Статус: Не в сети Регистрация: 16.12.2002 Откуда: TSC! | Москва
Кстати, при -smp 3 клиент культурно юзает только три ядра. И ни каплей больше, даже если их 4. Это для тех, кому дорог GPU ATI, хотя потери на SMP A3 очень большие при этом - вместо указанных anubias 7000 на 4 ядрах Фенома 2 3,4 ГГц я получаю на трёх ядрах такого же фенома 2 той же частоты 2800 ppd.
Launched as a service. Entered C:\фах1 to do work.
[13:50:12] - Ask before connecting: No [13:50:12] - User name: HMAO_TSC!Russia (Team 47191) [13:50:12] - User ID: E37300D467690A7 [13:50:12] - Machine ID: 1 [13:50:12] [13:50:12] Loaded queue successfully. [13:50:12] + Benchmarking ... [13:50:15] [13:50:15] + Processing work unit [13:50:15] Core required: FahCore_78.exe [13:50:15] Core found. [13:50:15] - Error: Length of work/wuresults_05.dat (6907918) exceeds packet limit set (5241856) [13:50:15] - Error: Could not transmit unit 05 (completed January 20) to work server. [13:50:15] - Error: Length of work/wuresults_05.dat (6907918) exceeds packet limit set (5241856) [13:50:15] Could not transmit unit 05 to Collection server; keeping in queue. [13:50:15] Working on Unit 06 [January 27 13:50:15] [13:50:15] + Working ... [13:50:15] [13:50:15] *------------------------------* [13:50:15] Folding@Home Gromacs Core [13:50:15] Version 1.90 (March 8, 2006) [13:50:15] [13:50:15] Preparing to commence simulation [13:50:15] - Looking at optimizations... [13:50:15] - Files status OK [13:50:15] - Expanded 390028 -> 2244040 (decompressed 575.3 percent) [13:50:20] [13:50:20] Project: 6318 (Run 3059, Clone 37, Gen 0) [13:50:20] [13:50:21] Assembly optimizations on if available. [13:50:21] Entering M.D. [13:50:41] (Starting from checkpoint) [13:50:41] Protein: Great Red Oystrich Makes All Chemists Sane in water [13:50:41] [13:50:41] Writing local files [13:50:41] Completed 465000 out of 500000 steps (93) [13:50:41] Extra SSE boost OK. [14:05:21] Writing local files [14:05:22] Completed 470000 out of 500000 steps (94) [14:20:37] Writing local files [14:20:37] Completed 475000 out of 500000 steps (95) [14:35:40] Writing local files [14:35:40] Completed 480000 out of
Вот. Считается обычным клиентом , ядро78. Если действительно эти задания начали приходить на НОВОГО клиента, напрашивается вывод: -скорее всего останется один клиент( и на одноядерники и на многоядерники), а разница в очках будет только за счёт скорости счёта.
Статус: Не в сети Регистрация: 13.05.2006 Откуда: Питер
не гоните на клиент,все что больше по номеру p6313 это обычные громаксы и должны считаться на FahCore_78.exe
Статус: Не в сети Регистрация: 05.12.2006 Откуда: Ханты-Мансийск
anubias А как же тогда высказывания наших комрадов с утверждениями о наблюдении ядра ГРО-А3 в диспетчере задач при расчёте этих заданий? Не ужели всё-таки ошибка? А я поверил..
Niko-zhukov я тоже не понимал почему ко мне ползут 2665 и стабильно дохнут три раза, а потом качаются нормальные для расчета на А3 ядре,пока не обнаружил ошибку в ярлыке. могу сказать только одно-кривые ручки или "и на старуху бывает непруха".
Добавлено спустя 48 секунд: Biker поживем увидим,а к тебе приходили на ядро А3 эти номера?
Я вот думаю при получении такой жабы на НОВОГо клиента надо убедиться в отсутствии ядра 78 в его папке, токгда можно будет с уверенностью сказать о возможности счёта ядром ГРО-А3 обычных заданий. Кстати задания 6318 на 1 ядре фенома 2,4 Ггц 78-м ядром давало ППД порядка 350, т.е. сравнимо с указанными выше результатами
Статус: Не в сети Регистрация: 12.10.2006 Откуда: РОССИЯ ОРЕНБУРГ
anubias писал(а):
Mihey-2010 писал(а):
ничего не понимаю но мне это нравится. пойду ка я подальше от компа. пусть считает...
странно слышать от TSC! Russia member факт известный,любая дополнительная загрузка на калькулятор негативно влияет на ППД, растет шаг,меняется бонус фактор. Подальше и подольше от компьютера
хех. я в команде с 13.10.2006 года. начинал считать на IP4 nortwood 2.26GHz 533fsb, 256 Mb Samsung pc2700, 256Mb+TwinMos pc3200, Winxp sp2, громаксы. не более 170ппд в сутки. потом гростами обменивались, там 330ппд. в августе 2007 пересел на C2D ноут в профиле и только тогда начал смп щелкать, только ппд был не более 800-900. и это было в радость, каждые 2 недели чистил радиаторы ибо пылью беспощадно забивались, там через почти год после первого слива первые счастливые 13к ппд за которые и попросил статус. а после мать на ноуте подохла нагрузку не держала. бросил считать. вот обновил конфиг и неделю только считаю, пока во все тонкости не проник поэтому и удивляюсь. сейчас вольюсь в "струю", узнаю по больше и меньше глупых вопросов постараюсь задавать
_________________ ДОБРО ПОБЕДИТ ЗЛО!!! ПОТОМ ПОСТАВИТ НА КОЛЕНИ И ЗВЕРСКИ УБЬЕТ!
Присоединяйтесь к TSC! Russia - www.tsc.overclockers.ru RUSSIA FOREVER!!!
Статус: Не в сети Регистрация: 26.08.2005 Откуда: 34
Нету в папке 78 ядра. В линухе оно строго. Просто какой-то косяГ в отображении. Кому интересно лог ковырять, мож чо здесь есть:
Код:
--- Opening Log file [January 31 10:53:58 UTC]
# Linux SMP Console Edition ################################################### ###############################################################################
[11:58:52] - Ask before connecting: No [11:58:52] - User name: LAV48 (Team 47191) [11:58:52] - User ID: 20736C690BAD6989 [11:58:52] - Machine ID: 1 [11:58:52] [11:58:53] Loaded queue successfully. [11:58:53] [11:58:53] - Autosending finished units... [January 31 11:58:53 UTC] [11:58:53] Trying to send all finished work units [11:58:53] + No unsent completed units remaining. [11:58:53] - Autosend completed [11:58:53] + Processing work unit [11:58:53] Core required: FahCore_a3.exe [11:58:53] Core found. [11:58:53] Working on queue slot 02 [January 31 11:58:53 UTC] [11:58:53] + Working ... [11:58:53] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 4 -checkpoint 15 -forceasm -verbose -lifeline 6474 -version 629'
[11:58:53] [11:58:53] *------------------------------* [11:58:53] Folding@Home Gromacs SMP Core [11:58:53] Version 2.13 (Tue Aug 18 18:28:33 CEST 2009) [11:58:53] [11:58:53] Preparing to commence simulation [11:58:53] - Assembly optimizations manually forced on. [11:58:53] - Not checking prior termination. [11:58:53] - Expanded 1799161 -> 2392545 (decompressed 132.9 percent) [11:58:53] Called DecompressByteArray: compressed_data_size=1799161 data_size=2392545, decompressed_data_size=2392545 diff=0 [11:58:53] - Digital signature verified [11:58:53] [11:58:53] Project: 6015 (Run 0, Clone 122, Gen 6) [11:58:53] [11:58:53] Assembly optimizations on if available. [11:58:53] Entering M.D. [11:59:00] Using Gromacs checkpoints [11:59:00] Resuming from checkpoint [11:59:00] Verified work/wudata_02.log [11:59:00] Verified work/wudata_02.trr [11:59:00] Verified work/wudata_02.edr [11:59:01] Completed 435930 out of 500000 steps (87%) [12:05:13] Completed 440000 out of 500000 steps (88%) [12:12:14] Completed 445000 out of 500000 steps (89%) [12:19:10] Completed 450000 out of 500000 steps (90%) [12:25:54] Completed 455000 out of 500000 steps (91%) [12:32:46] Completed 460000 out of 500000 steps (92%) [12:39:36] Completed 465000 out of 500000 steps (93%) [12:46:30] Completed 470000 out of 500000 steps (94%) [12:53:51] Completed 475000 out of 500000 steps (95%) [13:01:06] Completed 480000 out of 500000 steps (96%) [13:08:05] Completed 485000 out of 500000 steps (97%) [13:15:02] Completed 490000 out of 500000 steps (98%) [13:21:56] Completed 495000 out of 500000 steps (99%) [13:28:53] Completed 500000 out of 500000 steps (100%) [13:28:53] DynamicWrapper: Finished Work Unit: sleep=10000 [13:29:03] [13:29:03] Finished Work Unit: [13:29:03] - Reading up to 20449968 from "work/wudata_02.trr": Read 20449968 [13:29:04] trr file hash check passed. [13:29:04] edr file hash check passed. [13:29:04] logfile size: 56743 [13:29:04] Leaving Run [13:29:04] - Writing 20541243 bytes of core data to disk... [13:29:04] ... Done. [13:29:14] - Shutting down core [13:29:14] [13:29:14] Folding@home Core Shutdown: FINISHED_UNIT [13:29:14] CoreStatus = 64 (100) [13:29:14] Unit 2 finished with 92 percent of time to deadline remaining. [13:29:14] Updated performance fraction: 0.869742 [13:29:14] Sending work to server [13:29:14] Project: 6015 (Run 0, Clone 122, Gen 6)
[13:29:14] + Attempting to send results [January 31 13:29:14 UTC] [13:29:14] - Reading file work/wuresults_02.dat from core [13:29:14] (Read 20541243 bytes from disk) [13:29:14] Connecting to http://130.237.232.140:8080/ [13:30:23] Posted data. [13:30:23] Initial: 0000; - Uploaded at ~286 kB/s [13:30:24] - Averaged speed for that direction ~255 kB/s [13:30:24] + Results successfully sent [13:30:24] Thank you for your contribution to Folding@Home. [13:30:24] + Number of Units Completed: 12
[13:30:30] Trying to send all finished work units [13:30:30] + No unsent completed units remaining. [13:30:30] - Preparing to get new work unit... [13:30:30] Cleaning up work directory [13:30:31] + Attempting to get work packet [13:30:31] Passkey found [13:30:31] - Will indicate memory of 984 MB [13:30:31] - Connecting to assignment server [13:30:31] Connecting to http://assign.stanford.edu:8080/ [13:30:33] Posted data. [13:30:33] Initial: 40AB; - Successful: assigned to (171.64.65.56). [13:30:33] + News From Folding@Home: Welcome to Folding@Home [13:30:33] Loaded queue successfully. [13:30:33] Connecting to http://171.64.65.56:8080/ [13:30:40] Posted data. [13:30:40] Initial: 0000; - Receiving payload (expected size: 4836105) [13:32:20] - Downloaded at ~47 kB/s [13:32:20] - Averaged speed for that direction ~174 kB/s [13:32:20] + Received work. [13:32:20] Trying to send all finished work units [13:32:20] + No unsent completed units remaining. [13:32:20] + Closed connections [13:32:20] [13:32:20] + Processing work unit [13:32:20] Core required: FahCore_a2.exe [13:32:20] Core found. [13:32:20] Working on queue slot 03 [January 31 13:32:20 UTC] [13:32:20] + Working ... [13:32:20] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -nice 19 -suffix 03 -checkpoint 15 -forceasm -verbose -lifeline 6474 -version 629'
[13:32:20] [13:32:20] *------------------------------* [13:32:20] Folding@Home Gromacs SMP Core [13:32:20] Version 2.10 (Sun Aug 30 03:43:28 CEST 2009) [13:32:20] [13:32:20] Preparing to commence simulation [13:32:20] - Ensuring status. Please wait. [13:32:21] Called DecompressByteArray: compressed_data_size=4835593 data_size=23977273, decompressed_data_size=23977273 diff=0 [13:32:21] - Digital signature verified [13:32:21] [13:32:21] Project: 2669 (Run 2, Clone 114, Gen 115) [13:32:21] [13:32:21] Assembly optimizations on if available. [13:32:21] Entering M.D. [13:32:31] on if available. [13:32:31] Entering M.D. [13:32:39] (0%) [13:37:59] Completed 2500 out of 250000 steps (1%) [13:43:18] Completed 5000 out of 250000 steps (2%) [13:48:53] Completed 7500 out of 250000 steps (3%) [13:54:13] Completed 10000 out of 250000 steps (4%) [13:59:49] Completed 12500 out of 250000 steps (5%) [14:05:18] Completed 15000 out of 250000 steps (6%) [14:10:42] Completed 17500 out of 250000 steps (7%) [14:16:18] Completed 20000 out of 250000 steps (8%) [14:22:07] Completed 22500 out of 250000 steps (9%) [14:27:25] Completed 25000 out of 250000 steps (10%) [14:33:00] Completed 27500 out of 250000 steps (11%) [14:39:09] Completed 30000 out of 250000 steps (12%) [14:46:23] Completed 32500 out of 250000 steps (13%) [14:54:30] Completed 35000 out of 250000 steps (14%) [15:02:45] Completed 37500 out of 250000 steps (15%) [15:10:54] Completed 40000 out of 250000 steps (16%) [15:18:56] Completed 42500 out of 250000 steps (17%) [15:24:14] Completed 45000 out of 250000 steps (18%) [15:29:25] Completed 47500 out of 250000 steps (19%) [15:34:39] Completed 50000 out of 250000 steps (20%) [15:39:53] Completed 52500 out of 250000 steps (21%) [15:45:04] Completed 55000 out of 250000 steps (22%) [15:50:15] Completed 57500 out of 250000 steps (23%) [15:55:24] Completed 60000 out of 250000 steps (24%) [16:00:34] Completed 62500 out of 250000 steps (25%) [16:05:46] Completed 65000 out of 250000 steps (26%) [16:10:56] Completed 67500 out of 250000 steps (27%) [16:16:06] Completed 70000 out of 250000 steps (28%) [16:21:20] Completed 72500 out of 250000 steps (29%) [16:26:34] Completed 75000 out of 250000 steps (30%) [16:31:48] Completed 77500 out of 250000 steps (31%) [16:37:04] Completed 80000 out of 250000 steps (32%) [16:42:20] Completed 82500 out of 250000 steps (33%) [16:47:32] Completed 85000 out of 250000 steps (34%) [16:52:49] Completed 87500 out of 250000 steps (35%) [16:58:06] Completed 90000 out of 250000 steps (36%) [17:03:19] Completed 92500 out of 250000 steps (37%) [17:08:34] Completed 95000 out of 250000 steps (38%) [17:13:45] Completed 97500 out of 250000 steps (39%) [17:18:55] Completed 100000 out of 250000 steps (40%) [17:24:06] Completed 102500 out of 250000 steps (41%) [17:29:12] Completed 105000 out of 250000 steps (42%) [17:34:19] Completed 107500 out of 250000 steps (43%) [17:39:27] Completed 110000 out of 250000 steps (44%) [17:44:34] Completed 112500 out of 250000 steps (45%) [17:49:41] Completed 115000 out of 250000 steps (46%) [17:54:53] Completed 117500 out of 250000 steps (47%) [17:58:53] - Autosending finished units... [January 31 17:58:53 UTC] [17:58:53] Trying to send all finished work units [17:58:53] + No unsent completed units remaining. [17:58:53] - Autosend completed [17:59:59] Completed 120000 out of 250000 steps (48%) [18:05:06] Completed 122500 out of 250000 steps (49%) [18:10:15] Completed 125000 out of 250000 steps (50%) [18:15:22] Completed 127500 out of 250000 steps (51%) [18:20:30] Completed 130000 out of 250000 steps (52%) [18:25:40] Completed 132500 out of 250000 steps (53%) [18:30:48] Completed 135000 out of 250000 steps (54%) [18:35:57] Completed 137500 out of 250000 steps (55%) [18:41:07] Completed 140000 out of 250000 steps (56%) [18:46:15] Completed 142500 out of 250000 steps (57%) [18:51:22] Completed 145000 out of 250000 steps (58%) [18:56:35] Completed 147500 out of 250000 steps (59%) [19:01:46] Completed 150000 out of 250000 steps (60%) [19:06:54] Completed 152500 out of 250000 steps (61%) [19:12:08] Completed 155000 out of 250000 steps (62%) [19:17:16] Completed 157500 out of 250000 steps (63%) [19:22:24] Completed 160000 out of 250000 steps (64%) [19:27:34] Completed 162500 out of 250000 steps (65%) [19:32:43] Completed 165000 out of 250000 steps (66%) [19:37:50] Completed 167500 out of 250000 steps (67%) [19:43:02] Completed 170000 out of 250000 steps (68%) [19:48:10] Completed 172500 out of 250000 steps (69%) [19:53:18] Completed 175000 out of 250000 steps (70%) [19:58:29] Completed 177500 out of 250000 steps (71%) [20:03:38] Completed 180000 out of 250000 steps (72%) [20:08:44] Completed 182500 out of 250000 steps (73%) [20:13:53] Completed 185000 out of 250000 steps (74%) [20:19:00] Completed 187500 out of 250000 steps (75%) [20:24:08] Completed 190000 out of 250000 steps (76%) [20:29:17] Completed 192500 out of 250000 steps (77%) [20:34:24] Completed 195000 out of 250000 steps (78%) [20:39:31] Completed 197500 out of 250000 steps (79%) [20:44:44] Completed 200000 out of 250000 steps (80%) [20:49:53] Completed 202500 out of 250000 steps (81%) [20:55:00] Completed 205000 out of 250000 steps (82%) [21:00:11] Completed 207500 out of 250000 steps (83%) [21:05:18] Completed 210000 out of 250000 steps (84%) [21:10:30] Completed 212500 out of 250000 steps (85%) [21:15:44] Completed 215000 out of 250000 steps (86%) [21:20:56] Completed 217500 out of 250000 steps (87%) [21:26:10] Completed 220000 out of 250000 steps (88%) [21:31:22] Completed 222500 out of 250000 steps (89%) [21:36:34] Completed 225000 out of 250000 steps (90%) [21:41:49] Completed 227500 out of 250000 steps (91%) [21:47:00] Completed 230000 out of 250000 steps (92%) [21:52:12] Completed 232500 out of 250000 steps (93%) [21:57:25] Completed 235000 out of 250000 steps (94%) [22:02:37] Completed 237500 out of 250000 steps (95%) [22:07:48] Completed 240000 out of 250000 steps (96%) [22:13:03] Completed 242500 out of 250000 steps (97%) [22:18:14] Completed 245000 out of 250000 steps (98%) [22:23:27] Completed 247500 out of 250000 steps (99%) [22:28:40] Completed 250000 out of 250000 steps (100%) [22:28:42] DynamicWrapper: Finished Work Unit: sleep=10000 [22:28:52] [22:28:52] Finished Work Unit: [22:28:52] - Reading up to 21124224 from "work/wudata_03.trr": Read 21124224 [22:28:52] trr file hash check passed. [22:28:52] - Reading up to 4491496 from "work/wudata_03.xtc": Read 4491496 [22:28:52] xtc file hash check passed. [22:28:52] edr file hash check passed. [22:28:52] logfile size: 185372 [22:28:52] Leaving Run [22:28:52] - Writing 25950876 bytes of core data to disk... [22:28:53] ... Done. [22:29:13] - Shutting down core [22:29:13] [22:29:13] Folding@home Core Shutdown: FINISHED_UNIT [22:32:12] CoreStatus = 64 (100) [22:32:12] Unit 3 finished with 88 percent of time to deadline remaining. [22:32:12] Updated performance fraction: 0.870800 [22:32:12] Sending work to server [22:32:12] Project: 2669 (Run 2, Clone 114, Gen 115)
[22:32:12] + Attempting to send results [January 31 22:32:12 UTC] [22:32:12] - Reading file work/wuresults_03.dat from core [22:32:12] (Read 25950876 bytes from disk) [22:32:12] Connecting to http://171.64.65.56:8080/ [22:33:49] Posted data. [22:33:50] Initial: 0000; - Uploaded at ~243 kB/s [22:33:56] - Averaged speed for that direction ~253 kB/s [22:33:56] + Results successfully sent [22:33:56] Thank you for your contribution to Folding@Home. [22:33:56] + Number of Units Completed: 13
[22:34:04] - Warning: Could not delete all work unit files (3): Core file absent [22:34:04] Trying to send all finished work units [22:34:04] + No unsent completed units remaining. [22:34:04] - Preparing to get new work unit... [22:34:04] Cleaning up work directory [22:34:05] + Attempting to get work packet [22:34:05] Passkey found [22:34:05] - Will indicate memory of 984 MB [22:34:05] - Connecting to assignment server [22:34:05] Connecting to http://assign.stanford.edu:8080/ [22:34:07] Posted data. [22:34:07] Initial: 40AB; - Successful: assigned to (171.64.65.54). [22:34:07] + News From Folding@Home: Welcome to Folding@Home [22:34:07] Loaded queue successfully. [22:34:07] Connecting to http://171.64.65.54:8080/ [22:34:08] Posted data. [22:34:08] Initial: 0000; - Receiving payload (expected size: 1782065) [22:34:20] - Downloaded at ~145 kB/s [22:34:20] - Averaged speed for that direction ~168 kB/s [22:34:20] + Received work. [22:34:20] Trying to send all finished work units [22:34:20] + No unsent completed units remaining. [22:34:20] + Closed connections [22:34:20] [22:34:20] + Processing work unit [22:34:20] Core required: FahCore_a3.exe [22:34:20] Core found. [22:34:20] Working on queue slot 04 [January 31 22:34:20 UTC] [22:34:20] + Working ... [22:34:20] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 04 -np 4 -checkpoint 15 -forceasm -verbose -lifeline 6474 -version 629'
[22:34:21] [22:34:21] *------------------------------* [22:34:21] Folding@Home Gromacs SMP Core [22:34:21] Version 2.13 (Tue Aug 18 18:28:33 CEST 2009) [22:34:21] [22:34:21] Preparing to commence simulation [22:34:21] - Ensuring status. Please wait. [22:34:30] - Assembly optimizations manually forced on. [22:34:30] - Not checking prior termination. [22:34:31] - Expanded 1781553 -> 2059833 (decompressed 115.6 percent) [22:34:31] Called DecompressByteArray: compressed_data_size=1781553 data_size=2059833, decompressed_data_size=2059833 diff=0 [22:34:31] - Digital signature verified [22:34:31] [22:34:31] Project: 6024 (Run 0, Clone 8, Gen 1) [22:34:31] [22:34:31] Assembly optimizations on if available. [22:34:31] Entering M.D. [22:34:37] Completed 0 out of 500000 steps (0%) [22:40:53] Completed 5000 out of 500000 steps (1%) [22:47:14] Completed 10000 out of 500000 steps (2%) [22:53:17] Completed 15000 out of 500000 steps (3%) [22:59:24] Completed 20000 out of 500000 steps (4%) [23:05:35] Completed 25000 out of 500000 steps (5%) [23:11:37] Completed 30000 out of 500000 steps (6%) [23:17:43] Completed 35000 out of 500000 steps (7%) [23:23:56] Completed 40000 out of 500000 steps (8%) [23:30:09] Completed 45000 out of 500000 steps (9%) [23:36:15] Completed 50000 out of 500000 steps (10%) [23:42:25] Completed 55000 out of 500000 steps (11%) [23:48:34] Completed 60000 out of 500000 steps (12%) [23:54:45] Completed 65000 out of 500000 steps (13%) [23:58:53] - Autosending finished units... [January 31 23:58:53 UTC] [23:58:53] Trying to send all finished work units [23:58:53] + No unsent completed units remaining. [23:58:53] - Autosend completed [00:00:59] Completed 70000 out of 500000 steps (14%) [00:07:10] Completed 75000 out of 500000 steps (15%) [00:13:22] Completed 80000 out of 500000 steps (16%) [00:19:31] Completed 85000 out of 500000 steps (17%) [00:25:37] Completed 90000 out of 500000 steps (18%) [00:31:49] Completed 95000 out of 500000 steps (19%) [00:37:59] Completed 100000 out of 500000 steps (20%) [00:44:11] Completed 105000 out of 500000 steps (21%) [00:50:27] Completed 110000 out of 500000 steps (22%) [00:56:32] Completed 115000 out of 500000 steps (23%) [01:02:46] Completed 120000 out of 500000 steps (24%) [01:08:53] Completed 125000 out of 500000 steps (25%) [01:15:04] Completed 130000 out of 500000 steps (26%) [01:21:15] Completed 135000 out of 500000 steps (27%) [01:27:18] Completed 140000 out of 500000 steps (28%) [01:33:30] Completed 145000 out of 500000 steps (29%) [01:39:45] Completed 150000 out of 500000 steps (30%) [01:45:53] Completed 155000 out of 500000 steps (31%) [01:51:57] Completed 160000 out of 500000 steps (32%) [01:58:11] Completed 165000 out of 500000 steps (33%) [02:04:30] Completed 170000 out of 500000 steps (34%) [02:10:48] Completed 175000 out of 500000 steps (35%) [02:16:53] Completed 180000 out of 500000 steps (36%) [02:23:04] Completed 185000 out of 500000 steps (37%) [02:29:09] Completed 190000 out of 500000 steps (38%) [02:35:18] Completed 195000 out of 500000 steps (39%) [02:41:33] Completed 200000 out of 500000 steps (40%) [02:47:32] Completed 205000 out of 500000 steps (41%) [02:53:38] Completed 210000 out of 500000 steps (42%) [02:59:39] Completed 215000 out of 500000 steps (43%) [03:05:42] Completed 220000 out of 500000 steps (44%) [03:11:44] Completed 225000 out of 500000 steps (45%) [03:17:47] Completed 230000 out of 500000 steps (46%) [03:23:52] Completed 235000 out of 500000 steps (47%) [03:29:55] Completed 240000 out of 500000 steps (48%) [03:35:59] Completed 245000 out of 500000 steps (49%) [03:42:01] Completed 250000 out of 500000 steps (50%) [03:48:05] Completed 255000 out of 500000 steps (51%) [03:54:06] Completed 260000 out of 500000 steps (52%) [04:00:07] Completed 265000 out of 500000 steps (53%) [04:06:16] Completed 270000 out of 500000 steps (54%) [04:12:22] Completed 275000 out of 500000 steps (55%) [04:19:24] Completed 280000 out of 500000 steps (56%) [04:25:45] Completed 285000 out of 500000 steps (57%) [04:32:01] Completed 290000 out of 500000 steps (58%) [04:38:19] Completed 295000 out of 500000 steps (59%) [04:44:38] Completed 300000 out of 500000 steps (60%) [04:50:56] Completed 305000 out of 500000 steps (61%) [04:57:12] Completed 310000 out of 500000 steps (62%) [05:03:18] Completed 315000 out of 500000 steps (63%) [05:09:08] Completed 320000 out of 500000 steps (64%) [05:15:07] Completed 325000 out of 500000 steps (65%) [05:21:07] Completed 330000 out of 500000 steps (66%) [05:27:05] Completed 335000 out of 500000 steps (67%) [05:32:57] Completed 340000 out of 500000 steps (68%) [05:38:53] Completed 345000 out of 500000 steps (69%) [05:44:44] Completed 350000 out of 500000 steps (70%) [05:50:43] Completed 355000 out of 500000 steps (71%) [05:56:33] Completed 360000 out of 500000 steps (72%) [05:58:53] - Autosending finished units... [February 1 05:58:53 UTC] [05:58:53] Trying to send all finished work units [05:58:53] + No unsent completed units remaining. [05:58:53] - Autosend completed [06:02:24] Completed 365000 out of 500000 steps (73%) [06:08:19] Completed 370000 out of 500000 steps (74%) [06:14:11] Completed 375000 out of 500000 steps (75%) [06:20:02] Completed 380000 out of 500000 steps (76%) [06:26:02] Completed 385000 out of 500000 steps (77%) [06:32:03] Completed 390000 out of 500000 steps (78%) [06:38:03] Completed 395000 out of 500000 steps (79%) [06:43:56] Completed 400000 out of 500000 steps (80%) [06:49:50] Completed 405000 out of 500000 steps (81%) [06:55:40] Completed 410000 out of 500000 steps (82%) [07:01:30] Completed 415000 out of 500000 steps (83%) [07:07:24] Completed 420000 out of 500000 steps (84%) [07:13:22] Completed 425000 out of 500000 steps (85%) [07:19:11] Completed 430000 out of 500000 steps (86%) [07:25:10] Completed 435000 out of 500000 steps (87%) [07:31:10] Completed 440000 out of 500000 steps (88%) [07:37:07] Completed 445000 out of 500000 steps (89%) [07:43:04] Completed 450000 out of 500000 steps (90%) [07:48:57] Completed 455000 out of 500000 steps (91%) [07:54:48] Completed 460000 out of 500000 steps (92%) [08:00:40] Completed 465000 out of 500000 steps (93%) [08:06:34] Completed 470000 out of 500000 steps (94%) [08:12:29] Completed 475000 out of 500000 steps (95%) [08:18:24] Completed 480000 out of 500000 steps (96%) [08:24:15] Completed 485000 out of 500000 steps (97%) [08:30:14] Completed 490000 out of 500000 steps (98%) [08:36:08] Completed 495000 out of 500000 steps (99%) [08:42:02] Completed 500000 out of 500000 steps (100%) [08:42:03] DynamicWrapper: Finished Work Unit: sleep=10000 [08:42:13] [08:42:13] Finished Work Unit: [08:42:13] - Reading up to 20283912 from "work/wudata_04.trr": Read 20283912 [08:42:13] trr file hash check passed. [08:42:13] edr file hash check passed. [08:42:13] logfile size: 53944 [08:42:13] Leaving Run [08:42:16] - Writing 20371120 bytes of core data to disk... [08:42:17] ... Done. [08:42:27] - Shutting down core [08:42:27] [08:42:27] Folding@home Core Shutdown: FINISHED_UNIT [08:42:27] CoreStatus = 64 (100) [08:42:27] Unit 4 finished with 93 percent of time to deadline remaining. [08:42:27] Updated performance fraction: 0.882563 [08:42:27] Sending work to server [08:42:27] Project: 6024 (Run 0, Clone 8, Gen 1)
[08:42:27] + Attempting to send results [February 1 08:42:27 UTC] [08:42:27] - Reading file work/wuresults_04.dat from core [08:42:27] (Read 20371120 bytes from disk) [08:42:27] Connecting to http://171.64.65.54:8080/ [08:43:29] Posted data. [08:43:29] Initial: 0000; - Uploaded at ~320 kB/s [08:43:29] - Averaged speed for that direction ~266 kB/s [08:43:29] + Results successfully sent [08:43:29] Thank you for your contribution to Folding@Home. [08:43:29] + Number of Units Completed: 14
[08:43:36] Trying to send all finished work units [08:43:36] + No unsent completed units remaining. [08:43:36] - Preparing to get new work unit... [08:43:36] Cleaning up work directory [08:43:37] + Attempting to get work packet [08:43:37] Passkey found [08:43:37] - Will indicate memory of 984 MB [08:43:37] - Connecting to assignment server [08:43:37] Connecting to http://assign.stanford.edu:8080/ [08:43:39] Posted data. [08:43:39] Initial: ED82; - Successful: assigned to (130.237.232.140). [08:43:39] + News From Folding@Home: Welcome to Folding@Home [08:43:39] Loaded queue successfully. [08:43:39] Connecting to http://130.237.232.140:8080/ [08:43:40] Posted data. [08:43:40] Initial: 0000; - Receiving payload (expected size: 1798426) [08:43:45] - Downloaded at ~351 kB/s [08:43:45] - Averaged speed for that direction ~205 kB/s [08:43:45] + Received work. [08:43:45] Trying to send all finished work units [08:43:45] + No unsent completed units remaining. [08:43:45] + Closed connections [08:43:45] [08:43:45] + Processing work unit [08:43:45] Core required: FahCore_a3.exe [08:43:45] Core found. [08:43:45] Working on queue slot 05 [February 1 08:43:45 UTC] [08:43:45] + Working ... [08:43:45] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 05 -np 4 -checkpoint 15 -forceasm -verbose -lifeline 6474 -version 629'
[08:43:45] [08:43:45] *------------------------------* [08:43:45] Folding@Home Gromacs SMP Core [08:43:45] Version 2.13 (Tue Aug 18 18:28:33 CEST 2009) [08:43:45] [08:43:45] Preparing to commence simulation [08:43:45] - Assembly optimizations manually forced on. [08:43:45] - Not checking prior termination. [08:43:45] - Expanded 1797914 -> 2078149 (decompressed 115.5 percent) [08:43:45] Called DecompressByteArray: compressed_data_size=1797914 data_size=2078149, decompressed_data_size=2078149 diff=0 [08:43:45] - Digital signature verified [08:43:45] [08:43:45] Project: 6012 (Run 0, Clone 437, Gen 13) [08:43:45] [08:43:45] Assembly optimizations on if available. [08:43:45] Entering M.D. [08:43:52] Completed 0 out of 500000 steps (0%) [08:49:44] Completed 5000 out of 500000 steps (1%) [08:55:40] Completed 10000 out of 500000 steps (2%) [09:01:37] Completed 15000 out of 500000 steps (3%) [09:07:32] Completed 20000 out of 500000 steps (4%) [09:13:26] Completed 25000 out of 500000 steps (5%) [09:19:19] Completed 30000 out of 500000 steps (6%) [09:25:12] Completed 35000 out of 500000 steps (7%) [09:31:08] Completed 40000 out of 500000 steps (8%) [09:37:10] Completed 45000 out of 500000 steps (9%) [09:43:08] Completed 50000 out of 500000 steps (10%) [09:49:00] Completed 55000 out of 500000 steps (11%) [09:54:57] Completed 60000 out of 500000 steps (12%) [10:00:51] Completed 65000 out of 500000 steps (13%) [10:06:45] Completed 70000 out of 500000 steps (14%) [10:12:40] Completed 75000 out of 500000 steps (15%) [10:18:37] Completed 80000 out of 500000 steps (16%) [10:24:40] Completed 85000 out of 500000 steps (17%) [10:30:40] Completed 90000 out of 500000 steps (18%) [10:36:33] Completed 95000 out of 500000 steps (19%) [10:42:26] Completed 100000 out of 500000 steps (20%) [10:48:20] Completed 105000 out of 500000 steps (21%) [10:54:19] Completed 110000 out of 500000 steps (22%) [11:00:21] Completed 115000 out of 500000 steps (23%) [11:06:25] Completed 120000 out of 500000 steps (24%) [11:12:21] Completed 125000 out of 500000 steps (25%) [11:18:15] Completed 130000 out of 500000 steps (26%) [11:24:19] Completed 135000 out of 500000 steps (27%) [11:30:15] Completed 140000 out of 500000 steps (28%) [11:36:06] Completed 145000 out of 500000 steps (29%) [11:42:00] Completed 150000 out of 500000 steps (30%) [11:47:55] Completed 155000 out of 500000 steps (31%) [11:53:54] Completed 160000 out of 500000 steps (32%) [11:58:53] - Autosending finished units... [February 1 11:58:53 UTC] [11:58:53] Trying to send all finished work units [11:58:53] + No unsent completed units remaining. [11:58:53] - Autosend completed [11:59:51] Completed 165000 out of 500000 steps (33%) [12:05:44] Completed 170000 out of 500000 steps (34%) [12:11:47] Completed 175000 out of 500000 steps (35%) [12:17:39] Completed 180000 out of 500000 steps (36%) [12:23:33] Completed 185000 out of 500000 steps (37%) [12:29:27] Completed 190000 out of 500000 steps (38%) [12:35:25] Completed 195000 out of 500000 steps (39%) [12:41:22] Completed 200000 out of 500000 steps (40%) [12:47:22] Completed 205000 out of 500000 steps (41%) [12:53:24] Completed 210000 out of 500000 steps (42%) [12:59:21] Completed 215000 out of 500000 steps (43%) [13:05:20] Completed 220000 out of 500000 steps (44%) [13:11:17] Completed 225000 out of 500000 steps (45%) [13:17:16] Completed 230000 out of 500000 steps (46%) [13:23:11] Completed 235000 out of 500000 steps (47%) [13:29:04] Completed 240000 out of 500000 steps (48%) [13:35:08] Completed 245000 out of 500000 steps (49%) [13:41:01] Completed 250000 out of 500000 steps (50%) [13:47:00] Completed 255000 out of 500000 steps (51%) [13:53:00] Completed 260000 out of 500000 steps (52%) [13:58:54] Completed 265000 out of 500000 steps (53%) [14:04:48] Completed 270000 out of 500000 steps (54%) [14:10:51] Completed 275000 out of 500000 steps (55%) [14:17:07] Completed 280000 out of 500000 steps (56%) [14:23:18] Completed 285000 out of 500000 steps (57%) [14:29:17] Completed 290000 out of 500000 steps (58%) [14:35:22] Completed 295000 out of 500000 steps (59%) [14:41:27] Completed 300000 out of 500000 steps (60%) [14:47:32] Completed 305000 out of 500000 steps (61%) [14:53:36] Completed 310000 out of 500000 steps (62%) [14:59:34] Completed 315000 out of 500000 steps (63%) [15:05:38] Completed 320000 out of 500000 steps (64%) [15:11:44] Completed 325000 out of 500000 steps (65%) [15:17:53] Completed 330000 out of 500000 steps (66%) [15:23:52] Completed 335000 out of 500000 steps (67%) [15:29:51] Completed 340000 out of 500000 steps (68%) [15:35:58] Completed 345000 out of 500000 steps (69%) [15:42:03] Completed 350000 out of 500000 steps (70%) [15:48:09] Completed 355000 out of 500000 steps (71%) [15:54:16] Completed 360000 out of 500000 steps (72%) [16:00:26] Completed 365000 out of 500000 steps (73%) [16:06:35] Completed 370000 out of 500000 steps (74%) [16:12:49] Completed 375000 out of 500000 steps (75%) [16:18:54] Completed 380000 out of 500000 steps (76%) [16:24:54] Completed 385000 out of 500000 steps (77%) [16:30:59] Completed 390000 out of 500000 steps (78%) [16:36:57] Completed 395000 out of 500000 steps (79%) [16:43:05] Completed 400000 out of 500000 steps (80%) [16:49:09] Completed 405000 out of 500000 steps (81%) [16:55:11] Completed 410000 out of 500000 steps (82%) [17:01:18] Completed 415000 out of 500000 steps (83%) [17:07:22] Completed 420000 out of 500000 steps (84%) [17:13:26] Completed 425000 out of 500000 steps (85%) [17:19:30] Completed 430000 out of 500000 steps (86%) [17:25:39] Completed 435000 out of 500000 steps (87%) [17:31:46] Completed 440000 out of 500000 steps (88%) [17:37:48] Completed 445000 out of 500000 steps (89%) [17:43:51] Completed 450000 out of 500000 steps (90%) [17:50:03] Completed 455000 out of 500000 steps (91%) [17:56:02] Completed 460000 out of 500000 steps (92%) [17:58:53] - Autosending finished units... [February 1 17:58:53 UTC] [17:58:53] Trying to send all finished work units [17:58:53] + No unsent completed units remaining. [17:58:53] - Autosend completed [18:02:10] Completed 465000 out of 500000 steps (93%) [18:08:12] Completed 470000 out of 500000 steps (94%) [18:14:17] Completed 475000 out of 500000 steps (95%) [18:20:07] Completed 480000 out of 500000 steps (96%) [18:25:55] Completed 485000 out of 500000 steps (97%) [18:31:44] Completed 490000 out of 500000 steps (98%) [18:37:32] Completed 495000 out of 500000 steps (99%) [18:43:22] Completed 500000 out of 500000 steps (100%) [18:43:22] DynamicWrapper: Finished Work Unit: sleep=10000 [18:43:32] [18:43:32] Finished Work Unit: [18:43:32] - Reading up to 20446800 from "work/wudata_05.trr": Read 20446800 [18:43:32] trr file hash check passed. [18:43:32] edr file hash check passed. [18:43:32] logfile size: 54920 [18:43:32] Leaving Run [18:43:36] - Writing 20534984 bytes of core data to disk... [18:43:36] ... Done. [18:43:45] - Shutting down core [18:43:45] [18:43:45] Folding@home Core Shutdown: FINISHED_UNIT [18:43:46] CoreStatus = 64 (100) [18:43:46] Unit 5 finished with 93 percent of time to deadline remaining. [18:43:46] Updated performance fraction: 0.892161 [18:43:46] Sending work to server [18:43:46] Project: 6012 (Run 0, Clone 437, Gen 13)
[18:43:46] + Attempting to send results [February 1 18:43:46 UTC] [18:43:46] - Reading file work/wuresults_05.dat from core [18:43:46] (Read 20534984 bytes from disk) [18:43:46] Connecting to http://130.237.232.140:8080/ [18:46:55] - Couldn't send HTTP request to server [18:46:55] + Could not connect to Work Server (results) [18:46:55] (130.237.232.140:8080) [18:46:55] + Retrying using alternative port [18:46:55] Connecting to http://130.237.232.140:80/ [18:50:04] - Couldn't send HTTP request to server [18:50:04] + Could not connect to Work Server (results) [18:50:04] (130.237.232.140:80) [18:50:04] - Error: Could not transmit unit 05 (completed February 1) to work server. [18:50:04] - 1 failed uploads of this unit. [18:50:04] Keeping unit 05 in queue. [18:50:04] Trying to send all finished work units [18:50:04] Project: 6012 (Run 0, Clone 437, Gen 13)
[18:50:05] + Attempting to send results [February 1 18:50:05 UTC] [18:50:05] - Reading file work/wuresults_05.dat from core [18:50:05] (Read 20534984 bytes from disk) [18:50:05] Connecting to http://130.237.232.140:8080/ [18:53:14] - Couldn't send HTTP request to server [18:53:14] + Could not connect to Work Server (results) [18:53:14] (130.237.232.140:8080) [18:53:14] + Retrying using alternative port [18:53:14] Connecting to http://130.237.232.140:80/ [18:56:23] - Couldn't send HTTP request to server [18:56:23] + Could not connect to Work Server (results) [18:56:23] (130.237.232.140:80) [18:56:23] - Error: Could not transmit unit 05 (completed February 1) to work server. [18:56:23] - 2 failed uploads of this unit.
[18:56:23] + Attempting to send results [February 1 18:56:23 UTC] [18:56:23] - Reading file work/wuresults_05.dat from core [18:56:23] (Read 20534984 bytes from disk) [18:56:23] Connecting to http://130.237.162.125:8080/ [18:59:32] - Couldn't send HTTP request to server [18:59:32] + Could not connect to Work Server (results) [18:59:32] (130.237.162.125:8080) [18:59:32] + Retrying using alternative port [18:59:32] Connecting to http://130.237.162.125:80/ [19:02:41] - Couldn't send HTTP request to server [19:02:41] + Could not connect to Work Server (results) [19:02:41] (130.237.162.125:80) [19:02:41] Could not transmit unit 05 to Collection server; keeping in queue. [19:02:41] + Sent 0 of 1 completed units to the server [19:02:41] - Preparing to get new work unit... [19:02:41] Cleaning up work directory [19:02:42] + Attempting to get work packet [19:02:42] Passkey found [19:02:42] - Will indicate memory of 984 MB [19:02:42] - Connecting to assignment server [19:02:42] Connecting to http://assign.stanford.edu:8080/ [19:05:51] - Couldn't send HTTP request to server [19:05:51] + Could not connect to Assignment Server [19:05:51] Connecting to http://assign2.stanford.edu:80/ [19:09:01] - Couldn't send HTTP request to server [19:09:01] + Could not connect to Assignment Server 2 [19:09:01] + Couldn't get work instructions. [19:09:01] - Attempt #1 to get work failed, and no other work to do. Waiting before retry. [19:09:07] + Attempting to get work packet [19:09:07] Passkey found [19:09:07] - Will indicate memory of 984 MB [19:09:07] - Connecting to assignment server [19:09:07] Connecting to http://assign.stanford.edu:8080/ [19:12:16] - Couldn't send HTTP request to server [19:12:16] + Could not connect to Assignment Server [19:12:16] Connecting to http://assign2.stanford.edu:80/ [19:15:25] - Couldn't send HTTP request to server [19:15:25] + Could not connect to Assignment Server 2 [19:15:25] + Couldn't get work instructions. [19:15:25] - Attempt #2 to get work failed, and no other work to do. Waiting before retry. [19:15:42] + Attempting to get work packet [19:15:42] Passkey found [19:15:42] - Will indicate memory of 984 MB [19:15:42] - Connecting to assignment server [19:15:42] Connecting to http://assign.stanford.edu:8080/ [19:18:51] - Couldn't send HTTP request to server [19:18:51] + Could not connect to Assignment Server [19:18:51] Connecting to http://assign2.stanford.edu:80/ [19:22:00] - Couldn't send HTTP request to server [19:22:00] + Could not connect to Assignment Server 2 [19:22:00] + Couldn't get work instructions. [19:22:00] - Attempt #3 to get work failed, and no other work to do. Waiting before retry. [19:22:24] + Attempting to get work packet [19:22:24] Passkey found [19:22:24] - Will indicate memory of 984 MB [19:22:24] - Connecting to assignment server [19:22:24] Connecting to http://assign.stanford.edu:8080/ [19:25:33] - Couldn't send HTTP request to server [19:25:33] + Could not connect to Assignment Server [19:25:33] Connecting to http://assign2.stanford.edu:80/ [19:28:42] - Couldn't send HTTP request to server [19:28:42] + Could not connect to Assignment Server 2 [19:28:42] + Couldn't get work instructions. [19:28:42] - Attempt #4 to get work failed, and no other work to do. Waiting before retry. [19:29:31] + Attempting to get work packet [19:29:31] Passkey found [19:29:31] - Will indicate memory of 984 MB [19:29:31] - Connecting to assignment server [19:29:31] Connecting to http://assign.stanford.edu:8080/ [19:32:40] - Couldn't send HTTP request to server [19:32:40] + Could not connect to Assignment Server [19:32:40] Connecting to http://assign2.stanford.edu:80/ [19:35:49] - Couldn't send HTTP request to server [19:35:49] + Could not connect to Assignment Server 2 [19:35:49] + Couldn't get work instructions. [19:35:49] - Attempt #5 to get work failed, and no other work to do. Waiting before retry. [19:37:12] + Attempting to get work packet [19:37:12] Passkey found [19:37:12] - Will indicate memory of 984 MB [19:37:12] - Connecting to assignment server [19:37:12] Connecting to http://assign.stanford.edu:8080/ [19:40:21] - Couldn't send HTTP request to server [19:40:21] + Could not connect to Assignment Server [19:40:21] Connecting to http://assign2.stanford.edu:80/ [19:43:30] - Couldn't send HTTP request to server [19:43:30] + Could not connect to Assignment Server 2 [19:43:30] + Couldn't get work instructions. [19:43:30] - Attempt #6 to get work failed, and no other work to do. Waiting before retry. [19:46:12] + Attempting to get work packet [19:46:12] Passkey found [19:46:12] - Will indicate memory of 984 MB [19:46:12] - Connecting to assignment server [19:46:12] Connecting to http://assign.stanford.edu:8080/ [19:46:13] Posted data. [19:46:13] Initial: ED82; - Successful: assigned to (130.237.232.140). [19:46:13] + News From Folding@Home: Welcome to Folding@Home [19:46:13] Loaded queue successfully. [19:46:13] Connecting to http://130.237.232.140:8080/ [19:46:17] Posted data. [19:46:17] Initial: 0000; - Receiving payload (expected size: 1798495) [19:48:15] - Downloaded at ~14 kB/s [19:48:15] - Averaged speed for that direction ~167 kB/s [19:48:15] + Received work. [19:48:15] Trying to send all finished work units [19:48:15] Project: 6012 (Run 0, Clone 437, Gen 13)
[19:48:15] + Attempting to send results [February 1 19:48:15 UTC] [19:48:15] - Reading file work/wuresults_05.dat from core [19:48:15] (Read 20534984 bytes from disk) [19:48:15] Connecting to http://130.237.232.140:8080/ [19:49:12] Posted data. [19:49:13] Initial: 0000; - Uploaded at ~345 kB/s [19:49:13] - Averaged speed for that direction ~282 kB/s [19:49:13] + Results successfully sent [19:49:13] Thank you for your contribution to Folding@Home. [19:49:13] + Number of Units Completed: 15
[19:49:19] + Sent 1 of 1 completed units to the server [19:49:19] + Closed connections [19:49:19] [19:49:19] + Processing work unit [19:49:19] Core required: FahCore_a3.exe [19:49:19] Core found. [19:49:19] Working on queue slot 06 [February 1 19:49:19 UTC] [19:49:19] + Working ... [19:49:19] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 4 -checkpoint 15 -forceasm -verbose -lifeline 6474 -version 629'
[19:49:19] [19:49:19] *------------------------------* [19:49:19] Folding@Home Gromacs SMP Core [19:49:19] Version 2.13 (Tue Aug 18 18:28:33 CEST 2009) [19:49:19] [19:49:19] Preparing to commence simulation [19:49:19] - Assembly optimizations manually forced on. [19:49:19] - Not checking prior termination. [19:49:19] - Expanded 1797983 -> 2078149 (decompressed 115.5 percent) [19:49:19] Called DecompressByteArray: compressed_data_size=1797983 data_size=2078149, decompressed_data_size=2078149 diff=0 [19:49:19] - Digital signature verified [19:49:19] [19:49:19] Project: 6012 (Run 0, Clone 255, Gen 13) [19:49:19] [19:49:19] Assembly optimizations on if available. [19:49:19] Entering M.D. [19:49:26] Completed 0 out of 500000 steps (0%) [19:55:44] Completed 5000 out of 500000 steps (1%) [20:02:26] Completed 10000 out of 500000 steps (2%)
LAV48 писал(а):
Конфигурация: PhenomII X4 3.36GHz Hyper-V Ubuntu 9.04 server Номер задачи: 6317 (0-8-1) Имя задачи: p6317_sh3_with_ALA_frags Размер задачи: 1,70 МБ Размер результата: Очки: 336,00 Фреймы: 100 Ядро: GROMACS IP сервера: 171.64.65.111 Очков в час: 33,26 Очков в сутки: 798 Ср. время на шаг: 0:06:03 Bonus factor: 1,0000 Client.cfg: Завершено: 54% FahSpy 2.0.1
просмотрел вес лог
нашел
A3 Project: 6012 (Run 0, Clone 437, Gen 13) Project: 6024 (Run 0, Clone 8, Gen 1) Project: 6015 (Run 0, Clone 122, Gen 6) Project: 6012 (Run 0, Clone 255, Gen 13)
A2 Project: 2669 (Run 2, Clone 114, Gen 115) Project: 2669 (Run 2, Clone 114, Gen 115)
