CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 448.0 MHz (1:1) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 60°C (139°F) [0x78] (CPUTIN) Temperature 0 55°C (130°F) [0x37] (CPU) Temperature 1 36°C (96°F) [0x24] (System) Temperature 2 61°C (141°F) [0x3D] (PWM) Temperature 3 0°C (32°F) [0x0] (PWM Phase 2) Temperature 4 0°C (32°F) [0x0] (PWM Phase 3) Temperature 5 0°C (32°F) [0x0] (PWM Phase 4) Temperature 6 0°C (32°F) [0x0] (PWM Phase 5) Temperature 0 60°C (139°F) [0x28] (Core #0) Temperature 3 53°C (127°F) [0x2F] (Core #3) Temperature 1 50°C (121°F) [0x32] (Core #1) Temperature 2 54°C (129°F) [0x2E] (Core #2)
нихрена Core i7 не получается вопщемто... бум искать мегапамять, чичас Corsair CMS2 6400C4, и мегакулер, чичас Big Typhoon VX, Vcore=1,3675
CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6.0 RAS# Precharge (tRP) 6.0 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 448.0 MHz (1:1) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric)
Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 60°C (139°F) [0x78] (CPUTIN) Temperature 2 60°C (139°F) [0x78] (AUXTIN) Temperature 0 55°C (130°F) [0x37] (CPU) Temperature 1 36°C (96°F) [0x24] (System) Temperature 2 61°C (141°F) [0x3D] (PWM) Temperature 3 0°C (32°F) [0x0] (PWM Phase 2) Temperature 4 0°C (32°F) [0x0] (PWM Phase 3) Temperature 5 0°C (32°F) [0x0] (PWM Phase 4) Temperature 6 0°C (32°F) [0x0] (PWM Phase 5) Temperature 0 60°C (139°F) [0x28] (Core #0) Temperature 3 52°C (125°F) [0x30] (Core #3) Temperature 1 49°C (120°F) [0x33] (Core #1) Temperature 2 54°C (129°F) [0x2E] (Core #2)
System Details -------------- Name AMD K10 Codename Specification AMD Phenom(tm) II X6 1055T Processor Core Stepping Stock frequency 3300 MHz Core Speed 3205.7 MHz (14.0 x 229.0 MHz) FID range 5.0x - 16.5x
Northbridge ATI RD770 rev. 00 Southbridge ATI SB700 rev. 00
CAS# 7.0 RAS# to CAS# 7 RAS# Precharge 7 Cycle Time (tRAS) 20 Command Rate 1T Memory Frequency 610.6 MHz (3:8) Memory Type DDR3 Memory Size 4094 MBytes Channels Dual (Unganged)
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7600)
Voltage sensor 0 1.31 Volts [0x52] (CPU VCORE) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1
Temperature sensor 0 37°C (98°F) [0x25] (TMPIN0) Temperature sensor 1 52°C (125°F) [0x34] (TMPIN1) Temperature sensor 2 80°C (175°F) [0x50] (TMPIN2) Temperature sensor 0 43°C (108°F) [0x156] (core #0) Temperature sensor 1 43°C (109°F) [0x158] (core #1) Temperature sensor 3 43°C (109°F) [0x158] (core #3) Temperature sensor 2 43°C (109°F) [0x158] (core #2) Temperature sensor 5 43°C (109°F) [0x158] (core #5) Temperature sensor 4 43°C (109°F) [0x158] (core #4) Temperature sensor 0 41°C (105°F) [0x29] (GPU Core)
_________________ AMD Phenom1055T Материнская GA-890GPA-UD3H .БП 550 W
System Details -------------- Name AMD K10 product System Product Name Codename Specification AMD Phenom(tm) II X6 1090T Processor Core Stepping Core Speed 3210.7 MHz
Northbridge AMD 790FX rev. 00 Southbridge ATI SB750 rev. 00
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 535.1 MHz (3:8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) (Build 7600)
Temperature 0 47°C (116°F) [0x2F] (TMPIN0) Temperature 1 45°C (112°F) [0x2D] (TMPIN1) Temperature 0 37°C (97°F) [0x124] (Core #0) Temperature 1 37°C (97°F) [0x124] (Core #1) Temperature 2 36°C (97°F) [0x122] (Core #2) Temperature 3 36°C (96°F) [0x120] (Core #3) Temperature 4 36°C (97°F) [0x122] (Core #4) Temperature 5 36°C (96°F) [0x120] (Core #5)
_________________ Гробы разработчиков надо делать круглыми, чтоб переворачиваться было удобно!
System Details -------------- Name AMD Phenom II X3 550 Codename Heka Specification AMD Phenom(tm) FX-5000 Quad-Core Processor Core Stepping RB-C2 Technology 45 nm Stock frequency 2200 MHz Core Speed 2937.1 MHz FID range 5.0x - 11.0x
Northbridge ATI RD770 rev. 00 Southbridge ATI SB750 rev. 00
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 13 Command Rate (CR) 2T Memory Frequency 445.0 MHz (3:5) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Unganged)
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
Number of processors 1 Number of threads 3 Number of threads 3 (max 3) L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1
Temperature 0 40°C (103°F) [0x28] (SYSTIN) Temperature 1 52°C (125°F) [0x68] (CPUTIN) Temperature 2 35°C (94°F) [0x46] (AUXTIN) Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2)
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 510.0 MHz (5:6) Memory Type DDR2 Memory Size 6144 MBytes Channels Dual, (Symmetric)
Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 36°C (96°F) [0x24] (SYSTIN) Temperature 1 41°C (105°F) [0x52] (CPUTIN) Temperature 2 18°C (63°F) [0x23] (AUXTIN) Temperature 0 65°C (148°F) [0x23] (Core #0) Temperature 1 63°C (145°F) [0x25] (Core #1) Temperature 2 57°C (134°F) [0x2B] (Core #2) Temperature 3 54°C (129°F) [0x2E] (Core #3)
_________________ --- The place where gods come to die. ---
CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 2T Memory Frequency 299.8 MHz (1:1) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric)
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0)
Temperature 0 39°C (102°F) [0x27] (SYSTIN) Temperature 1 70°C (157°F) [0x8B] (CPUTIN) Temperature 2 114°C (236°F) [0xE3] (AUXTIN) Temperature 0 72°C (161°F) [0x1C] (Core #0) Temperature 1 75°C (166°F) [0x19] (Core #1)
Слабовато, хотя и не так уж плохо для старенького двухядерника. Насколько я вижу, толку от гипер-трейдинга в этом тесте никакого, и смысла брать i7 вместо i5 ориентируясь на кодирование видео нет?
Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1156 LGA (0x1)
Temperature 0 30°C (85°F) [0x1E] (TMPIN0) Temperature 0 79°C (174°F) [0x14] (Core #0) Temperature 1 74°C (165°F) [0x19] (Core #1) Temperature 2 71°C (159°F) [0x1C] (Core #2) Temperature 3 72°C (161°F) [0x1B] (Core #3)
Windows Version Microsoft Windows Server 2008 Service Pack 2 (Build 6002)
Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 45°C (112°F) [0x2D] (SYSTIN) Temperature 1 60°C (139°F) [0x78] (CPUTIN) Temperature 2 125°C (256°F) [0xF9] (AUXTIN) Temperature 0 50°C (121°F) [0x33] (Core #0) Temperature 1 58°C (136°F) [0x2B] (Core #1) Temperature 2 56°C (132°F) [0x2D] (Core #2) Temperature 8 46°C (114°F) [0x37] (Core #8) Temperature 9 54°C (129°F) [0x2F] (Core #9) Temperature 10 52°C (125°F) [0x31] (Core #10)
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 475.0 MHz (1:1) Memory Type DDR2 Memory Size 6144 MBytes Channels Dual, (Symmetric)
Temperature 0 35°C (94°F) [0x23] (SYSTIN) Temperature 1 39°C (101°F) [0x4D] (CPUTIN) Temperature 2 19°C (66°F) [0x26] (AUXTIN) Temperature 0 47°C (116°F) [0x35] (Core #0) Temperature 1 42°C (107°F) [0x3A] (Core #1) Temperature 2 41°C (105°F) [0x3B] (Core #2) Temperature 3 41°C (105°F) [0x3B] (Core #3)
CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 1T Memory Frequency 802.7 MHz (1:4) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged)
Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1
Temperature 0 48°C (118°F) [0x30] (CPU) Temperature 1 45°C (112°F) [0x2D] (Mainboard) Temperature 0 37°C (98°F) [0x126] (Core #0) Temperature 1 37°C (98°F) [0x128] (Core #1) Temperature 2 37°C (98°F) [0x126] (Core #2) Temperature 3 37°C (98°F) [0x128] (Core #3) Temperature 4 37°C (98°F) [0x127] (Core #4) Temperature 5 37°C (98°F) [0x128] (Core #5)
Temperature 0 43°C (109°F) [0x2B] (SYSTIN) Temperature 1 65°C (148°F) [0x82] (CPUTIN) Temperature 2 125°C (256°F) [0xF9] (AUXTIN) Temperature 0 55°C (130°F) [0x2E] (Core #0) Temperature 1 64°C (147°F) [0x25] (Core #1) Temperature 2 58°C (136°F) [0x2B] (Core #2) Temperature 8 50°C (121°F) [0x33] (Core #8) Temperature 9 52°C (125°F) [0x31] (Core #9) Temperature 10 58°C (136°F) [0x2B] (Core #10)
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 12 Command Rate (CR) 2T Memory Frequency 460.0 MHz (1:1) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Symmetric)
Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 30°C (85°F) [0x1E] (SYSTIN) Temperature 1 50°C (121°F) [0x64] (CPUTIN) Temperature 2 26°C (77°F) [0x33] (AUXTIN) Temperature 0 64°C (147°F) [0x24] (Core #0) Temperature 1 55°C (130°F) [0x2D] (Core #1) Temperature 2 54°C (129°F) [0x2E] (Core #2) Temperature 3 57°C (134°F) [0x2B] (Core #3)
зы h264.exe заменен на последнюю версию - 1732 на оригинальном exe фпс был 84\24 соответственно.
System Details -------------- Name AMD K10 Codename Specification AMD Phenom(tm) II X6 1055T Processor Core Stepping manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3300 MHz Core Speed 4172.1 MHz FID range 5.0x - 16.5x
Northbridge AMD 790X rev. 00 Southbridge ATI SB750 rev. 00
CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 20 Command Rate (CR) 1T Memory Frequency 794.7 MHz (3:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged)
Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 ============== #77 как бы два результата, остальное идинтично. Можете равняЦЦа на любой
System Details -------------- Name AMD Phenom FX-5000 Codename Deneb Specification AMD Phenom(tm) FX-5000 Quad-Core Processor Core Stepping RB-C2 Technology 45 nm Stock frequency 2200 MHz Core Speed 2860.0 MHz FID range 4.0x - 11.0x
Northbridge ATI 770 rev. 00 Southbridge AMD SB700 rev. 00
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 520.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1, v.178 (Build 7601)
Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1
Temperature 0 31°C (87°F) [0x1F] (SYSTIN) Temperature 1 56°C (131°F) [0x6F] (CPUTIN) Temperature 2 39°C (101°F) [0x4D] (AUXTIN) Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) Temperature 3 0°C (32°F) [0x0] (Core #3)
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 496.3 MHz (4:5) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric)
Temperature 0 35°C (94°F) [0x23] (SYSTIN) Temperature 1 40°C (103°F) [0x50] (CPUTIN) Temperature 2 29°C (83°F) [0x39] (AUXTIN) Temperature 0 66°C (150°F) [0x22] (Core #0) Temperature 1 63°C (145°F) [0x25] (Core #1) Temperature 2 55°C (130°F) [0x2D] (Core #2) Temperature 3 58°C (136°F) [0x2A] (Core #3)
CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 460.0 MHz (1:1) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric)
Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x0)
Temperature 0 40°C (103°F) [0x28] (SYSTIN) Temperature 1 54°C (129°F) [0x6C] (CPUTIN) Temperature 2 122°C (250°F) [0xF3] (AUXTIN) Temperature 0 52°C (125°F) [0x30] (Core #0) Temperature 1 54°C (129°F) [0x2E] (Core #1)
Результат просто поразил. Мало того, что x64 версия показала железобетонную стабильность (результаты сходятся до сотых долей), чего нельзя сказать про x86 реализацию, так она еще и выиграла дополнительные 4-5% (что в свою очередь позволит уменьшить продолжительность 2-го прохода на 1-2 часа при кодировании FullHD контента). P.S. Первому проходу внимания особо не уделяю поскольку он занимает гораздо меньше времени, да и производительность похоже здесь была ограничена использовавшимся 64-битным фреймсервером. Кому интересно могу поделиться x64 бенчмарком.
Статус: Не в сети Регистрация: 27.10.2010 Откуда: НН обл
По многочисленным просьбам в ЛС выкладываю 64-битный вариант x264 Benchmark. Для запуска используйте bench_script x64.bat Жду Ваших результатов, а так же отзывов и замечаний.
