:)Всем доброго времени суток!:)
Давайте узнаем мнение экспертов и любителей по данной теме.
OCZ DDR2 PC2-6400 / 800MHz / 4x4GB Modules / Vista Upgrade Edition
Технические характеристики:
800MHz DDR2
CL 5-6-6-18
(CAS-TRCD-TRP-TRAS)
1.8V
1.85V EVP
Available in 16GB (4x4096MB) "quad" kits*
Unbuffered
Black XTC Heatspreader**
Lifetime Warranty
240 Pin DIMM
“P45 Special” 4GB modules are exclusively supported by Intel®’s latest chipset. Available in 16GB "quad" kits, this new line of 4GB modules supports the latest memory-hungry applications and games, while offering superior performance headroom. As an industry first, OCZ brings system memory densities to the desktop segment that were reserved previously for high-end server configurations, offering a unique range of high-density kits to suit the varying requirements and budgets of gamers, enthusiasts, and professionals.
The PC2-6400 4GB modules are ideal for enthusiasts, professionals, and DIY system-builders using 64-bit operating systems that can take advantage of high density memory configurations. As the ultimate challenge for hardcore gamers, the latest DirectX-10 games require large amounts of memory to minimize swapfile access and allow smooth game play.
The new PC2-6400 Vista Upgrade series is optimized for perfect compatibility for those transitioning from Microsoft Windows® XP to 64-bit Vista. Furthermore, each OCZ Vista Upgrade module is 100% hand-tested for quality assurance and compatibility and is backed by an industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* Currently only P45 and P43 chipsets support 8GB/16GB RAM densities. In order to boot on some motherboards this product is programmed to 667MHz; to run at 800MHz you will need to manually set the speed to 800MHz and voltage to 1.8V in your BIOS.
**XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
Каковы ваши "за" и "против" данных очень интересных модулей ориентированных на профессионалов 8-) и энтузиастов :insane:?
Добавлено спустя 3 часа, 58 минут, 1 секунду
Не могу поверить, что нет желающих обсудить данный комплект 16гб!
Intel Core 2 Duo E6600 - 3330.29 MHz (370.03 * 9) \ ASUS P5B-Deluxe \ RAM Freq : 370 MHz - DDR2-SDRAM Dual Channel - Kingston 1024MB (PC2-5300) x 2
Вообще глухо.. зачем создавал..
куда ж ты на 16 гигов замахнулся. и 4 пока за глаза хватает.
chaos vs order
Ну например -
1) для работы с 3ds max
2) или полностью убрать файлы подкачки)))
ну это кому как ;)
с 16 гигами можно рамдиск устроить большой.
так делать нежелательно. лутше подкачку на рам диске размешать.
<<ATI OverClan>>
