[05:39:29] - Ask before connecting: No [05:39:29] - Proxy: mr-temp:8080 [05:39:29] - User name: Monomax_Ukraine (Team 47191) [05:39:29] - User ID: 15244CF466EDB469 [05:39:29] - Machine ID: 4 [05:39:29] [05:39:29] Loaded queue successfully. [05:39:29] + Benchmarking ... [05:39:31] [05:39:31] + Processing work unit [05:39:31] Core required: FahCore_78.exe [05:39:31] Core found. [05:39:31] Working on Unit 05 [October 24 05:39:31] [05:39:31] + Working ...
[05:39:31] + Attempting to send results [05:39:31] [05:39:31] *------------------------------* [05:39:31] Folding@Home Gromacs Core [05:39:31] Version 1.90 (March 8, 2006) [05:39:31] [05:39:31] Preparing to commence simulation [05:39:31] - Looking at optimizations... [05:39:31] - Files status OK [05:39:31] - Expanded 78882 -> 420497 (decompressed 533.0 percent) [05:39:31] [05:39:31] Project: 2124 (Run 16, Clone 11, Gen 10) [05:39:31] [05:39:31] Assembly optimizations on if available. [05:39:31] Entering M.D. [05:39:52] (Starting from checkpoint) [05:39:52] Protein: p2124_lambda_5way_melt_4_10011 [05:39:52] [05:39:52] Writing local files [05:39:52] Using table 3 [05:39:52] Extra SSE boost OK. [05:39:52] Writing local files [05:39:52] Completed 0 out of 20000000 steps (0) [05:39:52] - Couldn't send HTTP request to server [05:39:52] + Could not connect to Work Server (results) [05:39:52] (171.64.122.130:8080) [05:39:52] - Error: Could not transmit unit 04 (completed October 23) to work server.
[05:39:52] + Attempting to send results [05:39:59] - Couldn't send HTTP request to server [05:39:59] + Could not connect to Work Server (results) [05:39:59] (171.65.103.100:8080) [05:39:59] Could not transmit unit 04 to Collection server; keeping in queue.
Заменил client.cfg от домашней машинки на client.cfg от рабочей машины. Может что не так сделал?
_________________ Опасайтесь ваших желаний - они могут сбыться... TSC! Russia Member; *Cofradia Intel*; пенсионер оверклокинга.
Статус: Не в сети Регистрация: 05.01.2003 Откуда: Москва Фото: 2
Кстати не хреново зависят 1498 жабы от 1T и 2T.
Раньше максимальный ppd на этих жабах при 2T был у меня 173, сейчас посмотрел - максимальный ppd при 1T - 210
_________________ Устав традиций нужно соблюдать, Хоть и не раз ответят вам отказом: Конечно, баба может и не дать, Но предложить ты ей всегда обязан!
Статус: Не в сети Регистрация: 16.12.2002 Откуда: TSC! | Москва
Максим ppd на 1498 - это цирк. У одних он хаотично скачет, у других плавно падает, у третьих стабильно держится на одном показателе всю дорогу. Поэтому судить можно только по одной и той же жабе в пределах 3 - 6%, иначе может оказаться, что причина не в таймингах, а в закидонах жабы.
Мономах По FAHMon смотрю. Он просто может показывать максимальную скорость в ppd на каком-либо шаге
Вот по нему и смотрю.
Закидоны жабы по идее не могут быть настолько разными.
А то что она эта жабка любит скакать, сам знаю - то 240 метров под себя загребает, то 80 метров, обычно по 160-200.
TSC! Russia Vice-captain
Статус: Не в сети Регистрация: 21.03.2006 Откуда: Петербург
Anoss Я так и подумал. И по графикам видно. Кстати, скрипт заработал 12-го числа? Просто у тебя там статистика интересная, 12-го был резкий всплеск посещений. Интересно, что мой конторский ip в 20-ке посещений...
_________________ Революционеров можно убить, идеи — никогда.
Статус: Не в сети Регистрация: 01.04.2005 Откуда: Москва-Лубянка
Behc Ну да, 12-го, и по графикам, опять же, видно
…и благодаря qeops85 Армения на 3-м месте Добавлено спустя 11 минут, 39 секунд На самом деле, все указывает на то, что это не у меня инета не было, а сам http://fah-web.stanford.edu/serverstat.html не отвечал…)
Статус: Не в сети Регистрация: 28.05.2006 Откуда: Укр. Xарьков
получил новую ошибку ( Project: 2411 (Run 44, Clone 14, Gen 10))
Код:
[11:10:31] Completed 237500 out of 250000 steps (95) [11:13:48] Quit 101 - Fatal error: NaN detected: (ener[17]) [11:13:48] [11:13:48] Simulation instability has been encountered. The run has entered a [11:13:48] state from which no further progress can be made. [11:13:48] This may be the correct result of the simulation, however if you [11:13:48] often see other project units terminating early like this [11:13:48] too, you may wish to check the stability of your computer (issues [11:13:48] such as high temperature, overclocking, etc.). [11:13:48] Going to send back what have done. [11:13:48] logfile size: 298924 [11:13:48] - Writing 299487 bytes of core data to disk... [11:13:48] ... Done.
_________________ (_KoDAk_) Ukraine Для Блага Науки...
KoDAkchek Более развёрнутый вариант EUE. Бывает раз в 5-6 реже обычного. Скорее всего, причина всё равно в нестабильности системы, однако вероятно, что дело в самой жабе. О чём тебе и написано, собственно.
Зато за такую ошибку очки начисляют как правило именно пропорционально.
