Куратор(ы):   H_Rush
Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 12596 • Страница 583 из 630<  1 ... 580  581  582  583  584  585  586 ... 630  >
Фото: 124
Интересный девайс попал ко мне в руки - Hand 386.
Astra 6.99 определяет CPU как NexGen Nx586, но это глюк, потому что там стоит SoC ALi6117 - 386SX с обвязкой.
Может быть он и имеет какое-то отношение к NexGen Nx586, ведь Nx586 - это тоже 386-ядро, но я в этом очень сильно сомневаюсь.
nVidia (ULi/ALi) M6117C
386SX Embedded Microcontroller
Product Overview
The M6117C is a highly integrated, low voltage, single-chip implementation of Intel?
386SX compatible microprocessor plus ULi M1217B chipset. The M6117C provides the following functions :
1) Intel? 386SX core
2) Supports EDO DRAM controller including FP mode
3) Coprocessor Interface
4) ISA interface
5) Peripheral Interface (includes two cascaded 8237 DMA controllers, a 74612 memory mapper, 2 cascaded 8259 interrupt controller, and an 8254 programmer counter
6) Built-in RTC
7) Built-in PS2 Keyboard Controller and Mouse
8) Built-in WATCHDOG timer
9) 16-bit GPI/O
10) IDE interface.
Features
Static Intel 386SX compatible Core
Operating Power Supply 5.0V
Operating frequency 25Mhz to 40Mhz
Supports 80387SX coprocessor interface
Memory Controller
Supports EDO DRAM
Supports on board memory size up to 16M bytes for 386SX or
64M bytes upgrade system using 256K, 512K, 1M, 4M or 16M
SIMMs
Supports up to 4-bank DRAM interface
Page interleave DRAM access for FP mode
Programmable shadow RAM from A to B segment in 128K byte and C to F segment in 32K byte unit
Provides "RAS only" refresh or "CAS before RAS" refresh types
Parity generation and checking
Includes 2 cascaded 8237 DMA controllers
Includes 1 74612 memory mapper
Includes 2 cascaded 8259 interrupt controllers
Includes 1 8254 programming counter
ISA Interface
Executes cycles for requests from CPU, DMA and ISA bus master
Assembles or de-assembles data for multiple bus cycle or unmatched data width
Generates refresh signals to ISA slots during DRAM refresh cycles
Built-in RTC
Internal Real Time Clock that provides 128 byte CMOS RAM
Built-In PS2/AT Keyboard Controller
Internal PS2/AT keyboard controller and mouse
PMU interface
Supports CPU SMM mode, SMI feature
Supports APM control
Provides External Suspend mode switch
Provides four (4) system states for power saving (On, Doze,
Standby, Suspend)
Supports RTC alarm wake up control
Expandable GPI/O signals
Provides sixteen External power control input and output signals
Watchdog timer
When timer times out , a system reset or NMI or IRQ happens
IDE interface
Provides a decoder for external IDE connection
Packaging
208-pin PQFP package
На самом деле, M6117C за NexGen Nx586 принимает не только лишь Astra, но и Windows 95, и CPU-Z, не понятно только, каким образом они это определяют.
74573
20240724_210238.jpg [ 2.44 МБ | Просмотров: 2265 ]
А самое смешное заключается в том, что в вычислениях с плавающей точкой 386sx 40 МГц всё равно уступает i8087 8 МГц больше чем в 2 раза!
74545745467454774549
Фото: 124
Доехал, наконец, до меня Pocket 386. Думал, разницы в начинке с Hand 386 не будет. Однако, разница есть. В видеокарте и немного - в производительности. На этом возня с китайским ретро-новоделом закончена.
Windows 95
7465274653
Astra 7.10
74639746407464174642746437464474645
CheckIT 3.0
74646746477464874649
Помогите разобраться, собственно есть ASUS Р4С800 не делюкс, собственно перепрошил криво биос, восстановить можно через дискету и сд-ром, собственно взял болванку записал образ биоса, подключил сд-ром к плате, при загрузке пишет что сд-ром не найдет, может там кто помнит особенности восстановления биоса на материнских платой этой серии тех годов?
•i5-9400F •B360M Pro4 •32Gb •GTX1050 •2*SSD M.2 •750W
•i3-10100 •B460I-PLUS •32Gb •Intel UHD 630 •2*SSD M.2 •300W
•E7500 •775i65G •2Gb •HD4650 •2*SSD 2.5 •500W
Биос надо обзывать особым образом, типа Р4С800.ROM (в мануале по матери это написано)
И лучше с флопа, может, там по записи диска тоже есть какие-то нюансы
Нашел оригинальный образ iso к этой мат.плате и все получилось. Да биос должен был правильно называться.
Возник вопрос. Какая связка для WinXP будет предпочтительнее:
1. AsRock 775i65G R2.0+E5800
2. AsRock 775i65G R2.0+Q6700 (есть лишний кулер, который может обдувать околосокетное пространство).
Разгон не планируется. Имеется ли смысл от 4 ядер для WinXP? Собственно надо для относительно комфортного серфинга в Интернете, для игр и бенчей тех лет (HOMM 4, Doom 3, GTA 3, 3DMark 01, 03, 05 и т.п.). По видеокарте на данный момент есть FX5900 (полноценная, не ХТ) и 6600GT.
для однопотока первый вариант,хоть шина и на шаг меньше частота проца на 500+mhz выше
AM5 R7 7700=6050Mhz air WR
Это. 5900 или 6600гт ни разу не те карты, которые потянут игры, в которых старый квад даст профит.
На AsRock 775i65G процы вроде Е7400-7600 спокойно работают на 300 шине.
У меня кстати есть E7500 и E7600, мат.плата ревизии 2.04, биос последний, я искал и не нашел ответа, корректно ли работает по дефолту скажем E7600. Е5800 работает корректно, только POST долго проходит, но об этом я читал. Если кто либо подтвердит, что все без проблем и танцев с бубном, остановлюсь на E7600, если оно имеет смысл.
При 1066 шине с доступным делителем 3:2 память будет работать на 177МГц.
На ретровебе выложен модбиос с делителем 5:4, но я его не проверял.
На 300 шине с делителем 3:2 память будет на своих 200. У меня Е7400(или 7500, не помню) так стабильно работал.
Биос от версии R3.0 подходит в R2.0, а также в 775i65PE подходят обе версии (надо только родную двухмегабитную флешку поменять на четырехмегабитку)
Можно формулу по которой это посчитались?
i5 11400f | 16Gb | 3060 12Gb
Phenom II X3 720 | 16Gb DDR2 | 1030 2Gb
3/2 = FSB/RAM
RAM=FSB*2/3=266.66*2/3=177.77МГц
При делителе 5:4 будет
266,66*4/5=213,33МГц
2500k + gtx980ti + SSD :crazy:
серфинг на ХП для мазохистов, а вот игрушки и бенчи вполне.
Фото: 124
Не ослом единым, к тому же, ХР не так давно завершила жизненный цикл, со скоростью всё в порядке.
Безопасность под вопросом, но она и в актуальной ХР целиком зависела от адекватности пользователя.
matocob в прошлом году глубоко погружался в мир кастомных ХП браузеров. это было больно и унизительно))
если сегодня придумали какую рабочую альтернативу, здорово конечно. но я честно на это больше не куплюсь.
Фото: 124
Установить процессор и посмотреть религия не позволяет? На LGA775 работает корректно всё вплоть до Е8600, даже если BIOS его "не поддерживает" - вылезает раздражающая информационная строка CPU unknown, но работать будет, радикальных изменений в ядре нет. Если заработал Е5800, то будет работать и Е7600, т.к. всё это одно и то же ядро Wolfdale.
А вот с 4-ядерниками картина другая.
Процы с 1333 шиной могут не запуститься, может потребоваться мод на 1066. Не говоря уже о том, что для 865 чипсета это уже сильно перебор. А так, я даже xeon х2 запускал с 6М кэша на 865 чипсете.
CPU unknown 775 не выдает, но может ругаться на отсутствующий микрокод, асус, например. На ретровебе лежат модбиосы уже с микрокодами, как там указано.
Кстати, один из вариантов мода, как я понял, с форсированной установкой делителя 1:1 на 1066. У кого-нибудь 865 чипсет работал в таком режиме?
Фото: 124
Микрокод для одного и того же ядра одинаковый, т.к. набор регистров тот же.
Прикол был в том, что поддержку Wolfdale бросили на Е8500, так материнка (кстати, Асус, ага) ругалась именно на то, что не может опознать процессор.
Без микрокода вообще бы не запустилась, а так не смогла определиться с частотой шины и процессора, ну и соответственно с множителем.
для тех кто не заходит на барахолку Для коллекционеров пассивных видюшек - рабочая MSI NX7950GT-VT2D512EZ-HD за 300руб.
