Статус: Не в сети Регистрация: 25.08.2005 Откуда: Novosibirsk
MuRoW А почему нет?
MuRoW писал(а):
(производительность не падает?)?
Даже наоборот - она растет!
MuRoW писал(а):
Подскажите следует ли его вообще разгонять
Конечно следует! Добавлено спустя 3 минуты, 22 секунды Процы на ядре NewCastle - разгон в среднем 2400-2500 Мгц!
Вот, прочти:
http://www.overclockers.ru/lab/19291.shtml
Northbridge nVidia nForce3 250 rev. A1
Southbridge nVidia nForce3 MCP rev. A2
Graphic Interface AGP
AGP Revision 3.0
AGP Transfert Rate 8x
AGP SBA supported, enabled
AGP Aperture 32 MBytes
Memory Type DDR
Memory Size 512 MBytes
Memory Frequency 201.0 MHz (CPU/9)
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 7
Bank Cycle Time (tRC) 12
DRAM Idle Timer 16
Memory SPD
DIMM #1
General
Memory type DDR-SDRAM
Manufacturer (ID) Kingmax Semiconductor (7F7F7F2500000000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number MPXC22D-38KT3R-FNA
Manufacturing date Week 00/Year 00
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
DMI BIOS
vendor Award Software International, Inc.
version F15
date 10/19/2005
DMI System Information
manufacturer unknown
product unknown
version unknown
serial unknown
UUID FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
DMI Baseboard
vendor Gigabyte Technology Co., Ltd.
model nForce
revision x.x
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (internal)
port type USB
connector Access Bus (USB)
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 78
