Статус: Не в сети Регистрация: 30.01.2010 Откуда: Москва Фото: 27
NONsens писал(а):
хочется взять наиболее беспроблемную D5 с PWM для управления аквой.
Прямо сейчас в контуре EK-D5 G2 без проблем управляется акваэро 5.
CrownA писал(а):
контроллер, который они обещали догнать, перегнать, засунуть в задницу и там растоптать
Екашники обещали это только в твоих фантазиях. Ничего такого в реальности они не говорили. И забавно видеть, как у тебя кругом маркетологи врут, но у Аквы они святые и ничего не приписывают
Статус: Не в сети Регистрация: 21.10.2010 Откуда: ⠺⠕⠏⠗⠕⠎⠮⠢ Фото: 70
aquasuite X.60 (Insider) (22-NOV-2022)
Changelog:
New: Porting of aquasuite from .NET 4.8 to .NET 7.0 (.NET Core)
Update: Performance improvements in the aquasuite application and Aqua Computer background service
Update: Hardware monitoring
Update: Bug fixes
The changes in the aquasuite are much more extensive this time than the changelog suggest. Many functions have been rewritten or significantly optimized in terms of performance. In addition, the stability has been further improved. The new .NET 7.0 runtime environment is much more efficient than the previous versions.
Due to the large number of changes and adaptations, there will certainly still be a number of errors in X.60 despite many tests. For this reason, the current X.60 and the subsequent version will initially be published as an insider release.
The latest .NET 7 runtime for desktop applications must be installed to use aquasuite X.60.
We will try to correct bugs as soon as possible with new versions. There are no fimware updates included in the X.60 insider release. This allows you to switch back to the official X.59 version of aquasuite at any time. For this purpose, the setup from the download page must be used.
We ask for bug reports and feedback on X.60 and the following Insider versions. Please use this topic.
We wish you a lot of fun with the insider version and look forward to your feedback soon!
Статус: Не в сети Регистрация: 12.12.2016 Откуда: Чебоксары Фото: 0
Changelog:
Update: Bug fixes
Обновился пару дней назад. Периодический вылетает фоновая служба. Приходится останавливать и по новой запускать. В итоге плюнул пока и все данные беру только от HWiNFO И косяк с графикой.
aquasuite X.61 (Insider) (30-NOV-2022)
Changelog:
Update: Hardware monitoring (Ryzen 7000)
Bugfix: Autostart
Bugfix: Overview Pages
Notice: The update directly from aquasuite X.60 or X.61 to a newer version only works if the aquasuite was started with administrator rights. Alternatively, the setup from the website can be used for the update. This problem has been already fixed in newer versions.
aquasuite X.62 (Insider) (2-DEC-2022)
Changelog:
Bugfix: Firmware update process for mps and poweradjust
Changelog:
Bugfix: Autostart
Changelog:
Bugfix: aquasuite startup
Bugfix: aquasuite web
Подскажите пожалуйста, есть прямые ссылки на скачивание? У меня х6.0, через приложение не обновляется.
losinka писал(а):
Taimer81, поставь галочку в чекбоксе про инсайдер версию.
Не, дело не в этом, она стоит, проблема в том, что она скачивается, программа закрывается, а дальше ничего не происходит. Вроде как должна произойти установка, но этого не происходит.
Ребята подскажите пожалуйста. Хватит ли Flow sensor mps flow 100 для измерения потока контура проца с видеокартой? Ryzen 3900x + RTX 3090ti, 2 радиатора 360х120, помпа Barrow D5, контроллер aquaaero 6 pro. Или может есть другие альтернативы для покупки в Россию?
У меня I9-7960x в разгоне + 3080TI, расход держу постоянным 70 л/ч проблем с большой дельтой по воде нет, больше проблема снять все это тепло, в синтетике хорошо прогревает воду, пробовал 200 л/ч, дает только -3 -4 градуса с температуры ЦПУ, проц скальпирован. А в реальной жизни - рендеринг или игры вообще нет такой нагрузки на систему как в синтетических тестах.
