_________________ Twitter -> @1usmus
Все буде КНР
Статус: Не в сети Регистрация: 15.03.2006 Откуда: STOP WAR Фото: 0
KPAH писал(а):
инфомрация на уровне конспирологии в основном
Robert Hallock from AMD explained this perfectly. The CPU is programmed to use these voltages automatically. We know it's safe, because we designed it that way. The CPU cannot and does not use voltages that are unsafe for the silicon. The key thing that people forget in these cases is time and temperature. Running 1.4V or 1.5V here and there is not a big deal, because the CPU will eventually back down according to its pre-programmed model. Or if you have great cooling, that also offsets the thermal effect of voltage. In either case, you're seeing momentary blips of voltage that are offset by the hours per day your CPU is probably doing nothing at all--at a very low voltage. The average vcore for Ryzen over time is around 1.25V (give or take). tl;dr: leave the CPU alone, let it do its thing, don't worry. We designed the CPU to do this.
''It is perfectly okay if your CPU is periodically using 1.4-1.5V to achieve boost frequencies, and you should see dips into sub-1.0V as the CPU goes into idle. These dips may be brief, and that's okay. Load voltages of around 1.2-1.3V are perfectly okay also. This is the processor working as expected. Ryzen is a highly dynamic system, with up to 1000 voltage and clockspeed changes every second. You will see a lot of bouncing around as you work with your system.''
''You want to know if what you're seeing is "normal," but may not know what "normal" looks like. I get it! I want to assure you that the CPU needs voltages to boost, and voltages of 1.2-1.5V are perfectly ordinary for Ryzen under load conditions (games, apps, whatever). Even at the desktop, Windows background tasks need love too! You'll see the CPU reach boost clocks and voltages, too. ''
Статус: Не в сети Регистрация: 28.01.2004 Фото: 4
belayar писал(а):
А для 3900х нормально хватит Deepcool
Чем лучше охлаждение, тем выше частоты в бусте. То есть для 3900х хватает и бокса, только вот буст будет намного ниже. По собственному опыту могу сказать, что для 3900х трёхсекционка нужна, не меньше.
Писалось 11 месяцев назад, причём про народ, который 3900-й поджарил. Что-то у нас тут не слышно про убитые автоматом 3900-е и вообще 3000-е. А есть какие-то примеры массовой деградации у обычных пользователей?
Devijack писал(а):
избыточная неэфективность наверное более правильное выражение
В чём выражается эта "избыточная неэффективность"? По Вашей логике на том же 3600-м ГаммаХХ 400 должен ехать лучше Фумы, но это не так. И поскольку я на 3600-м откатал бокс, Кабуто, Noctua NH-C14, ГаммаХХ 400, Фуму и воду в подписи, то имею право и Вас, и кого-то другого заверить, что "избыточная неэффективность"- полная дичь. Тишина и холод может получиться только с хорошим кулером, боксом тоже можно пользоваться и не бояться перегрева, но вентиль бОльшую часть времени будет молотить от 2000 об/мин, ГаммаХХ 400 тоже едет хорошо, но шумно, Кабуто едет хуже ГаммаХХ 400, заметно хуже и шумнее, С14-й+ 2 TY140 pwm- шумно, или горячо, Фума и вода- замечательно.
belayar писал(а):
А для 3900х нормально хватит Deepcool GAMMAXX L240 ?
В соседней теме Хулигано не рекомендовал такие варианты, правда он вообще 240-280 воду не любит, и тем не менее, я бы тоже не рисковал. Поехать может, но надо быть готовым, что в процессорных нагрузках придётся держать вентили от 1300 об/мин и выше, а может и от 1500, а Дипкулы на 1500- ни хрена не тихо. И про буст коллега тут уже успел упомянуть.
_________________ MSI B550M Mortar/Ryzen 5 3600/Deepcool AG620/Kingston HyperX Fury DDR4 27700 16Gb/Palit 1660 Super Gaming Pro 6 Gb
Статус: Не в сети Регистрация: 21.01.2007 Откуда: Киев, Украина
Вчера обновилась винда до 2004 или как он там попугаев стало меньше ... у кого есть такой же ефект?
Пример cpuz Мульти коре был ~ 8500 балов cinebench r15 3200 По памяти на профильном камне сейчас -100-200 балов ... csgo bench был 599 fps сейчас вообще 499 нечего вроде не трогал ... развичто стало жарче в помещении ... но стоит большая вода.
Температуру буду пробовать снижать ... купил тюнячее крепленте от derbaurer под ряженку и житкий метал правдо с металом лоханулся взял coollabratory ultra.
_________________ ___________________________________ #1 R9 5900X /ASUS TUF X570/32GB/ASUS GTX 1080 TI OC/SSD 512 m.2/ WD 2x1TB/Enhance 850w/HeatKiller IV MORA3
Статус: Не в сети Регистрация: 04.07.2017 Откуда: Запоріжжя
Cкорее монописуально а не лучше.
Уровень шума пропорционален числу оборотов на венитляторе, не? На больших башнях менее производительные вентиляторы, вот и вся разница "прохлады и тишины" Если смущает шум, настраивай кривую оборотов в биосе под комфорт для ушей. Какая разница если вентилятор ревет как пылесос или крутится на неслышимых оборотах если башня при этом одинаково температуру забирает (а по факту не забирает) с крышки распределителя? Вспомни фуфыксы или зеоны, горячие как утюги. Большие по площади кристалы нормально передающие тепло, где сразу очевидна неэфективность СО, когда под крышкой 80гр то и кулер пальцы обжигает, с системника валит жар. На зен2 при 80 под крышкой башня еле теплая и с системника дует прохладный ветерок. Дошло что такое избыточная неэфективность? Теплообмена практически нет и фума твоя для 3600 так же фиолетова как зайцу стоп сигнал. Ты стрессы запусти и пощупай метал для понимания.
Все буде КНР
Devijack я так и сделал когда понял что вентилятору все ровно нет что выдувать, просто сделал кривую пониже чтобы не разгонялся, ну и как я понял на практике, лучше зафиксировать частоту на оптимальном уровне и подобрать минимальное напряжение для такой частоты, лучше наверное оффсетом, чтобы снижалось в простое.
