Соблюдение Правил конференции строго обязательно! Флуд, флейм и оффтоп преследуются по всей строгости закона! За статью можно проголосовать на странице материала.
Статус: Не в сети Регистрация: 20.04.2012 Фото: 15
Ryzen DRAM Calculator 1.3.1 by 1usmus Released
User 1usmus is the programmer of Ryzen DRAM Calculator, a must-have tool for any PC enthusiast with AMD Ryzen-powered machines. The tool simplifies the process of finding the right memory clock, timing, and voltage combination by adjusting other settings to match the setting you key in. For example, if you're looking for a memory clock of DDR4-3200 and CAS latency of 14T, the tool will put out "safe" and "stable" combinations of other timings and voltages. You can also make the app read Intel XMP and other fast SPD profiles from your modules, and translate them to Ryzen-friendly settings that run stable. In short, this is the app that clears that last bit of hesitation you had to embrace Ryzen. Get it from the link below.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 35
