Статус: Не в сети Регистрация: 29.10.2006 Откуда: москва
всем привет зарание извиняюсь , если пост не по теме или подобное где-то было, у меня на локальной машине посчиталось задание(большое какое-то слишком) а из дома не отправляется уже второй день, вот лог теперь в УД-кеше весит результат(всё в одном слоте) и не посчитаное задание, при включении пытается отправить, обламывается, и начинает считать задание.
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[02:51:40] - Ask before connecting: Yes
[02:51:40] - Use IE connection settings: Yes
[02:51:40] - User name: diver11 (Team 47191)
[02:51:40] - User ID: 642667550F528E28
[02:51:40] - Machine ID: 2
[02:51:40]
[02:51:40] Loaded queue successfully.
[02:51:40] + Benchmarking ...
[02:51:43] The benchmark result is 5520
[02:51:43]
[02:51:43] + Processing work unit
[02:51:43] Core required: FahCore_a0.exe
[02:51:43] - Autosending finished units...
[02:51:43] Trying to send all finished work units
[02:51:43] Core found.
[02:51:43] + Attempting to send results
[02:51:43] - Reading file work/wuresults_03.dat from core
[02:51:43] (Read 39285899 bytes from disk)
[02:51:43] - Presenting message box asking to network.
[02:51:43] Working on Unit 05 [April 26 02:51:43]
[02:51:43] + Working ...
[02:51:43] - Calling 'FahCore_a0.exe -dir work/ -suffix 05 -priority 96 -checkpoint 15 -forceasm -verbose -lifeline 2232 -version 504'
[02:51:44]
[02:51:44] *------------------------------*
[02:51:44] Folding@Home Gromacs 3.3 Core
[02:51:44] Version 1.73 (April 17, 2007)
[02:51:44]
[02:51:44] Preparing to commence simulation
[02:51:44] - Assembly optimizations manually forced on.
[02:51:44] - Not checking prior termination.
[02:51:46] Couldn't send HTTP request to server (wininet)
[02:51:46] + Could not connect to Work Server (results)
[02:51:46] (171.65.103.106:8080)
[02:51:46] - Error: Could not transmit unit 03 (completed April 25) to work server.
[02:51:46] - 12 failed uploads of this unit.
[02:51:46] + Attempting to send results
[02:51:46] - Reading file work/wuresults_03.dat from core
[02:51:47] (Read 39285899 bytes from disk)
[02:51:58] - Expanded 3957306 -> 21210245 (decompressed 535.9 percent)
[02:52:00] Couldn't send HTTP request to server (wininet)
[02:52:00] + Could not connect to Work Server (results)
[02:52:00] (171.65.103.100:8080)
[02:52:00] Could not transmit unit 03 to Collection server; keeping in queue.
[02:52:00]
[02:52:00] Project: 2614 (Run 3, Clone 252, Gen 2)
[02:52:00]
[02:52:04] + Sent 0 of 1 completed units to the server
[02:52:04] - Autosend completed
[02:52:33] Assembly optimizations on if available.
[02:52:33] Entering M.D.
[02:52:57] (Starting from checkpoint)
[02:52:58] Protein: LIPID ONLY
[02:52:59] Writing local files
[02:53:04] ***** Got a SIGTERM signal (2)
[02:53:04] Killing all core threads
Статус: Не в сети Регистрация: 14.04.2006 Откуда: Москва
Кажется проблема устранена - на "171.65.103.100:8080" отправилось рассчитанное задание с первой попытки, ну и то, что раньше лежало тоже отправилось еще дня два назад (правда пролежало конечно три дня готовым, ну ничего, гнилым не пахнет...).
Статус: Не в сети Регистрация: 12.10.2006 Откуда: РОССИЯ ОРЕНБУРГ
Я скоро материться буду... терпение иссякло! ладно до сервера не достучаться, но чтобы 4 жабы не засчитали это уже перебор!!!
Код:
[08:59:20] - Ask before connecting: No [08:59:20] - Use IE connection settings: Yes [08:59:20] - User name: Mihey-2010 (Team 47191) [08:59:20] - User ID: 7718F1A14E2F02E2 [08:59:20] - Machine ID: 1 [08:59:20] [08:59:21] Loaded queue successfully. [08:59:21] Attempting to return result(s) to server... [08:59:21] Trying to send all finished work units
[08:59:21] + Attempting to send results [08:59:21] - Reading file work/wuresults_08.dat from core [08:59:21] (Read 1309671 bytes from disk) [09:00:36] - Uploaded at ~17 kB/s [09:00:36] - Averaged speed for that direction ~26 kB/s [09:00:36] + Results successfully sent [09:00:36] Thank you for your contribution to Folding@Home. [09:00:36] + Number of Units Completed: 33
[09:00:36] + Sent 1 of 1 completed units to the server [09:00:36] ***** Got a SIGTERM signal (2) [09:00:36] Killing all core threads
_________________ ДОБРО ПОБЕДИТ ЗЛО!!! ПОТОМ ПОСТАВИТ НА КОЛЕНИ И ЗВЕРСКИ УБЬЕТ!
Присоединяйтесь к TSC! Russia - www.tsc.overclockers.ru RUSSIA FOREVER!!!
TSC! Russia Vice-captain
Статус: Не в сети Регистрация: 21.03.2006 Откуда: Петербург
Mihey-2010 Если есть копия результата, то попробуй слить ещё раз.
А агрессию можно выплеснуть в этой ветке форума докторов. Не забываем, что ругаться нужно на енглише.
_________________ Революционеров можно убить, идеи — никогда.
В том-то и дело что уже на 3 нет... а последнюю уже раз 6 отсялал за последние 2 дня.....
в ангийском нет таких слов... и регится муторно...( уже пробовал и не получилось)...
Статус: Не в сети Регистрация: 04.02.2005 Откуда: Россия\Москва Фото: 3
сделайте плиз таблицу соответствия значения priority в конфиге и получаемого приоритета в винде (средний/ниже среднего и пр.)
а то я ничего не понимаю =\
_________________ Присоединяйтесь к команде распределённых вычислений TSC! Russia
Статус: Не в сети Регистрация: 14.11.2003 Откуда: урановый рудник Фото: 1
Behc Здравствуй еще раз...
Нет, уже стабильно неделю ни разу не добавлялись очки (это минимум 4000). Только что в очередной раз отследил - отправилась готовая жаба, жду несколько минут. Ни одного очка не прибавилось.
Боюсь, что придется оставить мне фолдинг, потому как теряется всякий стимул продолжать.
П.С. Нет, и через 15 минут очки не добавились.
Aegis В это теме это не флейм, а решение проблем. Как такой вариант:
1. Удалить из реестра ключ HKEY_LOCAL_MACHINE\SOFTWARE\PandeGroup\Folding@home (на всякий случай)
2. Посчитать задания в течении недели под другим ником в нашей команде, который сливает не так много (чтобы можно было точно отследить). Например под этим. Добавлено спустя 3 минуты, 55 секунд Кстати, у кого-то в ваше банде Biomancer'ов 100% переразгон. Жабы мрут, Гринпис в ужасе!
2007-05-01 392 500 23 330 1,227
Жаб на 2 и 3 очка не бывает!
Статус: Не в сети Регистрация: 14.03.2006 Откуда: Made in USSR
Chugumoto, к примеру сервер №1 обновляется в 15:01, а №2 в 15:20
Ты слил жабу в 14:48. Другой кто-то слил жабу в 15:09 по очкам более чем у тебя.
Очевидно, что "другой" не попадает под обновление сервера №1, но попадает под №2.
И так, ты смещаешься с первого места на второе по статитике сервера №2, но по №1, ты будешь еще первый до следующего обновления
