Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 389 • Страница 16 из 20<  1 ... 13  14  15  16  17  18  19  20  >
Фото: 34
6a3apoB
интелы разные бывают ;)
FX 8120@4.8 GHz
pass1 set /AFFINITY 55
x264 r2106(64bit)
x264 HD BENCHMARK 4.0 RESULTS
Please do NOT compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
to http://forums.techarp.com/reviews-artic ... 4-0-a.html
Results for x264.exe r1913
Pass 1
encoded 1442 frames, 152.96 fps, 3912.58 kb/s
encoded 1442 frames, 151.83 fps, 3912.58 kb/s
encoded 1442 frames, 151.50 fps, 3912.58 kb/s
encoded 1442 frames, 152.29 fps, 3912.58 kb/s
Pass 2
encoded 1442 frames, 52.36 fps, 3965.22 kb/s
encoded 1442 frames, 52.32 fps, 3964.98 kb/s
encoded 1442 frames, 52.32 fps, 3965.29 kb/s
encoded 1442 frames, 52.23 fps, 3965.56 kb/s
System Details
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name Radeon HD 5850
Name Radeon HD 5850
Name Radeon HD 5850
Name Radeon HD 5850
Codename
Codename
Codename
Codename
Codename
Codename
Codename
Codename
Codename RV870
Codename RV870
Codename RV870
Codename RV870
Specification AMD FX(tm)-8120 Eight-Core Processor
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Technology 40 nm
Technology 40 nm
Technology 40 nm
Technology 40 nm
Core Speed 4840.4 MHz
Core Speed 4840.5 MHz
Core Speed 4840.7 MHz
Northbridge AMD 890FX rev. 02
Southbridge AMD SB850 rev. 40
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 11
Cycle Time (tRAS) 29
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
Number of processors 8
Number of threads 8
Number of threads 1 (max 1)
L2 cache 2048 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP
Package
Package
Package
Package
Package
Package
Package
Package
Temperature 0 36°C (96°F) [0x24] (CPU)
Temperature 1 46°C (114°F) [0x2E] (TMPIN1)
Temperature 2 22°C (71°F) [0x16] (System)
Temperature 0 29°C (84°F) [0x1D] (TMPIN0)
Pass 1
Pass 2
MythBuster (с) HertZ
6a3apoB писал(а):
где-то на 6 Ггц догонит интел :writer:
Если посмотрите результаты выше, то FX-8150 4,5GHz обгоняет 2500K 5GHz на втрором проходе. Первый проход всего лишь оценочный, а вот второй уже непосредственно кодирование видео.
Гробы разработчиков надо делать круглыми, чтоб переворачиваться было удобно!
Статус: В сети
парни не поделитесь ссылочкой на версию х64, а то только на х32 натыкаюсь
Alexandr82 угу круто 8 ядер опередили 4 несколько фпс :haha:
Ryzen 7 9700X / MSI X670E GAMING PLUS WIFI / 32Gb Ram /Palit GeForce RTX 5070 Ti GameRock
У процессоров Intel два потока на ядро, так что он формально тоже восьмиядерный
Статус: В сети
Alexandr82 а вы случаем 2500к с 2600к не путаете? или может ссылочкой поделитесь?
Действительно перепутал. Но не принципиально, FX-8150 скорее по маркетинговым соображениям восьмиядерный, а фактически он скорее четырехядерный с двумя потоками на ядро.
i7-2600K @4505MHz
Pass 1
encoded 1442 frames, 186.72 fps, 3911.63 kb/s
encoded 1442 frames, 184.35 fps, 3911.63 kb/s
encoded 1442 frames, 174.51 fps, 3911.63 kb/s
encoded 1442 frames, 182.02 fps, 3911.63 kb/s
Pass 2
encoded 1442 frames, 46.30 fps, 3960.00 kb/s
encoded 1442 frames, 46.20 fps, 3959.15 kb/s
encoded 1442 frames, 45.88 fps, 3959.73 kb/s
encoded 1442 frames, 46.14 fps, 3959.62 kb/s
System Details
Name Intel Core i7 2600K
Name Intel HD Graphics 3000 (GT2+)
Name AMD Radeon HD 6900 Series
Codename Sandy Bridge
Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
Core Stepping D2
Technology 32 nm
manufacturer Gigabyte Technology Co., Ltd.
vendor Gigabyte Technology Co., Ltd.
Technology 32 nm
Stock frequency 3400 MHz
Core Speed 4504.7 MHz
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel Z68 rev. B3
CAS# latency (CL) 10.0
Cycle Time (tRAS) 34
Command Rate (CR) 1T
Memory Frequency 1067.8 MHz (1:8)
Memory Type DDR3
Memory Size 16384 MBytes
Channels Dual
Number of processors 1
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
Package (platform ID) Socket 1155 LGA (0x1)
Temperature 0 23°C (73°F) [0x17] (TMPIN0)
Temperature 1 25°C (77°F) [0x19] (TMPIN1)
Temperature 2 30°C (86°F) [0x1E] (TMPIN2)
Temperature 0 33°C (91°F) [0x21] (TMPIN0)
Добавлено спустя 2 часа 4 минуты 37 секунд:
i7-2600K @4505MHz_x264 Video Codec rev. 2106
Pass 1
encoded 1442 frames, 185.25 fps, 3912.35 kb/s
encoded 1442 frames, 181.86 fps, 3912.35 kb/s
encoded 1442 frames, 183.51 fps, 3912.35 kb/s
encoded 1442 frames, 183.98 fps, 3912.35 kb/s
Pass 2
encoded 1442 frames, 47.46 fps, 3966.84 kb/s
encoded 1442 frames, 48.06 fps, 3966.71 kb/s
encoded 1442 frames, 47.91 fps, 3966.64 kb/s
encoded 1442 frames, 47.72 fps, 3967.72 kb/s
System Details
Core Stepping D2
Technology 32 nm
Technology 32 nm
Core Speed 4504.5 MHz
Memory Type DDR3
Channels Dual
Number of threads 8
Temperature 0 28°C (82°F) [0x1C] (TMPIN0)
Temperature 2 38°C (100°F) [0x26] (TMPIN2)
Temperature 0 36°C (95°F) [0x23] (TMPIN0)
Фото: 12
FX 8120@4.8 GHz
и у 2600К@4.5
10% преимущества у буля, на одной частоте паритет примерно, версия бенча одна, что тут про слив BlinkSGA говорил?
cypher1999 писал(а):Я офтоп и доволен как 🐘
Статус: В сети
Lorichic слепой фанатов или как? 4.8 у булыжник и 4.5 у санди, полюбому частота одна :lol:
i7-2600K @4811MHz
Pass 1
encoded 1442 frames, 185.66 fps, 3912.35 kb/s
encoded 1442 frames, 199.14 fps, 3912.35 kb/s
encoded 1442 frames, 197.18 fps, 3912.33 kb/s
encoded 1442 frames, 185.75 fps, 3912.35 kb/s
Pass 2
encoded 1442 frames, 51.06 fps, 3967.29 kb/s
encoded 1442 frames, 51.16 fps, 3967.65 kb/s
encoded 1442 frames, 51.20 fps, 3966.19 kb/s
encoded 1442 frames, 51.04 fps, 3966.76 kb/s
System Details
Core Stepping D2
Technology 32 nm
Technology 32 nm
Core Speed 4810.9 MHz
RAS# Precharge (tRP) 10
Memory Frequency 1069.1 MHz (1:8)
Memory Type DDR3
Channels Dual
Number of threads 8
Temperature 2 35°C (95°F) [0x23] (TMPIN2)
Temperature 0 29°C (83°F) [0x1C] (TMPIN0)
AMD FX-8150 - кодирование видео - http://www.u-sm.ru/index.php/obzoryi-i- ... 8-v-1.html
Последний раз редактировалось T2VOVIK 02.12.2011 21:02, всего редактировалось 1 раз.
Статус: В сети
о фигасе разница 1фпс, круто хотя еще давно было выяснено что буль себя проявляется в кодирование видео и архиваторах, а у нас я думаю все целыми днями этим и занимаются
Фото: 12
Что с глазами? :?: я так и написал FX 8120@4.8 GHz & 2600К@4.5, буль быстрее на 10%, а при равной частоте будет
Lorichic писал(а):
паритет примерно
i7-2600K @4814MHz_x264 Video Codec rev. 2106,32bit
Pass 1
encoded 1442 frames, 205.00 fps, 3912.35 kb/s
encoded 1442 frames, 207.39 fps, 3912.35 kb/s
encoded 1442 frames, 204.45 fps, 3912.35 kb/s
encoded 1442 frames, 209.78 fps, 3912.35 kb/s
Pass 2
encoded 1442 frames, 52.23 fps, 3966.80 kb/s
encoded 1442 frames, 52.34 fps, 3966.07 kb/s
encoded 1442 frames, 52.23 fps, 3966.08 kb/s
encoded 1442 frames, 52.36 fps, 3965.70 kb/s
System Details
Core Stepping D2
Technology 32 nm
Technology 32 nm
Core Speed 4814.5 MHz
Memory Frequency 1069.9 MHz (1:8)
Memory Type DDR3
Channels Dual
Number of threads 8
Temperature 0 27°C (80°F) [0x1B] (TMPIN0)
Temperature 2 39°C (102°F) [0x27] (TMPIN2)
Temperature 0 34°C (93°F) [0x22] (TMPIN0)
x264_64_r2106\2600k-4600MHz
Please do not compare it with older versions of the benchmark!
Results for x264_64.exe r2106
encoded 1442 frames, 190.99 fps, 3912.35 kb/s
encoded 1442 frames, 192.19 fps, 3912.35 kb/s
encoded 1442 frames, 191.40 fps, 3912.35 kb/s
encoded 1442 frames, 189.79 fps, 3912.35 kb/s
encoded 1442 frames, 52.20 fps, 3964.64 kb/s
encoded 1442 frames, 52.13 fps, 3965.75 kb/s
encoded 1442 frames, 52.43 fps, 3966.86 kb/s
encoded 1442 frames, 52.43 fps, 3966.21 kb/s
System Details
product System Product Name
Specification PC3-16000
Core Stepping D2
Technology 32 nm
Core Speed 4600.7 MHz
Southbridge Intel ID1C44 rev. 05
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Command Rate 2T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 800.2 MHz (1:6)
Memory Type DDR3
Number of threads 8
Temperature 0 26°C (78°F) [0x1A] (SYSTIN)
Temperature 1 0°C (32°F) [0x0] (CPUTIN)
Temperature 2 64°C (147°F) [0x80] (AUXTIN)
x264_64_r2106\2600k-4800MHz
encoded 1442 frames, 199.64 fps, 3912.35 kb/s
encoded 1442 frames, 198.35 fps, 3912.35 kb/s
encoded 1442 frames, 198.79 fps, 3912.35 kb/s
encoded 1442 frames, 195.02 fps, 3912.35 kb/s
encoded 1442 frames, 54.70 fps, 3965.58 kb/s
encoded 1442 frames, 54.66 fps, 3966.02 kb/s
encoded 1442 frames, 54.73 fps, 3965.54 kb/s
encoded 1442 frames, 54.57 fps, 3966.32 kb/s
System Details
Core Stepping D2
Technology 32 nm
Core Speed 4800.6 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 800.1 MHz (1:6)
Memory Type DDR3
Number of threads 8
Temperature 0 27°C (80°F) [0x1B] (SYSTIN)
Pass 1
encoded 1442 frames, 149.66 fps, 3911.63 kb/s
encoded 1442 frames, 150.36 fps, 3911.63 kb/s
encoded 1442 frames, 147.75 fps, 3911.63 kb/s
encoded 1442 frames, 149.21 fps, 3911.63 kb/s
Pass 2
encoded 1442 frames, 36.23 fps, 3959.51 kb/s
encoded 1442 frames, 36.50 fps, 3958.91 kb/s
encoded 1442 frames, 28.18 fps, 3959.61 kb/s
encoded 1442 frames, 27.37 fps, 3959.69 kb/s
System Details
Добавлено спустя 2 часа 57 минут 56 секунд:
Более точная информация..
Pass 1
encoded 1442 frames, 150.35 fps, 3911.63 kb/s
encoded 1442 frames, 151.45 fps, 3911.63 kb/s
encoded 1442 frames, 152.82 fps, 3911.63 kb/s
encoded 1442 frames, 150.92 fps, 3911.63 kb/s
Pass 2
encoded 1442 frames, 36.96 fps, 3959.87 kb/s
encoded 1442 frames, 36.49 fps, 3959.00 kb/s
encoded 1442 frames, 32.49 fps, 3960.31 kb/s
encoded 1442 frames, 27.73 fps, 3960.25 kb/s
System Details
Name Intel Core i7 870
Codename Lynnfield
Specification Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
Specification PC3-12800
Core Stepping B1
Technology 45 nm
Stock frequency 2933 MHz
Core Speed 3960.0 MHz
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel H55 rev. 06
RAS# to CAS# delay (tRCD) 10
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 2T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 900.0 MHz (2:10)
Memory Type DDR3
Memory Size 8192 MBytes
Channels Dual
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of threads 8
Package (platform ID) Socket 1156 LGA (0x1)
Temperature 0 29°C (84°F) [0x1D] (SYSTIN)
Temperature 1 49°C (119°F) [0x61] (CPUTIN)
Temperature 2 65°C (148°F) [0x81] (AUXTIN)
Intel i5-2500K,Thermalright HR-02 Macho@ 4.3 Ghz,GA-Z77-D3H,ZOTAC GeForce® GTX 670 AMP! Edition ,DIMM DDR3 1866MHz Samsung 8Gb,Chieftec APS-850 C.
Статус: В сети
Gremlin51 а это типа мои цитаты? :?:
x264_64_r2106\2600k-5000MHz
encoded 1442 frames, 204.05 fps, 3912.35 kb/s
encoded 1442 frames, 203.59 fps, 3912.35 kb/s
encoded 1442 frames, 202.70 fps, 3912.35 kb/s
encoded 1442 frames, 202.24 fps, 3912.35 kb/s
encoded 1442 frames, 57.06 fps, 3966.01 kb/s
encoded 1442 frames, 56.92 fps, 3964.63 kb/s
encoded 1442 frames, 56.88 fps, 3965.95 kb/s
encoded 1442 frames, 56.96 fps, 3965.85 kb/s
System Details
Core Stepping D2
Technology 32 nm
Core Speed 5000.9 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Type DDR3
Windows Version Microsoft Windows Server 2008 R2 Datacenter Edition (Full) Service Pack 1 (Build 7601)
Number of threads 8
x264 FHD Benchmark v1.0.1 64bit.
980@4.4 / 24Gb Corsair Vengeance 1600(8-9-8-24-1T) Uncore 3.2GHz
Mind is our power... Speed is our force...(c)
Фото: 34
FX 8120@4.8 / CPU-NB@2.76/ RAM Samsung 1333@1840/10-10-10-30/CR1:
25.09 fps / 1 m :39 c.
