В данной теме обсуждаем все, что связано с материнской DFI LanParty UT-X58 T3eH8
12/18 Official - first public release bios
12/25 beta - improved DDR3 compatibility
12/31 beta - changed boot logo
01/06 beta
Patch some board can not boot up as error code hang "B2"
Update Intel CPU micro code
Fixed the S3 resume fail when insert Hard Disk to SATA 3/4 port
Patch for SetFSB utility can not run
01/14 Official
Added Channel and Rank Interleave Setting Item.
Modify DMI configure.
Fixed QPI Item string error.
Fixed ABS Auto upgrade issue.
Please click here for Update the "LX58D114.ABS" first by Auto Boost system AP file when you changed BIOS version.
Edit: Please DO NOT update bios until you have read this thread regarding the ABS Profile update requirement for only SOME users.
01/23 Beta bios
Added Patch 363 Item for SSD issue.
- Disable for using IDE SSD, Enable(default) for ensure 2 IDE CDROM works
- SSD will not be an issue in AHCI and RAID mode, only in IDE more where some SSD not able to install OS when in IDE mode on ICH10R due to conflict between SSD firmware and JMB363 initial code. Solution: under Integrated Peripherals -> On chip IDE device -> JMB363 patch (default enabled) set to Disable.
02/06 beta
Update micro code for PCIE root port Max Link Width reported as x4.
Remove floppy B.
Remove Reset Configuration Data Item.
Remove COM by Auto.
Make sure legacy mode only be enabled in IDE mode.
02/17 beta (now official)
CPU shutdown temp use DTS.
Modify “Thermal Management” 、”TDC” and “TDP” function.
Added CPU Die temp item.
Update Intel micro code for new CPUs function.
2/27 beta
Рекомендации DFI UT X58-T3EH8 1 Обновленная версия setfsb 2.1.88 (не ставить галочку в поле ULTRA)
Последний раз редактировалось vulkanes 16.03.2009 20:59, всего редактировалось 4 раз(а).
Заблокирован Статус: Не в сети Регистрация: 30.10.2008 Откуда: и все...
Все последующие BIOS имеют улучшения предыдущих?
Кто прошивался WinFlash в вистеХ64 у вас всё нормально прошло?
(на сайте DFI не советуют шить этим прошивальщиком в висте,но я с дуру прошил дважды-пока всё нормально)
Вот ветка на XS http://www.xtremesystems.org/forums/sho ... ht=dfi+x58
_________________ Suum cuique/to each to his own/jedem das seine
vulkanes
я знаю,что многие не советуют шить из под Винды...Но опыт прошивки с Gigabyte(965 DQ6) и Asus X38 Maximus formula не показал у меня лично никаких проблем.
Дисковода у меня нет,а флешка чего-то не пошла...Выбора нет...
Насчёт нагрева-гонял я проц при 1.5V(для бенча надо было)питалово цифровое охлаждал вентилем+Flame freezer неплохо работает.Темпа у питалова была около 50-55
странно,заставил флешку работать как прошивалку биоса,прошил последний (227)с сайта,но дискета 2 не ушла...Сегодня прошью 206,посмотрю,что измениться...
Статус: Не в сети Регистрация: 03.03.2003 Откуда: Москва Фото: 0
Ребят,кто-нить городил воду на чипсет?
Я вчера попытался это сделать,в результате получается каша из шлангов.
В последствии пришлось отказаться от ватера на чипсет и вернуться на штатное охлаждение.
Чипсет слишком близко расположен к видеокарте и ватер установленный на чипсете сильно затрудняет сборку.
И такой вопрос сразу же.
Сильно вообще чипсеты и мосфеты греються при разгоне на данной мамке?
NOFX к сожалению моя ветка по WC сабжа лежит вместе с XS =((
на север проверены MCR30 и EK NB S-Max
Мосфеты при разгоне греются аццки: сча на проце 1.36Вольта 200х20 - час прайма и на мосфетах 72 градуса, на севере 36. без ватера на севере все еще хуже. хотя я еще не ставил Flame Freezer. Со слов EVO2000 кулерок нужно ставить на термопасту - очень даже помогает
В общем фигня полная какая-то.
Скачал последний официальный биос.
Выставляю шину 200Mhz....посткод выдаёт "CF".
Память OCZ 6Gb XTC Platinum OCZ3P1333LV2G 3x2Gb.
Ниидёт разгон нивкакую просто.
CPU Feature Set VR Current Limit Max: Disabled Thermal Management Control: Disabled EIST Function: Disabled CxE Function: Disabled Execute Disable Bit: Disabled Virtualization Technology: Disabled TDC Enable: Disabled x TDC Limit: 0 TDP Enable: Disabled x TDP Limit: 0
***** Logical Processor Setting ***** Intel HT Technology: Enabled Active Processor Cores: All
DRAM Timing Channel Interleave Setting: AUTO Rank Interleave Setting: AUTO Memory LowGap: 1536M
DRAM Command Rate: AUTO/1N/2N etc CAS Latency Time (tCL): 9 RAS# to CAS# Delay (tRCD): 9 RAS# Precharge (tRP): 9 Precharge Delay (tRAS): 24 REF to ACT Delay (tRFC): AUTO Write to PRE Delay (tWR): AUTO Rank Write to Read (tWTR): AUTO ACT to ACT Delay (tRRD): AUTO Row Cycle Time (tRC): AUTO Read CAS# Precharge (tRTP): AUTO Four ACT WIN Time (tFAW): AUTO
Voltage Setting O.C. Shut Down Free: Enable O.C.S.D.F CPU VID Control: AUTO CPU VID Special Add Limit: Enabled CPU VID Special Add: Auto Vcore Droop Control: Enabled DRAM Bus Voltage: 1.605v DRAM PWM Switch Frequency: Nominal DRAM PWM Phase Control: 2 Phase Operation CPU VTT Special Add: AUTO CPU VTT Voltage: 1.21v VTT PWM Switch Frequency: Nominal VTT PWM Phase Control: 2 Phase Operation CPU PLL Voltage: 1.80v IOH/ICH 1.1V Voltage: 1.11v IOH Analog Voltage: 1.10v ICH 1.5 Voltage: 1.5v ICH 1.05V Voltage: 1.05v DIMM 1/2 DQ/DQSTB Bus VREF: -00.0% DIMM 3/4 DQ/DQSTB Bus VREF: -00.0% DIMM 5/6 DQ/DQSTB Bus VREF: -00.0% ADDR/CMD VREF Control: Disabled x DIMM 1/2 ADDR/CMD Bus VREF: 110 x DIMM 3/4 ADDR/CMD Bus VREF: 110 x DIMM 5/6 ADDR/CMD Bus VREF: 110 CPU QPI Drive Strength: Normal IOH QPI Drive Strength: Normal
PPM Function: Enabled Turbo Mode Function: Disabled 1 core Max Turbo Ratio: 22x 2 core Max Turbo Ratio: 21x 3 core Max Turbo Ratio: 21x 4 core Max Turbo Ratio: 21x CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings * QPI Control Settings: Enabled QPI Link Fast Mode: Enabled QPI Frequency: AUTO/4.8GT/s/5.866GT/s/6.4GT/s CPU Base Clock (BCLK): 133 Mhz Boot Up CPU Base Clock: AUTO PCIE Clock: 100 Mhz DRAM Frequency: 6x/8x/10x/12x/14x/16x Memory multipliers UnCore Frequency: 2x to 32x Uncore multipliers (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled PCIE Spread Spectrum: Disabled
Добавлено спустя 5 минут, 19 секунд
NOFX писал(а):
Может кто-нить параметры выложить.
мои настройки 200х20 HT ON
Код:
Genie BIOS Setting
CPU Feature Set VR Current Limit Max: Enabled Thermal Management Control: Disabled EIST Function: Disabled CxE Function: Disabled Execute Disable Bit: Disabled Virtualization Technology: Disabled
DRAM Command Rate: 1N CAS Latency Time (tCL): 8 RAS# to CAS# Delay (tRCD): 8 RAS# Precharge (tRP): 8 Precharge Delay (tRAS): 21 REF to ACT Delay (tRFC): 60 Write to PRE Delay (tWR): 10 Rank Write to Read (tWTR): 6 ACT to ACT Delay (tRRD): 6 Row Cycle Time (tRC): 30 Read CAS# Precharge (tRTP): 6 Four ACT WIN Time (tFAW): AUTO
Voltage Setting O.C. Shut Down Free: Enable O.C.S.D.F CPU VID Control: 1.35 CPU VID Special Add Limit: Enabled CPU VID Special Add: Auto Vcore Droop Control: Disabled DRAM Bus Voltage: 1.635v DRAM PWM Switch Frequency: Nominal DRAM PWM Phase Control: 2 Phase Operation CPU VTT Special Add: AUTO CPU VTT Voltage: 1.28v VTT PWM Switch Frequency: Nominal VTT PWM Phase Control: 2 Phase Operation CPU PLL Voltage: 1.80v IOH/ICH 1.1V Voltage: 1.11v IOH Analog Voltage: 1.10v ICH 1.5 Voltage: 1.5v ICH 1.05V Voltage: 1.05v DIMM 1/2 DQ/DQSTB Bus VREF: -00.0% DIMM 3/4 DQ/DQSTB Bus VREF: -00.0% DIMM 5/6 DQ/DQSTB Bus VREF: -00.0% ADDR/CMD VREF Control: Disabled x DIMM 1/2 ADDR/CMD Bus VREF: 110 x DIMM 3/4 ADDR/CMD Bus VREF: 110 x DIMM 5/6 ADDR/CMD Bus VREF: 110 CPU QPI Drive Strength: Normal IOH QPI Drive Strength: Normal
* BCLK/UCLK/QPI Controller Settings * QPI Control Settings: Enabled QPI Link Fast Mode: Enabled QPI Frequency: 4.8GT/s CPU Base Clock (BCLK): 200 Mhz Boot Up CPU Base Clock: AUTO PCIE Clock: 100 Mhz DRAM Frequency: 8x UnCore Frequency: 16x
Factotum
у тебя чехарды с дискетой 2 не было?Не могу избавиться от неё...
Только 206 биос помогает,а прошьёшь новый-она, тут как тут...
Шью флешкой...Прошивка проходит без ошибок...
inhibitor я выкинул флопик как ненужный девайс, отключил его в биосе, там же и отключил контролер флопика, так что не знаю что сказать - у меня нет даже намека на присутствие флопика в природе
Factotum
у меня флопика и не было ...но когда заходишь в биос -показывает дискету А и Б(хотя они обе и отключены...)только 206 биос убирает вторую дискету...
ставишь новый(217 или 227),она появляется...
хех, тама флопики стоят в дефолте, что бы со старта в дефолте была возможность загрузки с флопика если чо - ручками переставьте
В разделе *Standart CMOS Futures*
Drive A: None
Drive B: None
далее в разделе *Integrated Pepipherals*
переходим в *SupеrIO Devices*
тут отключаем сам контролер флопика что бы не занимал ресурсов, я еще отключаю ненужные COM-порты
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 47
