Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 49 • Страница 1 из 3 • 1  2  3  >
CPU
* AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron AMD® AM2 processors: Athlon series / Sempron
* HyperTransport 3.0 (5200MT/s for AM2+) HyperTransport 1.0 (2000/1600MT/s for AM2)
* AMD OverDrive provides tuning options using the new “Advanced Clock Calibration” overclocking feature.
* Socket 940 AM2+ 65nm
Chipset
* AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB750
System Memory
* Four 240-pin DDR2 DIMM sockets
* Supports DDR2 667/800/1066 MHz DIMMs
* Supports dual channel (128-bit wide) memory interface
* Supports up to 8GB system memory
* Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
* 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
* 3 PCI slots
BIOS
* Award BIOS
* CMOS Reloaded
* CPU/DRAM overclocking
* CPU/DRAM/Chipset overvoltage
* 8Mbit SPI flash memory
Audio
* Realtek ALC885 8-channel HD Audio Codec
* High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN
* Marvell 88E8053 PCIE Gigabit LAN controller
* Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Serial ATA with RAID
* Supports up to 6 SATA devices
* SATA speed up to 3Gb/s
* RAID 0, RAID 1 and RAID 0+1
IDE
* One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Rear Panel I/O
* 1 mini-DIN-6 PS/2 mouse port
* 1 mini-DIN-6 PS/2 keyboard port
* 1 optical S/PDIF-out port
* 1 coaxial RCA S/PDIF-out port
* 6 USB 2.0/1.1 ports
* 1 RJ45 LAN port
* Center/subwoofer, rear R/L and side R/L jacks
* Line-in, line-out (front R/L) and mic-in jacks
Internal I/O
* 3 connectors for 6 additional external USB 2.0 ports
* 1 connector for an external COM port
* 1 front audio connector
* 1 CD-in connector
* 1 IrDA connector
* 1 CIR connector
* 6 Serial ATA connectors
* 1 40-pin IDE connector
* 1 floppy connector
* 1 24-pin ATX power connector
* 1 8-pin 12V power connector
* 2 4-pin 5V/12V power connectors (FDD type)
* 1 front panel connector
* 6 fan connectors
* EZ touch switches (power switch and reset switch)
Power Management
* ACPI and OS Directed Power Management
* ACPI STR (Suspend to RAM) function
* Wake-On-PS/2 Keyboard/Mouse
* Wake-On-USB Keyboard/Mouse
* Wake-On-Ring
* Wake-On-LAN
* RTC timer to power-on the system
* AC power failure recovery
Hardware Monitor
* Monitors CPU/system/chipset temperature
* Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
* Monitors the speed of the cooling fans
* CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
* ATX form factor
* 24.5cm (9.64") x 30.5cm (12") All specifications above are subject to change without prior notice.
LANPARTY DK 790FXB-M2RSH
CPU
Chipset
System Memory
Expansion Slots
* 3 PCI slots
BIOS
* Award BIOS
* CMOS Reloaded
Audio
LAN
IDE
Rear Panel I/O
* 1 RJ45 LAN port
Internal I/O
* 1 CD-in connector
* 1 IrDA connector
* 1 CIR connector
* 6 fan connectors
Power Management
* Wake-On-Ring
* Wake-On-LAN
Hardware Monitor
PCB
* ATX form factor
Последний раз редактировалось *jd* 21.04.2009 10:45, всего редактировалось 4 раз(а).
Собственно хотелось бы обсудить эту плату !
Есть ли обладатели данного сабжа на форуме ?
ТО что мне не понравилось так это то что Everet не знает такой платы и паказывает завышенную температуру проца !
нет 1394 (((
Фото: 8
*jd* А где ты ее покупал? Такуюже хочу! А у нас в Питере нет(
лениво подпись придумывать было )))
Брал в Х-мемори
Фото: 8
так и знал, сейчас у них ее нет... но сказали до нового года будет))) Как с разгоном на ней дела?
отлично профильный камень легко погнался до 3ггц упирается в NB встроенный в CPU (( но плата стартует и на 3.2 но винда не стабильна (((
Приобрёл сабж. Тоже в Х-мемори. Причём с приключениями.
Скоро начну экспериментировать с разгоном, буду отписываться.
PS На сайте DFI последняя версия BIOS указана R7SDC26 (от 26.12.2008)
PPS Не совсем понял с ABS: Сначала прошить BIOS, потом обновить профиль ABS, или наоборот?
Don`t smoke cigarettes, Don`t take any drugs Don`t go out the night - Just Fuc* ;)
сначала прошиваете BIOS потом обставляете АБС
Сабж из хмемори что-то никак не хочет запускаться с вистой. Помогите советом. Устанавливаю висту, она прекрасно устанавливается, даже спрашивает про имя компутера и пользователя, но запускаться после установки не хочет. То есть биос грузится и все останавливается. При этом на diagnostic led горит красным FF. Почитала инструкцию - вынимала батарейку cmos, результатов нет; перевтыкала видюху - то же самое. В общем, кто может что посоветовать. Я подозреваю что может надо биос перепрошить, но мне интересно устанавливалась ли у кого виста без перепрошивки биоса?
да все ставится ! по внимательнее с настройками BIOS а именно параметров SATa и IDE
вот помучалась установила ХР без изменения настроек биоса, но мне нужна виста. Буду очень благодарна, если подскажете какие именно должны быть настройки в биосе для двух винтов по 1 Тб подключенных по сата. хелп плиз...
Что-то совсем запутался, не могу найти инфу по SB750, какая температура должна быть, 50С это нормально?
И какаие напруги по дефолту у SB750 и 790FX?
А то переставлял напряжение и забыл какие были, сброс в дефолт на маме не дал результатов, почему-то?!
Спасибо!
Хоттабыч офигевал от своей дерзости, но продолжал бриться...
Как-то очень мало информации по данной плате, обсуждения фактически нет(
Хотелось бы услышать мнение владельцев, как ведет себя плата, какие результаты при разгоне, какие промблемы/минусы и т.д.
http://www.xtremesystems.org/forums/showthread.php?t=185498 Вот тут 50 страниц обсуждения по похожей плате.
Где-то читал, что слоты работают как x16/x16/x4 Возможно ли такая работа? В биосе есть распределение линий?
Всем привет, приобрел сабж. Такой трабл - во время прошифки моргнул свет - теперь плата не стартует, пост код - 88. Обнуление биоса не помогло. Что делать ??? Можно ли как-то без программатара обойтись ???
I7 2600K@4.2/Asrock P67/Kingston HyperX 8Gb 1866/OCZ 256Gb/GIGABYTE GTX 960/BenQ EW2430/LG 47LM620T/Yamaha RX-V471+NS-555+NS-C444+NS-333+YST-SW215
Вылезла проблема.
Если её желательно запостить в другом месте - скажите, пожалуйста.
С утра система запустилась как обычно, посидел за компом, потом выбрал выключение (через "Пуск"), вырубил монитор, ушёл.
Прихожу через несколько часов - комп работает, не выключен, одно ядро целиком занято процессом "Interrupts", отчего притормаживает всё остальное.
Перезагружаю - комп не стартует. Индикатор показывает 25 (не удаётся инициализировать VGA BIOS).
Перечисленные в мануале возможности возникновения проблемы исключил:
вынул все PCI карты, отсоединил все USB устройства (от пинов на маме тоже).
Замена видеокарты не помогла. Эта же видяха на другой маме работает.
Сброс БИОСа тоже не помог.
Что приходит на ум: незадолго до отказа поставил дрова на видео 10-8 (хотя возможно и днём ранее, точно не помню).
ЗЫ Месяц назад выгорела сетевуха во время грозы. Поставил PCI, в BIOS встроенную отключил. Работало всё корректно.
AnTim Похоже на отвал северника. Гроза свое черное дело сделала...
ЗЫ: А владельцы 790X-M2RS есть, а то темы про нее не нашел
http://www.lastfm.ru/user/shamoff
скажите где можно скачать биос модифицированный ...или как заставить показывать обороты фан 1 и т.п. 3х пиновый. в биосе не показывает да и вообще нигде ..везде по нулям.
FANATIST
Не найдешь ты такого - будет показывать только обороты 3-х кулеров, остальные не мониторятся.
Сейчас этот форум просматривают: dezmand07 и гости: 68
