Процессор Intel® Socket 2011 for 2nd Generation Core™ i7 Processors
*Refer to http://www.asus.com for CPU support list Supports Intel® Turbo Boost Technology 2 Чипсет Intel® X79 Оперативная память 4 x DIMM, Max. 32GB, DDR3 2400(O.C.)/2133(O.C.)/1866/1600/1333/1066 MHz Non-ECC, Un-buffered Memory Quad Channel Memory Architecture *Hyper DIMM support is subject to the physical characteristics of individual CPUs. Supports Intel® Extreme Memory Profile (XMP) *Refer to http://www.asus.com or this user manual for the Memory QVL (Qualified Vendors Lidts). Поддержка технологий Multi-GPU Supports NVIDIA® SLI™ Technology Supports AMD CrossFireX™ Technology Слоты расширения 2 x PCIe 3.0/2.0 x16 (dual x16, (Red)) 1 x PCIe 3.0/2.0 x16 (x8 mode, (Red)) 1 x PCIe 2.0 x4 Хранилище данных Intel® X79 chipset : 2 x SATA 6Gb/s port(s), (Red) 3 x SATA 3Gb/s port(s), (Black) 1 x eSATA 3Gb/s port(s), (Red) Support Raid 0, 1, 5, 10 ASMedia® ASM1061 controller : *1 2 x SATA 6Gb/s port(s), (Red) Локальная сеть 82579+8111E, 1 x Gigabit LAN Controller(s) Аудио SupremeFX III built-in 8-Channel High Definition Audio CODEC - Output Signal-to-Noise Ratio (A-Weighted): 110 dB - Output THD+N at 1kHz: 95 dB - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking Audio Feature : - SupremeFX Shielding™ Technology - Blu-ray audio layer Content Protection - 1500 uF Audio Power Capacitor - Creative ALchemy - Gold-plated jacks - EAX® Advanced™ HD 5.0 - X-Fi® Xtreme Fidelity™ - THX® TruStudio PRO™ - Optical S/PDIF out port(s) at back panel Порты USB ASMedia® USB 3.0 controller : 4 x USB 3.0 port(s) (2 at back panel, (Blue), 2 at mid-board) Intel® X79 chipset : 12 x USB 2.0 port(s) (8 at back panel, (Black)+(White), 4 at mid-board) Разгонные функции ROG Connect Extreme Engine Digi+ II : - 8 -phase CPU power design - 3 -phase VCCSA power design - 2 + 2 phase DRAM power design Mem TweakIt ProbeIt UEFI BIOS features : - ROG BIOS Print - GPU.DIMM Post GameFirst iROG Extreme Tweaker Loadline Calibration USB BIOS Flashback Overclocking Protection : - COP EX (Component Overheat Protection - EX) - ASUS C.P.R.(CPU Parameter Recall) Эксклюзивные особенности ASUS TurboV EVO : - CPU Level Up ASUS EPU : - EPU ASUS Exclusive Features : - MemOK! - Onboard Button : Power/Reset/Clr CMOS (at back IO) ASUS Quiet Thermal Solution : - ASUS Fan Xpert ASUS EZ DIY : - ASUS Q-Shield - ASUS O.C. Profile - ASUS CrashFree BIOS 3 - ASUS EZ Flash 2 - ASUS MyLogo 2 ASUS Q-Design : - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED) - ASUS Q-Slot - ASUS Q-DIMM - ASUS Q-Connector Разъемы на задней панели 1 x PS/2 keyboard/mouse combo port(s) 1 x eSATA 3Gb/s 1 x LAN (RJ45) port(s) 2 x USB 3.0 8 x USB 2.0 (one port can be switched to ROG Connect) 1 x Optical S/PDIF out 6 x Audio jack(s) 1 x Clear CMOS button(s) 1 x ROG Connect On/ Off switch(es) Разъeмы на плате 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s) 4 x SATA 6Gb/s connector(s) 3 x SATA 3Gb/s connector(s) 2 x CPU Fan connector(s) 3 x Chassis Fan connector(s) 1 x S/PDIF out header(s) 1 x 24-pin EATX Power connector(s) 1 x 8-pin ATX 12V Power connector(s) 1 x Front panel audio connector(s) (AAFP) 1 x System panel(s) 11 x ProbeIt Measurement Points 1 x Power-on button(s) 1 x Reset button(s) 1 x Go Button(s) Аксессуары User's manual I/O Shield 2 x SATA 3Gb/s cable(s) 4 x SATA 6Gb/s cable(s) 1 x SLI bridge(s) 1 x Q-connector(s) (2 in 1) 1 x ROG Connect cable(s) 1 x ROG theme label(s) 1 x 12 in 1 ROG Cable Label(s) 1 x ROG Door Hanger(s) BIOS 64Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS Администрированиe WfM2.0, DMI2.0, WOL by PME, WOR by PME, PXE Диск с драйверами Support DVD: - Drivers and applications * ASUS AI Suite II * ROG CPU-Z * ROG GameFirst Utility * Sound Blaster X-Fi MB2 Utility * ROG Mem TweakIt Utility * ASUS AI Charger+ * WinZip * ASUS USB 3.0 Boost * ASUS Webstorage * DAEMON Tools Pro Standard * Kaspersky® Anti-Virus 1-year license Форм-фактор uATX Form Factor 9.6 inch x 9.6 inch ( 24.4 cm x 24.4 cm ) Примечание *1: These SATA ports are for data hard drivers only. ATAPI device is not supported.
BIOS: Для инженерных процессоров SB-E необходимо использовать BIOS 1305, а для серийных использовать последний официальный. Инженерный процессор работает корректно только на BIOS 1305. Если Вы прошьетесь на более позднюю версию, то необходимо будет делать FLASHBACK до 1305. Так же Вы можете прошивать Вашу мат. плату без процессора методом FLASHBACK подключив только питание.
BIOS ДЛЯ RAMPAGE IV GENE!!! ОЧЕНЬ ВАЖНО!!! - Для процессоров SB-E рекомендуют биос не выше 4206 - Процессоры IVB-E стартуют ТОЛЬКО с биосом 4403 и выше (необходимо сразу прошить как купили мат. плату, т.к. может стоять биос 4206 и ниже) При этом, если у Вас в наличии только процессор на IVB-E(например 4930к), а версия BIOS 1005 и выше до 2ххх, то прошиться, можно только после конвертации! Так как для этого надо будет изменить структуру BIOS с ROM на CAP.
Как прошить-откатить BIOS с 4ххх 3ххх 2ххх на текущую, предыдущую или 1ххх серию. Метод FLASHBACK
1. Взять флешку любого объема (4Гб по умолчанию) 2. Отформатировать ее в FAT32 3. Скачать с офф сайта биос 1ххх 2ххх 3ххх 4ххх серии 4. Переименовать его в ERALL.ROM (если откат идет с 2ххх, 3ххх, 4ххх на 1ххх серию) или R4G.CAP (если откат идет с 4ххх, 3ххх, 2ххх на 4ххх, 3ххх, 2ххх серию). 5. Переписать его на флешку 6. Выключить компьютер 7. Вставить флешку в белый разъём USB на задней панели мат. платы. 8. Зажать кнопку "Rog connect" на 3 секунды и отпустить после того, как она начнёт мигать.(если мигает, не больше 5 сек., то это означает, что что-то не так с файлом, скорее всего не правильно обозвали файл) 9. Подождать 2-3 минуты, пока она перестанет мигать(мигать будет все быстрее и быстрее по мере продвижения обновления и в конце погаснет) 10. Готово
Конвертация BIOS
Процесс конвертации и обновления с помощью USB BIOS Flashback выглядит так: - необходимо разместить файл конвертера в корне USB-флеш накопителя, отвечающему следующим требованиям: -> файловая система FAT32, -> объем не более 8Гб. Конвертер можно скачать по ссылке: http://dlcdnet.asus.com/pub/ASUS/mb/LGA ... verter.zip - переименовать файл конвертера в R4G.ROM - подключить накопитель в выделенному разъему USB(ROG Connect Port - белый) - подключить блок питания и подать на него напряжение, при этом не включать саму систему(!) - нажать кнопку ROG Connect на материнской плате на ~3сек. - дождаться окончания процедуры конвертации BIOS
Затем, аналогичным образом необходимо обновить и сам BIOS, до последней версии, с той лишь разницей, что потребуется переименовать файл BIOS в R4G.CAP(обратите внимание, расширение CAP). Сам BIOS последней версии можно скачать по ссылке: http://dlcdnet.asus.com/pub/ASUS/mb/LGA ... S-4901.zip
Как прошить BIOS с 1ххх на 2ххх 3ххх 4ххх серию?
Если у Вас BIOS 1403 и ниже, то для этого необходимо прошиться с помощью конвертера!!! Скачиваем Rampage-IV-Gene-CAP-Converter (лежит на сайте ASUS в BIOS-Utilities) Скачиваем последний BIOS 2ххх.CAP (3ххх.CAP, 4ххх.CAP)
и записываем на флешку, предварительно отформатированную в FAT32, далее заходим в BIOS и переходим в раздел ASUS EZ Flash 2 ВЫБИРАЕМ файл Rampage-IV-Gene-CAP-Converter.ROM и благополученно шьемся
00 - Not used 01 - Power on. Reset type detection (soft/hard). 02 - AP initialization before microcode loading 03 - System Agent initialization before microcode loading 04 - PCH initialization before microcode loading 05 - OEM initialization before microcode loading 06 - Microcode loading 07 - AP initialization after microcode loading 08 - System Agent initialization after microcode loading 09 - PCH initialization after microcode loading 0A - OEM initialization after microcode loading 0B - Cache initialization 0C – 0D - Reserved for future AMI SEC error codes 0E - Microcode not found 0F - Microcode not loaded 10 - PEI Core is started 11 – 14 - Pre-memory CPU initialization is started 15 – 18 - Pre-memory System Agent initialization is started 19 – 1C - Pre-memory PCH initialization is started 1D – 2A - OEM pre-memory initialization codes 2B – 2F - Memory initialization 30 - Reserved for ASL (see ASL Status Codes section below) 31 - Memory Installed 32 – 36 - CPU post-memory initialization 37 – 3A - Post-Memory System Agent initialization is started 3B – 3E - Post-Memory PCH initialization is started 3F – 4E - OEM post memory initialization codes 4F - DXE IPL is started 50 – 53 - Memory initialization error. Invalid memory type or incompatible memory speed 54 - Unspecified memory initialization error 55 - Memory not installed 56 - Invalid CPU type or Speed 57 - CPU mismatch 58 - CPU self test failed or possible CPU cache error 59 - CPU micro-code is not found or micro-code update is failed 5A - Internal CPU error 5B - Reset PPI is not available 5C – 5F - Reserved for future AMI error codes E0 - S3 Resume is stared (S3 Resume PPI is called by the DXE IPL) E1 - S3 Boot Script execution E2 - Video repost E3 - OS S3 wake vector call E4 – E7 - Reserved for future AMI progress codes E8 - S3 Resume Failed E9 - S3 Resume PPI not Found EA - S3 Resume Boot Script Error EB - S3 OS Wake Error EC – EF - Reserved for future AMI error codes F0 - Recovery condition triggered by firmware (Auto recovery) F1 - Recovery condition triggered by user (Forced recovery) F2 - Recovery process started F3 - Recovery firmware image is found F4 - Recovery firmware image is loaded F5-F7 - Reserved for future AMI progress codes F8 - Recovery PPI is not available F9 - Recovery capsule is not found FA - Invalid recovery capsule FB-FF - Reserved for future AMI error codes 60 - DXE Core is started 61 - NVRAM initialization 62 - Installation of the PCH Runtime Services 63 – 67 - CPU DXE initialization is started 68 - PCI host bridge initialization 69 - System Agent DXE initialization is started 6A - System Agent DXE SMM initialization is started 6B – 6F - System Agent DXE initialization (System Agent module specific) 70 - PCH DXE initialization is started 71 - PCH DXE SMM initialization is started 72 - PCH devices initialization 73 – 77 - PCH DXE Initialization (PCH module specific) 78 - ACPI module initialization 79 - CSM initialization 7A – 7F - Reserved for future AMI DXE codes 80 – 8F - OEM DXE initialization codes 90 - Boot Device Selection (BDS) phase is started 91 - Driver connecting is started 92 - PCI Bus initialization is started 93 - PCI Bus Hot Plug Controller Initialization 94 - PCI Bus Enumeration 95 - PCI Bus Request Resources 96 - PCI Bus Assign Resources 97 - Console Output devices connect 98 - Console input devices connect 99 - Super IO Initialization 9A - USB initialization is started 9B - USB Reset 9C - USB Detect 9D - USB Enable 9E – 9F - Reserved for future AMI codes A0 - IDE initialization is started A1 - IDE Reset A2 - IDE Detect A3 - IDE Enable A4 - SCSI initialization is started A5 - SCSI Reset A6 - SCSI Detect A7 - SCSI Enable A8 - Setup Verifying Password A9 - Start of Setup AA - Reserved for ASL (see ASL Status Codes section below)* AB - Setup Input Wait AC - Reserved for ASL (see ASL Status Codes section below) AD - Ready To Boot event AE - Legacy Boot event AF - Exit Boot Services event B0 - Runtime Set Virtual Address MAP Begin B1 - Runtime Set Virtual Address MAP End B2 - Legacy Option ROM Initialization B3 - System Reset B4 - USB hot plug B5 - PCI bus hot plug B6 - Clean-up of NVRAM B7 - Configuration Reset (reset of NVRAM settings) B8– BF - Reserved for future AMI codes C0– CF - OEM BDS initialization codes D0 - CPU initialization error D1 - System Agent initialization error D2 - PCH initialization error D3 - Some of the Architectural Protocols are not available D4 - PCI resource allocation error. Out of Resources D5 - No Space for Legacy Option ROM D6 - No Console Output Devices are found D7 - No Console Input Devices are found D8 - Invalid password D9 - Error loading Boot Option (LoadImage returned error DA - Boot Option is failed (StartImage returned error) DB - Flash update is failed DC - Reset protocol is not available
*ASL Status Codes 01 - System is entering S1 sleep state 02 - System is entering S2 sleep state 03 - System is entering S3 sleep state 04 - System is entering S4 sleep state 05 - System is entering S5 sleep state 10 - System is waking up from the S1 sleep state 20 - System is waking up from the S2 sleep state 30 - System is waking up from the S3 sleep state 40 - System is waking up from the S4 sleep state AC - System has transitioned into ACPI mode. Interrupt controller is in PIC mode AA - System has transitioned into ACPI mode. Interrupt controller is in APIC mode
В данной теме ведется обсуждение: - ТОЛЬКО Asus Rampage IV Gene на Intel X79 LGA2011 (вопросы по ASUS Extreme/Black Edition/MAXIMUS/FORMULA будут удаляться) - Мат. платы, ее настройка, тюнинг, разгон; - Проблемы, связанные с ее эксплуатацией; - Особенности работы, совместимости, проблемы и тонкости с устройствами, возникающие при подключении и использовании - Софтовые проблемы, применимые к конкретной мат. плате (драйверы, утилиты); - Прочие, неразрывно связанные с платой нюансы, являющиеся индивидуальным совпадением и особенностью конфигурации - Проблемы с CPU возникающие на данной мат. плате
Остальное будет считаться оффтопиком и будет удаляться.
Прежде чем задать вопрос, удостовертесь в том, что бы Ваш ПРОФИЛЬ был ЗАПОЛНЕН, в противном случае Ваше сообщение будет УДАЛЕНО!!!
P.S. В теме разрешается ОФФТОПИТЬ ТОЛЬКО ПРИ ОСТРОЙ НЕОБХОДИМОСТИ и помещать Ваш текст в ТЭГИ ОФФТОП
Заблокирован Статус: Не в сети Регистрация: 26.02.2007 Фото: 74
Owerclocker А там без процессора в сокете может надо прошивать? Я не знаю, просто предположил. Как вариант искать 3ххх проц, собирать системник и шить через ез флэш.
Статус: Не в сети Регистрация: 26.11.2015 Откуда: берутся дети? Фото: 5
Жесть, ответ от ASUS:
Уважаемый пользователь продукции ASUS,
Если точное следование нашим инструкциям из предыдущих ответов не позволяет выполнить прошивку, стопорится на каком-то этапе или не приводит к ожидаемому результату по иным известным ли неизвестным причинам, то проблема может быть следствием наличия аппаратной неисправности или повреждения текущих прошивок пзу на плате, что является поводом для обращения в СЦ магазина для диагностики и тестирования платы, с целью установить источник проблемы и устранить неисправность.
Просто а ведь плата в полном порядке, просто они сделали то, что сами не знают как работает...
Статус: Не в сети Регистрация: 10.06.2003 Откуда: внутримкадово
Интересно, она до сих пор продается?!...
4 года материнка отработала без особых вопросов, ну разве что любила докопаться до модулей памяти самсунг (4 по 8 ГБ). Вчера, после очередного обновления windows 10 x64, не может загрузиться.
BIOS прошивается с кнопки ROG. Если видит флешку в USB2.0 портах с прошивкой R4G.CAP, стартует в режиме прошивки. Была залита прошивка 4901
Кстати, спасибо топикстартеру за информацию о R4G.CAP, документацию асусям влом обновить. Пробывал переименовывать в R4G.ROM - не видит флешку. Вообще ROM-прошивки теперь не видит.
Чем история с материнкой закончилась? Удалось зашить биос новый? После заливки конвертора, мне кажется, нужно стартануть и сделать сброс настроек BIOS. Но это уже нужен процессор, как я понимаю. Тогда уже можно и свежий биос залить. А какой у Вас процессор?
а можно подробности про "подрезку"?
Добавлено спустя 1 час 11 минут 14 секунд: Сколько раз перешиваю, при старте получается каждый раз разный код ошибок. Мне кажется это проблема микросхемы BIOS. Можно её купить новую и зашить средствами материнской платы. Или нужен программатор?
Да, снимаете бэкап со своей прошивки(заводской). Далее качаете последнюю прошивку. Открываете ее Hex Editorom, отрезаете первые два килобайта вначале файла(проще говоря удаляете циферки в начале файла до тех пор, пока файл не станет меньше на 2 килобайта) Потом вносите данные из заводской прошивки в новый последний биос(как это сделать можно прочесть в этой теме FAQ по прошивке и редактор индивидуальных данных BIOS плат ASUS P8xxx и их ROG-аналогов) И после этого прошиваете программатором, например таким - CH341A.
Впервые встречаю в своей практике. Глюк микросхемы BIOS. Заменили и прошили в сервисном центре "Ф-центр" на сухонской. Правда потеряли mac-address, но зато всё работает.
Статус: Не в сети Регистрация: 25.12.2006 Откуда: ПМР
Расскажу как я установил на ASUS Rampage IV GENE - Samsung 970 EVO 250Gb NVMe SSD Скачал биос с сайта https://www.win-raid.com/t2778f44-OFFER ... e-mod.html Распаковал его и закинул на флешку 8Gb формат FAT32 Выключил комп вставил флешку в белый разъем USB на задней панели и нажал кнопку на 3 сек та что ближе к USB она начала моргать мин 3-5 когда перестала я поставил Windows 10 он уже увидел SSD
аналогичная ситуация и у меня. камень i7 3820 биос был 4906 - flashback не помог. Пробую способ описанный выше ч/з программатор. не помогло... либо 00 либо циклический перезапуск...
28/11/2018 получил новый камень с али - e5 xeon 2603v2 прошился ч/з flashback до 4901 - все заработало. #77
Коллеги, уже всю голову сломал-нужен совет по ASUS Rampage IV GENE. Имеется PCI-E адаптер для NVME и сам диск. не могу установить его в качестве загрузочного диска. Что делал: 1) Установил, загрузил прошивку вот отсюда https://winraid.level1techs.com/t/offer-asus-rampage-iv-gene-bios-4901-nvme-mod/31947 - не помогло 2) Пытался встраивать драйвер на nvme в саму прошивку- два раза в разные добавлял и биос перешивал - тоже не помогло. В биосе диск не видно. Сам биос уже перекопал вдоль и поперёк. Причём, что самое интересное- я могу на NVME установить винду спокойно, установочный диск систему видит. Но загрузиться с него не выходит, в биосе не появляется pata, Куда копать, подскажите, плиз!
_________________ Танец с бубном-главный инструмент в руках успешного компьютерщика по решению проблем, точно также,как и метод научного тыка,в руках успешного ученого.
Спасибо. Подсунул в прошивку NvmExpressDxe_5.ffs и перешил биос. Пока видимых улучшений нет.
Ps. в итоге после кучи опытов с перепрошивкой я сдался. Видимо, надо пробовать другой вариант платы pci/диска... Модификацию биоса я делаю уже без мануалов, по памяти, разными способами...
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 58
