Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 70 • Страница 1 из 41  2  3  4  >
Optoma EW610ST-Короткофокусный 3D 720p DLP проектор
Specification:
Display Technology Single 0.65” WXGA DC3 DMD chip DLP® Technology by Texas Instruments
Native Resolution WXGA 1280 x 800
Brightness - BRIGHT mode1 3100 ANSI Lumens
Contrast 3000:1
Noise Level 29/31dB (STD/BRIGHT mode)
Aspect Ratio 16:10 Native, 4:3/16:9 Compatible
Weight 3.1 kg
I/O Connectors
Inputs: PC/Video: HDMI, 2 x 15 Pin D-sub (RGB/YPbPr), S-Video, Composite, 2 x Audio In - Jack/RCA, USB (remote mouse), Mircophone
Outputs: VGA Out, Audio Out - Mini Jack, +12v Trigger
Control: RS232, RJ45
Preset Mode
Movie: Maximum contrast and Colour accuracy
sRGB: Best Colour Reproductiion
User: Memorises user's settings
Presentation Default mode, perfect with computers or notebooks
Bright For environments with high ambient light (Brighest image)
Classroom 1500 ANSI Lumens, perfect for installations with interactive whiteboards
Blackboard Perfect for installations with blackboards
Maximum Resolution UXGA 1600 x 1200-так указывает производитель но мною лично проверено по HDMI держит входящий сигнал 1920х1080р 60Гц
Computer Compatibility UXGA, SXGA, WXGA, HD, XGA, SVGA, VGA, Mac
Video Compatibility PAL (B, D, G, H, I, M, N, 576i/p), NTSC (M, 4.43/3.58 MHz, 480i/p), SECAM (B, D, G, K, K1, L) HD (1080i, 720p)
Displayable Colours 1.07 Billion
Projection Lens F/2.8; f=7.35mm, Fixed Zoom
Throw Ratio 0.52:1
Projection Screen Size 1.13 – 5.67m (44.64” – 223.21”) Diagonal 16:10
Projection Distance 0.5 - 2.5 metres
Horizontal Scan Rate 15 - 91kHz
Vertical Scan Rate 25 - 85Hz (120Hz for 3D)
Lamp Type/Lamp Life2 4000/3000 hours (STD/BRIGHT mode)
Keystone Correction ± 40° Vertical
Audio 10W
Dimensions (W x D x H) 306 x 243 x 113mm
Remote Control Full function remote with direct source selecting
Power Supply 100-240V, 50-60Hz
Power Consumption 295W BRIGHT mode < 1W Standby mode, 205W STD mode < 1W Standby mode
Operating Conditions 5°C - 40°C, Max. Humidity 85%, Max. Altitude 3000m
Uniformity 80%
Security Security Bar, Kensington Lock, Password Protection
Standard Accessories Lens Cover, AC Power Cord, VGA Cable, Infra Red Remote Control with Batteries, Quick Start Card, CD User Manual, Warranty Card
Optional Accessories Wall Mount - OPCWM835
RoHS Compliant
3D Support 120Hz frame sequential 3D for resolutions up to 720P. 60Hz field sequential 3D for resolutions up to 480i.
3D Viewing Requires Optoma DLP® Link™ active shutter glasses – sold separately
3D Compatibility The 3D features of the EW610ST can only be used with compatible 3D content. Typical applications include use with 3D educational or 3D design and modelling
software. Currently the EW610ST does not support 3D TV broadcast systems, SKY in the UK or 3D Blu-ray, though support for these applications may be added in future using additional hardware.
Distance Calculator
Цена
Для совместного использования с Nvidia 3D Vision inf файл от ACER не подходит-получите рассинхрон очков поэтому на проектор необходимо установить данный драйвер:
; INF file generated by Monitor Asset Manager (2.59.0.920), 18/02/2011
; Copyright (c) EnTech Taiwan, 1995-2011.
; Internet: http://www.entechtaiwan.com
[Version]
Signature="$WINDOWS NT$"
Class=Monitor
ClassGUID={4d36e96e-e325-11ce-bfc1-08002be10318}
Provider=%MFG%
DriverVer=18/02/2011, 1.0.0.0
;CatalogFile=YourSignedCatalogFile.cat
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
;YourColorProfileFile.icm
[Manufacturer]
%VENDOR%=EDID_OVERRIDE,NTx86,NTamd64
[EDID_OVERRIDE.NTx86]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\OTM3034
[EDID_OVERRIDE.NTamd64]
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\OTM3034
[OVERRIDDEN-EDID.Install.NTx86]
DelReg=DEL_CURRENT_REG
AddReg=OVERRIDDEN-EDID.AddReg, MODE1, DPMS
CopyFiles=OVERRIDDEN-EDID.CopyFiles
[OVERRIDDEN-EDID.Install.NTamd64]
[OVERRIDDEN-EDID.Install.NTx86.HW]
AddReg=OVERRIDDEN-EDID_AddReg
[OVERRIDDEN-EDID.Install.NTamd64.HW]
[OVERRIDDEN-EDID_AddReg]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x3E,0x8D,0x34,0x30,0xE3,0x02,0x00,0x00,0x20,0x14,0x01,0x03,0x80,0x00,0x00,0x00,0x2F,0x00,0x00,0xA4,0x50,0x4F,0x8C,0x23,0x12,0x48,0x4F,0xAF,0xEF,0x80,0x61,0x7C,0x81,0x00,0x81,0x80,0xA9,0x40,0x81,0xFC,0x81,0xC0,0x45,0x7C,0xB3,0x00,0x1A,0x1D,0x00,0x80,0x51,0xD0,0x1C,0x20,0x40,0x80,0x35,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x00,0x38,0x78,0x1E,0x78,0x11,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x4F,0x70,0x74,0x6F,0x6D,0x61,0x20,0x33,0x44,0x30,0x34,0x0A,0x20,0x01,0x76
;Extension bloc #1, e.g., CEA-EXT, DID-EXT, etc.
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x20,0x76,0x4B,0x10,0x1F,0x05,0x14,0x04,0x22,0x13,0x03,0x12,0x20,0x21,0x23,0x09,0x1F,0x07,0x83,0x2F,0x00,0x00,0x67,0x03,0x0C,0x00,0x10,0x00,0x28,0x2D,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0x00,0x00,0x00,0x00,0x00,0x9E,0x01,0x1D,0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25,0x00,0x00,0x00,0x00,0x00,0x00,0x9E,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x8C,0x0A,0xD0,0x90,0x20,0x40,0x31,0x20,0x0C,0x40,0x55,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0xF2
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,1
[MODE1]
HKR,,MaxResolution,,"1280,720"
[OVERRIDDEN-EDID.AddReg]
HKR,"MODES\1280,720",Mode1,,"30.0-120.0,56.0-120.0,+,+"
[OVERRIDDEN-EDID.CopyFiles]
[Strings]
MFG="EnTech Taiwan"
DISC="Monitor EDID Override Installation Disk"
PRODUCTID="OTM Optoma 3D04 (OTM3034 EDID Override)"
VENDOR="OTM"
https://icg-extreme.team/
Уже почти решил брать данный сабж, камрад Kovzel своим довольно восторженным отзывом добил меня окончательно :beer: но так как с проекторами дела совсем не имел то возникло несколько вопросов, может и наивные но все же :oops:
1. Меню проектора и инструкция эсть на Русском языке.
2. Можно объяснить пошагово как и куда ставить мод. inf файл.
3. Как данный сабж ведет себя с очками от нвидии, есть ли какие недостатки типа мерцания или еще что, по сравнению с 3д монитором, т.к. проектор берется в основном под 3д.
4. Установка: в виду временного ограничения в размерах комнаты проектор предполагается установить на тумбочку высотой 30-40 см. и вот такой экран http://www.nix.ru/autocatalog/projector ... 01611.html допускается ли такая установка у данного проектора, ведь экран будет выше чем проектор.
И Kovzel просьба протестировать данный сабж в 2д и 3д режиме на размере вышеуказанного экрана, а то судя по калькулятору это примерно 0.9м. от экрана и стрелка калькулятора находится в красной зоне.
Осталось дождаться ответа, если все ок. то нажму заветную кнопочку "заказать" :-)
1 русское
2 копируем текст что я привел, вставляем в блокнот, сохраняем, переименовываем файл с .txt на .inf Далее лезем в диспетчер устройств находим проектор, нажимаем обновить драйвер, выбираем в ручную наш файл обновляемся, перезагружаемся. Заходим в панели нвидиа в настройки проектора ставим 720р 120Гц и включаем 3d vision, все. Проектор и моник по идее должны автоматом встать в режим дуал вью, перетаскиваем плеер разворачиваем экран и радуемся, если хотим запустить игру то делаем проектор основным устройством и играем (возможно игры на вторичном монике/проекторе можно как то иначе запускать я просто не в курсе)
3 после установки драйвера который я привел ни единого глюка не замечено тоесть работает все также как и с монитором только круче! :D
4 у меня у самого проектор стоять будет на стеклянной подставке 75см высотой на расстоянии порядка 1.6 метра, низ проецируемого расстояния будет на 13см выше чем центр линзы(при 0.9 метра и 1280х800 при 720 еще выше) (подробно здесь http://www.projectorcentral.com/pdf/pro ... l_5927.pdf) к тому же у проектора есть регулировка положения экрана вниз вверх вправо влево. Ставил такую длину экрана ничего крамольного не заметил.
ЗЫ а экран все же по возможности рекомендую хотя бы до двух метров в длину дотянуть оно стоит своих затрат
Kovzel Спасибо огромное :beer: Заказываю :tooth:
Правильно ли я понимаю что для 3д игр на проекторе кабель от компа к проектору нужен такой :?: http://www.computer32.ru/price/computer ... _10m_.html
у тебя на видео есть hdmi вот по нему и подрубай да не парься (единственное порекомендую купить HDMI кабель 1.4 с пометкой high speed -это высококачественные кабели пропускной способности хватает чтобы передать 1080p 3D 120Гц)
Kovzel Так в проекторе вход hdmi v.1.3, а для стерео 3д требуется hdmi v.1.4a :insane:
для 3D 1080p 120Гц стерео нужен вход 1.4a а для 720р и 1.3 хватит , а кабель я тебе просто рекомендую с запасом взять потом не придется менять,
в общем у меня все работает ;)
10 метровый 1.4 кабель встанет в некошерную сумму ;)
Asus ROG Strix Scar17 7945HX3D, 32gb@5200, RTX 4090 Mobile 16gb vram (175w)+OLED 27" MSI MAG 271E2
Да ему всегото метра два нужно на сколь я понял
Kovzel писал(а):
а для 720р и 1.3 хватит ,в общем у меня все работает ;)
Тогда я вообще ни чего не понимаю :insane: , почему по hdmi v.1.3 от сони пс-3 не принимается сигнал 3д в 720р, а от компьютера проектор принимает же точь такой :shock:
потому как сони дура ждет когда ее подключишь к интерфейсу HDMI 1.4 и доп приставка для этого проектора как раз и делает что на входе имеет 1.4 а на выходе к проектору 1.3
Kovzel понятно, тогда ждем размножения доп. приставок, уже и вторая ласточка есть :-) http://www.viewsonic.com/ces2011/projectors.htm
чисто теоритически имея моник или телек 3D с hdmi 1.4 можно сони завести в 3D 720p режим затем преткнуть кабель в проектор и наслаждаться - геморно зато безплатно :D
Хотелось бы подробный обзор данного проектора. Уже практически решился на его покупку. Экран будет 2.5-3 метра в ширину, сможет ли данный проектор дать такую картинку без искажений? И какие очки лучше всего подойдут для игр и Blu-ray 3D? (DLP-Link или 3D Vision)
Кто уже купил, порекомендуйте проверенное место (с доставкой, а то живу в глухомани)
обзора нет, есть положительные отзовы уже от двух человек ;) . У меня экран 3 метра длинной не понимаю о каких искажениях ты спрашиваешь? На счет очков для игр однозначно нужно будет брать 3D Vision дабы задействовать стерео режим в играх.
На счет где купить я брал за 30 но там где брал доставки в регионы нет можешь взять в этой конторе http://www.pult.ru/product/54486.htm или спросить у virus1973rus где он брал.
Да мне наплели, что если маленькое расстояние от проектора до экрана, могут быть геометрические искажения картинки.
А какой экран используешь? Или просто на стену? Рассчитываю на 3 метра, но пока нашел 244мм экран за 9500р.
Как вообще картинка смотрится? Если смотреть с 3-х метров, пиксели глаза не режут?
Проектор вживую никогда не видел, и как-то не думал его брать на замену телевизору. А тут смотрю все так хвалят, вот и я тоже загорелся.
666ds Меня все устроило в данном сабже, сам начитался разных страшилок про "офисники", но решил рискнуть и не зря :dance: Картинка смотрится шикарно, 3Д это вынос мозга на таком экране. Я сам планировал брать проектор через год в новую квартиру, бюджет определил 150тыс. с экраном, а тут смотрю камрад Kovzel хвалит, да еще по характеристикам расстояния экран-проектор он подходит под нынешнюю квартиру, покупкой доволен на все сто :super:
Очки однозначно бери 3D Vision, т.к. если использовать DLP-Link очки, то в проекторе надо включать 3д режим что приводит к значительному снижению контрастности, и картинка становится не такой четкой, в случае с 3D Vision картинка гораздо лучше, но все равно чтоб убрать даже малейшие артефакты в 3Д контрастность снижаю до 25%. Заказывал я в Москве за 30т. но мне проще, у меня друг работает в Москве, на него и заказал курьером.
экран брал такой http://www.pult.ru/product/44933.htm длина рабочей поверхности 297 см -экран можно регулировать на сколь разматывать. Пиксели и с 2х метров на контенте тоесть смотря фильм игру не замечаешь, только если включить рабочий стол и начать их спецом смотреть а с 3-4х метров вообще ништяк!
Спасибо! Осталось чуть-чуть поднасобирать денег и возьму там все сразу: проектор и этот экран.
Что пиксели не видны - очень радует.
Тебе Optoma должна отчисления делать, уже второй человек с твоей подачи берет этот проектор :)
Кстати, никто не интересовался где и почем брать запасные лампы для этой модели?
