Что посоветуете взять из этих моделей. Монитор нужен для игр, фильмов и интернета. Если есть обладатели ниже перечисленных мониторов, расскажите пожалуйста о ваших впечатлениях (цветопередача, скорость матрицы, углы обзора и т.д.)
BenQ E2400HD ASUS VW246H Samsung 2494HM
The Acer Nitro VG0 gaming monitors will be available in North America in June starting at $129.99; in EMEA in May starting at €129; and in China in May starting at ¥999.
These new IPS5 monitors with AMD Radeon FreeSync fits in the gaming spec with a blazing fast response time of up to 1 ms Visual Response Boost (VRB) and a 144Hz refresh rate. The Acer Nitro VG0 series is available with 27-, 23.8- and 21.5-inch panels delivering true-to-life color, and resolutions of 4K UHD, WQHD or Full HD. The ultra-thin Acer Nitro RG0 series boasts a sleek .27-inch thin profile and is offered in 27- and 23.8-inch models.
Boasting AMD Radeon FreeSync, the new Nitro monitor’s frames sync with the graphics card’s frames to eliminate screen tearing and minimize lag, allowing for smooth gaming. Integrated Visual Response Boost (VRB) decreases blur in fast moving images to achieve the effect of a 1ms MPRT, along with up to 144 Hz refresh rates. Integrated 6-axis color adjustment lets gamers fine-tune color, hue and saturation to best suit the game at hand, while built-in black boost enables gamers to select from 11 black level options for personal preference
вот только The Nitro VG0 series is available with 27-inch, 23.8-inch, and 21.5-inch panels with resolutions of 4K UHD (3840x2160), WQHD (2560x1440), or Full-HD (1920x1080). https://www.anandtech.com/show/12804/ac ... eesync-ips
Добавлено спустя 19 минут 31 секунду: https://www.computerbase.de/2018-05/ace ... tore-1-ms/ а тут пишут vg0 вообще разные одни в 3 размерах 1080р Acer VG0 Series (VG220Q, VG240Y, VG270) другие в 3 размерах и 3 разрешениях Acer VG0 Series (VG240YU, VG270U, VG270UP, VG270K)
На мониторе с IPS матрицей есть один пиксель, который на чёрном фоне горит синим, а на тёмно синем фоне чёрным. При комфортном для глаз расстоянии я его не вижу. Возможно ли такое вылечить? Конечно есть вариант в магазин вернуть/поменять, т.к. монитор только недавно(меньше недели назад) куплен(курьерской доставкой), но ехать до магазина далеко и не очень удобно.
P.S. оставлял на ~1,5 часа открытый JScreenFix = пиксель стал заметно тусклее(на чёрном почти не виден синий оттенок), но всё же он присутствует.
Посоветуйте монитор с IPS матрицей до ~16к. Для игр, но не гонюсь за герцами, 60 хватит. Очень важно качество матрицы. Желательно диагональ 24+(27 в идеале). Как вариант: BenQ BL2780T, но сомневаюсь в его качестве.
Статус: Не в сети Регистрация: 14.06.2009 Откуда: Омск
alexsam писал(а):
Похоже, новая матрица, еще и время отклика заявляют 1 мс
Сомнительно. Если бы была новая матрица, то ещё бы кто-то тоже анонсировал подобное. Да и 1мс у ips не может быть, даже с разгоном. Вообще не верю в общем, несерьёзный какой-то анонс, даже на оф сайте нет четких спецификаций.
Y1ROK писал(а):
и наконец-то начнут выкатывать новые мониторы без 90% брака
Про 90% ты конечно загнул. Ну а если там и действительно что-то новое, то брака будет как раз примерно столько)
alexsam писал(а):
Вот черт, собрался ехать выкупать philips 243S, отказываться что-ли???
Начитался новых обзоров, захотелось 24" 144Гц IPS. Но уже забрал филиппок. Пока новые видеокарты выйдут, пока новые мониторы до России доедут еще почти полгода пройдет, а там видно будет.
