Соблюдение Правил конференции строго обязательно! Флуд, флейм и оффтоп преследуются по всей строгости закона! За статью можно проголосовать на странице материала.
Статус: Не в сети Регистрация: 25.09.2008 Откуда: Санкт-Петербург
Драйвера под видео для Windows 9X и поддержку 3D в XP так и не предвидятся
changes
VirtualBox 5.0 will be a new major release. Here is an incomplete list of changes since VirtualBox 5.0 Beta 4: •GUI: NLS fixes. NLS strings are now frozen. •GUI: Improved HiDPI support for Windows host, icons/size-hint adjustments. •GUI: Use fast scaling mechanism for integer scale-factors (s. a. here). •Separate UI/VM: fixed completely broken re-attaching to a headless VM. •Drag and drop: fixed hang when reporting host errors such as inaccessible (locked) files. •PCNet: OpenStep fix (bug #10545) •Host-only networking: an attempt to fix some VERR_SUPDRV_COMPONENT_NOT_FOUND problems •NAT: Don't forcibly reset/drop all connections when link goes down •AHCI: fixed a possible hand during VM shutdown •Audio: fix audio output if the default output device changes, before this fix it would always stream to the output device being the default when the VM was started •VBoxSVC: don't keep the support driver permanently open •VBoxManage addencpassword: read the command line from the console or from a file •vbox-img: added resize command •X11 Additions: fix for X.org servers with RandR 1.1
