Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 41 • Страница 1 из 3 • 1  2  3  >
собственно, исходя из названия темы, цель добиться стабильности Prime, LinX, ну и в целом при 500 шине.
настройки следующие:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .................: Auto
CPU Clock Ratio .........................: 8x
Fine CPU Clock Ratio.....................: +5
CPU Frequency ...........................: 4.25GHz
********** Clock Chip Control ************
>>>>> Standard Clock Control
CPU Host Clock Control...................: Enabled
CPU Host Frequency (Mhz) ................: 500
PCI Express Frequency (Mhz) .............: 100
C.I.A.2 .................................: Disabled
>>>>> Advanced Clock Control [Press Enter]
CPU Clock Drive..........................: 800mV
PCI Express Clock Drive..................: 900mV
CPU Clock Skew (ps)......................: 0ps
MCH Clock Skew (ps)......................: 0ps
********** DRAM Performance Control ******
Performance Enhance......................: Standard
(G)MCH Frequency Latch...................: 333
System Memory Multiplier ................: 2.00B
Memory Frequency (Mhz) ..................: 1000
DRAM Timing Selectable ..................: Manual
Standard Timing Control
CAS Latency Time.........................: 5
tRCD ....................................: 5
tRP'.....................................: 5
tRAS.....................................: 18
остальное - auto
********** Motherboard Voltage Control ***
>>>>> CPU
Load-Line Calibration....................: Enabled
CPU Vcore................................: 1.4250
CPU Termination..........................: 1.40
CPU PLL..................................: 1.61
CPU Reference............................: 0.886
>>>>> MCH/ICH
MCH Core.................................: 1.40
MCH Reference............................: 0.886
MCH/DRAM Reference.......................: 1.000
ICH I/O..................................: 1.61
ICH Core.................................: 1.20
>>>>> DRAM
DRAM Voltage.............................: 2.00
DRAM Termination.........................: 1.00
Channel A Reference......................: 1.00
Channel B Reference......................: 1.00
Advanced Settings
Limit CPUID Max. to 3....................: Disabled
No-Execute Memory Protect................: Disabled
CPU Enhanced Halt (C1E)..................: Disabled
C2/C2E State Support.....................: Disabled
C4/C4E State Support.....................: Disabled
CPU Thermal Monitor 2(TM2) ..............: Disabled
CPU EIST Function........................: Disabled
Virtualization Technology................: Disabled
с такими настройками система грузится вплоть до 520Mhz по шине, а вот абсолютная стабильность проявляется только при 495 Mhz.
ребятки, что нужно/можно покрутить чтобы и на 500 Mhz все было типтоп? дело в том, что после 495 шины никакие крутилки и танцы не помогают прыгнуть даже на 1 Mhz выше. а вот 495-ую можно подобрать вполне рабочую вплоть до снижения вольтажей в районе 1,30-1,35 вольт CPU/FSB/NB.
q9650, giga ep45-ud3r, 8gb, Corsair 750W, GTX 570
мать нужна хорошая.
born9
:-) ты прикололся? Gigabyte EP45-UD3R или P - это лучшее, что когда-либо было создано на Р45-чипсете для разгона квадов!!!
Фото: 22
CPU Termination подними до 1,45 В, и CPU PLL подними до 1,8 В. Ну и на сам процессор желательно чуть приподнять напряжение.
Последний раз редактировалось bibukov 29.07.2013 0:13, всего редактировалось 1 раз.
bibukov
CPU Term подымал до 1.6, PLL тоже до 1.8, на проц кидал тоже 1.6 - не помогает. :-(
Последний раз редактировалось Intenso 29.07.2013 0:14, всего редактировалось 1 раз.
Фото: 22
CPU Termination подымай и на сам камень поболе.
bibukov
ну куда ещё-то? :roll: у людей при 1.3 хреначит тесты на ура.
Фото: 22
ну не 500 по шине! Ты итак уже стену FSB Wall долбишь. :bandhead:
bibukov
я понимаю wall когда система далее не грузится совсем, ну а у меня 520 по шине спокойно при вышеуказанных настройках легко берет.
Фото: 22
Одно дело берёт, а другое дело стабильно работает. Это разные вещи. Если ты упираешься в стену, то ничего не остается как откатиться назад на заведомо стабильные параметры.
bibukov
а может стена связана как-то с оперативой? хотя она у меня при 1.9 должна держать 1100Мгц, т.е 550 по шине
Intenso писал(а):
bibukov
я выставлял 2.1 вольт на своей DDR2, тем более моя полудохлая P5B... вообще даже не нагревались планки. Правда тогда С2D стоял, щас на кваде 9500 всё в дефолте, немогу обуздать его TDP, нет нормального кулера а купить .. нехочу трать ни копейки на этот старый металлолом.
Фото: 22
выстави при повышенном делителе и пониженной шине, и проверь через TestMem5.
Добавлено спустя 9 минут 26 секунд:
Вот тебе ещё пища для размышления. Никто там 500+ на 24/7 не ставит, ибо это анрил. Я сам в своё время пытал Q6600 на разных матерях. 500 брал на Asus P5Q, но стабильностью там даже близко не пахло. Реально на этой маман было держать 475 на воде.
Фото: 18
FSB - 500, с квадом, с 8ГБ памяти? Да нууу, анрил.
Можно попробовать оставить 4ГБ памяти и, если что-нибудь получится, то значит 8ГБ контроллер памяти не тянет на такой частоте
оставлял... даже одну плашку 2Гб только - нихрена не держит стабильно.
Фото: 22
Intenso и не будет. 500 FSB-это только для бенчей. В реале 450-норма для квадов. Там и напряжения особор завышать не надо. Так что успокойся и не мучай камень.
В теме квадов йорков кто-то гнал за 500, со стабильностью, на какой-то гиге вроде.
Фото: 58
neemestniii
наверно проц хороший и мать удачная попались...
Запахло рывком.....
Наверное, но там был ньюанс, как подтверждение стабильности был выложен скрин линпака, куча проходов, с использованием хорошего объема памяти, 64 бита, все круто и стабильно, но вот цифры флопсов были такиеже как и на моем кваде на примерно 200 мегагерц меньшей частоте.
И я не помню, был ли большой прогон прайма.
Да фигня все это: ты можешь сколь угодно эти праймы гонять, а при холодном старте получить болт. В этом всю фишка.
cron
