Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 386 • Страница 14 из 20 • <  1 ... 11  12  13  14  15  16  17 ... 20  >
Получилось как-то так (подключение DVI-D single-link, возможно в этом и проблема):
winXP - GW2760@73Гц+Nvidia gtx560
частота - 73Гц
Ручные настройки:
It's probably better to use these instead
Horizontal Active: 1920
Horizontal Front Porch: 20
Horizontal Sync Width: 20
Horizontal Total: 2070
Horizontal Sync: +
Vertical Active: 1080
Vertical Front Porch: 4
Vertical Sync Width: 5
Vertical Total: 1090
Vertical Sync: +
Выше поднять частоту не удалось без дефектов - "снег".
Monitor Asset Manager
Monitor
Model name............... BenQ GW2760
Manufacturer............. BenQ
Plug and Play ID......... BNQ78C6
Serial number............ H9D07428019
Manufacture date......... 2013, ISO week 38
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 600 x 340 mm (27.2 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.1
Display technology....... TFT
Controller............... Mstar 0x5800
Firmware revision........ 3.10
Firmware flags........... 0x0000005A
Active power on time..... 55 hours
Power consumption........ Not supported
Current frequency........ 80.00kHz, 73.00Hz
Color characteristics
Default color space...... sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.645 - Ry 0.334
Green chromaticity....... Gx 0.331 - Gy 0.629
Blue chromaticity........ Bx 0.155 - By 0.047
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-83kHz
Vertical scan range...... 50-76Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1280 x 1024p at 60Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1600 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
Report information
Date generated........... 07.02.2014
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0071
Operating system......... 5.1.2600.2.Service Pack 2
Raw data
00,FF,FF,FF,FF,FF,FF,00,09,D1,C6,78,45,54,00,00,26,17,01,03,80,3C,22,78,2E,2C,C5,A5,55,54,A1,27,
0C,50,54,A5,6B,80,81,80,81,C0,81,00,A9,C0,B3,00,D1,C0,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,56,50,21,00,00,1E,00,00,00,FF,00,48,39,44,30,37,34,32,38,30,31,39,0A,20,00,00,00,FD,00,32,
4C,1E,53,11,00,0A,20,20,20,20,20,20,00,00,00,FC,00,42,65,6E,51,20,47,57,32,37,36,30,0A,20,00,D0
скорее всего да.
6600k(boost 100x45/cache 44)скальп|Prime Z270-A|BL2K8G32C16U4B/8x2@3600/15-19-19-38/1.35v|msi gtx 1060 6g oc|BenQ GW2760HS|MZ-V6E250BW(win7x64)
товарищи, подскажите пожалуйста, старый моник самсунг приказал долго жить и покинул меня... встал выбор нового моника, из вариантов есть:
BenQ 27" GW2760HS
Dell 27" S2740L BK
Asus 27" MX279H
Acer 27" S276HLtmjj Titanium
Монитор LG 27" 27EA33V
Benq EW2730
что можете посоветовать из этого списка? самый более менее оптимальный вариант...
Добавлено спустя 7 часов 52 минуты 22 секунды:
взял BenQ 27" GW2760HS подскажите где свежие дрова скачать и более менее подробный монуал по настройке найти?
Добавлено спустя 1 час 27 минут 32 секунды:
не битый ли это пиксель братцы ?
Добавлено спустя 21 минуту 1 секунду:
Albulane писал(а):
Etevi Большинство делает по этой схеме BenQ GW2760HS #11586802
как сделаешь, отпиши пожалуйста как всё прошло. (взял ли монитор 75гц или нет)
п.с. на наклейку не смотри, это всё ерунда
мой экземпляр взял 75гц спокойно, ну по крайней мере пока что небыло замечаний по работе... 1 день только, пока все тесты и настройки!
Нас не сбить с пути, нам пофигу куда идти!
похоже на битый
есть ли смысл нести в магазин чтобы заменили?
Добавлено спустя 2 минуты 41 секунду:
да и как бы точно определить битый ли?
из-за битого пикселя не меняют. Лишь если магазин пойдет на уступки (так как несколько битых пикселей не являются основанием брака)
Добавлено спустя 37 секунд:
если он выделяется среди всех и не вытирается тряпкой (вдруг крошка или еще что) то битый
gar1n14
То что у вас на фотке на битый не похоже, скорее какое то светлое пятнышко. Битый он или тёмный, или светится определённым цветом.
them писал(а):
gar1n14
вопрос более не актуален, обменял монитор на нормальный!
Фото: 21
gar1n14 Правильно сделал.
В этой теме это уже 3-ий монитор с белыми засветами (включая мой)
монитор BENQ GW2760hs
Фото: 21
them зря, по мне так яркость вполне нормальная на минимуме.
Albulane
Самому жалко, но почти за два месяца так и не смог адаптироваться. Глаза дороже.
Фото: 21
them я когда первый раз включил на заводских настройках, у самого чуть глаза не вытекли =)))
убавил яркость практически в минимум, сразу привык, а недавно ещё побольше добавил (поставил яркость на 10), вполне комфортно.
Понимаю конечно что каждому своё, но просто, как мне кажется, за эту сумму сейчас чего-то более стоящего не найти, к сожалению
В эту сумму Iiyama ProLite X2483HSU, диагональка поменьше правда, но не беда.
а вы контраст пробовали уменьшать?
мне комфортно при 39(и днём и ночью). дефолтные 50 для меня перебор.
Конечно. Для тырнета ставлю яркость 0, контраст 30. Днём, когда яркий свет из окна, вроде как и нормально. А вот вечером/ночью не фонтан. Яркое искусственное освещение не люблю, сижу с настольной лампой. Может тут ещё причина в диагонали и отображении текста? На резкости 4 вроде как немножко мутновато, а на 5 уже перебор. Сейчас сделал браузер в оконный режим 4:3, вроде как получше.
Для фото/видео использую контраст 50, яркость 5-10.
P.S. Сейчас смотрел док.фильм "Жизнь" в full hd, обалденно, очень нравится цветопередача. Уже жалко продавать... :-(
у меня такие настройки - попробуй
яркость 0
контраст 39
четкость 4
гамма 3
Цвет.темп – User Define – 98,5/100/98
ночью сижу без дополнительного освещения(logitech luminous keyboard) :-)
а браузер я сразу на 4:3 перевёл.
Добавлено спустя 10 минут 58 секунд:
чтоб ещё больше понравилась - выставите по тестам настройки видеокарты.
http://forum.ru-board.com/topic.cgi?for ... art=140#19
Фото: 21
А не проверялись эти настройки в KMP плеере?
я всё видео только через него смотрю.
Если я всё правильно понимаю, то выставляется не в видеокарте, а именно в самом плеере, да?
скачайте 3 файлика - проверьте сами как оно у вас показывает.
почитайте дальше по ссылке. - в конечном итоге лучше это делать в настройках видеокарты - тогда видео на всех плеерах будет отображатся с правильной цветопередачей.
вот мои настройки видео для nvidia.
Добавлено спустя 6 часов 28 минут 3 секунды:
Фото: 21
caligula73 блин, чёто я туплю, эти же настройки для видеокарты нормально заработают при условии что на самом мониторе будут вот эти настройки
яркость 0
контраст 39
четкость 4
гамма 3
но у меня на мониторе стоят немного другие, значит придётся всё подгонять самому под свои настройки, не прокатило на халаяву слить :lol:
Цветовую температуру сделал по рекомендации ( 98,5/100/98)
яркость у меня 10
контраст стоковые 50
резкость 4
гамма 1
