Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 464 • Страница 1 из 24 • 1  2  3  4  5 ... 24  >
GRAW 2 PC Full is live!
Жанр: FPS
Разработчик: GRIN
Издатель: Ubisoft Entertainment
Издатель в России: GFI / Руссобит-М
Дата выхода: 17 июля 2007
Официальный сайт
Официальный русский сайт
Поддержка мультиплеера: LAN(16), Internet
Description:
Here are some examples: - Redefined game balance : weapons & ammunitions stock with, for instance : Less Grenades in the inventory & less power for the grenade launcher - Increased Recon ability for the Ghosts with improved sound management, for instance: The Ghosts are more silent when crouched or prone. - Additional level of polish : reworked the most frequent issues for game experience, for instance : annoying “enemy down” voices decreased, ADATS status on map made clearer, end round alarm sound for the “money time” (10 round last seconds), increased efficiency of the mounted weapons.
Демоверсия:
http://ghostrecon.uk.ubi.com/
http://www.gamershell.com/download_19479.shtml
http://downloads2.computergames.ro/hdd/demo/GRAW2_PC_MP_demo.zip
http://mirror2.computergames.ro/hdd/demo/GRAW2_PC_MP_demo.zip
мини FAQ:
1. Системные требования для полной версии игры
Minimum:
Processor: Intel or AMD, 2 GHz
Operating System: Windows XP/Vista
Memory: 1024 MB RAM
Disk Space: 5 GB
Graphics Card: 128 MB DX9.0c compatible card,
GeForce 6200 or higher
Radeon 9700 or higher
Sound Card: DirectX 9.0c compatible
DVD-ROM drive : x2 read speed
DirectX Version: 9.0c
Network: High-speed modem with 128 Kbits of data transfer upload rate for a client, 512Kbits of data transfer upload rate for a server on a full game.
Recommended Configuration:
Processor: Intel or AMD 2.8 GHz
Memory: 1024 MB RAM
Disk Space: 5 GB
Graphics Card: 256 MB DX9.0c compatible card,
CD-ROM or DVD-ROM drive : x2 read speed
Network: High-Speed Modem with 128 Kbits of data transfer upload rate for a client, 512Kbits of data transfer upload rate for a server on a full game.
Graphics Cards Supported:
Radeon 9700, Radeon 9800, Radeon X700, Radeon X800, Radeon X850, Radeon X1300, Radeon X1600, Radeon X1800, Radeon X1900, Radeon X1950;
GeForce 6200, GeForce 6600, GeForce 6800, GeForce 7800, GeForce 7900, GeForce 7950, GeForce 8800
2. Очень неплохой "народный" русификатор для полной версии игры (Spirit Team / ENPY Studio / SyS-team): http://zoneofgames.ru/index.php/gb/file/2013
3. Как включить "ручками" текстуры в режим "High".
- Заходим в директорию по умолчанию:
C:\Program Files\Ubisoft\Ghost Recon Advanced Warfighter 2\Data\settings\
(для Windows Vista: C:\Users\<имя пользователя>\AppData\Local\GRAW2\data\settings\)
- Открываем файл с помощью блокнота renderer_settings
render_config>
<d3d_device
adapter = "Radeon X1950 Pro"
adapter_num = "0"
driver = "ati2dvag.dll"
resolution = "1280 1024"
windowed = "false"
refresh_rate = "60"
<render_settings>
<variable name="adapter_num" value="0"/>
<variable name="anti_aliasing" value="edge_smooth"/>
<variable name="aspect_ratio" value="1.3333334"/>
<variable name="brightness" value="1"/>
<variable name="dynamic_lights" value="true"/>
<variable name="effect_quality" value="high"/>
<variable name="environment_detail" value="0.5"/>
<variable name="max_anisotropy" value="16"/>
<variable name="post_effect_quality" value="high"/>
<variable name="shadow_map_size" value="2048"/>
<variable name="shadow_quality" value="high"/>
<variable name="show_all_res" value="true"/>
<variable name="texture_quality" value="medium"/>
<variable name="texture_quality_backdrop" value="medium"/>
<variable name="texture_quality_buildings" value="medium"/>
<variable name="texture_quality_buildings_bump" value="medium"/>
<variable name="texture_quality_buildings_low" value="high"/>
<variable name="texture_quality_characters" value="medium"/>
<variable name="texture_quality_default" value="medium"/>
<variable name="texture_quality_effects" value="high"/>
<variable name="texture_quality_ground" value="medium"/>
<variable name="texture_quality_ground_bump" value="medium"/>
<variable name="texture_quality_gui" value=""/>
<variable name="texture_quality_lightmaps" value="high"/>
<variable name="texture_quality_no_lod" value="high"/>
<variable name="texture_quality_plants" value="high"/>
<variable name="texture_quality_player_vehicles" value="high"/>
<variable name="texture_quality_props" value="medium"/>
<variable name="texture_quality_props_bump" value="medium"/>
<variable name="texture_quality_props_high" value="high"/>
<variable name="texture_quality_silhouettes" value="medium"/>
<variable name="texture_quality_sky" value="high"/>
<variable name="texture_quality_vehicles" value="medium"/>
<variable name="texture_quality_weapons" value="high"/>
<variable name="texture_quality_weapons_third" value="medium"/>
</render_settings>
</render_config>
- Помеченные параметры меняем на "High"
4. Для тех, у кого проблемы с игрой, а именно после 2-ой миссии вы не можете выбрать следующую !
Данный профиль открывает все миссии кампании - и вы можете продолжать играть ! Инструкция внутри !
Забираем http://www.filefactory.com/file/1b397a
5. Последние патчи можно взять тут: http://patches.ubi.com/ghost_recon_adva ... rfighter_2
Отредактировано модератором: REtaiL_OZ. Дата: 18.07.2007 23:10
Отредактировано модератором: REtaiL_OZ. Дата: 30.07.2007 15:22
скажите как запустить под виста на Forceware 160 и выше
говорит требуется 158 и выше, а сам на 160ых не запускат
Добавлено спустя 4 минуты, 17 секунд
через .exe запустил, все ок
Aresstokrat А не подскажешь,в деме по локалке можно погамать? или только в нете?
BF3:Lexuz77RUS;BF3 Serv(32): RU[77] MOS.OBL PensionerCLUB - приглашаю всех :)
Lexus77, только в и-нете.
У кого какие вчепятления в целом об игре? есть хыть изменения какие заметные? :spy:
Не играл в 1 часть, поэтому об изменениях ничего сказать не могу. Графика мне не понравилась, дико убогая, на коробке360 НАМНОГО лучше, просто день и ночь. Геймплей мне показался скучноватым, игре не хватает динамики, передвижения игроков достаточно медлительные.
Ещё игра не распознаёт некоторые видеодрайвера, поругалась на мой Forceware 160.03. Но, несмотря на это, игра отлично идёт на максимальных настройках и нисколечко не тормозит. :)
Рзаницы с graw1 ни в графике, ни в геймплее не заметил.
Глупость, тут просто попалась скудная карта.
Всё точно так же, ка ки в первом graw. На любителя. Это больше симулятор, чем аркада, если можно так выразиться.
Я тоже заметил, правда у меня 158.27. Идет быстро, точно так же, как и первый.
В игру не внесли ничгео нового, всё также нужно ждать идиотов, которые не знают как нажать ready при старте игр.. Как же это бесит..
"And are you finding it a bit boring when one person endlessly wins?"
Я сказал, что не играл в GRAW1.
Ещё мне не нравится то, что иногда просто непонятно откуда тебя убили, хотя бы показали место, откуда был произведён выстрел. :x
У меня проблема с запуском (
Crash in application version: 29276.2404
c:\src\src\branches\graw2\dieselx\source\utility\Archive.cpp(2092) Cannot open c:\users\Администратор\appdata\local\graw2demo\data\settings\renderer_settings.xml with create mode: 0x2, access: 0x40000000, share_mode: 0x1 => error code 0x3: Системе не удается найти указанный путь.
Renderer: threaded
Physics : threaded
Может кто подскажет в чем проблема ... (Стоит Виста 32х)
Добавлено спустя 1 час, 43 минуты, 51 секунду
Проблема решена выставлением совместимости с ХР
У меня подобная ошибка вылетает после ~получаса-часа игры. Сначала появляется какой-нибудь баг (невидимая стена, нестреляющее оружие, невидимое (wtf?!) оружие :)), а затем и сам Error.
мдя фаны старых гостреконов запороли вполне себе приличную игру и превратили в уродца перевёртыша "не туда-не суда"
Добавлено спустя 1 минуту, 39 секунд
это тактический "симулятор" может он за вас не только врагов искать будет, но и убивать?
OsPa (BF2142)
team =RW= PID-92947651
Мдя :) Походу ты переиграл в первый Флэшпоинт :D А для Грава это стандартная ситуация :haha: Поэтому батенька надо в корне менять тактику своей игры,уметь ориентироватся по звуку (желательно играть НЕ одному,чтобы ктото прикрывал твой back) Зы: вообщето на компасе красным маркером всегда отмечается направление,откуда по тебе стреляют (этого более чем достаточно ИМХО).
В целом впечатления от демы: Графика немного изменилась в лучшую сторону (меня порадовало). Из нововведений - возможность подобрать оружие убитого,а также пострелять из стационарного пулемета. Что не понравилось - убрали возможность выбрать weapon kit по своему усматрению (можно выбрать только из уже готовых предустановок). Глюки: нормально поиграцца я так и не смог, т.к. после каждого раунда у мня "подвисал" лобби,приходилось закрывать игру по альт+Ф4, у другана такого небыло :spy: Ну вообщем как всегда остается только ждать и надеяццо на чудо,что всё поправят :weep:
OsPa, не язви, в том же допотомном Counter-Strike с этим делом и то лучше. Убили, увидел откуда и всё.
Lexus77, я не играл ни в один флешпоинт вообще. Если это стандартная ситуация, то нафиг это нужно, какой интерес? Куда смотреть, когда тебя моментально выносят, а ты не понял откуда?
скитт в допотопном кс всё построенно на динамике, сдесь как и просили игроки всё построенно на реалистичности
OsPa (BF2142)
Ну её тогда, эту реалистичность, поиграю во что-нибудь другое. :) Мой вердикт - шит (5/10) Надеюсь кампания будет получше.
Lexus77 Игра по ЛАН есть вообщето...
Fatal1'st, где? У меня при нажатии кнопки Multiplayer происходит сразу поиск геймспаевских серваков.
на х-боксе игра совсем другая, зачем её засрали остаётся только гадать
OsPa (BF2142)
Да! я уже заметил!! и то,что теперь,чтобы поиграть по ЛАН НЕнужен конект к геймспаю (в первом сильно напрягала эта фича,тот кто сервак в лан создает,может не конектицца к геймспаю,а те кто конектяцца к серваку в лан без геймспая ни-ни)
То Скитт: у млин! в CS оказываеццо тоже показывают кто тебя убил :D А если чесно - ненавижу CS :x Сколько можно играть уже в него :insane: как только не надоест :insane:
То OsPa: а штоб бабла еще содрать с нас, наивных :(
Lexus77, в CS'e после смерти камера поворачивается в ту сторону, откуда ты получил пулю, клоун. И не говори, что это не так.
OsPa, да, на ящике мне игра тоже больше понравилась, чем на пк. :P
Сейчас этот форум просматривают: Novasiris, RESIDENT, SlideX и гости: 39
