Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 212 • Страница 1 из 11 • 1  2  3  4  5 ... 11  >
Коллеги! Хочу предложить Вашему вниманию первую МВ от EPoX на 965 чипсете: EPoX EP-5P965+ GLi
Анонсирована совсем недавно – 14.11.2006:
http://www.epox.com.tw/eng/news_content.php?serno=56
http://www.epox.com.tw/eng/products_content.php?ps=449
Спецификация:
Intel P965 + ICH8R chipset, ATX size
FSB1066 / DDR2 800 / 8ch audio / 10 USB2.0 / PCI-E VGA / GbE LAN / 6 SATA II
CPU Socket:
Socket LGA775 for Intel Quad Core processor Q6000 series
Support Intel Core 2 Duo processor E6000/ E4000 series
Support Intel Dual core Pentium D 8xx/9xx series up to 3.6GHz
Support Intel Single core Celeron-D 3xx series, Pentium-4 5xx/6xx series, P4EE up to 3.8GHz
Support 533/800/1066 MHz front-side bus
Support Intel CPU manufactured in 65nm process.
Chipset:
Intel P965 + ICH8R (EP-5P965+ GLI only)
System Memory:
Four 240-pin DDR2 SDRAM DIMM sockets
Support 1.8v DDR2-533/667/800 DIMMs with dual channel architecture
Support single-sided or double-sided, non-ECC, DIMMs with 256Mb/512Mb/1Gb devices
Support up to 8GB system memory
Expansion Slots:
Three PCI connectors compliant with PCI v2.3
One PCI-Express (x1) connectors compliant with PCI Express 1.0a
One PCI Express (x16) connector compliant with PCI Express 1.0a
One PCI Express (x4) connector for extra PCI-E VGA in GLI (Graphics Link Interface) mode
EZ-IDE:
Two IDE interface (for 2 device) from onboard SiI3811A SATA-IDE converter for driver-free IDE
USB:
Ten USB connectors compliant with USB2.0 from embedded USB controller (4 connectors at rear panel)
S-ATA:
Six S-ATA II ports with up to 300MB/s bandwidth from ICH8R (EP-5P965+ GLI only)
LAN:
One Gb Ethernet from Realtek RTL8111B PCI-E (x1) controller
Audio:
Selectable 2, 6 or 8-CH audio from Realtek ALC883 HDA compliant CODEC
Support rear panel SPDIF Optical output.
Support Aux-In, CD-In
Support Front panel audio for Mic-In and stereo Line-out only.
(Front panel Line-out electrically shared with rear panel Line-out).
Support Jack detection for fool-proof audio device installation
I/O:
Onboard EPOX EP1308 LPC bus I/O controller
Legacy peripheral interface for PS/2 keyboard & mouse, FDD, Parallel, One Serial and IrDA (v1.0 compliant)
Support Hardware Monitoring for fan speed monitoring, CPU and System temperature.
Intelligent fan speed control for CPU-fan (PWM) for quiet operation
BIOS:
4Mb Flash EEPROM with Award Plug&Play BIOS
Support EZ Boot for fast bootable device selection
Support Magic Health for system hardware status report during system boot-up
Special Features:
Support KBPO (Keyboard Power ON) function
Support Wake-On-LAN by PME
Support Ghost BIOS for BIOS recovery
Support Thermo Stick digital thermometer
Onboard EZ-Button for convenient power-on
Support Asynchronous clocking mode between FSB and PCI/PCI-E
PowerBIOS for excellent overclocking features:
Programmable FSB and PCI Clock output frequency with 1MHz fine tuning
Support BIOS adjustable CPU multiplier, FSB clock, PCI-E x16 clock, DIMM frequency
Support BIOS adjustable voltage for CPU Core, chipset and DIMM
Powerful utilities for Windows:
Thunder Probe diagnostic utility for system hardware monitoring
Magic Flash for BIOS update without requiring DOS flash utility and bootable diskette
Magic Screen for personal bootup screen design
Form Factor:
305mm x 245mm x 40mm, ATX Size
Supported O/S:
Windows 2000/Windows XP
Accessories
User¡¦s manual
1 IDE cable & 1 FDD cables;
S-ATA data and power cables;
EZ-IDE cables
CD for drivers, utilities and bundle software
IO shield
В начале декабря должна появиться в продаже (мне ее обещали к 10 декабря…), поэтому, думаю, возможно, предварительно обсудить – что от нее ждать. А может быть, кто-то уже получил ее и протестировал на предмет разгона Е6х00.
Во всяком случае, после EPoX MF570-SLi остались неплохие впечатления и есть некая уверенность, что и этот продукт не разочарует.
Есть, как и на Asus Р5В-Deluxe и Gigabyte DS4, DQ6, возможность организовать работу двух видеокарт в режиме х16, х4.
Судя по заявлениям дилеров, цена должна быть в районе 4т. с копейками.
* * * Ошибаться может каждый, но не каждый может в этом признаться...* * *
вряд ли, а вот ожидать можно многого, так как эпокс достаточно часто затягивает с выпуском хороших продуктов, но без какой-либо информации остается только догадываться
Вещица интересная, только 1394 не хватает :(
Более мощный компьютер глючит быстрее и точнее.
Конечно, при всем, что есть на борту, наличие Wi-Fi совсем не помешало бы!
Что еще несколько смутило – это отсутствие активного охлаждения на мостах – ведь греться они должны серьезно, особенно в разгоне. Хотя, конечно, охладить их не представляется очень большой проблемой. Судя по фото, элементная база и цепи питания традиционно для EPoX на уровне...
Фары-вары, ваи-фаи и т.д. и т.п. На вас на всех не угодишь :) Но по сути это все - мелочи, вот если бы Епокс озаботился реализацией задания NB Strap посредством биос, это было бы в самом деле не лишним (и только ради этого я бы выбрал ее, будем надеяться и ждать). А остальное и у конкурентов есть, да и ничего не мешает самому необходимый контроллер воткнуть.
Добавлено спустя 28 минут, 16 секунд
Ехх ... Скачал мануал ... И не обнаружил нужного пункта в Bios Setup :(
Настоящее - сегодня :)
vansergeich
На самом деле, я жду от этой МВ хорошего и стабильного разгона по шине + мне нужно иметь возможность обеспечить совместную работу двух видеокарт (хотя бы х16, х4)...
А вот об этом нельзя поподробнее? :wink:
Ну почему же нельзя
http://forums.overclockers.ru/viewtopic.php?t=58848
vansergeich
Thanks, с интересом прочел - советую и другим.
Пока не увидим настройки BIOS EP-5P965+ GLi "вживую" - сказать, к сожалению, ничего не сможем... :(
Похоже, что поспешил! Уже 12 декабря, а МВ так и не видно... :oops:
Будем работать на Р5В-Deluxe. Всем - Sorry!
а у нас в москве ни неё... ни abit ab9 pro...
веще ни одной дешёвой матери кроме гигабайт дс3, а она без рэйда и ваще мне не нравится ((
я бы вот не стал гоняться за дешевизной, помнится пару лет назад с некоторым промежутком прикупил себе 2 эпоксовских мамки, на обеих через пару недель работы повскрывались все конденсаторы, я конечно перепаял, но стоить они стали автоматически почти вдвое дороже.
больше продукцию данной фирмы покупать особо желания не возникает...
У Epox очень хорошие мамы под АМД, с Интелом традиционно не везёт...
не пойму, с чего решили, что Sil - это преобразователь...
обычный рэйд-контроллер на 6 портов сата, или же 2 сата и 2 рата + 6 портов нативных
тяпнуть бы, да некого
Всем салют, взял себе вчера эту материнку :D В принципе обычная материнка как и все остальные. Из приимуществ на ней реализовано 2 IDE канала. Кото работают через специальную штуку которая называется EZ-IDE Bridge. Принцип такой, что для включения ИДЕ каналов надо соеденить саташным кабелем желтинкий САТА разъем и оранжевинький на материнке. Тоесть можно подключить макс 4 ИДЕ девайса + 4 САТА или только 6 САТА или 5 САТА и 2 ИДЕ.
Гнать пока не пробовал :( Погоню потом отпишу если кому интересно :)
RIS
В Питере их до сих пор нет! Обязательно напиши - как погонится! QNХ писал, что в биосе разгон забит с 266 до 510 - очень неплохо, но как по жизни получится? Мне лично EPoX нравится... :)
Главное - чтобы она без всяких модов держала шину >400, тогда вкупе с E4300 можно очень неплохую машинку получить, причем за разумные деньги, что с переходом на C2D очень немаловажно.
Magnus penis vitae basis est!
Velox
ну а что там по твоему? ))
залил на ПС новый биос, добавил линк в заметку
Конечно интересно! В разгоне и есть весь вопрос, ведь уже есть много "ржавых" неразгоняющихся материнок на P965. :(
QNX
Ждем резалтов!
YUA
у меня нет ни процессора ни памяти, так что в ближайшее время результатов не будет )))
Сейчас этот форум просматривают: Google [Bot] и гости: 55
