Статус: Не в сети Регистрация: 07.06.2013 Откуда: Русь Фото: 3
Litoy.88, да, Десятка. попробуй отключить обязательную проверку цифровых подписей.
Litoy.88 писал(а):
чуть старее драйвер
а теперь смотрим ченджлог.
Revision History
1.2.001.0349
- Change default value for AmdSataSWSP as enabled - Change default value for AHCI Link Power Management in Balanced power plan as HIPM+DIPM
1.2.001.0337
- Fix: Device Sleep bug
1.2.001.0335
- Fix: 4K native sector size support
1.2.001.0331
- Fix: System hang-up on some BIOS implementations (BUG323874)
1.2.001.0329
- Win7 to Win8 update failure fix (BSOD 0x BE)
Revision History: -----------------
1.3.001.0276 (02/15/2017)
- Added Server OS Support for Zeppelin.
1.3.001.0276
- Fix the CPU high utilization issue when CCC enable
1.3.001.270
- [CZ] Fix SATA PHY PLL not powered down after S3 resume - Work around Bastrop hardware issue for slumber exit fail and cause BSOD - [CZ] Fix SATA PHY PLL not powered down when ZPODD connected
1.3.001.266
- Work around Carrizo hardware issue for slumber exit fail and cause BSOD - Fix OS loading screen hang if skip password of hard disk, skip load security locked hard disk
1.3.001.0245
- Fix the SB700 A12 boot hang issue if PM is enabled - Enable MSI + CCC as one option - Fix the long timer DPC WHCK failure for WNGlitchfree HD Video Playback on AC - Add DID for KernCZ
1.3.001.0220
- Fix BSOD issue with new SSHD
1.3.001.0211
- Fix Devices Behind PMP fails to detect upon one device eject
1.3.001.0166
- Add the runtime D3 support - Default AHCI LPM setting in balanced power plan is set as HIPM + DIPM in DC mode and HIPM in AC mode to improve battery backup and also reserve performance if there is power plugged in - Fix the S4 BSOD 0xD1 - Fix ZPODD disappear issue when doing a eject
1.3.001.0156
- Change default value for AmdSataSWSP as enabled - Change default value for AHCI Link Power Management in Balanced power plan as HIPM+DIPM - Fix Perforce build warnings - Fix file encoding format
1.3.001.0068
- Fix BitLocker WHCK test failures with SSDs bug - Fix Error message when run Standby Critical Focus bug
1.3.001.0054
- Fix Device Sleep bug - Fix eSata plug-out bug
1.3.001.050
- Optimized S4-Hints function - Set FUA to 0 as default - Device sleep function
1.3.001.048
- Fix ZPODD-go to sleep pending issue
1.3.001.044
1.3.001.043
- VPD_ATA_INFORMATION implementation
1.3.001.0041
- Initial release
_________________ Україна - рідна мати, Не вкрадеш - не будеш мати. Я в Steam - http://steamcommunity.com/id/free_user/
Заблокирован Статус: Не в сети Регистрация: 25.08.2018
Кто нибудь есть хорошо знающий схему сайбера р2.0? Произошел казус при установке кулера IH-4700,пластиковый квадрат(на задний бекплейт) даванул сопративление(может конечно и не сопротивление это ),и оно обломилось(корявые китайцы,с размером ошиблись ) лучше бы сразу без этой вставки поставил,до контактов там далеко! так вот за что отвечает эта деталь?
Статус: Не в сети Регистрация: 07.06.2017 Откуда: Оренбург Фото: 203
Добавлено спустя 3 минуты 16 секунд:
Тоже самое было, но при установке бакпейта от Мачо, повезло что нашел этот маленький транзистор или чё там))) отнёс к мастеру сотовых телефонов, он за 100р припаял и всё. Мне гововорили что без неё пробуй включать, но я не рискнул.
Когтехват в схеме от ih4700 указано,что нужна. Система работает,но слоты pci-e х16 не работают,система не может инициализировать видео,максимум что смог,попасть в биос. Воткнул в коричневый pci-e вроде работает,но скорость х4 v1.1 Мелким паяльником вроде припаял,но чего-то не Але. Сегодня поеду к знакомому на паяльную стануию
S_Snake до смены охлада все работало,плату вроде не гнул. Собирал уже и в корпусе и на столе,не помогло. Не работают только серые pci-e. Когда втыкаю в серый,при включении на материнка герлянда,драм лед,цпу лед моргают по переменке,потом загорается гпу(или вга) лед(и горит) при этом спикер пищит 1длинный 3коротких. И загорается Бут девайс. Изображение не выводилось. Нажал сброс памяти,попал в биос,скинул все на дефолт,система запустилась,но после перезагрузки такая же ботва. Теперь даже после сброса не запускается
Сейчас этот форум просматривают: eugene159 и гости: 16
