Добавлено спустя 1 минуту 23 секунды: Новый биос 5103
BIOS 5103 for Z9PE-D8 WS released to public 1. Separate BIOS item "Enhanced Intel SpeedStep Technology" and "Turbo Mode". 2. Update RSTe to 3.7.0.1049. (Legacy Option ROM and UEFI driver) 3. Support Intel Ivy Bridge-E Series CPU.
*Refer to http://www.asus.com for CPU support list Supports Intel® Turbo Boost Technology 2.0
Чипсет Intel® C602
Оперативная память 8 x DIMM, Max. 64GB, DDR3 2133(O.C.)/2000(O.C.)/1866(O.C.)/1600/1333/1066 MHz ECC, Non-ECC, Un-buffered Memory Quad Channel Memory Architecture *Refer to http://www.asus.com or this user manual for the Memory QVL (Qualified Vendors Lidts). * For Registered Memory, Max. 256GB DDR3 1600/1333/1066/800 MHz
System Bus 8.0/7.2/6.4 GT/s Intel® QuickPath Interconnect
Поддержка технологий Multi-GPU Supports NVIDIA® 4-Way SLI™ Technology Supports AMD Quad-GPU CrossFireX™ Technology
Слоты расширения 4 x PCIe 3.0/2.0 x16 (dual x16 or quad x8) *1 2 x PCIe 3.0/2.0 x16 *1 1 x PCIe 3.0/2.0 x16 (x8 mode) *1
Хранилище данных Intel® C602 chipset : 2 x SATA 6Gb/s port(s), (Blue) 8 x SATA 3Gb/s port(s), (Black) Support Raid 0, 1, 5, 10 Marvell® PCIe 9230 controller : 4 x SATA 6Gb/s port(s), (Gray) Support Raid 0, 1, 10
Локальная сеть Intel® 82574L, 2 x Gigabit LAN Controller(s)
Звук Realtek® ALC898 8-Channel High Definition Audio CODEC - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking Audio Feature : - Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound - DTS Ultra PC II - Optical S/PDIF out port(s) at back panel
Порты USB ASMedia® USB 3.0 controller : 4 x USB port(s) (2 at back panel, (Blue), 2 at mid-board)
Workstation Feature 7 x PCIe x 16 slot(s) Quick Gate: 2 x vertical USB 2.0 on board ASWM Enterprise ASMB6-iKVM Remote Management Tool
Особенности ASUS Digital Power Design : - Industry leading Digital 7 +1 Phase Power Design - Industry leading Digital 2 Phase DRAM Power Design ASUS Exclusive Features : - Front Panel USB 3.0 Support - ASUS SSD Caching ASUS Quiet Thermal Solution : - Stylish Fanless Design Heat-pipe solution ASUS EZ DIY : - ASUS CrashFree BIOS 3 - ASUS EZ Flash 2 - ASUS MyLogo 2 - Multi-language BIOS ASUS Q-Design : - ASUS Q-Shield - ASUS Q-Code - ASUS Q-Slot - ASUS Q-DIMM
Разъемы на задней панели 1 x PS/2 keyboard/mouse combo port(s) 2 x LAN (RJ45) port(s) 2 x USB 3.0 6 x USB 2.0 1 x Optical S/PDIF out 6 x Audio jack(s)
Разъeмы на плате 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin) 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s) 2 x Vertical USB 2.0 port(s) 2 x COM port(s) connector(s) 6 x SATA 6Gb/s connector(s) 8 x SATA 3Gb/s connector(s) 2 x IEEE 1394a connector(s) 2 x CPU Fan connector(s) (4 -pin) 6 x Chassis Fan connector(s) (4 -pin) 1 x S/PDIF out header(s) 1 x 24-pin EATX Power connector(s) 2 x 8-pin ATX 12V Power connector(s) 1 x 4-pin EZ_PLUG Power connector(s) 1 x RAID key header(s) 1 x ASMB6-iKVM connector(s) 1 x VGA connector(s) 1 x Front panel audio connector(s) (AAFP) 1 x AUX panel header(s) 1 x SMBus header(s) 1 x System panel(s) 1 x Power-on button(s) 1 x Reset button(s) 1 x Clear CMOS jumper(s)
Аксессуары User's manual I/O Shield 2 x COM port cable(s) 8 x SATA 3Gb/s cable(s) 6 x SATA 6Gb/s cable(s) 1 x 3-Way SLI bridge(s) 1 x 4-Way SLI bridge(s) 1 x SLI bridge(s) 1 x 2-port USB2.0 + 1394 bracket(s)
BIOS 64 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.6, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Администрированиe WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Диск с драйверами Drivers ASUS Utilities ASUS Update
Форм-фактор EEB Form Factor 12 inch x 13 inch ( 30.5 cm x 33 cm )
Примечание *1: This motherboard is ready to support PCIe 3.0 SPEC. Functions will be available when using PCIe 3.0-compliant devices. Please refer to http://www.asus.com for updated details.
Статус: Не в сети Регистрация: 17.08.2010 Откуда: Дюссельдорф
да у меня эта вторая материнка , первая глючила сразу, при перезагрузке иногда застревала на 1.5-2 минуты потом инцилизилась , память вместо 32гб то 30 то 28 то 16 вообщем гемор ,сдал взял другую эту же модель , полет норма все работает и летает
Добавлено спустя 27 минут 30 секунд: где купили такую материнку?
Статус: Не в сети Регистрация: 04.12.2011 Откуда: Санкт-Петербург Фото: 6
alexmvd брал в Сотмаркете. Очень не хотели её принимать и отправляли в сервис центры, а те обратно к ним. Прождал 2 месяца результатов и забрал деньги.
я спросил про Evga Classified SR-X где купили?
Добавлено спустя 2 минуты 24 секунды: я свою первую Asus Z9PE-D8 WS брал тоже в сотмаркете и с ней тоже косяк был который я описал, вторую Asus Z9PE-D8 WS взял в Nix все работает беспроблем
Чем 770 лучше Titan ?
Добавлено спустя 2 минуты 36 секунд: Кстати в пятницу мою материнку которую брал в сотмаркете с боем приняли обратно , не хотели говорили что по закону в течении недели можно вернуть так как продают дистанционно ссылались на пункт 26.1 о защит прав потр вот такая фигня
Добавлено спустя 49 секунд: Сейчас на материнке которую взял с nix она нормально работает
alexmvd в соотношении цена/производительность 770-я лучше. Она по сути является допиленной 680-й. Титан имеет смысл брать как одиночную карту (в Mini-ITX систему например).
alexmvd надо тесты читать - какая карточка в какой игре какие показатели показывает. Хотя опять же за это время серьёзно обновились драйвера. Но если есть деньги, то лучше Titan.
Сейчас этот форум просматривают: Mark Andy, Max085 и гости: 65
