Press Release Source: Intel On Monday January 31, 2011, 9:59 am
SANTA CLARA, Calif.--(BUSINESS WIRE)-- As part of ongoing quality assurance, Intel Corporation has discovered a design issue in a recently released support chip, the Intel® 6 Series, code-named Cougar Point, and has implemented a silicon fix. In some cases, the Serial-ATA (SATA) ports within the chipsets may degrade over time, potentially impacting the performance or functionality of SATA-linked devices such as hard disk drives and DVD-drives. The chipset is utilized in PCs with Intel’s latest Second Generation Intel Core processors, code-named Sandy Bridge. Intel has stopped shipment of the affected support chip from its factories. Intel has corrected the design issue, and has begun manufacturing a new version of the support chip which will resolve the issue. The Sandy Bridge microprocessor is unaffected and no other products are affected by this issue.
The company expects to begin delivering the updated version of the chipset to customers in late February and expects full volume recovery in April. Intel stands behind its products and is committed to product quality. For computer makers and other Intel customers that have bought potentially affected chipsets or systems, Intel will work with its OEM partners to accept the return of the affected chipsets, and plans to support modifications or replacements needed on motherboards or systems. The systems with the affected support chips have only been shipping since January 9th and the company believes that relatively few consumers are impacted by this issue. The only systems sold to an end customer potentially impacted are Second Generation Core i5 and Core i7 quad core based systems. Intel believes that consumers can continue to use their systems with confidence, while working with their computer manufacturer for a permanent solution. For further information consumers should contact Intel at http://www.intel.com on the support page or contact their OEM manufacturer.
Что известно на данный момент: 1. Баг затрагивает только четыре SATA2 порта. Два порта SATA3, а также дополнительные SATA порты, организованные контроллерами сторонних производителей (Marvel и др), багу не подвержены. 2. Баг выражается в постепенном падении производительности SATA2 портов в плоть до полного неопределения SATA устройств, подключенных к ним. 3. Intel уверяет, что SATA устройства при этом не страдают. 4. Темпы деградации портов зависят от: температуры, напряжения на чипсете (?) и активности использования устройств, подключенных к SATA2 портам. 5. Баг присутствует во всех выпущенных на данный момент материнских платах на чипсетах Cougar Point (P67, H67 и других под Sandy Bridge). В чипсете ревизии B1 бага не было, однако эта ревизия в продажу не попала. Все материнские платы, выпущенные для конечных производителей, произведены на чипсете ревизии B2, имеющей баг. 6. Производство исправленных чипсетов (ревизия В3) должно быть налажено в середине февраля. Материнские платы на новой ревизии чипсета следует ожидать в марте-апреле. 7. Чипсет Z68 сразу выйдет без этого бага.
Рекомендация пользователям: 1. Перевесить все имеющиеся SATA устройства на SATA3 порты. 2. Если же использования SATA2 портов избежать не удается, повесить на них малоиспользуемые, некритичные девайсы (например, оптический привод).
Реакция производителей материнских плат:
Процедура замены в зависимости от производителя материнской платы (на примере магазина "Юлмарт", Россия):
MB производства Intel Замене подлежат все платы на степинге B2. С 11 апреля платы можно сдавать в наш гарантийный отдел. Далее они напрямую отправляются в Intel и через 10-14 дней приходит замена. В случае отсутствия нужной позиции на складах интела, срок может увеличится.
MB производства ASUS Замене подлежат все платы на степинге B2 в период с 1 мая по 31 июля. Можно будет сдать старую плату и получить замену в нашем гарантийном отделе. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы.
MB производства MSI Массовой замены не будет, в гарантию будут приниматься платы только с демонстрируемым дефектом, иначе говоря если у вас все работает, поменять плату не получится.
По производителю ASRock Массовой замены не будет, в гарантию будут приниматься платы только с демонстрируемым дефектом, иначе говоря если у вас все работает, поменять плату не получится.
По производителю Gigabyte Появилась информация. Можно будет сдать старую плату и получить замену в нашем гарантийном отделе, если дефект проявляется. В случаи отсутствия на складе подходящей замены вам вернут полную стоимость сданной материнской платы. В случае, когда дефект не проявляется, но Вы хотите её сдать, требуется ПОЛНЫЙ комплект (заводская упаковка, диски, кабели)
Статус: Не в сети Регистрация: 20.09.2006 Откуда: Striy/Ukraine
CoolCmd, а у тебя какая мать? на каких вольтажах работает чипсет и не прыгают ли онные при нагрузке винтов? З.Ы. а не с тобой ли я воевал за армию ПАК в БФ2142?
CoolCmd на Асус Делюкс 8 портов - у меня забьются все, там же еще двд и е-сата на морду подключить надо, на мать пофиг, главное чтобы харды не сдохли - там у меня инфы навалом, мать если что по гарантии поменяю - это не проблема если покупать в нормальных конторах с нормальной гарантией и обслуживанием.
У меня, кстати, температура южного моста Р67 в простое, за месяц выросла с 29 градусов до 35-36. Так что даже не знаю, может первая ласточка. У меня занято 4 парта.
В рапорте рекомендуют устройства которые поддерживают 6G цеплять на 6G порты интелла, а все что 3G вешать на сторонний контроллер. Как я понял именно использование 3G устройств, независимо от того в какой разъем подключены приводит к деградации чипа.
Заблокирован Статус: Не в сети Регистрация: 30.10.2007 Откуда: Одесса
zyn писал(а):
смешно читать тех, кто считает что проблема преувеличена если бы это было так интел не писал бы что им будет нужно потратить $700 миллионов на исправление рынок прореагировал - интел на пару процентов подешевел, амд на 5 процентов подорожал... на фондовых биржах не дураки сидят...
если бы все было так просто - на сцену бы вышел представитель интел, и повторил бы выступление стива джобса - "Вы неправильно вставляете винчестеры", "Это фича, просто используйте 6Gbps порты" и пообещал бы вам прислать "бесплатные бамперы" (pcie адаптеры sata).
Ну хз. Полгода-год назад была статья на тему несовместимости ХР и турборежима s1156. Там вроде USВ-порты начинали подтупливать малость. И что? Имхо на самом деле большинству плевать на производительность а все графики хороши только для фанатских дискуссий.
_________________ Если Бог за нас, кто против нас?(с) Библия В случае масштабных военных действий, эвакуация населения не только не производится, но и не планируется.
Статус: Не в сети Регистрация: 20.11.2004 Фото: 23
manon Моя мать не мониторит напряжение моста и сомневаюсь что у кого-то есть такая фишка, так что нужно мультиметром щупать. Бросков быть не должно, южник жрет копейки. Да, было дело.
Два порта значит на каком-то стороннем контроллере вися, за них можно не волноваться. Деградируют только 4 SATA3, в них лучше ничнго не засовывать. Или можно так: засунул в прт, он через годик здох, переткнул в другой порт и так пока мамку не сменяешь. Это если есть свободные порты, разумеется.
MagicBolls Температура - это не следстие, а причина.
Те не правильно понял.
Interestingly enough the problem doesn’t affect ports 0 & 1 on the 6-series chipset. Remember that Intel has two 6Gbps ports and four 3Gbps ports on P67/H67, only the latter four are impacted by this problem.
Добавлено спустя 1 минуту 19 секунд:
MagicBolls Температура - это не следстВие, а причина.
С этим конечно спорить сложно, но хочу заметить что на улице похолодало, дома тоже, охлаждение в корпусе не менялось, а температура выросла. И кто знает как именно деградация проявляется кроме как в замедлении быстродействия.
CoolCmd Да у меня хардов больше чем разъемов на мамке, а еще привод и е-сата на морду надо..... Может как вариант взять временно дешевый контроллер в ПСИ/ПСИ-Е и на нем пересидеть - мне харды жалко и инфу на них елси они будут страдать - на мать вообще пофиг - пусть подохнет - пойду и поменяю...........
CoolCmd Тогда почему там же рекомендуют медленные девайсы цеплять не на intel 6g а на сторонние контроллеры?
Добавлено спустя 1 минуту 19 секунд: MagicBolls Возможно просто разница температуры из-за версии BIOS? Поидее ошибки SATA должен мониторить тот же UATA CRC error rate, у вас там по нулям?
Последний раз редактировалось ego0550 01.02.2011 0:01, всего редактировалось 1 раз.
Я рассматривал данный вариант. И пришел к выводу что не было резкого скачка, от перехода к конкретной версии БИОСа. Возможно я упускаю какой-то момент или просто накручиваю себя. Надо ждать более развернутой официальной информации по этому вопросу. Я указал на этот факт, чтобы другие обладатели мат. плат на Р67 обратили на него внимание в работе своих плат. Опровергли или подтвердили его.
PS смотрел на паказатели в БИОСе и утелитах, а также на ощущения пальца.
Крупнейший американский online магазин NewEgg убрал ВСЕ процессоры и материнки Sandy Bridge и принимает все возвраты подряд по упрощенной процедуре! А наши продавцы я думаю с удовольствием будут продолжать барыжить браком
на этом сайте до сих пор реклама крутится, не удивительно что топик запрятали в раздел флейм
Статус: Не в сети Регистрация: 12.07.2005 Откуда: Краснодар Фото: 0
Партии дефектных микросхем были отгружены начиная с 9 января. Компания считает, что с вопросами замены продукции столкнется относительно небольшое число потребителей.
Я мать 12 купил января. Тоесть я никак не могу попасть под бракованные микросхемы. Так как партия их была с 9 января отгружена а не с Декабря. Вы это понимаете? Или брак идет начиная с выпуска первых партий. Или же определенной с 9 Января отгруженной?
Dr Kazay, скажите спасибо российскому отделению интел за молчание и учите английский все существующие сейчас чипсеты бракованные, не бракованые начнуть поставлять не раньше чем через месяц(!), не бракованым неоткуда сейчас взяться, фабрика интел печатала в январе и в декабре одно и тоже
_________________ '
Последний раз редактировалось zyn 01.02.2011 0:17, всего редактировалось 1 раз.
Фантазер. Есть у них в прайсе и маманьки и камни. Камни нет смысла запрещать, глючат только маманьки.
Но то что перебои с маманьками пол-месяца или месяц будет это точно. Только позже, когда у магазинов склады опустеют. Производители маманек по идее сейчас должны были остановить отгрузку и ждать три недели когда интел наклепает южников новой ревизии.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 35
