Статус: Не в сети Регистрация: 11.04.2009 Откуда: Одесса
Мне вот интересно уменьшится ли срок службы материнки и на сколько если она будет в разогнанном состоянии работать? Добавлено спустя 5 минут, 20 секунд
r27 писал(а):
вышел новый BIOS 2205. кто пробовал?
При этой версии БИОС винда в диспетчере задач стала видеть 3069Мб ОЗУ вместо 3581Мб на предыдущем 2001. Так что поменял прошивку на старую... Добавлено спустя 14 минут, 56 секунд
mourder писал(а):
Всем привет! у меня вопрос можно ли на этой мамке ASUS M2N32-SLI DELUXE запустить Phenom II X4 940 box или нет?
Судя по твоей подписи можно наверно? Скажи какая версия БИОС и как вообще работает?
_________________ Phenom II X6 1090T (@4GHz), ASUS Crosshair IV Formula, Sapphire 4890 Toxic 1000/4400, Mushkin Redline 4Gb DDR3-1600, Seasonic X-750, Win7 Ultimate x64
After seeing several conflicting reports that the new Phenom II cpus would work on some older motherboards, and not on others, I decided to try and replace my AMD 6000 on my ASUS M2N32-SLI Deluxe with a Phenom II 940 to see if it would work. Well, the good news is that the upgrade went very smoothly. After loading the defaults for the motherboard BIOS, I reset, powered down, removed the 6000 CPU, replaced with the 940 and MX2 paste (using a Noctua heatsink & fan), rebooted the computer, and it seems to run just fine. It shows "Unknown Processor" in the BIOS, but Windows XP Pro currently shows four cores. I had to go into the BIOS to set my RAM timings back to 4-4-4-12, and, I managed to overclock it to 3.3 Ghz, and so far it is stable (I have not really tested its stability yet in gaming or through specific test programs because of a lack of free time, nor have I pushed the CPU further to see how high I can OC it).
I am using the latest mobo BIOS (2101) from the ASUS website.
To those people who own this motherboard with the Nvidia 590 chipset, the Phenom II 940 does work, and it may lead to cost savings in terms of an upgrade.
Now, I am not sure about performance differences between the AM2 and AM2+ boards, but the fact I have it running means I do not have to buy a new motherboard just yet.
According to PC Wizard, temps are around 42 per core.
System Specs:
Phenom II 940 m 3.3 Ghz
Noctua CPU Cooler
Corsair XMS 2 Gigs RAM DDR2-800
Seagate 500 GB HDD
Creative SB XtremeMusic
Windows XP Pro 32-bit
Corsair 620 PSU
ATI 4850 with Accelero cooler
Just thought I would share this information with others especially those who own older AM2 boards.
*Edit* - I just upgraded to 4 gigs of Corsair RAM running @ 5-5-5-18, 1.90 Volts, and at DDR2 800. I also formatted Windows XP Pro and the system runs like a top. Doubled the CPU cores on my system, ditto for the RAM, and it runs really great! Добавлено спустя 3 минуты, 42 секунды
C_i_t_r_u_s писал(а):
ну 1,5 года в очень жеских условиях при напрягах почти все на макс точно проработала.
Я вот просто думаю что нет смысла напрягать мамку с Феном 9850 и гнать его до 3-х Ггерцов, а просто поставить 940-й.
Ну а уже если гнать 940-й то это будет намного более оправдано в плане производительности.
ASUS M2N32-SLI DELUXE запустить Phenom II X4 940 нормально пашет с GF GTX285 в 3дмарке 06 выбивает 18 000 - 18 500 суй гони будет бульдозер.
Все старые Phenom в топку это было издевательство и очень горячо.
P.O.D. писал(а):
Кстати, у кого на этой матери отвалился Wi-Fi и в диспетчере задач висит "неизвестное устройство" могу рассказать как восстановить.
))) Расказуй, только ради интереса... Добавлено спустя 6 минут, 1 секунду И подскажите как в БИОСе называется раздел где можно напряжение ОЗУ настроить.
Статус: Не в сети Регистрация: 10.02.2006 Откуда: UA
Ну ради интереса долго рассказывать. Вкратце - берем в руки мультиметр, откручиваем модуль wi-fi, проверяем напругу +3,3В, проверяем какой порт юсб из двух сдох, и вместо него подключаем другой, свободный порт. Вкратце все
З.Ы. Товарищи, читал тут про датчик температуры материнки но так и не смог его найти, ткните пальцем плз
Блин, хотел комп "пропылесосить", в общем почистил все от пыли (вроде аккуратно стрался), а завести не получилось! Мать сдохла, по непонятной мне причине! Что в утиль ее? И если покупать, то что посоветуете за место этой чтоб старый проц можно было использовать AMD Athlon 64 x 2 4600?
slava4791 а ты уверен что ты ее хорошо пропылесосил?
может пока пылесосил часть пыли в слоты попала и все.
какие признаки система подает? вообще не заводится, или заводится и чета пищит?
Вентиляторы крутятся, писков нет. Не выдает на экран ничего!! Был такой симптом вначале, не открывался ДВД отсек, но когда я все поотключал и подключил к мамке только самое необходимое ДВД заработал, может это и не связано. Вот подумал, может ли быть такое от БП?
Проц и видяха рабочие, проверил на др. компе. Добавлено спустя 1 час, 46 минут, 53 секунды C_i_t_r_u_s
Во спасибо тебе мил человек! Если б не ты пошел бы я в магаз за новой мамкой. Ты же заставил меня усомниться и "поверить в мою мать"! оказалось все настолько банально, что писать смешно! Вся проблема была в запавшей кнопки РЕСЕТа на корпусе, я ж вертел его во время пылесосания, а так как кнопочкой этой пользовался крайне резко, то она то от этой пыли видать и застряла!
slava4791 да на здоровье, вообще в будущем никогда ни делай поспешных выводов если железо что то косячить стало. все надо много раз перепроверить и только потом уже решать.
Статус: Не в сети Регистрация: 26.11.2006 Фото: 10
Приветствую! Вопрос в следующем: кто-нибудь знает как изменять из под BIOS такой параметр памяти как Refresh Cycle time DIMM 0 - 3, этот параметр выствляется для каждого слота памяти по отдельности. Конкретно в BIOS его не нашел, но может при помощи комбинации других таймингов его можно изменить? Проблема в следующем: стояла пара Mushin HP-2 6400 4-4-4-12 @ 1000Mhz 4-5-4-12 2.1v, поставие еще дополнительно OCZ Reaper 6400 4-4-4-15 и сейчас это все дело работает вместе на 1000 4-5-4-12 2.1в через Memset посмотрел, что для слотов где стоит Muskin мать выставила Refresh Cycle time DIMM по 327 ns, а для OCZ по 75 . что для разгона мало, и нужно повысить. Memset не хочет повышать. Кто знает как это сделать?
Статус: Не в сети Регистрация: 02.12.2007 Откуда: Люберцы
Приветствую! проблема такая: пытались разогнать другу проц Phenom 9950 успешно разогнали до 3.2ГГц потестили вроде бы всё нормально... но стоит сделать перезагрузку комп не включается! все вентиляторы работают но сигнала нет! сбросили разгон тоже самое и так до тех пор пока не вынули батарейку биоса так он загружается но до 1 перезагрузки потом опять тоже самое...стоит выключить тумблер на БП и включить всё работает опять же до 1 перезагрузки...
Пробовали перепрошить биос всё тоже самое... Cистема такая:Проц: Phenom 9950 Мат плата: Asus M2N32-SLI Deluxe/Wireless Edition 4Гб DDR2 800 Samsung Видео:Radeon HD 4870 512мб БП FSP 600ватт нужна ваша помощь! Sad
PhenomFX,
№1 - обнови биос.
№2 - У меня такая же проблема была. Подгорела оператива. Попробуй проверить планки. Пусть поработает с одной, потом с другой и т.д.
Может такая же история.
PhenomFX, тогда даж не знаю. У меня комп так работает при запуске только когда там стоит подгоревшая планка оперативы.
Пробуй всё в системе проверять. Проц, видео, винт, меняй и проверяй. Если все будет без изменений, прийдется нести мать в сервис чтоб они разбирались.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 28
