Всем не хворать! Вопрос такого плана... Пользуюсь программой MediaInfo для оценки качества скачанного видеофайла. Приведу пример результатов оценки:
1) Показатели для файла DVD:
General Complete name : E:\ФИЛЬМЫ DVD. ПРОДОЛЖЕНИЕ\ночь страха\VTS_01_2.VOB Format : MPEG-PS File size : 1 024 MiB Duration : 28mn 4s Overall bit rate : 5 098 Kbps
Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, Matrix : Default Duration : 28mn 4s Bit rate mode : Variable Bit rate : 4 192 Kbps Nominal bit rate : 9 800 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4/3 Frame rate : 29.970 fps Standard : NTSC Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.405 Stream size : 842 MiB (82%)
Audio #1 ID : 128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Duration : 28mn 4s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Video delay : -281ms Stream size : 89.9 MiB (9%)
Audio #2 ID : 129 (0x81) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Duration : 28mn 4s Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Video delay : -217ms Stream size : 51.4 MiB (5%)
Menu Format : DVD-Video
2) Оценка качества файла формата mkv:
General Complete name : E:\ФИЛЬМЫ HDTV. ЛУЧШЕЕ\семь.mkv Format : Matroska File size : 4.37 GiB Duration : 2h 7mn Overall bit rate : 4 922 Kbps Encoded date : UTC 2006-11-28 14:32:09 Writing application : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19 Writing library : libebml v0.7.7 + libmatroska v0.8.0
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Muxing mode : Container profile=Unknown@5.1 Codec ID : V_MPEG4/ISO/AVC Duration : 2h 6mn Bit rate : 4 056 Kbps Nominal bit rate : 4 150 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.184 Stream size : 3.60 GiB (82%)
В оценке обоих файлов присутствует 3 значения битрейта: Overall, просто Bit rate, и Nominal bit rate! Не ясно на какой из 3-х показателей ориентироваться для априорной оценки качества видеофайла? Согласитесь, что 9800 намного выше, чем 4192! Благодарю за ответ)
Статус: Не в сети Регистрация: 17.04.2008 Откуда: Москва
бит рейт - количество бит в секунду. чтоб узнать его в kbps, берешь размер файла в кб и делишь на время в секундах. вот чем номинал и простой битрейт отличаются - хз.
Статус: Не в сети Регистрация: 14.06.2006 Откуда: Нижние Матюги Фото: 109
Тут сравнение необъективное будет, т. к. уже кодеки разные.
Добавлено спустя 2 минуты 32 секунды: Overall - общий битрэйт, со звуком Bit rate - усредненный на всю продолжительность видео, фактический Nominal bit rate - битрэйт, выставленный в настройках при начале кодирования
Конкретный и исчерпывающий ответ, Уважаемый... Единственное, Nominal bit rate- это, случайно, не максимальный поток видео для ДАННОГО файла?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 69
