With Turbo Enabled, increasing the FSB also increases the Turbo Frequency With Offset Voltage Mode you can fully utilize C'n'C and APM Mode I recommend to keep the offset voltages to Auto with the "+" using Ultra LLC on the CPU and Auto LLC on the CPU/NB. If you are going for an extreme difference between stock frequency and Turbo frequency, then you should increase the CPU Offset Voltage to Compensate Example: 4.6Ghz with a Turbo of 5.6Ghz you might need an offset of +0.15v The higher you raise the FSB, the higher the Auto CPU and CPU/NB voltage will be set.
As you can see from my pictures, for my system the best FSB speed was 233. This allowed me to run my ram near my spec of 1866Mhz and also allows me to stay within my thermal limits when Turbo engages.
The actual turbo listed is not what it will go to. The Turbo listed is the highest level of Turbo - on an FX8350 that would be 4.2Ghz, so a Multiplier of 21. The normal turbo that will run all 8 cores is 4.1Ghz so a Multiplier of 20.5, which will let me run 4.776Ghz with a 233FSB. Under a heavy load, the CPU will cycle between my set CPU Ratio and the Turbo Speed to run cooler. Or it will just stay at the set CPU Ratio - which is ~4.5Ghz
So using this method I will have a 17% increase in Single Threaded Performance and a 12.5% increase in Multithreaded Performance. With the power saving features I idle at 68W. (Full System) At full load 280W which is the same as a Manual 4.5Ghz Overclock.
Добавлено спустя 4 минуты 30 секунд: из плюсов ...по обзорам наших камней, у нас сильный провал в задачах на одно ядро (тут и может помочь турбо), а где робят все ядра, там все ОК
Добавлено спустя 1 минуту 30 секунд: и самое главное, меньше нагрев и выше отзывчивость
scrubber Ну смотри, взять к примеру 8300 под воздухом, чтобы он оставляя часть ядер на 4700, а часть подкидывал до 5200 придется лупить под 1.6v как минимум, что никак нельзя сделать стандартными методами из биоса так как напруга на турбо от туда не настраивается, такое возможно разве что через амдмсртвикер, если настраивать напругу под турбо. Либо изначально лупить 1.6, но это просто тупость. А теперь берем кулер залман 10х оптима, который держал мой 8300 при 4700, он такие извращения с турбо не переварит просто. Максимум если только пробовать при напруге 1.45-1.5v, но там и прибавка будет сомнительной +200Мгц макс, а не 500. Такие высокие вольтажи и большие скачки под воздухом, это гарантированна деградация со временем и все из-за того что получить 5200 в однопотоке? Потому что 5200 при половине ядер проц просто фигу покажет при таком охладе. Ну а если смотреть на добротную СВО, то он должен потянуть 5000 по всем ядрам без всего этого безобразия и стороннего софта, и при таком раскладе зачем турбо? Абсолютно бесполезная вещь, которая может только помочь процу уйти в мир иной раньше времени при таких то высоких вольтажах. Турбо актуально для тех, у кого кулерки с 2-3 теплотрубками и частоты в районе 4000-4300 по всем ядрам, вот они могу настраивать на 4500 4 потока к примеру еще стандартными методами из биоса без лишних софтовых заморочек. ИМХО конечно.
S_Snake писал(а):
не выйдет, APM не даст за пределы 125 ватт выйти, иначе ТурбоКорка не работает.
люди вроде юзали амдмсртвикер для такого извращения.
Статус: Не в сети Регистрация: 24.01.2006 Откуда: Северное Тушино Фото: 7
C_i_t_r_u_s Нужно питало офсетом поднимать!!!, допустим в стоке было 1,3 значить офсет +0,3
Добавлено спустя 1 минуту 40 секунд: в итоге получишь 1,6, хотя турбо не такой требовательный к поднятию напруги, должно хватить 1,5-1,55 (ядра робят не все...больше стабильность)
Добавлено спустя 3 минуты 53 секунды: Ты ща на каком разгоне остановился?
scrubber Ну допустим плата сотворит турбо через офсет под 1.55-1.6, а как ты это охлаждать собираешься воздухом? И для чего тебе нужна такая производительность для однопотока?
scrubber писал(а):
отзывчивость системы в обычных приложениях
1) Я юзаю несколько приложений, и им больше нравится когда все ядра на большей частоте. Не будут же они к примеру вешаться только на одно все вместе и при этом мешать друг другу. 2) От ссд, и разгона КП и памяти на низких таймингах куда больше растет отзывчивость системы, нежели от проца.
S_Snake писал(а):
напруга: ауто, LLC: сверхвысокий, 4900 в однопотоке (в WoT) держит уверено.
scrubber писал(а):
S_Snake а я про что!!!
Молодец, выиграл пару фпс отностительно 4700 к примеру. И стоило оно того? От разгона КП с памятью больше пользы, чем от турботуфты в тех же самых танках.
Статус: Не в сети Регистрация: 30.08.2015 Откуда: Москва Фото: 42
scrubber
прогони CINEBENCH
_________________ Ryzen 7 5800x(4.7Ггц) ASUS PRIME X470-PRO PVS 3800Мгц(15-14-14-28-1Т) Red Devil 6600 XT 2800/2150 Cooler Master Silent Pro M2 RSA00-SPM2D3-EU
scrubber писал(а):
а кто кп и память мешает гнать
scrubber писал(а):
турбо тут не помеха
1) С 2006 года на форуме и не знаете про эффект качелей между частотами проца, кп и памяти? То что кп на 2600 бегает на 4500, уже не факт что при 4900 будет таким же стабильным при той же напруге. Это уже давно известный факт. 2) Из-за нескольких неощутимых % в однопотоке я точно не стану так заморачиваться, тем более если меня интересует многопоток.
scrubber писал(а):
а прирост будет не только в танках. но и в жабе например, да куча прог короче
Да на глаз даже и 10% не увидишь, а Вы тут со своими жалкими несколькими %. Пара фпс в танках можно назвать приростом? И что за идиотизм покупать 8-ми ядерную вишню, если основные задачи это однопоточка? Идите и купите пенек, он в стоке уделает в однопоточных задачах любую вишню.
Статус: Не в сети Регистрация: 17.08.2015 Откуда: Москва-Орел
Приветствую. Поставил Fx 8320 на Gigabyte 970A DS3P. По дефолту напряжение на ядро было 1.35. Решил попробовать скромно поднять до 4ггц, без поднятия напряжения. В биосе первые три параметра в Advance Frequency Settings с авто перебил на указанные значения - 200/2200/2400 Поднял множитель до 20 и соответственно частоту до 4гц. Далее - Turbo Boost - Dis, Core Unlock - Enb, CnQ - Dis, C1E - Dis, Core C6 - Dis, Hpc - Enb. Вольтаж на процессор не трогал. Вольтаж северника с авто перебил на +0.000, Vcore Loadline Calibration перевел в режим Regular. Сохранил, загрузился, поставил прогон ОССТ и сразу же ошибка. Вернулся в биос и поднял напряжение на проц на 0.1. Поставил снова на прогон ОССТ - 11 мин. Ошибок не было. Температура согласно датчикам всевозможных мониторинговых программ не поднялась выше 63 под Zalman 10 Optima. Есть нечто пугающее меня. Стартует комп теперь со второго раза после нажатия кнопки питания. Боязно, я новичок, но если не ошибаюсь, то 4ггц это даже не разгон для данного процессора, учитывая его заявленный турбобуст. Ну или скажем условия разгона крайне щадящие. Поправьте, пожалуйста, если я несу ерунду. Хотелось бы получить оценку профи относительно графиков и рекомендации.
#77 #77 #77 #77
Конфиг: Gigabyte 970A DS3P, AMD Fx 8320, Gigabyte GeForce GTX 770 2GB GDDR5, WD Blue 1Tb, Fractal Design Integra M 650w.
Последний раз редактировалось C_i_t_r_u_s 11.09.2015 14:33, всего редактировалось 1 раз.
Smoke77 писал(а):
ricepudding Двойной старт фирменный глюк от Gigabyte. Core unlock выключите, у процессора нет ядер, которые можно разблокировать
Безобидный фирменный глюк или предупреждающий о каких-то неприятных последствиях знак? Для меня предпочтительно сохранить компоненты живыми с безопасным функционалом. Существует ли какая-то опасность или неоднозначность в напряжениях по моим графикам? В случае удачи при повторном прогоне на 20 минут можно быть уверенным в том, что стабильность и безопасность работы есть с вероятностью 99%?
Последний раз редактировалось ricepudding 11.09.2015 13:41, всего редактировалось 1 раз.
Статус: Не в сети Регистрация: 14.01.2011 Откуда: Волгоград Фото: 105
ricepudding Фактически происходит потеря питания между стартами. Жесткие диски этого не любят и некоторые модели могут выйти из строя (к примеру ряд моделей ssd OCZ).
_________________ Команда TSC! Russia: http://tscrussiateam.ru http://forums.overclockers.ru/viewforum.php?f=21
Неприятно. Я так понимаю, единственное решение проблемы - возврат к стоку. SSD не планируется. Добавится еще один WD Blue 1tb и до новой системы уже через пару лет. Благодарю за пояснение.
ricepudding Иди в ветку по своей МП и узнавай вылечили ли двойной старт и если вылечили, то на какой биос шиться. Большие картинки под спойлер убирать надо, людям же неудобно листать форум.
Сейчас этот форум просматривают: sharikiki и гости: 26
