Куратор(ы):   ykk
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 3672 • Страница 184 из 184<  1 ... 180  181  182  183  184
Куратор темы
Только что Intel запустил пресс-релиз:
Intel Identifies Chipset Design Error, Implementing Solution
Press Release Source: Intel On Monday January 31, 2011, 9:59 am
SANTA CLARA, Calif.--(BUSINESS WIRE)-- As part of ongoing quality assurance, Intel Corporation has discovered a design issue in a recently released support chip, the Intel® 6 Series, code-named Cougar Point, and has implemented a silicon fix. In some cases, the Serial-ATA (SATA) ports within the chipsets may degrade over time, potentially impacting the performance or functionality of SATA-linked devices such as hard disk drives and DVD-drives. The chipset is utilized in PCs with Intel’s latest Second Generation Intel Core processors, code-named Sandy Bridge. Intel has stopped shipment of the affected support chip from its factories. Intel has corrected the design issue, and has begun manufacturing a new version of the support chip which will resolve the issue. The Sandy Bridge microprocessor is unaffected and no other products are affected by this issue.
The company expects to begin delivering the updated version of the chipset to customers in late February and expects full volume recovery in April. Intel stands behind its products and is committed to product quality. For computer makers and other Intel customers that have bought potentially affected chipsets or systems, Intel will work with its OEM partners to accept the return of the affected chipsets, and plans to support modifications or replacements needed on motherboards or systems. The systems with the affected support chips have only been shipping since January 9th and the company believes that relatively few consumers are impacted by this issue. The only systems sold to an end customer potentially impacted are Second Generation Core i5 and Core i7 quad core based systems. Intel believes that consumers can continue to use their systems with confidence, while working with their computer manufacturer for a permanent solution. For further information consumers should contact Intel at http://www.intel.com on the support page or contact their OEM manufacturer.
Полный текст: http://newsroom.intel.com/community/int ... g-solution
Зеркало: http://finance.yahoo.com/news/Intel-Ide ... l?x=0&.v=1
Ссылки по теме:
Technology@Intel · Chipset With Potential Problem - What To Do
AnandTech - Intel Discovers Bug in 6-Series Chipset: Our Analysis
AnandTech - The Source of Intel's Cougar Point SATA Bug
The Tech Report - Intel finds flaw in Sandy Bridge chipsets, halts shipments
Tom's Hardware - Intel Identifies Cougar Point Chipset Error, Halts Shipments
Tom's Hardware - Sandy Bridge Debacle: What It Means for You
pcgameshardware.de - Probleme mit Intel-Chips P67 und H67 für Sandy-Bridge-CPUs bestätigt (на немецком)
РИА Новости - Ошибка в новом чипсете обойдется Intel в миллиард долларов
iXBT: Ошибка в чипсетах Intel 6-й серии
Overclockers.ru - Asus, Gigabyte и Toshiba принимают назад продукты на базе дефектных чипсетов Intel
Intel Provides Update on Support Chip Design Issue
Что известно на данный момент:
1. Баг затрагивает только четыре SATA2 порта. Два порта SATA3, а также дополнительные SATA порты, организованные контроллерами сторонних производителей (Marvel и др), багу не подвержены.
2. Баг выражается в постепенном падении производительности SATA2 портов в плоть до полного неопределения SATA устройств, подключенных к ним.
3. Intel уверяет, что SATA устройства при этом не страдают.
4. Темпы деградации портов зависят от: температуры, напряжения на чипсете (?) и активности использования устройств, подключенных к SATA2 портам.
5. Баг присутствует во всех выпущенных на данный момент материнских платах на чипсетах Cougar Point (P67, H67 и других под Sandy Bridge). В чипсете ревизии B1 бага не было, однако эта ревизия в продажу не попала. Все материнские платы, выпущенные для конечных производителей, произведены на чипсете ревизии B2, имеющей баг.
6. Производство исправленных чипсетов (ревизия В3) должно быть налажено в середине февраля. Материнские платы на новой ревизии чипсета следует ожидать в марте-апреле.
7. Чипсет Z68 сразу выйдет без этого бага.
Рекомендация пользователям:
1. Перевесить все имеющиеся SATA устройства на SATA3 порты.
2. Если же использования SATA2 портов избежать не удается, повесить на них малоиспользуемые, некритичные девайсы (например, оптический привод).
Реакция производителей материнских плат:
Процедура замены в зависимости от производителя материнской платы (на примере магазина "Юлмарт", Россия):
MB производства Intel
Замене подлежат все платы на степинге B2.
С 11 апреля платы можно сдавать в наш гарантийный отдел.
Далее они напрямую отправляются в Intel и через 10-14 дней приходит замена.
В случае отсутствия нужной позиции на складах интела, срок может увеличится.
MB производства ASUS
Замене подлежат все платы на степинге B2 в период с 1 мая по 31 июля.
Можно будет сдать старую плату и получить замену в нашем гарантийном отделе. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы.
MB производства MSI
Массовой замены не будет, в гарантию будут приниматься платы только с демонстрируемым дефектом,
иначе говоря если у вас все работает, поменять плату не получится.
По производителю ASRock
По производителю Gigabyte
Появилась информация. Можно будет сдать старую плату и получить замену в нашем гарантийном отделе, если дефект проявляется. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы.
В случае, когда дефект не проявляется, но Вы хотите её сдать, требуется ПОЛНЫЙ комплект (заводская упаковка, диски, кабели)
Asrock
Asrock (Россия)
Gigabyte
Gigabyte (Россия)
Gigabyte (Россия)
Asus
Asus (США и Канада)
Asus (Россия)
MSI
MSI (Россия)
MSI (Украина)
...производителей ноутбуков:
RETERA.RU - Из-за проблем с чипсетами Intel многие компании отзывают свои ноутбуки
Toshiba
Как отличить материнские платы на новом степинге от старых:
MSI
ASRock
Gigabyte
Asus
Примеры борьбы с магазинами, которые отказываются менять материнки B2 на B3:
Баг в чипсетах Intel P67-H67 #8270030
Форма-заявка на сайте Гигабайта
Последний раз редактировалось Dark Knight 27.05.2011 9:24, всего редактировалось 48 раз(а).
edit
Добрый день уважаемые ! Начну по порядку ) Мой системник iCore 760/16gb/1+1Tb и 500Gb+500Gb все Seagate/1Gb 460gtx/700watt Acbel Win7 Ничего не разогнано, все в штатном режиме.
В 2011 году приобрел мат. плату Asrock P67 Transformer , на плате sata3 и Usb3, в то время даже устройств не было таких , ну да ладно подумал я , на будущее сказал себе и все так было бы если бы не одно маленькое "Но" .
Шло время , спустя которое все отлично работало , спросите вы где же то самое но, а вот оно , счастье длилось не долго ! Через 3 года прям на рабочем столе при просмотре страниц браузера тачка просто зависла , ну и ладно подумал я .
Жму резет , все это конец , дальше биоса мы уже не грузились, первая мысль "ну приехали" , а система была построена из Raid stripe 0 на sata 3 портах там жили 2 hdd 500Gb + и 2 hdd 1Tb под кино и музыку сидели на портах sata2.
Диагностика показала что 2 hdd stripe покрылись бэдами , откуда там они так резко , когда система регулярно проверялась, ок снимаю их лечу на другой тачке , все ок , подключаю обратно винты , начинают по очереди не определяться, думаю ну клево что еще ) , ок откладываю в сторону. Беру hdd 1Tb на нем тоже беды , лечу все ок , подключаю в порты sata2 где он жил и ставлю винду , ставилась долго что еще не так ?
Доставил систему врубаю hdd tune и такой ОМГ ! скорость ! Где ты ? а скорость раньше была 110Mb, стала 10~30Mb страшный график рисует, решил проверить все порты.
Во всех портах та же самая картина то определяется то нет , если определяется то скорость ниже плинтуса, в портах sata3 но не намного . Остался еще один не проверенный жесткий диск на 1Tb назовем его "счастливчик", на нем всего пара бедов была. Что же делать подумал я, полез читать форумы , узнаю об этой теме, но уже понимаете поздно, так как уже много времени прошло.
На плате был еще сторонний контролер построенный на марвеле 363 для Esata , подключаю туда и о чудо скорость нормальная но это пичаль порт то 1, а жестких дисков 4 .
Лезем в биос копать настройки , нахожу напругу на южном Volt PCH ставлю 1,141 , о чудо , скорость на портах вернулась и винты уже определялись стабильно )))
Так я просидел еще немного но не долго "Умирают" hdd 500Gb + 500gb+1Tb -3 винта , куча бедов и в конце не определяются контролер ушел в блокировку и не вернулся ))) какая удача! О чудо "Счастливчик" остался жить
Итог 3 винта в помойку остается 1, так и сижу на нем, думаю хуже уже быть не может, скажете ну да! Отвечу может!
Так я просидел чуть больше года это был 2015 лето, на 1 винте в 1Tb с поднятым напряжением южном мосту , подключенным в сата3 и тут снова траблы, тачка повисла, думаю ну ок пришло твое время брат)
Снимаю "Счастливчика" вешаю на другую тачку , проверяю все ок , чисто бедов 0 все норм , понимаю что плата совсем офигела чудит по черному ) то видит винт то не видит ) пробовал разные кабеля , не помогло )))
Стало ясно что зависание было из за того что винт перестал видеться в биос , ну ладно лекарство есть , сажаю его на марвел 363 доп контроллер в плате , все работает , сидим так еще год, вроде уже все.
Нет не все! лето 2016, тачка зависает при просмотре фильма, жму резет , комп стартует и спикер пищит 3 раза , я такой ура что то новое! Ну так как винт был в марвеле то точно уже не проблема ))))
Звук спикера сказал что проблема с оперативной памятью , типо ее нету )) думаю 4 планки по 4Gb ему мало что ле! Ок достаю ее, чищу, вставляю тоже самое 3 сигнала, ну клево! Вытаскиваю 2 оставляю 2 , чудеса включился.
Стало ясно что 2 слота под память сказали хватит жить так долго, умирают ближние слоты (Dual Channel: DDR3_A2, DDR3_B2, Blue) , так как двух канальный режим остался жить то стало ясно, дело исключительно в плате.
Удивительно что при этом память целая осталась, оставил 8Gb в двух слотах в двух канальном режиме , так и сижу. CD-ROM в pci sata1 контроллер на силиконе.
Жду новых приключений )
Всем спасибо за внимание )
R5 5500, Asus TUF Gaming B450-PLUS II, 32GB@3600Mhz, GTX 1080Ti, SSD 1Tb, Deepcool PQ650M, LG 32QN600-B, Spyder 4 DisplayCAL 3.8.9
Фото: 24
кг
За сообщение вида "Не могу создать тему в барахолке. Почему?“ будет ЖК 1 месяц за нарушение п. 2.1 правил конференции - игнорирование поиска.
У меня глюки с портами sata ушли только на z77. B2 (одна)/B3(три) страдали одним и тем же, все устройства просто исчезали или скорость падала до нуля. Стояло 7 дисков.
danil_sneg вам бы профиль свой исправить ну что бы ошибок не было прежде чем других учить.
Род занятий: Ценообразователь.
http://ru.thefreedictionary.com/
Привет всем. У меня проблемы начались с одним винчем Wd black. Битые сектора оказались программными. Заремапил и забил. Но сейчас уже есть нечитаемых секторов. Думал проблема в самом диске. Сегодня как и год назад один из винчей стал раскручиваться и резко останавливаться и так по кругу. Я его временно вырубил. После следующей загрузке еще один винч ниже его в корпусе так же стал чудить. Я отрубил все hdd кроме ssd системный. Разгон при всем при этом был снят.
Грешу на:
1) Брак конкретной материнки с его болячками.
3) Проблема с южным мостом или нечто подобного из-за бюджетного блока питания тоже со своими проблемами.
Что за марвел 363 доп контроллер в плате?
Мать Asus P8Z68-VLX, соответственно с чипсетом Z68. Подозреваю, что столкнулся с такой же проблемой. Но как проверить, что точно виноват чипсет - не знаю.
По сообщению Aida южный мост: Intel Couguar Point Z68. Версия/степпинг = 05/B3.
Проблемы началась много лет назад, ещё со старыми HDD - диски иногда "отваливались", и перезапускались. Я долго и упорно ковырял в строну питания, разъёмов, шнурков и т.п. (Насчёт блока питания - нет. Во первых это проявлялось на разных блоках питания, во вторых они из дорогой ценовой категории). И вот теперь такая же фигня стала происходить РЕГУЛЯРНО с новым диском. Как это выглядит: чаще всего при поиске по всем файлам на диске; или при копировании всего диска куда-то: операция подвисает, диск в редких случаях перезапускается, ещё в более редких случаях "отвисает". Но самое интересное, что после перезапуска компьютера по RESET - ошибки в этом же месте больше никогда не появляются. Все файлы (исходные) целые. В SMART никаких ошибок насчёт сбойных секторов нет. Потом проблема появлялась в другом месте... И так бесконечно.
Вспомнил о дохлых чипсетах 6x серии. И решил переставить свой диск из SATA3 в SATA2 разъём - и проблема сразу исчезла. Что интересно в другом SATA3 разъёме у меня стоит загрузочный диск - после отключения от SATA3 проблемного диска, загрузочный перестал определяться. Пришлось его тоже переставить в SATA2. Вот такая непонятная фигня...
Может кто сталкивался с похожими симптомами? От чего это? У меня уже никаких идей нету.
P.S. С ОЗУ на этом компьютере всё нормально. Оно даже без разгона. Может только с охлаждением южного моста - не очень. Он очень горячий при работе с дисками и на него ничего не дует. (Вот прямо сейчас сжимаю ~23Гб архив, так палец долго удержать не получается - горячо).
Ретроклокер
Фото: 26
jek1975 давно пора поставить обдув на чипсет, предварительно заменив термоинтерфейс под радиатором чипсета и понаблюдать, так и до отвала не далеко.
Ваша проблема к проблеме Intel P67-H67 не отностися, все же другой набор логики.
Мои_статьи https://overclockers.ru/tag/show/10017/max1024
Фото: 7
jek1975 Ранее тут писал про В2 платы - я брал первую Р67-ую от Интел на ревизии Б2...
В Интел-ах, в отличии от других производителей мосты работали на стоковом напряжении (т.е. не под гарантированный разгон), а это меньший нагрев и ... больший срок эксплуатации.
Как известно в Б2 заявили отвал САТА 2 портов.
НА третий год при зеркалировании больших дисков стало заметно проседать скорость в портах САТА2 - обдув 80 мм на минимальных оборотов зоны с чипсетом решал проблему.
Потом купил ИНтел по новее на Z77-ом... Там кстати на и на всех 67-ых, 68-ых и 70-ых была заметна деградация по скорости при длительных копированиях больших объёмов, частично решаемая дополнительным обдувом.
НА пятый год владения достал ту самую Интел на Р67-ом с Б2 чипом - подключил а там ... САТА 2 все отказали!!!
Причём снимал я её с эксплуатации рабочей... как-то потом доставал для каких-то целей - работало всё ... а тут при любом подключенном САТА2 устройстве зависание на инициализации дополнительного ROM-BIOS с индикацией соответствующего ПОСТ кода (мать Intel DP67BG - там отличная встроенная диагностика).
Подключаешь девайсы в САТА3 - всё ОК, но ... их там всего ДВА.
Как то так!
З.Ы. Мать продал в своём городе для работы под Ксеон из китая с ОДНИМ диском...
Всем спасибо за ответы. Наконец-то решил свою проблему (после многих лет). Виноват был я а не чипсет или провода.
Причина была в разгоне PCI шины до 103.5 МГц. Почему я раньше не подумал на это? Потому что на ещё более старых компьютерах переразгон по PCI шине у меня вызывал сбои в передаче файлов, синие экраны, и всякое такое, что заметить и понять очень легко.
В этом же случае никаких синих экранов, никаких повреждений файлов. Только непонятные перезапуски дисков (в разное время две разных модели), что было похоже на проблемы с проводами, а не на сбои в передаче данных. Поэтому долгое время я мучал провода - менял разные шнурки, приклеевал разъёмы к диску двухсторонней пенопластовой лентой и т.п...
Ну и радиатор чипсета я тоже в этот раз снял. Там до сих пор была родная розовая жвачка (только я пользуюсь этой мамкой около 10 лет, а ещё и до меня был хозяин. Заменил на самую тонкую и мякгую термопрокладку из своих запасов. (Термпосту туда пихать бессмысленно - радиатор "висит" на пружинках - пока это всё будешь прикручивать и наклонять в разные стороны - от термопасты ничего не останется).
Уже больше недели прошло. Ни одного перезапуска или отвала диска до сих пор не было!
Фото: 7
jek1975 Я на большинстве своих плат, в том числе и на Интелах х67, х68, х77, х87, сразу менял термоинтерфейс под радиаторами чипсетов.
Исключения составляли случаи, когда удаление терморезинки приводило к тому, что радиатор "садился" на какую-нибудь деталь на плате (может привести к КЗ).
Никаких проблем с установкой и дельнейшей эксплуатации это не приводило.
Температурный режим, предполагаю, что изменялся не сильно, на сами радиаторы прогревались после этого заметно быстрее, да и были субъективно горячее - это как бы свидетельствует о лучшем отводе тепла.
Другое дело что для нормальных микросхем чипсетов это было ни об чём, т.к. они изначально рассчитывались на высокие температуры при работе.
А вот для "багованного" чипсета P67 на матери Intel DP67BG (ревизии В2) - это точно не было лишним... Косвенно это подтвердила её беспроблемная эксплуатация в течении всего гарантийного срока (ТРИ года)...
Фото: 23
южники жрут копейки, им резинки хватает за глаза.
Разгони форум и сайт overclockers.ru: https://coolcmd.github.io/for/
https://youtu.be/4A67iTiOD_g
Фото: 7
CoolCmd Тут, по спецификации Интел, как бы и не южник - хаб...
Но греется он очень хорошо!
По спецификациям от Интел допустимые рабочие температуры под 90 градусов допустимы... есть упоминание 120 градусов как критические значения.
Но если в контексте данной темы смотреть на мосты версии В2, то высокие температуры и напряжения питания реко ускоряют процесс деградации тех самых групп транзисторов, что ответственны за тактование элементов контроллера САТА 300.
Соответственно, чем ниже рабочая температура и напряжения питания - тем дольше отработает мост ревизии В2.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 47
