Side Inlet Performance I did experiment with side inlet performance with my initial discharge only pressure testing and found that performance suffered significantly to the point where the stock top performs better in many cases. I didn't retest these side inlets in measuring total head, so I have pulled those results, but I expect them to scale similarly and the stock top performs nearly as well as any of the aftermarket side inlet tops. There is a significant loss in the 90 degree bend.
I would not recommend using the side inlets unless you absolutely have to.
Thanks! Martin
_________________ Water Cooling System Koolance --- Superior Liquid Cooling Solutions.
