Куратор(ы):   fera2k    djon776
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 23529 • Страница 335 из 1177<  1 ... 332  333  334  335  336  337  338 ... 1177  >
Aqulibrium писал(а):
Кто в курсе 34UC99-W на 75 Гц+Nvidia кадры не пропускает?
Или на нем 75 Гц нормально работают также как и на 88-м, только с AMD?
Да ладно.. по любому же кто-нибудь купил?
скорее всего да
Refresh Rate 60 Hz / 75Hz with Display Port with FreeSync
http://www.lg.com/us/monitors/lg-38UC99 ... de-monitor
для 88 и 98 есть такая инфа, скорее всего для 99 тоже.
75гц разблокировали без пропуска кадров вставив в систему карту от амд в качестве второй, монитор подключен к нвидиа. решение так себе конечно.
тут http://www.overclock.net/t/1597604/lg-3 ... ors-thread пишут следующее:
FreeSync and 75 Hz resfresh rate
By default, both 34UC88 and 34UC98 feature 60 Hz refresh rate. However, both are featuring AMD FreeSync technology that allows panel to reach 75 Hz. After enabling FreeSync in monitor OSD, 75 Hz refresh rate appears in control panel. However, you can do this effectively only with AMD card, because even though it theoretically works with Nvidia cards, there is phenomenon called frame skipping that will cause all your system and monitoring tools report 75 Hz and FPS while you will see only 60 FPS effectively and those additional 15 frames are going to be skipped.
According to report, inserting additional AMD card to your system removes firmware lock and you can now have 75 Hz with Nvidia GPU, so maybe you can try to find a way to fool the system and make it see AMD card that you don't have:
Quote:
Originally Posted by Powergate View Post
Found something interesting today, i put my RX 480 in the free pcie slot below my GTX 1070.
The Monitor now shows Freesync as active without frameskipping.
The displayport cable is connected with the Nvidia card, the AMD card just acts as some kind of dongle.
FreeSync itself is not working (tested with the Windmill demo). It's just a workaround for the 75hz firmware lock on Nvidia cards.
Aqulibrium
Разгони сам. Мониторы от LG гонятся, как минимум, до 75Гц.
скорее всего да
Я это все конечно понимаю, но интересно то, что если для 88, 98 моделей везде указывают базовую частоту в 60 Гц, то на том же офиц. Сайте LG в 99 стоит 75 Гц (без каких либо условий).
А какая разница что я сам разгоню, что выставлю уже готовый пресет? По-моему это одно и то же.
не забывайте про пропуск кадров
Добавлено спустя 32 минуты 38 секунд:
эммм наоборот условие есть:
Конечно, не забываю. Есть онлайн-утилиты(+фотоаппарат), позволяющие оценить качество разгона. Все это есть в теме посвященной разгону мониторов.
ну так без ВК от АМД монитор, как раз и пропускает кадры.
фикс этого дела пока упоминается только один = в комп втыкают вторую видеокарту от АМД.
Речь в общем то шла о модели 34UC99, зачем про 38 писать?
Магия прям. С видеокартой от АМД монитор тянет 75Гц, а без - не тянет.
Все дело в настройках - если правильно выставить тайминги, то будет честные 75Гц и на НВидиа.
прошу прощения недосмотрел :cry:
Добавлено спустя 33 секунды:
нет просто заблочено если в системе нет вк от амд.
tier_i писал(а):
Почему тут не рассматривается такой монитор как AOC U3477PQU
Нафиг 21:9 плоский и дешёвые АОС не торт.
i7 4790K / 16 DDR3 / Asus 1080Ti / SSD / Моник AOC 27" 2650x1440-165hz G-sync на IPS/ Oculus Rift CV1
А вот сколько нога занимает стола вглубь? Самая не большая это у LG?
На столе глубиной 55 см плохо будет с такими большими мониторами 35" нос будет упираться в монитор или нормально?
В идеале бы конечно 160х80
Куратор темы
у меня 70см, и хочу расширить стол покупкой нового стола, хочу купить вот такой размерами 160х80, условные +10см дадут более широкий круговой обзор, можно конечно стол выдвинуть на себя от стены и прикрепить монитор на кронштейн, чтобы монитор от края был выдвинут не более 10-15см.
пример
http://www.ink-market.ru/images/goods/33834/1350841759-full.jpg
Добавлено спустя 7 минут 40 секунд:
естественно это ненормально, для 35 дюймов угол обзора будет совсем маленький.
Как раз вчера его смотрел) на самом деле больше ничего и не нашёл, один треш продают... ну и у нас его не купить :facepalm:
Куратор темы
Лучше и нет, но цена огонь за кусок дерева и пару железок, 17к это слишком дорого, хотя стол берется на века. Мой текущий стол сам делал, купил фанеру 160x70 и поставил на ножки от старого компьютерного стола. Решил брать этот стол из-за того, что у него регулируется высота 65-85см, + на 10см шире моего.
ну как вариант на геймпаде поигрывать)
Добрый день, после апгрейда столкнулся с проблемой.
На мониторе LG 34um59 картинка стала будто слегка замыленная, глаза стали уставать.
Будто есть какое то мерцание, сложно вообщем объяснить но картинка явно изменилась хотя настройки монитора я не трогал.
Да и апгрейд был только процессора и материнской платы, т.е не должно было повлиять на отображение.
Кто сталкивался с чем то подобным?Может ли это быть от плохого качества шнура HDMI?(стоит комплектный от монитора)
Фото: 11
очень может быть
вот нормальные кабеля
http://www.avsale.ru/inf/6062/
Слава Роботам! Убить всех человеков!
miwa
Дороговато для меня, можете посоветовать что то побюджетней?
Просто я не совсем уверен что дело именно в нем.
Фото: 11
эти посомтри
Кабели HDMI Kramer Electronics
http://avtech.ru/hdmi-cable/
Сейчас этот форум просматривают: BlackStrider и гости: 7
