Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 41271 • Страница 1248 из 2064<  1 ... 1245  1246  1247  1248  1249  1250  1251 ... 2064  >
Old post...
BenQ E2400HD
ASUS VW246H
Samsung 2494HM
Bomchik писал(а):
а что вообще это такое? Я что-то в гугле не могу найти. Все к принтерам отсылает такое название.
https://pcmonitors.info/reviews/aoc-g2590px/
Interlace pattern artifacts
Some models exhibit what we refer to as ‘interlace pattern artifacts’, particularly but by no means exclusively those with high refresh rates. These artifacts can also be referred to as ‘inversion artifacts’ or ‘scan lines’. Sometimes static interlacing patterns are visible, whereby shades are broken up into thin (usually vertical) lines that alternate between a slightly lighter and slightly darker than intended variant of the shade. Dynamic interlacing patterns may also be observed, which take many forms and sometimes appear as a sort of mesh, grid or lines or ‘interference’ when you observe motion on the monitor.
The G2590PX did not show obvious static interlace pattern artifacts, but we did observe quite strong dynamic interlace patterns. When movement was observed on the screen, the image sometimes appeared to break up into an interference pattern composed of vertical pinstripes. We found it quite noticeable, even from a viewing distance of well over 70cm. Although we noticed the effect and would much prefer it wasn’t there, we wouldn’t say it was too distracting when focusing on gameplay. At lower refresh rates this effect became more pronounced, being quite obtrusive at 60Hz to our eyes. It’s worth remembering that how obvious a user finds these patterns depends on the viewing distance, their eyesight and sensitivity to such things.
Сложно объяснить как это выглядит. Как легкие вертикальные прозрачные линии, иногда заметны при движении головы на некоторый оттенках(на статичных картинках, тот же браузер) или же в играх при движении на некоторых текстурах. При низкой частоте(на 60Гц) оочень сильно полосит. При 144Гц это слабо заметно, может вообще не заметите.
Здравствуйте,форумчане!
Не могу определиться, выбором, хочу монитор для игр, диагональ 23-24, отклик 1мс и возможно 144гц
Бюджет 10-15к
Смотрел эти:
Acer Nitro VG240YUbmiipx
AOC g2460Fq
AOC G2590VXQ
Есть у кого такие?
Или ваш вариант... спасибо!
Кто-нибудь может рассказать про качество мониторов Dell.
В частности интересен S2419H
Geeforce RTX 3070//Ryzen 5 3600//ASUS TUF B450-PRO GAMING//Samsung 860 EVO 500 Гб//G.Skill Ripjaws V 32 ГБ//be quiet! PURE POWER 11 CM 600W Gold
Здравствуйте.ViewSonic 23.8 "VA2419-SH изображение белесое черный цвет серый какойто.У ips так всегда?Прошлый acer на va черный действительно черный и цвета очень яркие.При включение холодильника тухнет экран на 1 секунду вероятно скачек напряжения в сети происходит это норм?
Боюсь тебя ждет немало разочарований от современных мониторов после после VA старой школы. Могу посоветовать на всякий случай проверить динамический диапазон в настройках видюхи, чтоб он был "0-255", а так же сбросить настройки моника и яркость выкрутить на минимум для проверки.
i7 10700k, ASUS Z490-P, Palit 4070TiS (Gaming PRO OC), 2*8 DDR4 Samsung, SSD 256 850Pro+512 860Evo+4Тб+4Тб, БП CHIEFTEC GPM-750S, мон S27BG650EI
Фото: 37
В общем, приобрел AOC С24G1. Субъективно - хороший монитор. Как по качеству сборки, так и картинки. В играх просто бомба. Но, есть вопросы. Пара битых пикселей по углам (не критично, туда почти и не смотрю никогда, в играх вообще не видно, т.к. они не светятся). Есть ощущение, что грязная лицевая панель матрицы, т.е. когда смотришь почти впритык на белом фоне много темных пятнышек внутри. Не знаю, может ли такое вообще быть? Они еле заметные, полпикселя. Но это точно не битые пиксели. Хотя, я не понимаю что это ) На расстоянии в половину вытянутой руки не видно (а битые пиксели виднеются на расстоянии руки).
В сравнении с samsung c24f390 (рабочий): У самса картинка все-таки получше, черный более черный. У С24G1 я вообще не понял, что с черным. Моя старая TN Benq показывает более глубокий черный цвет (т.е. черный на экране, как черный пластик рамки, нет явного различия в цвете с реальным). А тут он какой-то вообще не черный. Какой-то темный фиолетово-бордовый что ли, с каким-то переливом. Это видно на панели задач Win10. Я даже полез смотреть настройки цвета в драйверах (цветовой диапазон). Но потом подключил сразу 2 моника к одной видяхе, и разница на лицо. Это огорчило. С24G1 показался немного ярковатым ночью, при снижении яркости картинка теряет в цвете, поэтому только фиксированное значение. Настройки брал с сайта https://pcmonitors.info/reviews/aoc-c24g1/, как и цветовой профиль. При включении ночного режима в win10 глазам становится комфортнее. Шрифты что на самсе, что на ЛОСе "волосатые" (опять же "палится" на панели задач) , на TN benq такого нет, опять же это видно только впритык. Да и вообще, если этого не знать, то никогда и не заметишь.
Но все это фигня, "парит" меня следующее: Затемненные области сантиметра по 3 от левого и правого края (особенности подсветки или матрицы?). И на левой области я вижу еле заметное межпиксельное пространство! Как на пассивной 3д панели. А на правой нет ) Выглядит, как темные еле еле заметные полоски. Особенно видно на НЕ белом цвете, а, например, список контактов вайбера. Заметить трудно, но глаз цепляет. Владельцы С24G1 отзовитесь, есть ли у вас такие проблемы? Что вообще это за хр**ь? Можно ли нести обратно. как брак?
Все это дело подключено по DP на 144hz.
Ryzen 5600x, Asus b550i, 32Gb 3600cl16, rtx 3070, SBlasterX G6, SF600pl, Ssupd Meshlicious, Gigabyte fi25f
idhas
Если бы была хоть одна из описанных проблем, они бы всплыли бы хоть в одном из обзоров. Фото дефектов бы. У меня ничего подобного не замечено.
Некоторое время сидел на пресете каналов с pcmonitors, сейчас сижу на пресете "warm" + яркость 35. Профиль не стал ставить, в играх и так все нормально. Шрифты лохматые - контрятся либо масштабированием до 125% либо игнором сего факта. При убавлении яркости цветность никуда не исчезает, имхо это так кажется на контрасте меду яркой и задавленной картинкой.
Фото: 37
aggile
Попробую сделать фоток. Но то, что нет в обзорах, это не значит, что этого не может быть.
Лечить "волосатые" шрифты не вижу смысла, тем более масштабированием, этого не видно все равно.
А с черным как обстоит дело? Есть с чем сравнить?
ицы не меряют программами, то что вы там смотрите это время кадра. Как раз для 60гц оно 16мс. Отклик матрицы измеряется спец оборудованием. Оно есть далеко не у всех обзорщиков.
redstorm333 писал(а):
шлейфов нет
Ага и ниже ваше же видео со шлейфами от колонн)))[/quote]
а так это шлейфы а не разрыв кадра понятно .То есть у мен и на ютубе шлейфы а не разрыв кадра .
Так и в аниме при смене панорамы -то же шлейф?
блин мне нужен монитор без вот таких шлейфов и трясушейся лагающей панорамы в аниме)
блин я в печале и теперь не знаю что взять -мне эти шлейфы везде мерщится будут)
блин на что его поменять ?в озене там где брал из бюджетных .НО горят ИПС еще хуже ВА -но это же самсунг -может шлейфов не будет .
Samsung S27E391H
или опять на унылыую ТН вернутся (ияме доверия нет у их апис шлейфы еще хуже - тн хз )да и цвета на ВА конечно в два раз лучше -но где найти не тормознутую ВА за 15 к .
ли вот на такой асер добавить?там типо г-син 1 мс для игр .
Монитор Acer RG270bmiix -н оуже в другом магазине брать.
Я уж не знаю посоветуйте что нибудть до 15 к -без шлефов ,разрывов кадра и нормальной смены панорамы -деблюр наверно надо ?
Каждый субпиксель на ВА состоит минимум из 2 частей которые могут гореть независимо. То что вы описываете может быть битой частью этого субпикселя. Чтоб это понять надо увеличительное стекло.
Фотки с такой же проблемой на этом монике видел на реддите и еще где-то
А в антибликовом покрытии есть отличия?
Ну это засветы матрицы. Тут такое дело, что они могут как увеличиться, так и уменьшиться. Вообще, по опыту, я бы после покупки нового моника погонял его на яркости близкой к максимальной на всяких ярких динамичный роликах(даже тогда когда не за компом). Если можно так выразиться, надо прогреть матрицу, чтобы за 7 дней понять что с засветами, в какую сторону идут изменения и если не устроит по возможности вернуть.
Это линии сканирования, бывают как вертикальные, так и горизонтальные. Это можно назвать "нормой" для высокогерцовых моников, тн точно, из VA на самсунге(144Гц) тоже такое есть. Это никак не убрать, но при низкой герцовке эти полосы пропадают или становятся менее заметны. Возможно даже на 120 их уже не будет видно. Да, и это не гарантийный случай.
И еще такой вопрос. Почему не взяли самс 144Гц(при том что самс на 60Гц с такой же матрицей уже имеется), из-за цены?
на 60-75Гц от деблюра глаза вылезут.
Вот самый быстрый моник 27" 75Гц, но это тн
Iiyama GB2730HSU-1
Про разрывы кадра не понял ниче. Это тиринг, без всинк в играх он будет всегда. Чтобы его не было надо юзать всинк(привет инпут лагу) или брать амд карту и моник с фрисинк, а если нвидиа то моник с гсинк. Это если мы про игры. В фильмах и роликах никакого разрыва кадров не должно быть.
панорамы в аниме)
ЧЕ ПАЦАНЫ АНИМЕ (гуглится) :lol:
Добавлено спустя 13 минут 11 секунд:
ах да, она и будет трясущаяся, т.к твое ониме наверное 30 фпс, а моник 60Гц(ну или 75). Такое будет со всеми фильмами и роликами, это норма как бы. Юзай svp тогда, раз надо плавности, перегоняй 30 фпс в 60, но там есть небольшие артефакты.
Добрый день камрады!
Подумываю сменить свой dell u2311h(fullhd ips).
Два дня читал отзывы и обзоры того что сейчас продается на рынке.Но так ничего и не присмотрел-))
Подскажите модели с такими требованиями:
Бюджет до 22000
23-24 дюйма,ips(c хорошей цветопередачей),матовый.
Или же дальше сидеть на своем и ждать 120-140гц ips с таким размером?
вот че ты ржешь при просомотре аниме часто понорама едит в бок или вверх без смены кадра - и именна эта смены панорамы лагает .И на старых моих тн и но этом бенке -этот эффект .
меня это вымораживает - в кино такого или не или не заметно
Iiyama GB2730HSU-1 -ты этот моник в реале вдел ,пользовался?
я моуг поднапрячся и взять самый дешевый 144 гц за 18 к -ток у меня в нормальных играх больше 60 фпс не бывает а в основнмо 45 .))
https://market.yandex.ru/product--monit ... fers-first
сначала надо определиться зачем, а там уже думать дальше. :-)
я сказал почему это. Ставь svp, смотри есть при 60 фпс такое или нет.
Я видел обзоры(видео) и у меня есть тн моник на 24.5 матрице этого же поколения. Просто ты определись тебе шашечки или ехать. Яркости/красивости, но мазня и шлейфы, или не столь яркие звенящие цвета, но макс скорость. Все сразу не бывает. Хотя нет, бывает, но это 2к 27" ипс 144Гц за 35к + , но оно не подойдет тебе для ониме и для игр, т.к надо оч мощное железо.
в этом нет смысла.
Фото: 37
Это какой Samsung? Если C24FG73FQI, то из-за дизайна: нога огромная, порты в горизонтальной плоскости, внешний БП.
А по поводу покрытия: на самсунге оно матовое, на ЛОСе как-будто полуматовое, но 100% комфортное.
огромная нога у fg70, y fg73 обычная нога.
внешний бп это ведь плюс, а не минус.
да он. Выбирать из-за дизайна такое себе, главное изображение, имхо. Тут же тоже нога не меленькая, порты тоже как-то спорно, вы не вплотную к стене его ставите(хотя тут могут быть варианты), да и кронштейн можно прицепить( - большая нога) , внешний БП - по мне так плюс, меньше греется матрица.
Просто если сравнивать качество картинки вашего самса и на 144Гц - это практически одно и тоже, там даже матрицы с одним индексом, только разных ревизий. Видимо на 144Гц версии просто добавили слой квантовых точек, поэтому картинка на нем более насыщенная(в красных и зеленых оттенках).
Фото: 37
Ну, обзоры-то я почитал, по ним качество картинки хорошее, да и меня оно устраивает, тем более, что хотел именно игровой монитор. Затем цена. Монитор своих денег однозначно стОит. И после того, что вы мне рассказали, думаю, претензии к нему отпали. А бегать глазами выбирать монитор просто лень. Да и в нашем городе - это нереально, на полках не найти. Поставить 2 рядом и сравнить - физически невозможно. Я этот-то ждал неделю, пока придет.
idhas да это понятно. С самсом тем тоже куча всяких проблем, если даже не больше чем с этим, то засветы, то битые пиксели. Вообще все хай Гц моники это лотерея. Так что не известно что лучше, да и аок этот не плох в любом случае.
Хочется более интересную картинку-))
Или я вообще не замечу разницы если взять моник с такой же диагональю плюс минус,на ips матрице,но на led подсветке и чуть большей герцовке?
Мой больше 65 не может.
idhas
Черный нормальный, кстати. Были IPS и были TN рядом, на этом лосе он чернее. По оттенкам у моих глаз и калибратора претензий к черному также нет :) В настройках, случайно, не включен какой-нибудь заводской пресет или дополнительные фильтры изображения (зелень, кожа и т.д. ) ? Они реально там жуткие. У меня все по дефолту (как после сброса), только правленые ргб, яркость и овер на высоком стоит - картинка норм.
