Here is an update and some more details on the third generation GPU core. As I stated before, this core is built on OpenMM, which brings the science further along and allows us to make easier updates. OpenMM supports OpenCL in beta form in its 1.0 release (scheduled for late January 2010), but it is important to stress that the OpenCL support is very early and so we will not be relying on OpenCL in the first releases of the GPU3 core.
This means that the core will only roll out for NVIDIA first. ATI has depreciated Brook, but does not have a fully-functioning OpenCL implementation, so we are stuck in between support on the ATI side. Once the OpenCL implementation matures (on both ATI and NVIDIA), we will be able to finish and optimize our OpenCL code (we can't reliably optimize code until the implementations are more finalized), and then the OpenCL portions will go into QA.
So, if you are interested in OpenCL (especially in terms of ATI support), this will not be in the initial release, but once the environment has matured, we will push forward. By the way, once OpenCL support for multi-core boxes has matured, we will also see about porting the GPU3 code as a new SMP2 style core as well (i.e. threads-based SMP support). If the performance is strong, it's appealing to think that we can go back to having a single dominant code base for much of FAH's calculations.
Just an update on my blog post. I want to make it clear that we're seeing problems in both of our ATI and NVIDIA GPU OpenCL implementations for OpenMM. Maybe it's on our side (I'm bet some bugs are on our side), but we suspect there could possibly be some issues with both the NVIDIA and ATI OpenCL implementations (and maybe even Apple's). We are working with everyone closely to either fix our bugs or get our code compliant with the OpenCL implementations.
Also, it looks like I should have been more careful in my wording of my previous post. I was referring to the issues above when talking about whether the ATI implementation was "fully functional" and some groups have gotten this out of my intended context. As far as I understand, the ATI OpenCL implementation is fully functional.
Finally, it is important to note that our Brook code is still supported, just not actively developed so Folding@Home/OpenMM is concentrating on shifting to OpenCL, so no more active development using Brook.
Статус: Не в сети Регистрация: 06.10.2009 Откуда: Москва
У самого с баблом не акти и тож думаю, что на новый камень (вроде как ко мне едет 970-й) придётся ставить (временно) мой ТТБТ... В номинале то будет воркать, а вот про разгон наверное и не стОит говорить
_________________ TSC! Russia - http://forums.overclockers.ru/viewforum.php?f=21 Обезьяньи гонки 2011 - http://forums.overclockers.ru/viewtopic.php?f=21&t=392609
Статус: Не в сети Регистрация: 24.01.2010 Откуда: RT | МО
noname2 У человека проблема - нехватка общения! Никто его внутренний мир не считает наполненным и не признает величия его разума, вот он и опщается. Придумывает, фантазирует и выдает свои мысли за чужие. Знал бы он что розетка там исследует про изучение заморзке и бомбардировке... Прикинь простооооор для умозаключений, а тут только вон его порабощение... Кому нужны генные рабы, если все и так уже давно рабы мошны...
TSC! Russia member
Статус: Не в сети Регистрация: 24.07.2004 Откуда: Yaroslavl Фото: 32
Hil
что ЭП и ТВ - без разницы
как это по русски звучит? не понял о чем речь..
да и в соседней не фонтан,...и живёшь не над вокзалом
живу в соседней комнате, вокзал ближайщий в 15 км, на 470 и вентеля на 2000 не жалуюсь, как и на слух пока еще.. Щас жду когда завезут новые скайзы на 3000rpm.. и о чем это тебе говорит? свист дросселей в бп, теликах/мониках ЭЛТ слышу до сих пор за десятки метров... и??
_________________ Бег – искусство оставаться на месте
Статус: Не в сети Регистрация: 16.12.2002 Откуда: TSC! | Москва
О фанатичной преданности бренду. Или о сильно улучшенном нереференсном охлаждении. Ибо абсолютно по всем обзорам времён релиза референс 470-я была шумнее 480-ой и на тот момент самой шумной картой (по крайней мере, среди одночипов).
Статус: Не в сети Регистрация: 19.11.2010 Откуда: Волжский/Волг-д
Эхх... так и не получилось 500к за месяц выжать. А очень хотелось. Очков 498,225 Заданий 505 http://folding.extremeoverclocking.com/ ... =&u=314962 Сезон обогревателей кончается, а посему (если LAV48 разрешит конечно) меняю 9600ПЫЩ и 8800ПЕЧ на ПЕЧ450. Возможна доплата пивом
Эхх... так и не получилось 500к за месяц выжать...
а вот тут я сразу про бабло подумал фига се думаю чел напрягся... не дотянул за месяц до пол ляма... мне бы его проблемы - подумал я............ насчёт 450-й печи поддерживаю тебя - хороший выбор
TSC! Russia member
Hil про первый вопрос? что это было, бэримор?
а этот вывод вообще с чего? и какому бренду (чтоб мне знать )? если все таки сходишь в профиль то будет понятно что низкие частоты мне пофигу, а из соседней комнаты вообще побарабану даже когда эта 470 с кулером на 100% жабы на 7,2к очков сутками напролет считала.. кулер на 470 референс - ничего не трогал (охлад корпуса если интересен : 4 шт 120мм +4 шт 140мм)
Статус: Не в сети Регистрация: 02.02.2010 Откуда: Пермь
Почему троллю? Сейчас встретил, вот и задумался. Ненадолго, естественно. Что за ЦП и в каком количестве используют. Буржуйские ядра или свои, убогие, показывающие нормальный результат разве что в небольшой толике ПО. Как связаны ядра между собой. Как охлаждение организовали. Ибо корпус что-то маловат для всего этого. В ролике только общая концепция на миг появилась.
_________________ Распределенные вычисления - http://tscrussiateam.ru/ Форум нашей команды - http://forums.overclockers.ru/viewforum.php?f=21
