Press Release Source: Intel On Monday January 31, 2011, 9:59 am
SANTA CLARA, Calif.--(BUSINESS WIRE)-- As part of ongoing quality assurance, Intel Corporation has discovered a design issue in a recently released support chip, the Intel® 6 Series, code-named Cougar Point, and has implemented a silicon fix. In some cases, the Serial-ATA (SATA) ports within the chipsets may degrade over time, potentially impacting the performance or functionality of SATA-linked devices such as hard disk drives and DVD-drives. The chipset is utilized in PCs with Intel’s latest Second Generation Intel Core processors, code-named Sandy Bridge. Intel has stopped shipment of the affected support chip from its factories. Intel has corrected the design issue, and has begun manufacturing a new version of the support chip which will resolve the issue. The Sandy Bridge microprocessor is unaffected and no other products are affected by this issue.
The company expects to begin delivering the updated version of the chipset to customers in late February and expects full volume recovery in April. Intel stands behind its products and is committed to product quality. For computer makers and other Intel customers that have bought potentially affected chipsets or systems, Intel will work with its OEM partners to accept the return of the affected chipsets, and plans to support modifications or replacements needed on motherboards or systems. The systems with the affected support chips have only been shipping since January 9th and the company believes that relatively few consumers are impacted by this issue. The only systems sold to an end customer potentially impacted are Second Generation Core i5 and Core i7 quad core based systems. Intel believes that consumers can continue to use their systems with confidence, while working with their computer manufacturer for a permanent solution. For further information consumers should contact Intel at http://www.intel.com on the support page or contact their OEM manufacturer.
Что известно на данный момент: 1. Баг затрагивает только четыре SATA2 порта. Два порта SATA3, а также дополнительные SATA порты, организованные контроллерами сторонних производителей (Marvel и др), багу не подвержены. 2. Баг выражается в постепенном падении производительности SATA2 портов в плоть до полного неопределения SATA устройств, подключенных к ним. 3. Intel уверяет, что SATA устройства при этом не страдают. 4. Темпы деградации портов зависят от: температуры, напряжения на чипсете (?) и активности использования устройств, подключенных к SATA2 портам. 5. Баг присутствует во всех выпущенных на данный момент материнских платах на чипсетах Cougar Point (P67, H67 и других под Sandy Bridge). В чипсете ревизии B1 бага не было, однако эта ревизия в продажу не попала. Все материнские платы, выпущенные для конечных производителей, произведены на чипсете ревизии B2, имеющей баг. 6. Производство исправленных чипсетов (ревизия В3) должно быть налажено в середине февраля. Материнские платы на новой ревизии чипсета следует ожидать в марте-апреле. 7. Чипсет Z68 сразу выйдет без этого бага.
Рекомендация пользователям: 1. Перевесить все имеющиеся SATA устройства на SATA3 порты. 2. Если же использования SATA2 портов избежать не удается, повесить на них малоиспользуемые, некритичные девайсы (например, оптический привод).
Реакция производителей материнских плат:
Процедура замены в зависимости от производителя материнской платы (на примере магазина "Юлмарт", Россия):
MB производства Intel Замене подлежат все платы на степинге B2. С 11 апреля платы можно сдавать в наш гарантийный отдел. Далее они напрямую отправляются в Intel и через 10-14 дней приходит замена. В случае отсутствия нужной позиции на складах интела, срок может увеличится.
MB производства ASUS Замене подлежат все платы на степинге B2 в период с 1 мая по 31 июля. Можно будет сдать старую плату и получить замену в нашем гарантийном отделе. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы.
MB производства MSI Массовой замены не будет, в гарантию будут приниматься платы только с демонстрируемым дефектом, иначе говоря если у вас все работает, поменять плату не получится.
По производителю ASRock Массовой замены не будет, в гарантию будут приниматься платы только с демонстрируемым дефектом, иначе говоря если у вас все работает, поменять плату не получится.
По производителю Gigabyte Появилась информация. Можно будет сдать старую плату и получить замену в нашем гарантийном отделе, если дефект проявляется. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы. В случае, когда дефект не проявляется, но Вы хотите её сдать, требуется ПОЛНЫЙ комплект (заводская упаковка, диски, кабели)
Заблокирован Статус: Не в сети Регистрация: 30.10.2007 Откуда: Одесса
Clay Allison писал(а):
CyberTronics писал(а):
в докладе заявлено о ошибке в ДИЗАЙНЕ и о намарениях исправить ошибку в ЧИПЕ. То есть, мне кажется, софтом тут дело не поправить.
А помните TLB bug? Ошибку сначала исправили новыми версиями биоса, при этом падала производительность. только потом выпустили новые ревизии процессоров где ошибки не было.
В линуксе был патч,который не приводил к падению производительности. К тому же вот http://www.overclockers.ru/hardnews/32080.shtml и никаких комментариев по поводу причин перевода на новый степпинг. Да и от владельцев таких систем особых жалоб не поступало.(ну разве что некоторые траблы с рэйд-массивами). Видимо через биос как-то пофиксили.
_________________ Если Бог за нас, кто против нас?(с) Библия В случае масштабных военных действий, эвакуация населения не только не производится, но и не планируется.
А мне пофиг, я все равно буду скоро брать мать Р67 и проц, если мать будет глючить, то поменяю по гарантии, благо на Асусы в нормальных местах гарантия 3 года..... Невижу смысла поднимать панику - гарантия то есть на все - че вы паритесь - ошибки были всегда и будут и это нормально и если новые биосы непоправят это и мать заглючит, то вперед в гарантию и нет проблем!
Статус: Не в сети Регистрация: 25.08.2010 Откуда: Можайск
Но понадобится некоторое время на обмен! Где-то поменяют сразу, где-то через неделю... Так и будем всю жизнь по гарантийкам мотаться .
_________________ Важно не то, как ЛЮДИ относятся к тебе, а как ТЫ ОТНОСИШЬСЯ к ЛЮДЯМ!!!
Статус: Не в сети Регистрация: 13.04.2006 Откуда: Kyiv
Ага... В гарантию. А тебе там скажут - Это не баг это фича! И уйдёшь ты ни с чем.
BrainOS По закону диагностика при сдаче в гарантию может быть 21 рабочий день, так что все нормально - сразу нигде необязаны менять, есть закон и в нем установлены соответствующие сроки на диагностику (до 21 рабочего дня) и на ремонт (до 45 рабочих дней)!
На самом деле все эти глюки у 95% пользователей себя никак не проявляют. Вот например http://www.cyberguru.ru/hardware/proces ... page4.html и никаких массовых проблем не наблюдается. Опять же видимо все прекрасно фиксится через биос. С большой долей вероятности в этот раз также все проскочит. Ну а если нет то можно утешать себя что новое железо это не только новый уровень производительности но и ложечка дегтя. Но опять же это коснется далеко не всех имхо.
Дело в том что уже вышли биосы 1204 - пока самые свежие на Асус и скоро будут 13хх биосы, в общем когда я буду мать брать уже будет 13хх биос и сразу его прошью и потестю - думаю вендоры вкурсе ошибки, раз за месяц по несколько биосов выкатывают - видимо много ошибок и думаю все пофиксят, все равно проца 2600к пока нигде у нас нет и невижу смысла брать мать, проц заказали из за бугра, ждемс....
Статус: Не в сети Регистрация: 12.07.2005 Откуда: Краснодар Фото: 0
Delite86 Деградации самого чипсета? Но этож не ведет к смерти переферии я так понимаю. Просто будет не корректная работа. Вообщем ждем новых биосов и новых комментариев. У меня гарантия на мать 3 года. Я обычно через пол года мать меняю. Так что думаю проблема не такая уж и большая.
То есть я могу, скажем, в мае обратиться в официальный сервисный центр, они протестируют (в течение 21 дня) и выдадут заключение, с которым я пошагаю в магазин на обмен? А если проблема себя не проявит? Можно ли сослаться на информацию по ссылке в первом сообщение данной темы?
Dr Kazay Да, я тоже через год-полтора сменю на 2011 или че там будет, так что мне пофиг - я по 5-7 лет на одном железе не сижу......да и мать буду брать с гарантией 3 года - так что мне вообще пофиг
BrainOS Если плата будет глючить то поменяют, а елси она с САТА конкретно ваша будет работать нормально, то зачем идти в сервис и сидеть месяц без платы? Идти надо с конкретной проблемой, а не то что типа прогоните тесты - я что то где то читал про глюки!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 39
