Статус: Не в сети Регистрация: 20.12.2014 Откуда: СПб Фото: 1
Купили вчера Dell AW3418DW. Долго смотрели на матрицу и нашли таки пиксель. С одной стороны горит красным, с другой зеленым. Сначала не хотели брать, потом решили все-таки взять, с мыслью о том, что если будет бесить - заменим. Равномерность подсветки на мой взгляд хорошая. Из косяков отмечу провсет диода подсветки кнопки питания через рамку, и большую подставку. В остальном пока норм.
У вас нет необходимых прав для просмотра вложений в этом сообщении. _________________ [9900K][XI Formula][G.Skill 3200 cl14 4*16GB][GIGABYTE MSI 3080Ti suprim X ][SSD Samsung 970 Pro 512GB][DELL U3417W]
A 34″ 3440 x 1440 (21:9) UltraWide screen is employed, using a Samsung SVA (‘Super’ Vertical Alignment) based panel. This includes a 1500R curve, designed to draw you in for a bit of extra immersion without feeling unnatural or uncomfortable. Some would tell you viewing comfort could be enhanced by the curve, in fact, and for screens as wide as this the curve tends to make sense. A 3000:1 static contrast ratio is specified alongside 178° horizontal and vertical viewing angles, whilst a light matte anti-glare screen surface is employed. A 144Hz refresh rate is supported with Adaptive-Sync, including support for AMD FreeSync on compatible GPUs and systems. The variable refresh rate range is 48 – 144Hz with LFC (Low Framerate Compensation) supported. True 8-bit colour is supported, whilst a flicker-free WLED backlight is used offering 91% DCI-P3 colour space coverage (~115% sRGB and 98% Adobe RGB specified). Alongside a 300 cd/m² typical maximum luminance. The monitor provides basic HDR support – it will respond to HDR content, but does not comply with even the lowest level of VESA DisplayHDR certification.
A 1ms MPRT response time is specified using the included MBR (Motion Blur Reduction) strobe backlight function. As usual, take any specified response time with a good dose of salt. “Low Input Lag” is also noted in the specifications, whilst the monitor includes a range of LBL (Low Blue Light) settings for enhanced viewing comfort. The monitor attaches centrally to the included stand, with a mixture of matte black plastic and red elements included at the rear. The stand offers tilt, swivel and height adjustment. A quick-release mechanism is included, allowing the included stand to be easily removed and replaced with an alternative 100 x 100mm VESA compatible solution. The ports face downwards and include; 2 DP 1.4 ports, 2 HDMI 2.0, 4 USB 3.2 ports, a 3.5mm headphone jack and an AC power input (internal power converter).
It’s listed for ~$450 in the US with release expected December 15th 2019.
Я правильно понимаю что на 3440 x 1440 мониторе будут полосы при просмотре ЛЮБОГО видео ? ну то есть, HD 1080px будут полосы, UHD в природе в 2 форматах 3840x1600 и 3840x2160, оба не совпадают с обеими сторона 3440 x 1440
Вроде разобрался, получается такое масштабирование с сохранением пропорций 1. 3840x1606 -> ок, 3440 x 1440 (похоже именно для этого делают странный размер 3840x1606) 2. 1920x804 -> ок, 3440 x 1440 3 1280x536 -> ок, 3440 x 1440
4. 3840x2160 -> полосы слева и справа (преобразуется в 2560х1440) 5. 1920x1080 -> аналогично п.4 ^ 6. 1280х720 -> аналогично п.4 ^
т.е противоположность к 16:9 - где были с полосами сверху и снизу полос не будет, где полос не было на 16:9 - будут слева и справа
Куратор темы Статус: Не в сети Регистрация: 10.01.2010 Фото: 2
ApA писал(а):
IIYAMA ProLite XUB3493WQSU-B1
ApA писал(а):
Стоит брать?
Монитор без наворотов и пафоса по самой доступной цене, раньше он за 40к.+ стоил, сейчас даже чуть менее 30к.
Качаем рип формата 2,40:1 (видео: 1920x804)и не надо ничего растягивать, сериалы все формата 16:9, полосы будут в любом случае. Сейчас все фильмы выкладывают формата 16:9, это все рипы 1080p, + делают рипы под 21:9 из этого исходника.
Ребят что выбрать, бюджет 65-70к, взять ЛЖ 34GK950G или dell aw3418dw. С деллом вроде как смущает что не стоит он своих денег, в штатах его по 700 баксов продают без скидок, а у нас за него до 80тр ломят.. У лыжи при этом цена и у нас, и забугром сопоставимая. И чем проверять их в магазе? Все проги вроде tfttest и nokia monitor test уже не поддерживают разрешения выше 2500.. А тут 3400. Юзать буду под фильмы, игры, серфинг в инете. Видяха 1080ти и менять не планирую, мысленно уже смирился с низким фпс.
я лыжу взял, вчера привезли, тоже дел смотрел как один из вариантов по сути вся разница в едва уловимой цветопередаче (sRGB - 89/97% у дела vs 99/134% у лыжи) плюс у лыжи подсветка прикольная стену освещает проверял дома при доставке, к ноуту подключил и там AIDA64 с картинками (достаточно чтоб проверить) падений фпс кстати не заметил, по крайней мере взглядом (софт для отображения FPS отвык юзать после покупки 1080ти), мб это gsync там колдует
Последний раз редактировалось Gefest. 07.11.2019 10:37, всего редактировалось 1 раз.
Статус: Не в сети Регистрация: 18.07.2017 Откуда: Кубанистан Фото: 6
Лыжу видел в технопоинте за 60к. У делл плюсом только расширенная гарантия, матрица там такая же, материалы на любителя (маркий глянец). Стоит ли переплата за бренд и +1 год гарантии почти в 20к - решать вам.
_________________ i9-9900K/ MSI RTX 2080S Gaming X Trio @2040/18000 MHz/ MSI MEG Godlike Z390/ NH-D15/ 32GB DDR4 Viper 4 Steel @4400 MHz/ Seasonic Prime Titanium 850W
Статус: Не в сети Регистрация: 24.08.2016 Фото: 0
Матрица не такая же. у LG 5 ревизия матрицы у Dell 4. 5 ревизия нативно 144гц, 4ая -100гц. Но из-за ограничений пропускной Gsync модуля у 950g нет поддержки 144гц, нативные 144гц есть у 950f
Несколько раз в месяц происходит мерцание экрана, не в прямом смысле, а торможение при свертывании окон. Лечится сбросом разгона до 100Гц либо нужно поиграть в профиле и выставить 115Гц например. Поэтому, лучше монитор с базовой частотой 144Гц, 100Гц кажется мало, конечно лучше 60гц, но недостаточно.
Статус: Не в сети Регистрация: 15.03.2019 Фото: 1
Подскажите, пожалуйста, если я предпочитаю запускать видеоигры и смотреть фильмы в темной комнате, то монитор с каким типом матрицы лучше предпочесть: IPS или VA? Дело в том, что я сильно опасаюсь IPS-glow.
