Куратор(ы):   fera2k    djon776
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 23507 • Страница 596 из 1176<  1 ... 593  594  595  596  597  598  599 ... 1176  >
Статус: В сети
Фото: 131
Опять 1шт. От Делла завезли в сити :D
5800х/MSI X570-A PRO/BallistiX 2x16Гб/Palit RTX 4080 Gamerock/AW3423DWF
Не совсем ultrawide но будут похожие модели скоро в данном сегменте
Acer Predator X27 Review - 4k 144Hz
https://www.limscave.com/acer-x27
Black Crush above 120Hz (144Hz)
The Acer suffers from black crush issues when using 120Hz @SDR mode. When using HDR @144Hz, the black crush does not appear.
Встречайте Black Crush теперь и на IPS :D
HDR SDR chroma subsampling
Выводы
Pro & Contra
Pro:
- Super sharp (4K) UHD screen with a very high pixel density combined with 120Hz (144Hz overclock) with G-Sync HDR Support
- 99% Adobe RGB Color Space coverage for best colors
- 384 individually controlled dimming zones (Local Dimming)
- Good gamma settings which are especially very important
- Overall a good and simple OSD Menu
- Superior white point and backlight uniformity. Much better than many other gaming monitors but still worse than graphics monitors for around 1300$ from Eizo or NEC for example.
- An excellent (!) responsiveness due to the higher PPI and the fast IPS panel
- No scanlines and artifact issues
- Best gaming monitor yet on the market for games & movies
- Awesome viewing angles and a very good IPS contrast. The IPS glow is not entering anymore the center of the screen and is not changing anymore in viewing angles and the distance to the monitor
- Included monitor shading hoods
Nice to have:
- A good foot stand
Neutral:
- You cannot change the brightness when using HDR (There is still a trick where you simply can reduce RGB settings to reach a lower brightness)
- SDR Blooming
- Quantum Dot colors in SDR mode look very unnatural and very oversaturated but they are doing a GREAT job for HDR and
- 4:4:4 HDR @ 10-Bit in the graphics cards settings (8-Bit + FRC monitor) only @98HZ
Contra:
- Only an "okay" build quality for this price tag. The build quality is equal to the Acer X34P for example, which has a good overall build quality (for around 1000$)
- Inverse Blooming
- HDR Blooming is clearly more visible than when using SDR
- Extreme weird build in fan which sometimes can get extremely loud, especially when mounting the VESA mount on the monitor without modding it to let the fan "breathe"
- The amount of the IPS Glow and Backlight Bleed is unacceptable for the price tag even when it looks better than on current WQHD 165Hz IPS panels with activated local dimming zones
- Black crush above 120Hz (144Hz)
В комментах там написал один из пользователей :
I have the PG27UQ, The stand base is metal and the top part is plastic. Bezels are 19.9mm top, 18.2mm sides and 22.3mm bottom. My fan is super quite and I have wc'd pc with 400rpm noctua NF F12 fans with a max of 800rpm.
и другой: :lol:
So its simply 4k 120hz 8 bit sdr monitor with 300 max brightness and poor contrast+ bad ips glow.
or 4k 98hz 10 bit hdr monitor with max 1000 peak brightness and buggy blooming + bad ips glow.
+trash fan
+small screen for 4k
aaaaaaaand its 2500 damn euro... lol
Обожаю твои новости читать :beer: всегда радуешь меня :D
Блек краш на прямом угле вот это да ! :shock:
Вот только это не Блек краш , а на последних фото видно что все это очень похоже на смену диапазона цвета.
На последних фото видно как цвет изменился с полного 0-255 до ограниченного 16-235.
Верхние квадраты окрасились в черный без различия в оттенках, видимо проблема в отображении диапазона цвета.
Если судить по квадратам на его фото то диапазон цвета стал 18-252 где черный примерно начинается уже на 18.
Жаловались на блек краш под углами у ВА , картинка высветлялась, зато на ипсе она теперь затемняется :D
Samsung C32HG70
Все ждали матрицу которая будет иметь достоинства всех матриц , а не все их недостатки :lol:
Глоу, засветы, вентилятор, проблемы с оттенками черного/серого, 4-2-2, 98Hz что дальше ?
Продолжение следует.....
Еще немного ипс мутирует до ....
R5 5500, Asus TUF Gaming B450-PLUS II, 32GB@3600Mhz, GTX 1080Ti, SSD 1Tb, Deepcool PQ650M, LG 32QN600-B, Spyder 4 DisplayCAL 3.8.9
Последний раз редактировалось Z1oiUzer 20.06.2018 17:13, всего редактировалось 1 раз.
Фото: 15
GRZ писал(а):
Нужен универсальный монитор для работы и игрушек (но всё же работа в гораздо большем приоритете) с IPS матрицей, диагональ 27-34.
Бюджет: не более 30.000 рублей, отдать - и забыть на долгие годы, а в момент покупки знать, что лучшего решения за ту же сумму не найти.
ржал в голос
Acer Predator X27 слева против обычного ипса 144Гц справа....
GRZ писал(а):
Бюджет: не более 30.000 рублей, отдать - и забыть на долгие годы, а в момент покупки знать, что лучшего решения за ту же сумму не найти. :-)
В 21:9 сегменте мониторы можно по пальцам пересчитать. LG 34UM69G-B безальтернативный вариант с этим бюджетом и вашими потребностями. В противном случае стоит присмотреться к 16:9 и задуматься стоит ли игра счеч ради 20 см. http://www.displaywars.com/27-inch-16x9-vs-34-inch-21x9
Я ранее писал, что у меня от этого монитора очень уставали глаза и я даже собирался его продавать, но спустя 3 месяца адаптации все стало хорошо.
такого сильного даже на хорошем VA нет
а потом выпустят типа обновлённую версию типа с хдми 2.1 и подороже якобы там у него характеристики лучше, а по факту тока порт поменяли
а по скорости матрица хорошая, даже у х34 мутнее тарелочка.
Я даже больше скажу, вы такого не на одном современном ВА не найдете :D
Я не знаю почему Лим назвал эту проблему Блек краш когда это откровенные проблемы с цветом ACER X27 и не более.
На 120Гц у него нет блек краша, а на 144Гц есть, любой человек знает (про любого утрирую :D ) что вылечить блек краш нельзя это особенность матрицы.
Для ВА блек краш это простой сдвиг гаммы под углами, сопровождается высветлением черного цвета, а так же добавкой паразитного оттенка, происходит сдвиг гаммы.
4 современных ВА и не на одном вы не найдете подобной проблемы ACER X27 :-)
Philips BDM3270 32-inch VA
Asus PB328Q 32-inch AMVA QHD
AOC AG352UCG Curved G-Sync
Asus ROG Strix XG35V
Последний раз редактировалось Z1oiUzer 20.06.2018 18:39, всего редактировалось 1 раз.
логично звучит, но как тогда называется когда фон чернее чем на самом деле?
Ничего если отвечу цитатой ? Из двух сотен обзоров на мониторы, автора которого все знают по фамилии но не знают в лицо :D
Цитата: из любого обзора Грыжина.
Максимальное же воздействие приходится на крайние тёмные оттенки, которые относительно быстро высветляются – тот самый Black Crush-эффект, или, если говорить простым языком, более сильный цветовой сдвиг, чем у IPS/PLS/AHVA-решений.
Тем же, кто вспоминает о неразличимости тёмных оттенков у старых *VA, можем сказать следующее: производители давно победили эту проблему правильной заводской настройкой, а там, где она не проведена, всё исправляется дополнительной ручной настройкой и калибровкой.
Вот в случае с Acer Predator X27 4k 144Hz производитель не победил и не сделал правильную настройку :D
Я вот отменил заказ на Асер и сохранил 3000$ ;)
Последний раз редактировалось Z1oiUzer 20.06.2018 19:26, всего редактировалось 1 раз.
The panel production for the VA panel used in the Acer Predator X35 and ASUs ROG Swift PG35VQ is expected in July so we wouldn’t expect monitors until around October right now
https://twitter.com/TFTCentral/status/1 ... 4590770177
Working on the review of the @ViewSonic VP3881 professional range monitor with 37.5” ultra wide IPS panel, hardware calibration and uniformity correction features
кстати если верить тфтцентралу то HP Omen X35, AOC AGON AG352UCG, Asus ROG Strix XG35VQ, AOC AGON AG352UCG6 (120Hz) все они на одной матрице и надежда что aoc ag352ucg6 на новой матрице не оправдываются.
http://www.tftcentral.co.uk/articles/hi ... h_rate.htm
BesInc как всегда радуешь полезными ссылками :-)
Жду Декабря :-) 31.5" flat 165Hz
Z1oiUzer
Да Лыжа наконец выпустит продукт в обоих сегментах
27" 2к ips 165гц где раньше царила AUO
и 32" 2к 165гц.
а вот сегмент игровых и доступных 24" и 27" fullhd 144hz опять продинамили похоже. там так и будут царить TN и VA.
BesInc писал(а):
32" 2к 165гц.
Надеюсь он не 100к будет стоить :D , сижу такой думаю если сборка ВА от лыжи стоит 50К :roll:
Z1oiUzer писал(а):
и сохранил 3000$
Прикольно, несколько минут назад было 2000.
Так то это был сарказм (тонкий юмор) , просто подумал что за 2000 его в Росссии не продадут, поэтому исправил ;)
на эти денжыща наверное лучше телек нормальный взять и соньку и то больше кайфа будет чем с купутера
Всем привет. Кто подскажет, нормально ли будет играться на ultrawide 34 дюймовом мониторе в быстрые онлайн шутеры? И сильно ли при этом будет виден эффект шим, шлейфы и т.п. на ips матрице?
Последний раз редактировалось adept1 20.06.2018 23:26, всего редактировалось 3 раз(а).
Присоединяюсь :beer:
adept1
в шутеры имхо не сильно удобно когда приходится смотреть на миникарту или хп бар расположенные по углам.
Сейчас этот форум просматривают: sirshadow123 и гости: 7
