* Операционная система Microsoft Windows XP/Windows Vista/Windows 7; * AMD Athlon 64 3800+ с тактовой частотой 2,4 ГГц/Intel Pentium IV 530 с тактовой частотой 3,0 ГГц или лучше; * 2 Гб оперативной памяти; * 11 Гб свободного места на жестком диске; * Видеокарта NVIDIA 7800GT/ATI Radeon X1900 с 256 Мб видеопамяти или лучше; * Звуковая карта, совместимая с DirectX 9.0c; * Клавиатура и мышь.
Рекомендуемые
* Операционная система Microsoft Windows XP/Windows Vista/Windows 7; * Процессор AMD Athlon 64 X2 5200+ Dual Core с тактовой частотой 2,6 ГГц/Intel Core 2 Duo E6420 Dual Core с тактовой частотой 3 ГГц или лучше; * 3 Гб оперативной памяти; * Видеокарта NVIDIA 8800GT/ATI Radeon HD4830 с 512 Мб видеопамяти или лучше; * Звуковая карта, совместимая с DirectX 9.0C; * Клавиатура и мышь.
* Fixed unlocalized text in Customize Controls screen. * Player mouse functionality no longer drops out when the Video Card Driver Warning appears. * User.ini no longer overwritten when game loads. This should address mouse sensitivity issues as well as many v-sync option bugs. * Enables BioShock 2 to play the new Protector Trials DLC * Changes the game version # visibly displayed in the Single Player main menu to Version 1.4 * Enables music in the game's Single Player main menu (console versions already had this... for PC, the music was always included in the game files, but it didn't play) * Overwrites User.ini on installation, so you'll lose your Single Player keybinds * Dramatically increases Single Player GFWL sign-in time due to added GFWL sign-in bug
PATCH #3 LIST
* Fixed MP freezing and connectivity issues * Implemented color-blind friendly hacking UI. * Fixed further issues related to HUD stretching. * Resolved functionality issues related to NVIDIA 3D Stereo options. Option in the Single Player Options Menu was removed and is now activated through the NVIDIA hardware. * Fixed an issue where the User's whole vision would become blurred while using ironsights in DirectX10. * Fixed a problem where trying to install a patch manually through the appdata directory would not work properly. * Fixed an exploit in Multiplayer involving Rebirth * The "Reset All" option in the Multiplayer Controller Settings now functions properly. * Fixed further issues related to plasmid gene bank hotkeys not taking effect in-game. * Resolved a problem where two parties consisting of five players were unable to join the same game lobby for any game mode except Survival of the Fittest. * Fixed various localization bugs for Multiplayer * Fixed an issue where task switching while in a game lobby would not initiate. * Improved security for various weapon loadout files and fixed related exploits. * Fixed issue where the title will fail to direct the user to the proper lobby when a join-able match is in session and the user accepts a game invite or attempts to join session in progress. * Fixed issue when BioShock 2 fails to apply the title update when the files are placed in the appdata directory manually * Fixed text overrun on the Corpse counter from the first Little Sister * There are 53 achievements available to the user after installing TU 047. * Fixed issue where BioShock 2 is listed as two separate games in the Games for Windows - LIVE guide after installing the title update and earning achievements. * Fixed Spanish language issue where text overrran the textbox provided on the multiplayer lobby * Fixed German language map title for Fontaine Fisheries * Players can automatically reach rebirth rank 40 with any rank rebirth profile by viewing the epilogue within the apartment. * Changes made to customizable controls using the "Reset All" function are not saved when the game is restarted. * Fixed issue where the title will fail to properly task switch while in a game lobby when account management is chosen on Vista x86 PCs * Fixed exploit where the user can modify the user specific .ini to acquire weapon loadouts before reaching the appropriate rank
PATCH #2 LIST
* Fixed an issue where 16:9 and 16:10 resolutions were letterboxed versions of 4:3 resolutions, thereby properly fixing the FOV by expanding the horizontal player view as intended. * Fixed an issue where holding the M1 button would not register in Multiplayer gameplay.
PATCH #1 LIST
* Fixed accepting a game invite on the Multiplayer Menu via Friend Invite causing a crash. * Fixed a black screen that would occur minimizing and restoring the game in Windows 7. * Fixed the ability to adopt or harvest Little Sisters after rebinding the ‘F’ or ‘B’ keys to Zoom, Fire or Fire Plasmid. * Fixed Big Daddy HUD elements remaining on screen when not appropriate. * Fixed an issue where the player’s plasmid hand would become unresponsive if they pressed the Next Plasmid key immediately after firing any chargeable plasmid (such as ElectroBolt 2). * Fixed a potential save file issue. * Fixed an issue where the resolution would change on its own if entering gameplay in a 16:10 resolution on a native 16:10 monitor. * Fixed a problem where if you were running the game in a resolution higher than your desktop resolution the mouse cursor wouldn’t be able to go across the whole screen. * Fixed an issue in Windows 7 where certain Radio messages could become scrambled or broken after defeating a Big Sister if Voice audio had been turned down or muted previously. * Fixed a crash while playing Dionysus Park on a 32-bit machine. * Fixed a crash that would occur sometimes loading a previous manual save made before any present QuickSave. * Fixed a crash while signing in to GFWL when running compatibility mode for XP SP2 while running Vista. * Fixed an issue where you couldn’t play audio diaries in certain areas. * Fixed a rare crash that could occur any time before a specific Big Sister sequence.
Последний раз редактировалось Dark Knight 02.06.2011 9:22, всего редактировалось 2 раз(а).
Main Character
Dark Knight Список эпически смешон. Какой нафиг DX11 (да и 10 тоже) в NFS Shit или Dragon Age?
_________________ Исследования показывают, что хранить лестницу в доме опаснее, чем ружье. Поэтому у меня 10 ружей, на случай, если какой-нибудь псих попытается протащить лестницу.
Статус: Не в сети Регистрация: 13.11.2005 Откуда: Ukr-ne
поиграл...нравится пока..ну я в общем то другого и не ожидал..первая часть была хороша...тут еще интереснее..Биг Дэдди все таки. Новая система хака дверей, летающих роботов еще не пробоввал ломать. Графически все то же самое (не знаю что там можно о дх11 прикрутить )..с всинк фпс все вемя на 60...без него о 70 до 200
Добавлено спустя 7 минут 50 секунд: о...у меня получилось АА врубить...нужно ланчер переименовать вБиошок, и добавить профиль этот и уже для негь параметры задать.
Добавлено спустя 5 минут 3 секунды: ого...с 8Q АА проседает до 35...а так в районе 40-55.
Добавлено спустя 2 минуты 38 секунд: смешно, загрузка моего квада всего 30%
_________________ 4770K,Maximus VI impact, Manli GTX 1080 TI FE,16GB Kingston Hyper X Beast DDR3 2400
Статус: Не в сети Регистрация: 04.08.2004 Откуда: Moscow
m_west писал(а):
Мне так кажется, что графика хуже стала.
сам ещё не играл, но то что графика стала точно хуже заметил ещё с первых скриншотов игры. Связались с приставками, блин А ведь первая часть была одной из разряда "графический прорыв!"
Сейчас этот форум просматривают: ekawa, xSerJx и гости: 60
