Статус: Не в сети Регистрация: 22.03.2004 Откуда: Россия, Королев
Fighter Не смог достучаться не до первого, не до второго сервера, для чего-то... Сказал попробую попозже, причем это было уже в 18-й раз
Может прокси или файрвол режет?
Статус: Не в сети Регистрация: 16.11.2004 Откуда: Санкт-Петербург
Дайте плз ссылку на ФАК. Не понимать я что такое QMD , Gromacs и т.д. Добавлено спустя 46 минут, 22 секунды Решил глянуть статистику юзера. Вчера было все нормально, никаких номеров команд не менял. А в статистике вот такое
GvozD Last updated: Mon Jan 30 15:00:00 PST 2006 Mon Jan 30 23:00:00 UTC 2006
Date of last work unit 2006-01-29 03:20:52 Total score 1257 Overall rank (if points are combined) 189464 of 528857 Active processors (within 50 days) 1 Active processors (within 7 days) 1
GvozD has contributed work units with more than one different team number. The contributions are listed below.
Contributions by team and project:
Donator GvozD Team Default (includes all those WU returned without valid team number) (0) Score 1216 (certificate) Donator Rank 191974 of 528857 WU 765 (certificate) Date of last work unit 2003-09-28 00:06:15 Active processors (within 50 days) 0 Active processors (within 7 days) 0 Detailed listing for projects 0-999 Detailed listing for projects 1000-1999 Detailed listing for projects 2000-2999 Detailed listing for projects 3000-3999
Donator GvozD Team TSC! Russia (47191) Score 41 (certificate) Donator Rank 431387 of 528857 WU 1 (certificate) Date of last work unit 2006-01-29 03:20:52 Active processors (within 50 days) 1 Active processors (within 7 days) 1 Detailed listing for projects 0-999 Detailed listing for projects 1000-1999 Detailed listing for projects 2000-2999 Detailed listing for projects 3000-3999
If you have multiple team designations, you will see multiple records above. A given WU has a single username and team associated with it. This designation can not be changed for WUs that have already been turned in to our servers. You can change the team or username for future WUs in the config panel of the client.
Что делать?
Добавлено спустя 2 минуты, 28 секунд При этом в командной статистике я посчитал одну жабу и имею 41 очко. Бред какой-то. Добавлено спустя 18 минут, 36 секунд В общем, насколько , я понял. Существует еще один аккаунт под именем Gvozd и он состоит в дефолтной команде , то бишь нулевой. И теперь жабы выполненные обоими аккаунтами будут считаться как один общий чтоли? Получается что выход из создавшейся ситуации один. Потерять свои первые 41 очков, переименоваться и считать как бы заново. Помогите, плз, а то у меня Gromaсs считается здоровый. Абыдна !
Добавлено спустя 1 минуту, 13 секунд Только вот найти этот второй аккаунт мне не удалось почему-то. В команде под номером 0 минимальное кол-во очков ~21k. Или я чего-то не понимать
_________________ Аудиофил, оверклокер и лучший друг твоей мамы.
Статус: Не в сети Регистрация: 01.10.2003 Откуда: Челябинск
ГВОЗДЬ У тебя сколько компов? Один? Проверь в client.cfg номер команды.
Кстати! Судя по датам, все нормально. Под старым именем (точнее не именем, а номером команды) ты сливал в 2003 году, а сейчас все нормально и все считается куда надо.
Статус: Не в сети Регистрация: 22.12.2005 Откуда: Вологда
Учимся правильно себе команду прописывать.
А в командной у тебя действительно 41 очко. И это не глюк. Добавлено спустя 1 минуту, 27 секунд Хм. Не заметил.
Нарушитель видимо прав.
to ГВОЗДЬ Номер команды тут ни причем.
У меня такая же ситуация была не далее как позавчера.
Посчитал громакс , слил и на тебе: пишет, что в 2003 году я посчитал эту жабу и очки занесли на счет какой-то команды за номером 10971 и теперь я числюсь в двух командах.
Однако через несколько часов (часов через 5) все стало как надо и мне зачислили честно заработанные 244 очка
Пара дополнений:
1) Во время этого счета нагрузка на систему была минимальной. Несколько часов инета-музыки-мелких прожек типа GoldEd. Никаких игр и кодирования видео 2) FahCore_96.exe как видно патченный, выкачан по приводившейся где-то здесь ссылке.
3) По времени на кадр бывают и перекосы:
[14:06:19] Completed 1321 out of 2064 steps (64)
[14:06:19] Writing local files
[14:16:03] Completed 1342 out of 2064 steps (65)
