Куратор(ы):   ykk
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 3672 • Страница 4 из 184<  1  2  3  4  5  6  7 ... 184  >
Куратор темы
Только что Intel запустил пресс-релиз:
Intel Identifies Chipset Design Error, Implementing Solution
Press Release Source: Intel On Monday January 31, 2011, 9:59 am
SANTA CLARA, Calif.--(BUSINESS WIRE)-- As part of ongoing quality assurance, Intel Corporation has discovered a design issue in a recently released support chip, the Intel® 6 Series, code-named Cougar Point, and has implemented a silicon fix. In some cases, the Serial-ATA (SATA) ports within the chipsets may degrade over time, potentially impacting the performance or functionality of SATA-linked devices such as hard disk drives and DVD-drives. The chipset is utilized in PCs with Intel’s latest Second Generation Intel Core processors, code-named Sandy Bridge. Intel has stopped shipment of the affected support chip from its factories. Intel has corrected the design issue, and has begun manufacturing a new version of the support chip which will resolve the issue. The Sandy Bridge microprocessor is unaffected and no other products are affected by this issue.
The company expects to begin delivering the updated version of the chipset to customers in late February and expects full volume recovery in April. Intel stands behind its products and is committed to product quality. For computer makers and other Intel customers that have bought potentially affected chipsets or systems, Intel will work with its OEM partners to accept the return of the affected chipsets, and plans to support modifications or replacements needed on motherboards or systems. The systems with the affected support chips have only been shipping since January 9th and the company believes that relatively few consumers are impacted by this issue. The only systems sold to an end customer potentially impacted are Second Generation Core i5 and Core i7 quad core based systems. Intel believes that consumers can continue to use their systems with confidence, while working with their computer manufacturer for a permanent solution. For further information consumers should contact Intel at http://www.intel.com on the support page or contact their OEM manufacturer.
Полный текст: http://newsroom.intel.com/community/int ... g-solution
Зеркало: http://finance.yahoo.com/news/Intel-Ide ... l?x=0&.v=1
Ссылки по теме:
Technology@Intel · Chipset With Potential Problem - What To Do
AnandTech - Intel Discovers Bug in 6-Series Chipset: Our Analysis
AnandTech - The Source of Intel's Cougar Point SATA Bug
The Tech Report - Intel finds flaw in Sandy Bridge chipsets, halts shipments
Tom's Hardware - Intel Identifies Cougar Point Chipset Error, Halts Shipments
Tom's Hardware - Sandy Bridge Debacle: What It Means for You
pcgameshardware.de - Probleme mit Intel-Chips P67 und H67 für Sandy-Bridge-CPUs bestätigt (на немецком)
РИА Новости - Ошибка в новом чипсете обойдется Intel в миллиард долларов
iXBT: Ошибка в чипсетах Intel 6-й серии
Overclockers.ru - Asus, Gigabyte и Toshiba принимают назад продукты на базе дефектных чипсетов Intel
Intel Provides Update on Support Chip Design Issue
Что известно на данный момент:
1. Баг затрагивает только четыре SATA2 порта. Два порта SATA3, а также дополнительные SATA порты, организованные контроллерами сторонних производителей (Marvel и др), багу не подвержены.
2. Баг выражается в постепенном падении производительности SATA2 портов в плоть до полного неопределения SATA устройств, подключенных к ним.
3. Intel уверяет, что SATA устройства при этом не страдают.
4. Темпы деградации портов зависят от: температуры, напряжения на чипсете (?) и активности использования устройств, подключенных к SATA2 портам.
5. Баг присутствует во всех выпущенных на данный момент материнских платах на чипсетах Cougar Point (P67, H67 и других под Sandy Bridge). В чипсете ревизии B1 бага не было, однако эта ревизия в продажу не попала. Все материнские платы, выпущенные для конечных производителей, произведены на чипсете ревизии B2, имеющей баг.
6. Производство исправленных чипсетов (ревизия В3) должно быть налажено в середине февраля. Материнские платы на новой ревизии чипсета следует ожидать в марте-апреле.
7. Чипсет Z68 сразу выйдет без этого бага.
Рекомендация пользователям:
1. Перевесить все имеющиеся SATA устройства на SATA3 порты.
2. Если же использования SATA2 портов избежать не удается, повесить на них малоиспользуемые, некритичные девайсы (например, оптический привод).
Реакция производителей материнских плат:
Процедура замены в зависимости от производителя материнской платы (на примере магазина "Юлмарт", Россия):
MB производства Intel
Замене подлежат все платы на степинге B2.
С 11 апреля платы можно сдавать в наш гарантийный отдел.
Далее они напрямую отправляются в Intel и через 10-14 дней приходит замена.
В случае отсутствия нужной позиции на складах интела, срок может увеличится.
MB производства ASUS
Замене подлежат все платы на степинге B2 в период с 1 мая по 31 июля.
Можно будет сдать старую плату и получить замену в нашем гарантийном отделе. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы.
MB производства MSI
Массовой замены не будет, в гарантию будут приниматься платы только с демонстрируемым дефектом,
иначе говоря если у вас все работает, поменять плату не получится.
По производителю ASRock
По производителю Gigabyte
Появилась информация. Можно будет сдать старую плату и получить замену в нашем гарантийном отделе, если дефект проявляется. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы.
В случае, когда дефект не проявляется, но Вы хотите её сдать, требуется ПОЛНЫЙ комплект (заводская упаковка, диски, кабели)
Asrock
Asrock (Россия)
Gigabyte
Gigabyte (Россия)
Gigabyte (Россия)
Asus
Asus (США и Канада)
Asus (Россия)
MSI
MSI (Россия)
MSI (Украина)
...производителей ноутбуков:
RETERA.RU - Из-за проблем с чипсетами Intel многие компании отзывают свои ноутбуки
Toshiba
Как отличить материнские платы на новом степинге от старых:
MSI
ASRock
Gigabyte
Asus
Примеры борьбы с магазинами, которые отказываются менять материнки B2 на B3:
Баг в чипсетах Intel P67-H67 #8270030
Форма-заявка на сайте Гигабайта
Последний раз редактировалось Dark Knight 27.05.2011 9:24, всего редактировалось 48 раз(а).
edit
такс, не знаю правильный ли ход моих мыслей, но изложу как я все понял.
прочивав по ссылке Delite86 - http://techreport.com/discussions.x/20326
нашел вот эту строку:
The ports potentially affected, interestingly enough, are the four 3Gbps SATA ports on the chipset. The two 6Gbps SATA ports aren't at risk.
то есть не все порты уязвимы, тогда я вспомнил что на именитых матерях для добавления розьемов САТА, производитель собачит туда еще микросхемы сторонних производителей.
Зашел почитать спецификации о своей мамке http://www.asrock.com/mb/overview.asp?Model=Fatal1ty%20P67%20Professional&cat=Specifications - там сказано:
- 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)
на сайте Асуса о P8P67 DELUXE - http://www.asus.com/product.aspx?P_ID=FpufhQASBFHNvccl
то же самое (если не учитывать разницу в количестве самих розьемов)
Тоесть, я предположу что даже если и чип попался с багом, подключив устройства к портам от другой микросхемы (на Асусе они темно-синие) - можно обойтись и без глюков.
не пинайте сильно если где то оплошал.
Intel Core i7 2600k/AsRock P67 Fatal1ty (B2)/Kingston HyperX DDR3/Asus ENGTX 460 768Mb Direct CU/Thermaltake Purepower 680W
Mosga писал(а):
Деградация наблюдается только на SATA 3G портах 3-6, с портами SATA 6G 1-2 проблем не происходит.
Это типа рекламы,покупайте SATA 6
XAM писал(а):
Вот задница.
Ты не один такой,я тоже заказал жду подарка
Добавлено спустя 1 минуту 6 секунд:
Himik_15 писал(а):
У вас разве нет материнок что ли?
Когда заказывал,еще небыло
Ошибки по SATA быстро наполнят счётчики SMART. Винты получается тоже "пострадают".
Поидее только с данными чипсетами. На других всё станет на свои места.
i5-2400 / Asus P8Z68-V / 2*4Gb 1333MHz / 40Gb SSD / 1Tb + 2Tb WD / Apple Keyboard / Razer DB / Dell U2311h
С какого перепугу? СМАРТ система накопительная.
Не-не, я ж не про смарт) я имею ввиду, что допустим, если писать здесь будет с ошибками, то на других чипсетах - без.
Фото: 547
almazmusic
Только SMART будет загажен основательно.
Посмотрел в аиде
Южный мост Intel Cougar Point P67
Версия 04
знать бы теперь какие версии с багом, а то к дате привязали и фиг чего поймешь. А то может пока не поздно все на SATA6 перекинуть :-)
Господа а кокая блин разница? порты сата 3 есть они обратно совместимы с сата 2 (2 порта родных чипа + 2 марвела
итого хватает на 90 процентов систем.)
да неприятно :) но критически ничего страшного
"Прежде, чем сделать открытие, загляни в учебник" - инженерная мудрость
И сколько теперь ждать? Когда до нас дойдут нормальные материнки?
Хотя я собирался брать 1 хард у которого sata 6gb, так-что по-боку)
Разве что dvd-rw.
Bumbr Аналогично - 04. Думаю, что у всех версии пока одинаковые.
Вы хотите об этом поговорить? ☺
Фото: 23
Mosga писал(а):
Спасибо, первая ссылка интересная. Написано, что деградируют только порты SATA3. Таким образом те у кого 1 винт и резак можно воткнуть свое добро в два порта SATA6 и успокоится. У меня правда два винта, резак будет висеть на SATA3, но я его редко использую, а в сообщениях написано, что деградируют при высоких нагрузках. В общем паника отменяется. :)
Последний раз редактировалось CoolCmd 31.01.2011 23:22, всего редактировалось 1 раз.
Единственное кто знает, вдруг через месяц окажется что там ещё что-то не так...
Фото: 23
Версия 04
У ВСЕХ она одинаковая. Новая исправленная ревизия будет только в конце февраля.
смешно читать тех, кто считает что проблема преувеличена
если бы это было так интел не писал бы что им будет нужно потратить $700 миллионов на исправление
рынок прореагировал - интел на пару процентов подешевел, амд на 5 процентов подорожал...
на фондовых биржах не дураки сидят...
если бы все было так просто - на сцену бы вышел представитель интел, и повторил бы выступление стива джобса - "Вы неправильно вставляете винчестеры", "Это фича, просто используйте 6Gbps порты" и пообещал бы вам прислать "бесплатные бамперы" (pcie адаптеры sata).
удивляет отсуствие официального сообщени от интел россия и тишина на основных сайтах, может журналисты ждут когда им дадут сглаженную формулировку?
исправленые материнки дойдут до россии не раньше лета, а там уже они никому (кроме тех кто уже купил камни) будут не интересны, все будут ждать борьбу титанов - Intel LGA 2011 и AMD Bulldozer...
думаю багнутые буки не будут вывозить, так как они прошли недешевую таможню, так что их вообще нельзя будет покупать...
зы почему все таки обсуждение официального пресс релиза интел о браке перенесли в офтопик? модераторы, давайте переходите на сторону посетителей, а не производителей.
Последний раз редактировалось zyn 31.01.2011 23:32, всего редактировалось 4 раз(а).
Фото: 41
CoolCmd
У меня хардов как грязи - забью все 8 портов........... :shock: :mad2:
Albatron 8800GTX&MSI 8800GTS 512@пали смертью храбрых! Killer=nVidia OverGuru!
"Team Russia"
Последний раз редактировалось Himik_15 31.01.2011 23:25, всего редактировалось 1 раз.
Блин сейчас русские торгаши либо будут молчать и дальше продавать, либо при выходе новой ревизии опять цены вскрутят, типо встречайте: не баганутые материнки! :D
Народ объясните, все Р67 бракованные или только те что выпущены после 9 января?
Фото: 23
Intel’s Steve Smith, vice president and director of PC client operations and enabling at Intel, says that the specific problem occurs over time, and is affected by temperature and voltage. It’s more likely to manifest in configurations with lots of data being moved across the SATA 3 Gb/s ports—that’s why OEMs are encountering a problem now. The company says it would have expected roughly 5% of systems to be affected over a three-year period.
По предварительным прогнозам штеуда за три года сдохнут всего 5% южников. Чета маловато...
Так же написано, что на деградацию влияют напряжение и температура. Так что лично я попробую понизить напряжение со стандартных 1.05 В, тем более на разгон это не повлияет.
Добавлено спустя 1 минуту 7 секунд:
MagicBolls ВСЕ! С 9 начали продавать, именно это имелось ввиду. Просто нужно читать весь текст, а не только одно предложение.
Добавлено спустя 1 минуту 29 секунд:
В южнике 6 портов. Но я тебе не завидую.
Вроде бы все на данный момент...
Важно не то, как ЛЮДИ относятся к тебе, а как ТЫ ОТНОСИШЬСЯ к ЛЮДЯМ!!!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 126
