Соблюдение Правил конференции строго обязательно! Флуд, флейм и оффтоп преследуются по всей строгости закона! За статью можно проголосовать на странице материала.
Step 20 iPhone 5s Repairability: 6 out of 10 (10 is easiest to repair) + Just like in the iPhone 5, the display assembly is the first component out of the phone, simplifying screen replacements. + The battery is still fairly easy to access, even though it's not technically "user replaceable." - The battery has lost the 5's convenient pull tab, and gained more resilient adhesive—it now requires heat and prying to remove. - The fingerprint sensor cable could be easily ripped out of its socket if a user is not careful while opening the phone. - The iPhone 5s still uses Pentalobe screws on the exterior, making the 5s difficult to open. - The front glass, digitizer, and LCD are all one component, thereby increasing cost of repair.
"HTC One M8"
Step 19 HTC One M8 Repairability Score: 2 out of 10 (10 is easiest to repair) - It's very difficult—although no longer impossible—to open the device without damaging the rear case. This makes every component extremely difficult to replace. - The battery is buried beneath the motherboard and adhered to the midframe, hindering its replacement. - The display assembly cannot be replaced without tunneling through the entire phone. This makes one of most common repairs, a damaged screen, very difficult to accomplish. - Copious amounts of tape, adhesive, and copper shielding make many components difficult to remove and replace. + Solid external construction improves durability.
"Samsung Galaxy S4"
Step 23 Samsung Galaxy S4 Repairability Score: 8 out of 10 (10 is easiest to repair) + The battery can be replaced in seconds, without any tools. + Very easy to open and access internal components. + There are only 11 screws in the entire device, all standard Phillips #0 (no proprietary or security sizes). +/- Most of the smaller components are modular and can be replaced individually, but several of them are adhered in place, increasing replacement difficulty. - The glass is fused to both the display and the display frame, increasing repair costs. - You'll have to go through the entire phone in order to replace the front panel, since everything is built into the back of it.
_________________ Just because I'm crazy doesn't mean you should try it. I'm a professional.
Статус: Не в сети Регистрация: 30.05.2010 Откуда: 812(78)
Кто то ожидал от HTC чего то иного? Отсутствие нормальной поддержки софта, крайне низкая ремонтопригодность и подставление задницы каждому юридическому отделу это кредо HTC
Добавлено спустя 3 минуты 41 секунду: Одна из немногих контор, которая платит дань за свою аппаратуру на android и мелкомягким и яблочникам.
_________________ То, что мыслимо, то осуществимо.
Статус: Не в сети Регистрация: 24.12.2011 Откуда: Харьков
Расположение батареи между платой и дисплеем абсолютно недопустимо - при взрыве или другой проблеме с батареей в первую очередь лопнет дисплей и своими осколками вонзится в тело владельца. С айфонами такие случаи уже были...
_________________ We are not so S.M.A.R.T. as we imagine...
Статус: Не в сети Регистрация: 19.08.2013 Откуда: St. Petersburg
watchmaker
Да прямо пробьет насквозь владельца осколками. У меня лопнуло защитное стекло на первом ноуте из за совсем незначительного разбухания батареи. Под стеклом находится специальный гель, чтобы отделить от него осколки нужно еще достаточно постараться.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 33
