbolt header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Slow Mode switch(es)
9 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x BIOS Switch button(s)
1 x LN2 Mode jumper(s)
1 x ROG extension (ROG_EXT) header(s)
1 x KeyBot Button
1 x Sonic SoundStage Button
1 x Safe Boot button
1 x ReTry button
Accessories
User's manual
I/O Shield
10 x SATA 6Gb/s cable(s)
1 x ASUS 3T3R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x CrossFire cable(s)
1 x Q-connector(s) (2 in 1)
3 x Thermal sensor cable pack(s)
1 x 12 in 1 ROG Cable Label(s)
1 x X-Socket 2 kit
1 x ROG Door Hanger(s)
OC Panel Kit:
- 1 x OC Panel(s)
- 1 x OC Panel 5.25-inch bay metal case
- 1 x OC Panel Cable(s)
- 1 x OC Panel screw pack(s)
BIOS
2 x 128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.7, WfM2.0, SM BIOS 2.8, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 2, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information.
Manageability
WfM2.0, DMI2.7, WOL by PME, PXE
Support Disc
Drivers
ROG GameFirst III
ROG RAMDisk
ROG CPU-Z
ROG Mem TweakIt
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
ASUS WebStorage
HomeCloud
ASUS Utilities
Form Factor
Extended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
Note
1. 28-LANE CPUs can only support up to 3-Way SLI™/ 3-Way CrossFireX™
2. The PCIE_X8_4 slot shares bandwidth with M.2 x 4.
40-LANE CPU: The PCIeX8_4 slot can only be used in x4 mode or lower when used simultaneously with the M.2 connector. If x8 mode is used, the two connectors will be mutually exclusive.
28-LANE CPU: The PCIE_X8_4 slot will be disabled and the M.2 connector will always be enabled.
3. The PCIE_X4_1 (gray) slot shares bandwidth with the PCIE_X1_1 slot, USB3_E910 and SATAExpress_E1 connector. When the PCIE_X4_1 slot is occupied by an X1 or X2 device, the SATAEXPRESS_E1 will be disabled. When the PCIE_X4_1 slot is occupied by X4 device, the SATAEXPRESS_E1, USB3_E910 ports, and the PCIE_X1_1 slot will be disabled.
4. Due to chipset behavior, the SATA6G_78, SATA6G_910 ports do not support IRST including RAID configuration.
5. These functions will work depending on the CPU installed.
6. These SATA ports share bandwidth with the PCIE_X4_1 slot, and when the PCIE_X4_1 slot is ocuupied, the SATA ports will be disabled. These SATA ports are for data hard drives only. ATAPI devices are not supported.
7. 2 x USB2.0 port at mid-board shares with ROG extension (ROG_EXT) port.
8. USB3_E910 ports at back panel will be disabled when the PCIE_X4_1 slot is occupied by an X4 bandwidth device.
9. Extreme Mode capabilities, including V1, V2, DRAM and other voltage definitions, vary by chipset. Please refer to your motherboard manual for details.
10. One 5.25" drive bay is required for NORMAL Mode installation.
The product (electrical , electronic equipment, Mercury-containing button cell battery) should not be placed in municipal waste. Check local regulations for disposal of electronic products.
• All specifications are subject to change without notice. Please check with your supplier for exact offers. Products may not be available in all markets.
• PCB color and bundled software versions are subject to change without notice.
• Brand and product names mentioned are trademarks of their respective companies.
Новые возможности мат. платы (Eng)
We have the usual LN2 Mode Jumper and Slow mode switch as seen below.
What’s new are the Safe Mode Button and the Retry button.
Both these buttons function very similarly, once pressed, the system would immediately shutdown and power on by itself.
The difference is that
- Safe Mode button would power up the system in Safe mode
- Retry button powers up according to the settings set in the BIOS.
Both do not clear the settings you have saved in your BIOS.
Traditonal way to enter safe mode is by pressing the power button for 4 seconds
When you finally want to give up trying to boot at a certain setting, the Safe mode does it for you without you having to waste time pressing the power button for 4 seconds.
The retry button lets you retry booting at tough to boot settings. An example is getting a hang at post code ‘bf’ when trying to boot with tough Memory settings.
A lucky boot will get you to boot successfully so pressing the retry button here can save you time in getting a post.
It can also save you time at a processor hard lock whereby the reset button gives no response.
Советы (Eng)
- The Safe mode button saves you time and triggers a shutdown and bootup in Safe mode when you give up trying to boot at certain settings.
- CPUZ opens up pretty slowly, so use realtemp to check the actual cpu frequency
- When a heavy load such as PhysX/CPU test comes and the system shuts down and powers up by itself, this is due to the OCP on the PSU being triggered with a high transient load. You will need to change out a PSU or lower the load line so that CPU input voltage droops when the load comes.
- Sometimes a certain DRAM Frequency is just tough to boot due to clock and RTL combination, and going higher actually boots up fine, so try higher as well.
- When Pushing Single Stick of DRAM, the best slot to use would be Channel A red slot, the red slot most left.
- When just focused on maxing out BCLK, you can try low CPU Input voltage like 1.65v and match it with 1.85v PLL Termination voltage.
- Note that 13x~17x Core and Cache Ratios are buggy and can be unstable to don’t use those ratios.
- You may find Game Tests and Physics Test liking different temperatures on the CPU, maybe -95~100C for GT, as cold as possible for PT. So while PT is loading, set Pause ON with OC Panel, pull CPU down to colder temps and unpause.
- The best overclocking DRAM Ratios are the 2400 ratio and below most of the time. The Higher Ratios may not work as well.
- For Win XP, Disable Speedstep in the BIOS to get the Turbo Ratios to work.
- A lot of times, booting up too cold (say -130C), the CPU trips out and you’re stuck at 12x CPU Ratio in the OS. You will have to warm up and you will see the ratio come back to normal.
Официальные страницы на сайте ASUS:
Rampage V Extreme Eng
Обзоры:
Обзор и тестирование RVE на Guru3d (Eng)
Софт:
Офицальная страница загрузки Rampage V Extreme
Надеюсь кто то подхватит тему и станет куратором, создал что бы было с чего начинать, мать уже продается за бугром, можно так же почитать тут тему про RVE http://www.overclock.net/t/1510001/asus ... ers-thread
"Я не настолько богат, чтобы покупать дешевые вещи" (с) Барон Ротшильд
Последний раз редактировалось Atheros 21.08.2016 11:47, всего редактировалось 1 раз.
Фото: 7
Ну что еще ни кто не ставил данный продукт.
У меня уже руки чешутся как у наркомана, купить все и сделать новый ПК.
Тоже ее буду брать. Жду цены в россии. За бугром 15к
Что rulezzz что suxxx познать нам суждено, а выбрать лишь P-III дано
Фото: 7
Да даже дороже чуток, но неважно.
Я уже начла покупать новое железо
Пока начал с DDR4? уже заказал вот такую вот:
http://www.amazon.com/dp/B00MPIEDZ8/ref ... 00_TE_item
Вот сижу и думаю стоит брат 8 ядер или все таки 6.
Ты сам что думаешь?
Я хочу 8 и тебе советую. Если есть деньги то можно и отобрать проц который сможет 4800 на воде. У меня пока нет. Думаю из германии заказать там мать 15139 и проц бокс 5960х 37700 возможно попадется удачный экземпляр. В россии пока цены очень большие. Но надо ещё сначала старое железо продать. Память возьму пока одну планку на 4 самую дешевую. Потом как будут деньги закажу нормальную память и ссд в м2 разъем. Возьму бу 780 и буду собирать воду. Такие планы. И оверхард обещали ещё корпус привезти. Как то так. Сейчас продаю все старое железо и заказываю 5960х и мать
Добавлено спустя 3 минуты 15 секунд:
remmer29 память неплохая но дорогая слишком. Может взять проще от корсара, которая гонится до 3100 с таймингами 14 slamms приводил маркировки. Хотя эта очень красиво смотреться будет тоже такую ддр3 хотел в свое время но денег не было, так и не купил.
remmer29
В ситилинке продаются за 21тыр
А я сжал волю в кулак и решил ждать 4-6 месяцев - пока ажиотаж схлынет и новые решения появятся. Ну и ценник нормализуется.
Тоже думаю что 8 ядер будут перспективнее. Ибо их выбирают из отбраковки 12-ти ядерных. А все что совсем никуда не годится идет на 6-ти ядерные...
Плюс более низкий вольтаж в стоке.
MSI X370 ХP G Titanium | R5 1600X+Kryos XT .925 | Sapphire ProDuo | 256Gb Kingston HyperX Savage + 4Tb WD Se | Corsair AX1200i
Фото: 7
Я тоже думаю, что надо себе собрать максимум по железу, коли деньги есть сейчас, на все это.
А где ты собираешься заказывать в германии. Скинь сайт пожалуйста.
Старое железо я буду продавать все целиком вместе с монитором и колонками и наушниками в декабре.
ты про 6 ядер или про что?
Я тоже так думал, но потом решил, что есть риск, что доллар может вырасти до 40р, то тогда и цены будут ого го какие.
Короче каждому своё тут не поспоришь.
Я уже устал сжимать и меня уже колбасит от желания все собрать новое и я уже начал покупать все по чуть чуть.
remmer29
http://www.citilink.ru/catalog/computer ... ry/957820/
Фото: 7
AZon52
я знаю что они там есть но я уже заказал на amazon за 525*37= 19 425р
Что за чушь вы в каждой теме пишите.
Реальную ссылку можете дать где говорится что i7-5690x - отбраковка от 12 ядерников?
gessler человек просто неверно понял материал. Там говорится что 5960х это 12 ядерный проц с отключенными 4 ядрами. Вот поэтому может он решил что это отбраковка.
Куратор темы
Фото: 199
remmer29 ну почему же) юзаем от души ) отличная плата
Фото: 7
ты к чему?
Куратор темы
Фото: 199
Atheros надеюсь на воде проц 5960х не выгорит сокет при 4800 на 1,4в на рампаге 5?
Куратор темы
Фото: 199
Pahen ну это как например новая BMW может сломаться ) шансы малы но иногда бывает ) брак бывает во всем,ни одна компания не даст 100% гарантию что их продукт не сломается. Но из практики я заметил что проблем с продуктами компании ASUS меньше всего
Фото: 7
Atheros
Это точно я еще с 3 рамками гоню ни когда проблем не было.
Фото: 7
Atheros
скажи пожалуйста ты на новую маму воду не ставил если да то какие водоблоки подходят?
remmer29
Если на проц, то любой водоблок совместимый с 2011
Сейчас этот форум просматривают: AnDS, chigolberi, globnet, Sobakevich, Tipchic и гости: 15
Яндекс.Метрика
