Куратор(ы):   nixon2992
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 75 • Страница 1 из 41  2  3  4  >
Куратор темы
Фото: 76
Фото ASUS Strix X99
27653
Официальные страницы ASUS:
Strix X99 eng
Strix X99 ru
Характеристики
Процессор
Intel® Socket 2011-v3 Core™ i7 X-Series Processors
Supports Intel® 14 nm CPU
Supports Intel® Turbo Boost Max Technology 3.0
* Refer to http://www.asus.com for CPU support list
Чипсет
Intel® X99
Память
8 x DIMM, Max. 128GB, DDR4 3333(O.C.)/3300(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
Quad Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to http://www.asus.com for the Memory QVL (Qualified Vendors Lists).
Multi-GPU Support
Supports NVIDIA® 3-Way SLI™ Technology
Supports NVIDIA® 2-Way SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX Technology
Слоты расширения
3 x PCIe 3.0/2.0 x16 ( x16, x16/x16, x8/x16/x8 mode with 40-LANE CPU; x16, x16/x8, x8/x8/x8 mode with 28-LANE CPU)
1 x PCIe 2.0 x16 (x4 mode)
2 x PCIe 2.0 x1 *1
Накопители
New Intel® Core™ i7 X-Series Processors :
1 x M.2 Socket 3, with M Key, type 2242/2260/2280/22110 storage devices support (Support PCIE SSD only)
1 x U.2 port, support PCIe 3.0 x4 NVM Express storage
Intel® X99 chipset :
1 x SATA Express port, Compatible with 2 x SATA 6.0 Gb/s ports
8 x SATA 6Gb/s port(s),
Supports Intel® Smart Response Technology, Intel® Rapid Recovery Technology*2
Сеть
Intel® I218V, 1 x Gigabit LAN Controller(s)
Wireless Data Network
Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Supports MU-MIMO
Bluetooth
Bluetooth V4.1
Звук
ROG SupremeFX 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- Optical S/PDIF out port(s) at back panel
- Audio amplifier: Provides the highest-quality sound for headphone and speakers
- Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity
- Sonic Radar II
USB порты
5 x USB 3.1 Gen 1 port(s) (1 at back panel, blue, 4 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, , 4 at mid-board)
ASMedia® USB 3.0 controller :
3 x USB port(s) (3 at back panel, blue)
ASMedia® USB 3.1 controller :
2 x USB 3.1 Gen 2 port(s) (2 at back panel, , Type-A + USB Type-CTM)
Фичи материнской платы
ROG RAMCache
Overwolf
GameFirst IV
USB BIOS Flashback
5-Way Optimization by Dual Intelligent Processors 5
- 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo Core App
Gamer's Guardian:
- ESD Guards on LAN, Audio, KBMS and USB3.1/3.0/2.0 ports
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- USB BIOS Flashback
- MemOK!
- AI Suite 3
- Ai Charger+
- ESD Guards
- USB 3.0 Boost
- USB 3.1 Boost
- Disk Unlocker
- Mobo Connect
- PC Cleaner
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 4
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- Push Notice
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
RAMCache
AURA: RGB Lighting Control
Operating System Support
Windows® 10 , 64bit
Windows® 8.1 , 32bit/64bit
Windows® 7 , 32bit/64bit
Порты внешние
1 x PS/2 keyboard/mouse combo port(s)
1 x LAN (RJ45) port(s)
1 x USB 3.1 Gen 2 (red)Type-A
1 x USB 3.1 Gen 2 (black)USB Type-CTM
4 x USB 3.1 Gen 1 (blue)
4 x USB 2.0 (one port can be switched to USB BIOS Flashback)
5 x Audio jack(s)
1 x USB BIOS Flashback Button(s)
1 x ASUS Wi-Fi GO! module (Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.0
Порты внутрение
1 x U.2 port
1 x AAFP connector
1 x Aura RGB Strip Header
2 x USB 3.1 Gen 1 connector(s) support(s) additional 4 USB 3.1 Gen 1 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x SATA Express connector: , Compatible with 2 x SATA 6.0 Gb/s ports
1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Support PCIE SSD only)
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x Thunderbolt header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x EZ XMP switch
1 x 5-pin EXT_FAN(Extension Fan) connector
1 x DRCT header(s)
1 x MemOK! button(s)
1 x Thermal sensor connector(s)
1 x CPU OV
1 x Power-on button(s)
1 x Reset button(s)
1 x Clear CMOS jumper(s)
1 x Water Pump header (4-pin)
1 x ROG extension (ROG_EXT) header(s)
1 x 14-1 pin TPM connector
1 x COM port header
1 x High AMP Fan header (4-pin)
Комплект поставки
User's manual
I/O Shield
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x CPU installation tool
1 x Supporting DVD
1 x ASUS 2T2R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
1 x Cable ties pack(s)
ROG Fan Label
1 x Extension Cable for RGB strips (80 cm)
BIOS
128 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS,
ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information.
Manageability
WfM 2.0, WOL by PME, PXE
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Инструкции и QVL:
Руководство пользователя
QVL на оперативную память Broadwell-E
QVL на оперативную память Haswell-E
Софт:
Официальная страница
Предварительная настройки материнской платы при первом включение
1.В UEFI пункте Ai Tweaker отключите Asus Multicore Enchament переведя в disabled - отключает авторазгон по максимальной множителю Turbo Boost(Задирает напруги на VCC Core и возможно на другие компоненты CPU)
2.Если память с XMP(CLK DDR4>2666Mhz или маленькое значение СAS Latency(от С14)) :Вручную выставить вручную частоту, заполнить первичные тайминги и зафиксировать напряжение для DRAM(обычно 1.35в),Если память JEDEC(1866-2133Mhz(HSW-E)/2400(BRD-E)):Заполнить первичные тайминги и зафиксировать напряжение DRAM (стандарт 1.2в).
3.Если планируется разгон CPU в Digi+ Power Management CPU переключить с AUTO на Extreme(При наличие необсулуживаемой СВО/разгоне от 4 Ghz, рекомендуеться обдув VRM).
4.При разгоне памяти от 2800Mhz рекомендуеться выставить переключить Digi+ Power Management DRAM phase control с Standard в Extreme и Cpu Phase control в Extreme и желательно зафиксировать значение VCCSA приблизительно 1.0в).Также при любых операциях с памятью настоятельно рекомендуется зафиксировать VCCIO на 1,05в для Haswell-E и 0,95в для Broadwell-E! Значение VCCSA по умолчанию около 0,9в для памяти 2133Mhz 1.2в.
5.Обязательно активируете в меню Monitor пункт Anti Surge Support(Защита OVP/OVC материнской платы).
6.Для обычного режима эксплуатации рекомендуется выставить VccIn 1.8 и Load Line Calibration :Level 1 - работа системы по спецификации Intel.При разгоне VccIn 1.9 и Load Line Calibration :Level 6.
7.Для предотвращения повреждения FIVR разогнанного процессора во время работы с приложениями использующие AVX2 пропишите в пункте CPU Integated VR Limit:157A(0.9 VCCIn Max).В случае достижения порогового значения процессор начнет сбрасывать частоту или материнская плата отключит систему в целях сохранения CPU.
8.После установки операционной системы не ставьте AI Suite 3!!Так как это ПО криво управляет параметрами МБ.
FAQ(Решение типичных проблем)
Q:У меня периодически отваливаються USB устройства,как решить проблему?
A:
27729
Включить полную инициализацию USB.
27728
Увеличить PCH Core Voltage до 1,08 вольта.
28388
Q:Периодически сам отключается WIFI модуль и теряеться соединение.
A:
29288
29289
29290
Q:При изменение входного напряжения CPU(VCC In) после перезагрузке BSOD(Актуально для UEFI 0801).
A:После изменения данного параметра рекомендуеться полностью обесточивать систему.
Q:На плате есть M2 слот какой тип накопителей он подерживает?
A:Только PCI-E NVME.
Q:Здравствуйте,хочу спросить про пункт в UEFI Asus multicore enhachement на Strix x99.
Насколько я понял эта опция просто фиксирует максимальный множитель Turbo Boost 2.0 на все ядра ,параллельно увеличивая напряжения питания на core и uncore.
Работает ли она для Xeon E5 2695v3?Будет ли на нем на всех 14 ядрах максимальный множитель 33 или на нем этот пункт работать не будет.
A:Данный параметр устанавливает максимальный множитель для всех ядер в режиме Turbo, независимо от текущего количества "занятых" ядер процессора.
С Xeon нет, не работает, только с десктопными CPU.
Q: Материнская плата перестала проходить POST тест(POST 00) - фикс(источник:BlueRaiderVol - ASUS ROG Forum)
A:
1.Вытащить батарейку с МБ на пару дней.
2.Очистить CMOS
3.Загрузиться с клавишей MemOK.
Распределение линий PCI-E в зависимости от процессора
27731
Распределений 8 линий PCI-E чипсета и Flexible IO
28834
Важная информация!!
Диапазон допустимых напряжений на компоненты CPU
Руководство ASUS по разгону Broadwell-E
Руководство ROG по разгону Haswell-E
Руководство ASUS по разгону RAM
Допустимые напряжения для Broadwell-E в номинальном режиме
27787
29408
Допустимые напряжения для Haswell-E в номинальном режиме
27786
Максимальные токи и рассеиваемая мощность Haswell-E/Broadwell-E 6-8 cores
28093
Диапазоны напряжений подаваемые на чипсет и от чипсета и их номинальные значения
29560
29561
29330
Максимальные значения напряжений на узлы CPU при разгоне
Ядро ЦП - не поддавать больше 1,35в
Кэш ЦП - не поддавать больше 1,35в
CPU VRM - не поддавать больше 1,95в
VCCIO - не поддавать больше 1,3в (лучше < 1,25в)
VCCSA - не поддавать больше 1,3в(лучше < 1,25в)
VRM:FAQ и описание настроек
Q:Меня также интересуют описание режимов работы Digi+ VRM по части переключения фаз.В режима AUTO для CPU Phase control в каком режиме работает VRM?Можете пожалуйста описать поведение CPU VRM при следующих режимах работы:AUTO,Standart, Optimised и Extreme.
A: AUTO - автоматически, в зависимости от текущей нагрузки на процессор, то есть происходит автоматическое переключение на один из остальных возможных режимов.
Standart - по спецификации Intel.
Optimized - по разработанному инженерами ASUS алгоритму.
Extreme - следует из названия, то есть устанавливает минимальную частоту переключения(Активны все фазы).
Q:Какой из предложенных режимов лучше использовать при разгоне,а какой при обычном режиме использования процессора на частотах которые соответствуют спецификации Intel?
A:В обоих случаях оптимальный вариант - Auto Выбор определенного значения имеет смысл только с в случае нестабильной работы системы и подозрений, что причина именно в частоте переключения фаз. В этом случае оптимальный вариант определяется опытным путем.
Q:Так же можно спросить про безопасную температуру VRM CPU и какой диапазон считается безопасным для DrMos сборок?
A:Температура самих модулей не критична, она может достигать и значений в 105С без каких-либо последствий, однако такие значения критичны для других компонентов на плате, равно как и для самой PCB, так что лучше не допускать нагрева VRM-модулей выше 85С.
Особенности взаимодействия Source Clock Tuner и M.2 NVME SSD(Решение)
Source Clock Tuner
Значение по умолчанию Source Clock Tuner: 7Ohm dbi ,для CPU Strap 100Mhz.
28164
Рекомендованные значения от ASUS:
Strap 100Mhz - 6Ohm dbi
Strap 125Mhz - 8Ohm dbi
Strap 167Mhz - 4Ohm dbi
XMP:Особенности работы на данной плате
В связи с поступлением в продажу модулей совместимых с 1151 прошитые в них настройки напряжений могут повредить IMC(встроеный контролер памяти) особенно на Broadwell-E.Поэтому категорически рекомендуеться выставлять тайминги и напряжение вручную при изменение скорости работы ОЗУ.
Пользовательские настройки разгона
Статистика по браку/неисправностям
Идет сбор данных..
По мере накопления материала FAQ и шапка будут обновляться.
В данной теме ведется обсуждение:
- ТОЛЬКО Asus Strix X99 на Intel X99 LGA2011-3!
- Мат. платы, ее настройка, тюнинг, разгон;
- Проблемы, связанные с ее эксплуатацией;
- Особенности работы, совместимости, проблемы и тонкости с устройствами, возникающие при подключении и использовании
- Софтовые проблемы, применимые к конкретной мат. плате (драйверы, утилиты);
- Прочие, неразрывно связанные с платой нюансы, являющиеся индивидуальным совпадением и особенностью конфигурации
- Проблемы с CPU возникающие на данной мат. плате
Остальное будет считаться оффтопиком и будет удаляться.
Последний раз редактировалось nixon2992 16.09.2017 11:26, всего редактировалось 42 раз(а).
Куратор темы
Фото: 76
Задавайте вопросы ответы на которые хотите увидеть в FAQ.
Обновил спойлер с по первичной настройке матери пункт по разгону памяти(Указаны корректное значение VCCIO в номинале для Broadwell-E).
Последний раз редактировалось nixon2992 10.09.2017 16:34, всего редактировалось 1 раз.
Фото: 12
Если делать по уму ветку, можно посмотреть как сделан Фак на Рампаге 4 Black, там присутствет:
1. Список драйверов необходимых после установки win
2. Скрины настроек разгона процессоров (особенно интересна серия 6)
3. Схема распределения линий PCI-E
4. Настройка Offset
5. Особенности и параметры подаваемых вольтажей
6. Прочие тонкости
От себя могу помочь разжевать настройки разгона 6850k в плане вольтажей (допустимые значения), скрины могу дать, мелкие плюшки типа настройки подсветки памяти Corsair led, результаты разгона памяти :beer:
2K G-sync 1080 ti жижа, пока хватает...
жду
Добавлено спустя 1 час 13 минут 21 секунду:
Есть ли у кого фото что находится под крышкой в центре матери на которой надпись republic of gamers
Intel core i7 6800k, ASUS STRIX X99 GAMING, 4Gb*8 kingston savage 2800MHz, msi gtx 1070 hawk x ek. Кастом сво
Фото: 12
Разьём питания на диод и два крепежных отверстия, я ещё на рампаге4 Black снимал этот Рог, чтобы моноблок поставить, сзади два винта должно быть, раскрути да посмотри, в чем проблема?
гарантия :(
Куратор темы
Фото: 76
Можешь скинуть,я добавлю в шапку,буду очень благодарен.
Фото: 12
Да конечно, дай пару-тройку дней, сейчас как раз пределы камня 6850 и настройки биваса щупаю, память гоняю.
Сделаю скрины настроек, памяти - выложу сюда.
Давайте отразим допустимые значения на ряд напруг основных при разгоне:
Ядро ЦП (вилка)
CPU VRM
Кэш ЦП
VCCIO
VCCSA
Разгон Кэша
Разгон памяти, тайминги и вольтажи
Статью по разгону можно запилить в фак http://edgeup.asus.com/2016/06/17/broad ... ing-guide/
Чтобы детки такое видео не смотрели больше и не деградили или жгли камни
https://youtu.be/5FeCdhsYA8g
:beer:
Куратор темы
Фото: 76
Ядро ЦП (вилка)
CPU VRM
Кэш ЦП
VCCIO
VCCSA
Разгон Кэша
Также желательно настройки Digi+ VRM выложить,чтобы была полная информация о настройке силовой части МБ.
Фото: 12
Примерно разгон памяти - на что равняться, может кто больше толкнет :crazy:
430038003200.jpg [ 109.37 КБ | Просмотров: 2576 ]
6850k
проц 4300 кэш 3800 память 3200
6900k
проц 4300 кэш 3500 память 3200
Куратор темы
Фото: 76
Нужна ли вам информация о рассыпухе на МБ?
То что найду в шапке выложу.
Кстати нашел случай выгорания VRM CPU на 0801 UEFI при разгоне RAM до 3Ghz за 4 месяца.
Фото: 33
Блин, что то я все больше робею брать стрикс)или такое бывает с бродвелами только?а с хасвелами не горят?
Фото: 12
Начнёшь ловить измену - обязательно сгорит :beer:
Для начала разгона камня, необходимо погрузится в тонкости и аспекты подаваемых и допустимых напруг на узлы, если не смотря ставить 1,49 на ядро и доверится автоматике мат. платы - результат не заставит себя долго ждать :beer:
Из основных напруг подлежащих изучению выделю:
1. Ядро ЦП - не поддавать больше 1,35
2. Кэш ЦП - не поддавать больше 1,35
3. CPU VRM - не поддавать больше 1,95
4. VCCIO - не поддавать больше 1,3 (лучше < 1,25)
5. VCCSA - не поддавать больше 1,3 (лучше < 1,25)
6. Не перегревать камень выше 85 градусов в тестах, про рабочие режимы молчу
Фото: 33
Reveal809
Это точно :D
Куратор темы
Фото: 76
Ну это единственный случай+там человек только изменил множитель ОЗУ,а остальные настройки оставил на авто.Этот один случай с Broadwell-E и то может по криворукости владельца).
Добавлено спустя 5 часов 21 минуту 39 секунд:
Еще просьба написать дату сборки системы для статистики по материнской плате.
Также введу переписку с Suport ASUS по этой материской плате,описывайте вопросы которые хотите чтобы я задал в техподержку ASUS.
Фото: 12
sams.jpg [ 130.99 КБ | Просмотров: 2242 ]
Source Clock Tuner
Если выставить не AVTO значение, то M.2 ssd будет работать в режиме 2Х4 - это чревато снижением скорости ssd M.2 в два раза.
Можно в шапку запилить и задать вопрос почему такой баг??? :mad2:
Куратор темы
Фото: 76
Reveal809 писал(а):
Source Clock Tuner
Спросил и жду когда отпишуться,пока не получу ответа будет висеть в шапке.
Еще отпишитесь ставили вы Ai SUITE?
Такая же бага есть и на RV5 E10 в новом UEFI 1701.
https://rog.asus.com/forum/showthread.php?93845-Rampage-v-edition-10-bios-1701
Начал сбор статистики по браку/неисправностям ASUS Strix x99 за все время с начала ее продаж!
Добавлены рекомендации по настройке при первом запуске материнской платы.
В общем у меня история с этой матерью такая. Купил с камнем 6800K и оперативой Kingston DDR4-3200 8192MB PC4-25600 (Kit of 2x4096) HyperX Pred (HX432C16PB3K2/8). Охлад Zalman CNPS10X Performa+, в общем все как положено. Радости не было придела, с настройками биоса особо не экспериментировал. Профиля XMP было 2, на 3000 и 3200. На 3200 не заводилось вообще. Пробовал вручную без поднятия напряжения(хотя точно не помню уже, возможно поднимал), так же безуспешно. Ну в итоге оставил на XMP 3000, там заодно был не большой разгон проца по шине 120-125. Ну думал ладно асусу виднее...
Но спустя 3 месяца, он заснул вечным сном, в прямом смысле этого слова - не вышел из ждущего режима, а на матери загорелась лампочка CPU LED.
Подозрения пали на мать, но увы умер камень. Лично возможности проверить не было, но мать говорят целая.
Что посоветуете, как ее нормально настроить без разгона, или вообще лучше избавляться от нее?
Phenom 9950, 2.6 GHz/Zalman 7500-AlCu/MSI K9A2 Platinum/1xHynix 2GB + 2xKingston 1GB/MSI N660 TF 2GD5 OC/Crucial CT128M4SSD2/WD 1 TB/FSP AURUM AU-650M
Оверквотинг
посмотри мои сообщения если интересно, да и вообще всю ветку Intel Haswell-E / Broadwell-E LGA 2011-3
я также спалил 6850 с помощью ХМР, только у меня он за неделю помер, и таких случаев несколько 6900 даже один помер у участника форума, вот такая байда. Контроллер памяти выгорает у бродвела при авторазгоне памяти. И эта проблема как я понял на всех платах ASUS. На счет настройки, разгоняй ручками, все напруги в узлах прописывай сам.
I7 6850K 4,2 1,175V /NH-15D+Grizzly/ ROG Strix x99 / 32GB DDR4 3000 MHz / m.2 Plextor m8pe 512/msi GTX 1080 SLI/corsair 1000i/ 4K sony 55"
Последний раз редактировалось Igor-Igor 24.07.2017 7:15, всего редактировалось 1 раз.
Нарушение п. 3.8 ПК, ЖК 1 день.
Сейчас этот форум просматривают: Danila1989, Gradient1712, toliyn19 и гости: 15
Яндекс.Метрика
