_________________ Twitter -> @1usmus
Кто перешел с зен или зен+? На сколько у зен 2 выше латентность памяти? Хочу примерно прикинуть что получу. Сейчас у меня 67нс. Ниже уже не получится. Память плохая.
Все буде КНР
Статус: Не в сети Регистрация: 15.03.2006 Откуда: STOP WAR Фото: 0
Код:
x264, x265 and VTM video encoders can use AVX2 or AVX-512 to speed up encoding.
Код:
Intel AVX is designed for use by applications that are strongly floating point compute intensive and can be vectorized. Example applications include audio processing and audio codecs, image and video editing applications, financial services analysis and modeling software, and manufacturing and engineering software.
Any application which uses Intel IPP / Intel MKL. Any application which uses OpenBLAS, Apple Acceleration Library, Eigen. Most of the Signal / Image Video Processing Filters (And Image and Video Compression libraries). Compression utilities. So we got something like: Adobe Photoshop. Adobe After Effects. Adobe Premiere. Photoshop / After Effects / Premiere Plug In's. PeaZip / 7 Zip / WinRar. x264 / FFMPEG. Excel. MATLAB / Octave / Python (Numpy, Scipy, TensorFlow, etc...). Julia. Numeric Libraries (Used intensively in many applications). I can go on and even be more specific.
It is much easier to vectorize code than to parallelize it. Hence advancement like AVX & AVX2 are welcome.
Pay attention that what needed to support efficient vectorization is localization of the data. Hence we need CPU's with larger and faster (Or same speed to the least) cache system. We also need more bandwidth for the Main Memory system.
Все буде КНР
У меня лично получилось 70нс. но у меня память 2400...при 3400 получилось 16-18-18-36 при 1,35v. Может быть и быстрее получилось бы, но я не хочу повышать напряжение.
cachemem2.png [ 92.35 КБ | Просмотров: 509 ]
Код:
Memory latency from Zen 2 is comparable to that of Zen and Zen+. This performance is, again, in spite of the segregated IO die for Zen 2 parts. As a point of reference, AMD’s claimed cache latency improvements look to hold true. Our SiSoft Sandra Cache and Memory Bandwidth test delivers 58.9ns for the Zen Ryzen 7 1800X, 52.6ns for the Zen+ Ryzen 7 2700X, and 33.1ns for the Zen 2 Ryzen 7 3700X and Ryzen 9 3900X. Running 3600MHz C16 DDR4 with Ryzen 9 3900X reduces that latency figure by 6% down to 31.1ns.
Статус: Не в сети Регистрация: 23.12.2018 Откуда: Ростов-на-Дону Фото: 11
Всем доброго вечера! Вопрос по андервольту. Решил понизить напряжение при мультипотоке через минусовой оффсет. Я перешел на АМД две недели назад. Потихоньку разбираюсь в особенностях системы. До этого сидел на Интеле (Z77, I5-2500K). Там при минусовом оффсете напряжение при нагрузке снижалось. Здесь, я так понимаю, наоборот - увеличивается. Ставлю оффсет "минус" 0,05. При прохождении Cinebench R20 в мультипотоке набивает 7100 очков. При увеличении минусового оффсета на один шаг (-0,6....) +8 очков в Cinebench. Частота выше при прохождении Cinebench и напряжение при нагрузке тоже растет. Собственно вопрос: как правильно организовать андервольт процессора без снижения поризводительности?
_________________ STREACOM BC1 V2/Ryzen 9 5900X/ROG Crosshair VIII Hero/KFA2 GeForce RTX 3090 TI HOF
Статус: Не в сети Регистрация: 13.11.2019 Откуда: Moldova
igo писал(а):
Alex_Str скрины нет, но в HWiNFO64 в авто буст до 4325 при 1.53в на рабочем столе, под фумой 2 50* со скочками до 60\65* в аиде fpu 80\85* и при этом фума еле теплая это писец товарищи! Чукча 19 год 52 неделя (последняя неделя года) производитель Малайзия
вернул это "чудо" по сижу на 2600 @3.9 1.275v память 3533 подожду либо выхода хт, либо осени, там зен 3, и опять снижение, и авось что из ласт производства появится щас кстати взял за 15200 оем бокс 17000 в сц кстати сказали, если возьму бокс, наклейку вскрою, хрена верну потом! так что, если кто будет так же искать, брать только оем
у меня на 3700х точь в точь такие же температуры, простои 40-50 со скачками до 65, бустится в играх он до 4300-4350, 4392 он показывает только на рабочем столе, в fpu тоже до +85 доходил пока я не выставил отрицательный офсет -0.07500 сейчас с -0.06825 стоит. Одни говорят это нормальная температура для 3700х, другие что не нормально. Еще с момента перехода на Ryzen 3700x появилась ошибка nvlddmkm 14 при просмотре видео, дрова пару раз сносил через DDU не помогает. На форуме tomshardware целая ветка про это, одни говорят биос у Амд кривой, другие пишут дрова NVIDIA виноваты.
_________________ Gigabyte GeForce RTX 2070 SUPER GAMING OC 3X WHITE 8G, Asus X570 PRIME-P, RYZEN 3700X, Crucial Ballistix BL2K8G32C16U4B@3600CL16 WD BLACK SN750 500GB
Все буде КНР
troggi
Код:
Conclusion: Do you have problem with NVIDIA driver (nvlddmkm error)? And do you have GTX 660, GTX760, GTX1660, RTX2070, RTX2080TI, ... just some NVIDIA graphics card? This is not problem of driver, this is a problem of NVIDIA hardware. This is an official conclusion of NVIDIA tech support. What to do? I do not know. I bought another graphics card, some RX590 (no, really no NVIDIA HW, thanks to the recommendations of their tech support). It is only 14 days now, so no premature conclusions can be made. But so far RX590 works without any problems (neither HW nor SW problems, stability is perfect)...
I would like to thank to NVIDIA's technical support team for helping me to solve a long-standing problem with their graphics card. :-)
Alex_Str писал(а):
troggi
Код:
Ну на Intel i7 3770 этой проблемы не было за 5 месяцев не разу, а тут за неделю штук 5. Да и пишут те что обновились до AMD AGESA ComboAm4PI 1.0.0.5 у них пропала проблема
Все буде КНР
troggi Я ничего против NVidia или Intel не имею (кроме цен =)), но как я понял данная ошибка у многих и решения у нее нет, разве что пробовать разные версии драйвера и смотреть статистику с какими МВ/чипсетами есть такая ошибка.
да мне также до лампочки дрязги этих корпораций, главное производительность за $ вот решение
Tarkus100 у меня, по крайней мере цп диод показывает верную температуру. На материнке есть сенсор tsi0 он как я понимаю показывает температуру сокета под процом, и она совпадает с температурой цп диод.
Здравствуйте! У меня проблема с процессором R5 3600X. При снятии охлаждения,вырвал проц из сокета,несколько ножек было погнуто,одна отломилась.Ножки выровнял,но перестала работать память в 3-х слотах из 4-х. Что делать?
Статус: Не в сети Регистрация: 30.04.2013 Откуда: Москва Фото: 0
сила есть,а ума как говорится,блин если кулер легко не идет почитать хотя бы надо было как снимать припаять ногу обратно если не вырвано с дорожками,тогда скорее всего заработает
Сейчас этот форум просматривают: Bing [Bot], Garik14, Pester и гости: 67
