На видео просто очень высокий поток. Найдете хоть один бесшумный расходомер для такого потока? В реальном контуре, если сумеете добиться такого потока, шум жидкости в водоблоках и шум помп заглушит это потрескивание )
Today in an intensive quality control we found a problem in the production at a small number of high flow NEXT sensors. When the magnets were pressed into the turbine, an incorrect pressing tool was used on some turbines. This leads to incorrect centering of the shaft and can cause noise due to tumbling of the rotor.
If you notice disturbing noises from your sensor at a flow rate of less than 200l/h (0.9 gal/min), please contact our Support (info@aqua-computer.de). In that case we need your address and the serial number of the device from the aquasuite. We will replace the affected sensors afterwards.
The error affects only a few of the sensors produced from November. Noises at higher flow rates are normal and no reason for replacement. Also, an audible noise is basically normal in close proximity to the sensor.
The noise of the high flow NEXT series is quieter than the known high flow sensors. Should the noise be higher in your case, please also arrange for a replacement.
We want to ensure total customer satisfaction with this product and apologize to affected customers for the inconvenience.
Due to the current CoVid19 situation, processing will take longer than normal. Also, the exchange will not be possible immediately. Therefore, the exchange may take a few weeks. The old sensor has to be returned only after receiving the new one.
We give you 3 month time for the replacement, after that time the old sensor will be automatically deactivated in the aquasuite and can no longer be used.
Статус: Не в сети Регистрация: 28.02.2008 Откуда: Калининград Фото: 99
Аквовцы пишут что при высоком потоке (выше 300л/ч) будет не бесшумным, ещё вообще пишут что он тише прежнего high flow USB. Недавно объявили о бесплатной замене для владельцев у кого датчики шумят, т.к. обнаружили недочёт в конструкции.
Статус: Не в сети Регистрация: 13.12.2019 Откуда: Германия
Syber, спасибо! Вопрос про 270л/ч: как такое может быть? Если помп несколько, то минимум одна из них должна крутить на 270л/ч. От двух помп, работающих на 150л/ч, больше 150 всё равно быть не должно. КАК? :)
_________________ Опять проснулся с мыслью, что в городе немцы.
Статус: Не в сети Регистрация: 24.01.2006 Откуда: RU, Кемерово Фото: 21
Это откуда же такие выводы?) В каждом контуре одни и те же помпы будут давать совершенно разный поток - каждый водоблок, радиатор, куча уголков и т. д. дают своё сопротивление. Поэтому такие заявления не имеют основания. Опять же от потокомера зависит - MPS 400 в моём контуре показывал 400+л/ч, а механика при этом всего 270л/ч и ей доверия больше.
k2viper писал(а):
Стоит в том же месте что mps400 или в другом? Помню у тебя mps не по "фен-шую" стоял.
Практически в том же - mps был вкручен во входной порт топ, а этот вкручен на выходе. Поэтому разница не принципиальна. Хочу заметить, что mps у меня всегда показывал очень большие цифры - даже будучи установленным в совершенно ином месте и положении в ранних версиях контура
Заблокирован Статус: Не в сети Регистрация: 07.08.2013 Откуда: Тула Фото: 53
k2viper писал(а):
Я ставлю найденную на OCN кривую
По хорошему кривые надо не искать, а делать самому в процессе калибровки. Иначе там можно такого накривить, что ни один выпрямляющий раскривитель не справится
Syber писал(а):
Никаких сторонних кривых не загонял в него - использовалась встроенная.
Я бы использовал её, но пишут что она под 13/10 шланги и фитинги. Поэтому использовал чужой опыт ) Понятно что надо самому калибровать в своём контуре, но если контрольный термометр у меня есть, то контрольного измерителя потока нет.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 34
