Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 50 • Страница 1 из 3 • 1  2  3  >
Ура .... одна из нормальных игр от EA вышла в свет. Защита SafeDisc и серийник, размер - 1.92gb. Пока сборка только от Razor1911 .... Качаем и делимся впечатлениями.
The minimum system requirements for NHL 07 are as follows:
1 GHz Intel Pentium III or equivalent processor.
256 MB RAM.
Required Operating Systems:
Windows XP or Windows 2000.
Note: Windows 95, Windows NT 4.0, Windows 98 and Windows ME are not supported.
2.41 GB free hard disk space (additional space required for DirectX 9.0c installation and for saved games)
DirectX 9.0c Compatible Sound Card (see below).
DirectX 9.0c Compatible 3D accelerated 64 MB video card or equivalent (see below).
Broadband connection for online gameplay.
Required software for online play:
Internet Explorer 6.0 or later for online play.
Macromedia Flash 6.0.79.0 or later for online play.
DirectX 9.0c
Supported sound cards:
NHL 07 supports DirectSound. If your sound card driver does not support DirectSound you may experience choppy or stuttering sound or sound that cuts in and out. If your sound card driver does not support DirectSound, we recommend obtaining updated drivers from your sound card manufacturer.
The supported chipsets are:
ATI Radeon Series:
7500, 8500, 9xxx series, Xpress 200, X300, X550, X600, X700, X800, X850, X1300, X1600, X1800, X1900.
NVIDIA GeForce Series:
GeForce3, GeForce3 Ti200/Ti500, GeForce4 Ti4200/Ti4400/Ti4600/Ti4800SE, FX series, 6200, 6600, 6800, 7300, 7600, 7800, 7900,
Other Video Card Series:
SLI Technology.
Intel 915, Intel 950.
S3 DeltaChrome, S4 Nitro, S3 DeltaChrome, S8, S3 GammaChrome, S18 Pro.
*Note: Laptop versions of these chipsets may work, but are not officially supported as they have not been tested. The NVIDIA GeForce MX series are not supported. It is recommended that you update your video card drivers to the most recent released by the manufacturer. DirectX 9.0c is required to run the game and is included on the NHL®07 DVD.
Как время летит.... Уже скоро как 10 лет на данном форуме сижу...
KALISTOR
Хотя бы ссылку дал ...
Вам может показаться, что я повторяюсь, но я буду распоряжаться вашими жизнями, как мне вздумается. Постарайтесь этого не забывать...
|Клан Дедов|
Rev@n На что ???
Ждем лицензию англ.!!! В это надо поиграть просто-в NHL06 до сих пор рублюсь-такого андреналина ни в одной игре не встречал.
KALISTOR
Как саундтреки из игры?! :)
*Cofradia Intel*
*CI_Hardware_Support_team*
KALISTOR писал(а):
На что ???
KALISTOR писал(а):
Качаем.
откуда...
|Клан Дедов|
KALISTOR вау ! обязательно куплЮ!!!
З.Ы. а фифа там когда будеТ!?
http://www.DolbiTTeam.ru |Установка автозвука, подбор компонентов, настройка и т.д. и т.п.| +7(918)399-6-777, ICQ 271-39-24
Rev@n писал(а):
ткуда... __________
P2P-сети.
the cause is lost...we know everything...you'll all be slaves...nothing can stop this [DROP!]
LSSAH Еще качаю.... Все-таки ~ 1,93gb качать.... Но чую игра кул .... в отличии от отстойной Fifa07
Rapsodi Ну эта вроде в конце сентября ....
Ну что кто-нибудь скачал ???
|Клан Дедов|
Rev@n Ну скачал .... и даже установил. Сейчас будем гамать.
давай, расскажеш потом
Asus G551JM Intel Core i7 4710HQ @ 2.5 Ghz 16 ГБ DDR3-1600 Nvidia GeForce GTX 860M (2 ГБ GDDR5) Samsung 850EVO SSD 250GB
Можно не покупать. Отличий от нхл2006 как у фифы. Графика та же. Все то же. Даже команды так же на лёд выезжают. Вратари - просто песня. Вратарь у которого все параметры по 100 не ловит от синей линии. На диффикалте к 13 минуте 1-го тайма (Россия-швеция) счет был 7-1, грустно. Надо просто подьехать поближе и ударить посильнее. А играл с канадой так за матч они набили 15 ударов и забили 5 голов. Зато защита научилась пасы с одного края на другой перехватывать. Короче, изменений как в патче.
Orc
А стиль, атмосфера хоть на йоту изменились? Самое главное: как музыка?!
Добавлено спустя 6 минут, 23 секунды
Хорошо, что хоть игру не изуродовали... Как Овечкин, кстати? :)
*Cofradia Intel*
Предупреждение
Санта-барбара все продолжается? :) Помоему с NHL99 ничего не меняется, чем-то старые серии даже лучше были.
Я толерантный - ненавижу всех одинаково.
Фото: 5
Люди помогите!!! При запуске игры вижу этот экран и больше ничего :(
«Я знаю, что ничего не знаю, но многие не знают и этого» - Сократ
Sancho1985
Лечится, кажись, откл. или вкл. VSync.
*Cofradia Intel*
Последний раз редактировалось LSSAH 16.09.2006 19:43, всего редактировалось 1 раз.
Фото: 5
LSSAH
Огромное, СПАСИБО!!! ЩАС заченим, что это за фрукт =)
А может кто знает где русик скачать? :?:
если хочеш кого-то разорить...
ПОДАРИ ЕМУ КОМПЬЮТЕР
Да в общем по сравнению с 2006 игра очень мало изменилась. Так что атмосфера - та же. Музыка еще попсовее, но я всегда ее вырубаю. Овечкин по силе как Самсонов скорость высокая, меткость вроде тож. Ковальчук просто зверь, так бортует, 2/3 штрафов на нем висят (интересно какой у него в игре вес). Комментарии понравились.
Orc
Значит берем. :)
*Cofradia Intel*
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 117
